The 91 & 92 Probe V6 used the Vulcan, the 93+ used a Mazda designed and sourced engine. The more powerful 2.2 liter turbo motor was a Mazda sourced engine as was the base n/a 4.This has been discussed before, along with Toyota still using the 22RE at this time. The Mazda 626 was introduced in 1979 so I don't see that as been influenced by the Probe which came out in 1989.
Again, the 93+ (the GF) was originally set up to be a sedan with a coupe/hatch derivative. This time, both engines were sourced from Mazda (2.3l I4/2.5l V6,IIRC) while the rebadged Tribute got the 3L duratec that Captain so enjoys.
Those that believe that anything with more than 4 cylinders (or rotors) are 'Mazda' engines are deluding themselves IMO.
Thankfully, we know what they say about opinions :P
I don't see Accord, I see IS250 or whatever the little RWD Lexus is called right now.
certainly a lot fuzzy recollections, there.
i'm pretty sure the 3.5 and up DT are a different architecture than the 3.0 DT.
The 2003-2006 Mazda6 s also had the Ford Duratec30(200hp), with the addition of Mazda's VV-T (220hp).
capitan-
The new Duratec35 and 37 are not just bored/stroked versions of the Duratec30. The 35 and 37 are adaptable to direct injection and are equipped with VV-T. Also, fuel economy has been drastically improved. Preliminary figures have Mazda's 3.7L version getting 27mpