2001 - 2006 Honda CR-Vs
1225226228230231314
  • hawkeye70hawkeye70 Member Posts: 43
    Motordavid,
    We have an '03 CR-V. I agree with your assessment of the CR-V front seats. Not only is the legroom sacrificed for more back seat legroom, but the seat bottom cushions are too thin for my bony cheeks and lack long enough thigh support for me (6' 5"). My wife thinks they are fine (5' 7"). I modified the seat track to get an additional 2" of travel rearward which helps the legroom, but haven't attempted to do anything with the bottom cushion.
  • autosaurusautosaurus Member Posts: 90
    I've test drove the car before, once for about 1/2 hour and the seats seemed ok. I'm 5'9" and currently drive a Civic and have little problems. The seats aren't as comfortable as my volvo, but those are some of the best seats available anywhere.
    Whats the deal with the fire in the CRV's.. is this an isolated thing?
    Also, the car is being driven to the dealer from another one, wi;ll have about 30 miles on it? Anyone see a problem with this?
  • surfbabe1977surfbabe1977 Member Posts: 30
    The gaslight came on for the first time today. I like to keep her gassed up, but I had an extended trip...anyhooo...I looked in the owner's manual and it says that I need to refuel soon, but doesn't tell me approximately how many miles I can go until I run outta gas? Anyone have any ideas? I went ahead and stopped in an unfamiliar place today...which I don't like to do because I was attacked by a stranger in a public parking lot about 6 weeks ago.
    David: we noticed the same thing. My wife is 5'8" and was comfortable, but I'm 6" and also felt front legroom could be better.
    Interestingly, this was not a problem when I drove. It was the front passenger seat that just didn't seem to have enough room for me (we were shopping for my wife's car).
    What's funny is that the rear seat has a *lot* more leg room than the front, so they could easily give it 3" more seat travel and noone would mind.
    Maybe hawkeye took pictures? I raised the front seat track on my Miata for more thigh support, and some really tall folks have modified their Outback's seat track also.
    -juice
    I've never seen the seat travel explained by Honda, but I have doubts about them cutting it short to give the rear seats more space. That's pretty silly.
    It's more likely, IMHO, that they designed the seating position with an eye on where the body is positioned in relation to the B pillar. Put the seat too far back and the seat belt will not hold the occupant. Nor will the B pillar provide the same protection in a side impact crash.
  • tellantellan Member Posts: 6
    I got my 2003 CR-V EX this spring. So far I only found two more male CR-V(2002-2004 model) driver in town(population 200K). There're more than dozen male drivers on 2001 and before model.
    On weekends, I have to take passenger's seat and give the key to my wife. I like my CR-V, but for this reason, maybe I should buy a Pilot instead.
    Not to put too fine a point on it, but... You're going to buy a car based on what other people drive?
    varm: I also thought about air bag placement. But the wheel tilts, right? If it's down most of the way, I think you'd still be protected by the front air bag.
    Is the side air bag seat mounted? If so it would move back with the seat.
    -juice
    Juice - I think the airbags are not relevant to the issue. The side bags are built into the seats, so they move with the seat. Common recommendation is to sit as far away from the wheel as possible (while still being able to reach it, of course). So I doubt that the front impact bag is an issue either.
    The seatbelt is another story. It's attached to a stationary pillar. The belt is designed to hold the driver against the seatback. If the seat is shifted back behind the pillar (or even flush with it), the belt is going to be slack.
    hawkeye: do you have that problem? In other words, is the seat belt anchor still far back enough to rest against your shoulder, or is there slack?
    -juice
  • kizhekizhe Member Posts: 242
    I own CR-V EX 2003. I am H=6.2' , W=180 lb.
    I have absolutely NO problems with leg room, arms room, head room, butt room, etc. .
    It might be a problem for some, but do not blame Honda for it, blame McDonalds... :-).
    Big Macs don't make my legs longer, hee hee.
    I think seat width is fine. Headroom to spare. The bottom cushion could be longer for more thigh support, but I feel that way about almost every car I've ever sat in.
    The front driver's seats really benefits from that arm rest, without it I felt like I didn't have enough side support.
    -juice
    -juice : I like that arm rests too.
    Big Macs don't make anything longer, but they make EVERYTHING wider, which
    adds to discomfort. What bothers me sometimes is the sun light from the side,
    which I block using the sun wiser. Interesting, I did not have that problem with other cars.
    Also, during rain/snow, when you open the door, you got water/snow coming from that rubber seal.
    Roof do not have enough overhang to protect seats from water.
    During that kind of weather I got towel handy to protect my seats.
    I have a '99 model, but my sister drives a 2003. Both are 5 speed EXs. I've gone back and forth between them a few times.
    I found the seats somewhat more comfortable in the 2003. The cushion is larger, the adjustments are more... well... adjustable, and although the position with the steering wheel is still bus-like, it feels more natural in the 2003.
    With the '99, I do have more foot room, but the real difference is a proper dead pedal on the floor. The "bump" in the 2003 model isn't big enough for my size 11 shoes.
    FWIW, I'm 6'1", 190 lbs, and wear a 33" inseam (you'll never find them on the rack).
    Having driven several small SUVs over the past 5 years, I rate the new CR-V about par for the course. Some have more legroom, but even smaller seat cushions. Others force you to sit on the floor like a race car. On the whole, most of them a just plain similar. These are entry level SUVs and you get what you pay for.
  • sabrina9sabrina9 Member Posts: 148
    Found this post on another site. It is from July. Unfortuantely, the email of the author has changed, but I am hoping he sees it here. This represents the earliest fire so far. Funny, when I asked Honda if there were reports of any other fires, they said no, yet I found two so far. This is NOT any of the ones on the NHTSA website, so it repesents a new one. Verbatim (with spelling errors). Although it does not say it, I have to presume that 2900 miles was the first oil change. Long time followers will note this is identical to the other cases.
    "Daughter took 2003 CR-V to dealer fo Oil Change at 2900+ miles. Three miles down the road after the oil change at 2900+ moiles, a fire started
    in the engine compartment. When the fire department finally arrived, the car
    was totally engulfed and will not be repairable.
    1. Any history of this. 2. Suggestions as to possible cause? Oil fill cap had been replaced."
    I think it was Varmint who said Honda monitors this site. Two pieces of advice for Honda
    1. You had better get to the bottom of these before someone gets hurt. No more "undetermined". It is not rocket science.
    2. When loyal customers (I think I speak for all the people on the NHTSA website) have had traumatic experiences with your product, treat them nicely first, figure out the cause later.
    Width is not a problem, the seats are actually pretty wide. Actually I think that's why I liked the arm rests.
    You're probably referring to the Forester? hee hee
    Hey, at least Subaru actually uses the Forester in WRC Reconaissance runs, to make course notes for rallies. And the XT model is as quick as some race cars.
    -juice
    Juice - Actually, the X-Terra is pretty low. It's not awkward, but it fells odd for such a trucky truck.
    It's been a while, but I do recall it had stadium seating, i.e. the back seat towers over the front.
    Forester's seat is only slightly higher than the WRX, but at least it is higher. The shifter is also longer for better reach.
    CR-V has a really high vantage point. I think in my Miata I'm eye level with your shins! LOL
    -juice
    I checked NHTSA reports for Honda CR-V and CRV (two separate model sets ?).
    I checked all 'component' lists.
    People who filed complains were not sure which component to blame and reported them
    multiple times for different components (just in case?). It is confusing. I was able to find 3 unique cases(or so I think?).
    Which belongs to sabrina and which to the latest case? How many unique cases do we have?
    Note, in the first case it said: Fire: NO ????.
    Second case did not report date of failure! Sloppy reports?
    If reports are sloppy or confusing people(or Honda) would treat them accordingly.
    Here they are:
    Report Date : December 30, 2003 at 03:00 PM
    Make : HONDA
    Model : CR-V
    Year : 2003
    Crash : No
    Fire : No
    Number of Injuries: 0
    ODI ID Number : 10051179
    Date of Failure: December 17, 2003
    Component: ENGINE AND ENGINE COOLING
     Summary:
    I BROUGHT MY 2003 HONDA CR-V EX MODEL IN TO MAINE MALL HONDA IN SOUTH PORTLAND, MAINE FOR ROUTINE 10,000 MILE SCHEDULED MAINTENANCE, WHICH INCLUDES CHANGING THE OIL, ROTATING TIRES AND INSPECTING FLUID LEVELS.
    WITHIN 5 MILES OF LEAVING THE DEALERS LOCATION, THE ENGINE CAUGHT FIRE AND THE CAR WAS A TOTAL LOSS. I FIRST NOTICED SMOLE BY LOOKING IN THE REAR VIEW MIRROR APPROXIAMTELY 2 MILES AFTER LEAVING THE DEALERS LOCATION.
    THINKING IT WAS JUST SOME SPILLED OIL, I KEPT ON DRIVING UNTIL I NOTICED THE LOW OIL LIGHT COME ON THE DASHBOARD. I PULLED THE CAR OVER AND SMELLED OIL. AT THAT POINT I OPENED THE HOOD OF THE CAR AND SAW FLAMES IN THE ENGINE. THE MAINE STATE POLICE ARRIVED WITHIN 5 MINUTES AND DETERMINED THAT THE FIRE WAS TOO FAR PROGREESED TO SAVE THE CAR. THE SOUTH PORTLAND AND SCARBOROUGH MAINE FIRE DEPARTMENTS ARRIVED WITHIN 10 MINUTES TO PUT OUT THE FIRE.*AK
    Report Date : December 30, 2003 at 03:11 PM
    Make: HONDA
    Model: CR-V
    Year: 2003
    Complaint Number: 10042645
    Date of Failure: ?
    Component: ELECTRICAL SYSTEM: WIRING: FRONT UNDERHOOD
     Summary:
    AFTER HAVING THE SHIFT CABLE LINKAGE CORROSION RECALL REPAIRS PERFORMED,
    WHILE DRIVING AT 30/35 MPH, VEHICLE CAUGHT ON FIRE FROM UNDER THE
    WINDSHIELD. THE CAUSE OF THE FIRE WAS UNDETERMINED. *AK
    Report Date : December 30, 2003 at 03:27 PM
    Make: HONDA
    Model: CRV
    Year: 2003
    Complaint Number: 10045221
    Date of Failure: October 6, 2003
    Component: ENGINE AND ENGINE COOLING:ENGINE
    Summary:
       6 DAYS AFTER HAVING THROTTLE CABLE RECALL AND A/T SHIFT CABLE RECALL AND
       O/C, CAR BURST INTO FLAMES (TOTALED) WHILE DRIVING 20-25 MPH. HONDA SAYS
       NOT DEFECT? CAR HAD 8200 MILES ON ODOMETER. NO EVIDENCE THAT OIL FROM
       O/C CAUSED FIRE. HONDA INVESTIGATIONS HAS NO ANSWER. FIRE STARTED OR WAS
       FIRST EVIDENT IN DRIVERS WHEEL WELL AREA. *LA
    'Practical' approach: Do we need to drive with a fire extinguisher?
    I know in some foreign countries they are mandatory!
    The X-Terra's back seats tower over the front because they sit on top of the gas tank. It's been a while since I drove the X-Terra, but I recall sitting in it and wondering why my knees were so high.
  • kyfdxkyfdx Moderator Posts: 273,919
    They marketed this as a whole new vehicle, but I could swear its just a re-skin of the old Pathfinder that ended with the '95 model year. I had a '95, and it had the same exact rear seat.. It looked real spacious, but you sat up about six inches higher than the front with the same high knee effect.
    regards,
    kyfdx
  • jlarosa1jlarosa1 Member Posts: 6
    I have owned three Honda cars. I currently have a Honda 1997 CR-V. I am planning to purchase a 2004 Honda CR-V in the spring. After reading another post of another Honda CR-V cathcing fire after an oil change I am starting to get concerned about purchashing another CR-V. Is Honda addressing this issue?
    I was reviewing the nhtsa database but December is not posted yet.
    http://www.nhtsa.dot.gov/cars/problems/MonthlyDefects/
    I saw this one post on google:
    http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe- =UTF-8&threadm=M1mIb.12230%24lo3.7122%40newsread2.news.pas.ea- rthlink.net&rnum=1&prev=/groups%3Fq%3DHonda%2B2003%2BCR-V- %2Bfires%26hl%3Den%26lr%3D%26ie%3DUTF-8%26oe%3DUTF-8%26selm%3DM1m- Ib.12230%2524lo3.7122%2540newsread2.news.pas.earthlink.net%26rnum- %3D1
    Jim L.
    Wasn't the old Pathfinder a unibody, though? Xterra has a full frame. It's much more trucky than the Hard Body ever was.
    I strongly prefer more car-like models like the CR-V, Forester, and RAV4. At least the driving experience.
    -juice
    The new Pathfinder in '96 was the first one to be unibody.. Having owned the Pathfinder and both generation CRVs, I have to agree with you.
    regards,
    kyfdx
    The three NHTSA reports are from different people. Honda knows about all of them. Mine is the October 6. Sometimes the summaries don't carry right. All reported fires if you see the whole report. Also, remmebr, the persons who filled these out are likely very frustrated and sometimes they don't complete the fields. The point is not detail, but rather the general info
    They are under different components, I presume because the people did not know where to put them. There is no category for "undetermined fire". That is why mine is where it is. I just chose the closest component. What they are under is in no way determinative of what the cause is. What would you put it under?
    I do not know why there is a CRV and CR-V. I was puzzled too.
    If Honda is addressing the issue it is news to me. The yhave not contacted me or my insurance company. Also, these 4 are not the last ones I will be reporting on. I just make sure I have confirmation before I say anything.
     I just report the facts, you make your own judgements
    The X-Terra is based on the Frontier pick-up truck. That's the way they used to make most SUVs.
    and the old Pathfinder based on the Hardbody.. both pretty crappy, in my opinion.. I like the looks of the Pathfinder, though.
    Funny, but a very similar discussion is already going on in a comparison thread. I use the X-Terra as an example of how mid-size vehicles are creeping into the small SUV class.
    varmint "CR-V vs Escape" Dec 31, 2003 3:37pm
    Maybe I should start a separate thread on "what makes a small SUV small?"
  • real4wd1real4wd1 Member Posts: 8
    Are you people typical of todays Car based SUV buyer ? Statements like: The X-Terra is based on the Frontier pick-up truck. That's the way they used to make most SUVs.
    Do you even know what body on frame construction and 2 speed transfer cases are ? Thats HOW they make REAL 4WD vehicles which are capable of true offroading and unlike the gurlish V which are Civics with AWD, why dont you just buy an AWD minivan and stop pretending your in something its not. My wife drives an 01 'V' and I drive it from time to time and its a very nice car but dont mistaken the difference between the CRV and real 4wd trucks. I offroad regularily and I would never dream of taking my wifes whimpy little CRV offroad, some of you guys babble on about not underestimating how great the CRV is offroad but sheesh I can take a beater Corolla offroad and if you beat on it hard enough on the trail it will make it up to certain point until you break something and thats not what offroading is all about, plus according to my wifes owners manual the warranty is void if I take it offroad and bust something.
    I think you don't understand the purpose of the CRV. First owning a REAL 4WD doesnt make you a "tough guy". Just makes you kinda out of touch with reality if you think you can commute to work each day in it. I see lots of "tough guys" in "REAL 4WD" here in the north east sliding off the road in snow storms because they dont have enough brains to understand how to use their trucks. If you want to be a "Real Tough Guy" use a "Mountain Bike" to "off road" and use something safe to drive on road.
  • beebee13beebee13 Member Posts: 38
    the honda crv has the mulit-port and the saturn vue has the other...what;s the difference? Also, I am trying to decide between the two cars...reading about the crv fires is scaring me though...any new news on these? Are leather seats an option on the CRV-EX? thanks.
    "Are you people typical of todays Car based SUV buyer?"
    No. For one thing, all false modesty aside, I know a heck of lot more about them than the typical buyer. I also use mine off-pavement more than the typical buyer.
    "Do you even know what body on frame construction and 2 speed transfer cases are?"
    Yes, and that is exactly why I tend to avoid them.
    Don't take my comments out of context. I know there are good reasons for building SUVs on truck platforms. But there are also good reasons for building uni-body variants. (This is where I would start asking you if you know about crush zones, fuel econonmy, drivetrain binding, etc.) In the context of this discussion, I was simply stating a fact. The X-Terra is based on a truck. That gives it much different characteristics than the unibodies in this class. In fact, some differences are so great, I tend to treat them like two separate classes.
    Beebee - How technical an answer do you want? Do you have a decent grasp on how an internal combustion engine works? If not, explaining multiport fuel injection is going to take a while. For most owners, the difference between the two designs isn't going to be noticed. Suffice it to say that both mix air and fuel for the engine.
    If you are looking for a general recommendation on which to buy, it would help if you told us how you are going to use it. Both vehicles have their strong points.
    As for the fires, the latest posts are in the CR-V problems thread. We really don't know anything other than the fact that a problem has been reported.
  • sfsmithsfsmith Member Posts: 20
    A question for the informed. My 02 CRV (48,500 miles) is making a loud, low whirring noise when the system kicks in. I notice it now because it's the first opportunity(?) to use it with 18" of wet snow around. While I'm on the subject, my 2 cents on the effectiveness of the CRV in wet snow......it works reasonably well....but not enough weight. The CRV tends to squirm around alot... I had to chain up to get out and down the road today. I didn't get far without chains on Tuesday.
    Thanks for your feedback.
    Steve
    Good point about the creeping, varmint. I think it has to do with price. With incentives, vehicles like the Rodeo and XTerra end up competing in the small class, mainly because they overlap in price. $17-23k is where most of them price out.
    One look at payloads, curb weight, towing capacity, etc., tells you they are mid-sized.
    Coincidentally, I test drove a Grand Cherokee Columbia Edition today. We got a $50 offer for a gift card at Sharper Image, so why not?
    It only confirmed my preference for car-based SUVs. Sorry, "gurlish pretenders", LOL.
    The truck has a nasty driveline whine, audible at any speed. Salesman said it would go away when warm but it didn't. NVH was just awful, lots of wind and tire noise. The HO V8 was torquey, but not any quicker than the last 'V I test drove, and certainly not worth the 15/20 EPA numbers.
    Unless I just had to tow a boat or something large, there's just no way you could pry me away from my gurly pretender (a Forester in my case).
    For $6 grand less, I could get a Forester XT that could run circles around the GC, handling and acceleration, how's that for gurlish? I realize people have different needs and preferences, but mine favor a more refined, car-like, and yes sporty driving experience.
    -juice
    I am not a 'pretender' and I know exactly why I bought my CRV.
    I do NOT need Frame-base 4WD.
    I never go off road - I go to work every day.
    I used to work in Africa years ago and I know WHAT REAL
    Off Road truck is: Good old rusty Landrover, Russian rugged jeep or Toyota trucks, which I never even saw here in U.S. And remember: no plastic parts at the front! They would turn into "noodles" pretty soon. No fancy electrical stuff! Tolerance on fuel(with dust and rust)- need a good fuel filter and a radiator which would take water with frogs. (More primitive - the better).
    But I do not live in Africa - I live in the U.S. and
    I need a reliable, roomy, economical, comfortable runaround vehicle (CR-V) with occasional capability of handling snow storms, period.
    CRVs appeal to poseurs pretty much along the same vein as these Civic drivers who lower them and add on these tin can mufflers then they think they are all that, can you spell wannabe? The way CRV owners flaunt "Honda" reliability and superior on road handling is just hilarious and comparing a CRV to an Xterra is a joke. The Xterra fills a niche market with true purpose while the CRV tries to be the Mcdonalds of SUVs trying to appeal to everybody, your better off with a minivan than a CRV then at least you dont come off as one of those people with the pretend Civic based wannabe offroader. Honda targets the CRV for girls and old folks who need extra traction and want to look good and outdoorsy in their cute SUV and in it does a good job for what it was intended to be and anti minivan SUV.
  • vman123vman123 Member Posts: 10
    are you joking?when I bought my V last year I looked at Liberty xtera gran cherokee jeep wrangler 4runner and freelander(british trash) and after many months of research I came to the conclusion the V will outdo all of these so called offroaders in every category.Incidently I was offroading a few weeks ago and a Jeep Liberty who was in front of me on a steep rockyhill got stuck while I drove easily by.I didnt have a rope to help pull him out.Real time 4x4 in the V doesnt need that low gear because it has its own internal low gear when I am offroad which means it will do everything the xterra and Liberty can do offroad and more while getting much much better fuel economy
    Your profile says you drive an LX470, let's analyze the whole wannabe issue, shall we?
    My dad worked in Belize and Suriname, and they had UN-spec vehicles in their fleet, for REAL off road use, as you say. The Land Cruiser was among their favorites, but let's look at how they were equipped:
    * diesel engine
    * manual transmission
    * vinyl seats and floor mats
    * steel wheels with nobby tires
    * clean, narrow body with no fender flares
    You are masquerading around in a luxury vehicle, a tuxedo on what underneath used to be an off road ready vehicle, but is now dressed up for use at the Country Club. Face it. Automatic tranny, auto climate control, gas engine, heated leather seats, wool carpets, huge alloys wheels with pavement-biased tires.
    Who is the pretender here? Honestly? You gonna take a $60 grand vehicle off road? Scratch up those huge fender flares? Even if you do, is that particularly smart?
    You have a very, very nice luxury truck for pavement use, by the way.
    AWD Minivan? Let's rule on the DCX and GM vans right away for not meeting reliability standards for the crowd here. That leaves the Sienna, which has NO SPARE TIRE, so it cannot be allowed to drive on the beach.
    Not an alternative for lots of people here, sorry.
    Too bad I can't import those real Land Cruisers, equipped the way that fleet was, to the US. And just so you know, those cost about $22,000, so the other $40 grand or so you paid was for that tuxedo.
    Nice tux! LOL
    -juice
    my V will smoke any Landcruiser offroad because of the Real Time 4WD, I was offroad a few weeks ago in the mountains there was one of those Freelanders and a Landcruiser. Man I must say those Freelanders are the worst offroad, he got stuck in a small mud puddle and my V drove by easily then there was this Landcruiser up a steep hill who was also stuck, my V drove right past him easily too people underestimate how great the V is offroad.I am about to add extra offroad lights.
  • terrafirmaterrafirma Member Posts: 212
    I don't know whether to laugh or cry because you are so very misinformed!
    The CRV is a great little street suv. It is a 4 wheel independent unibody based off the Civic platform. Look under your rear bumper. You see those long skinny suspension arms mounted to a dropped a-arm mounting point?
    That is a passenger car suspension.
    Besides having NO articulation, that suspension would snap in half on stuff a Land Cruiser or 4Runner would easily walk through.
    The "real time 4wd" in the CRV is fine for on-road duties but isn't even close to being designed for off-road! It is beyond laughable for you to even compare the CRV to any real SUV off road.
    Honda will gladly tell you the exact same thing! Maybe you feel mighty in a CRV going down a bumpy dirt road but that isn't considered off-roading.
    You need a real SUV for off roading. That is why people use Land Cruisers, 4Runners and Xterras. Unlike on the street, you can't fake your way up and down a mountain range.
    Sorry, this is your wakeup call. The CRV is an excellent product designed for on-road activities. Look around, there is a good reason people don't lift and wheel CRV's.
    As for the American Land Cruiser being a "pretender", that is really showing some ignorance. It is one of the all-time greatest SUV's on the planet! Can't off road? Check out http://realcruiser.com/ and you tell me.
    Read my post, I was talking about the LX470 guise specifically.
    But thanks for making my point for me - those look like properly equipped SUVs, knobby tires and mostly older models that don't cost $60 grand.
    -juice
     ateixeira wrote-
    "Automatic tranny, auto climate control, gas engine, heated leather seats, wool carpets, huge alloys wheels with pavement-biased tires.
    Who is the pretender here? Honestly? You gonna take a $60 grand vehicle off road? Scratch up those huge fender flares? Even if you do, is that particularly smart?"
    Almost every Land Cruiser on that site fits your description above. Pavement biased tires? Have you seen the CRV's? Have you seen the LX's? Even with bald tires it would still be better off road.
    Who cares how much it costs? It's all relative.
    Many of those Land Crusiers cost those owners alot of money and $60 large is alot more common than you think.
    What is important is the capability of the SUV.
    The LX470 (FJ100) is supremely capable. Not as good as the 90's Toyota Land Cruiser but still so much more capable off road than a CRV ever could be.
    The CRV is an excellent on-road compact suv. I really like them and Hondas in general. However, people like VMAN make laughable statements about the CRV's capablilities. I wouldn't off road a Civic sedan which sounds about as ridiculous as saying the CRV is superior to real SUV's
    The Duelers on most CR-Vs are all terrain tires.
    I drove all over the Outer Banks and didn't see any newer LX470s/Land Cruisers, only one or two decade-old models. I bet less then 3% truly use those capabilities, so it's fair to say the other 97% are pretenders, no?
    Capable? Sure, but virtually noone makes use of that capability.
    CR-V owners use RT4WD every time it rains, snows, even on light gravel trails, dirt roads, sand or other unimproved surfaces. I think it's fair to say owners use their (lesser) capabilities far more often.
    -juice
    First having just came back from a 2 day trip in a Land Rover Discovery the conclusion was that we would have been much more comfortable in my CRV. We didnt go off road but on interstate 95 there isnt many places to go off road.. and the cost of the gas could have paid my monthly CRV payment!
    Most of my clients in a northern NJ HIGH INCOME area have SUV's (Lexus and Hummers are a big favorite). I find it pretty funny that many times I have to go out to the truck with them to show them how to work some of the 4 wheel drive features.. some of them wont even take the truck out if it's snowing!!!..
    so while the big SUV's may be capable off roaders, I would bet that 99% of those buying them never go off road..unless your talking about the ramp leading to the mall parking lot. They buy them because they feel they need the size for car pooling but in reality a mini van or a CRV is a much better choice for them. They just like the way they look in a big SUV and be damned with the cost! They also feel that they sit up higher so they get better cell phone reception!!! :)
    "I drove all over the Outer Banks and didn't see any newer LX470s/Land Cruisers, only one or two decade-old models. I bet less then 3% truly use those capabilities, so it's fair to say the other 97% are pretenders, no?
    CR-V owners use RT4WD every time it rains, snows, even on light gravel trails, dirt roads, sand or other unimproved surfaces. I think it's fair to say owners use their (lesser) capabilities far more often."
    _________________________________________________
    Most CRV owners don't take their cars off road either. Are they all "pretenders?"
    I am talking about the capability of a Land Cruiser and LX470, NOT the capabilities of the drivers! It is not my place to judge how owners use their vehicles. I am judging the capabilities of the PRODUCTS.
    LX470s and Land Cruisers have FULL TIME 4WD so they use their system all the time. Besides that, they have a CENTER LOCKING DIFFERENTIAL, 4LO GEARING and SRA.
    The CRV is a great on-road go-getter. It is in no way comparable to the off-road capabilities of a Land Cruiser, LX470 or 4Runner.
    Why not focus on the CRV's true strengths (great MPG, lots of room in a small pkg, inexpensive, good quality, comfortable,etc) instead of trying to fabricate complete falsehoods on what a CRV can do offroad, where it has no place because it wasn't designed for.
    Don't take my word for it, read Edmunds review or any other. Look under your CRV and look under a LX. Look at the size and construction of the suspension.
    You'd have to ask a CR-V owner, LOL.
    I don't doubt that those SUVs are capable, and I don't even disagree with what you've stated. Though you have to admit the idea of taking a $60k designer luxury SUV off road is just silly.
    Someone was trolling (not you, BTW) and said everyone here would be better off in a minivan, I don't believe that is the case. That's all I'm saying.
    -juice
    I think the idea of taking a $20,000 CRV off road is silly. The LX is capable off road, nothing silly about that. Plenty of people off road expensive trucks. Look at the Land Rover expedition clubs for one.
    If I owned a CRV (which I would be proud to own if I ever needed one) I would never subject it to that kind of abuse because I would want it to last 100,000 miles and not have expensive suspension or mechanical damage because I know it was not designed to off road.
  • lurkercrv99lurkercrv99 Member Posts: 2
    My name is Thom Madden and I was a long time lurker with a 2002 V and this recent conversation prompted me to respond. Firstly, Vman123 get real with your claims to the V's offroad prowess, let me enlighten you further to an experience I had with my 02 V last summer. I hooked up with some of the offroad enthusiasts from the hondasuv group they assured me my V is as least as capable as the Liberty and Grand Vitara. So this summer I packed up the V and went into the interior on a stocker 4x4 run, others in the group were some Liberty's, Grand Vitaras, Wranglers and Grand Cherokees, all dead stock.
    Now before I go any further let me say I LOVE my V its awesome are town and perfect for my family. Now we started off on the highway, about 3 hours travel then we hit some logging road heading up the camp site then the convoy moved off to a road which didnt look so bad, it was rocky and there were some 6 inch deep washouts but my salesguy assured me no problem with light offroading and some members of the the other board assured me if a Liberty or Gran Vitara can make it then it will be easy for me. Thats where the story took a nasty turn and I HOPE LIKE HECK HONDA IS LISTENING ?
    My V had problems on the light rocky section right from the get go, I thought there was a mechanical problem for sure, while the others were easily crawling up the slope my V kept stopping in the rocks and one wheel kept spinning I had to make a run at several sections with foot to the floor and I was upset because I felt like I was abusing my new to me shiny V. Anyways I was holding up the convoy really bad and it was embarrasing and I was really disappointed. Finally the last straw fording a 6 inch deep stream, No problem but to get out of the stream was a deep rut, again the Liberty Grand Vitara and Cherokee climbed out there easily and they were travelling really slow so I thought this will be easy, as I approach the exit to the stream the V slams to a stop, I floor it and wheels are spinning, I had to back up and make a full throttle run at it but when I did the rear suspension got hung up on some small rocks and I was messed!, anyways to make a long story shorter and $2100 later and a $310 towbill back to civilization and one broken ego.
    Honda would not even consider touching me with warranty and my insurance company said no way since I was offroad. To finish off my story we packed up the gear in the Gran Cherokee and left the V on the side of the stream as we continued on but my trip was shot and I was in no mood for a good time, I couldnt go back because this would have forced one of the other guys to drive me. Anyways I still love my V but it doesnt go near offroad trails and despite the fact that these guys on Hondasuv go offroading well I came the conclusion that you can offroad with it but something will break so dont bother, it was an expensive lesson to be learned. I am also having rear tire alignment problems even after spending over $2k to get the suspension fixed.
    When I spoke to my salesman about this light offroading claim he said he meant smooth logging roads and nothing more. NO the CRV will not offroad very well unless you floor it everywhere at the risk of breaking stuff but as a city SUV it is excellent. Sorry for the sob story but this is just a word of warning to all who think they have an offroad vehicle,
    unfortunately while most on this board know what the V is good for most of the guys on hondasuv think differently,they always dis and knock other SUVs like Xterras and so forth and brag about their offroading trips but now I know the difference between awd car based and 4wd truck based SUVs and if the guys on hondasuv knew the difference they might not have showered me with such BAD advice. Its still my fault for listening to such ignorance. Im gonna keep my V for 100,000 miles provided I can get the rear suspension back to normal and it is the most reliable vehicle I have owned next to my Accord but I will never take it offroad again.
    Again, terrafirma, I agree, but I bet most of the vehicles in the Land Rover expedition clubs are older Discos and Defenders. Besides one or two newbies just for bragging rights.
    I'm not suggesting that CR-V owners go rock hopping, but it seems to meet the light duty needs that are more common anyway. In other words, they are using the vehicle as it was intended to be used. IMO that's not pretending, it's just practical.
    My roommate and 2 friends all had Wranglers at one point in time, and we'd go off road. All 3 had lifts, and still each would suffer damage on each trip. Brake lines, clutches, we even bent a leaf spring on one. Each time they'd limp home.
    You gotta pay to play, it goes with the territory that there will be damage when you challenge a vehicle like that. That's why I think it's kind of silly to take a $60k LX470 off road, scratch up that gorgeous pearlescent paint.
    -juice
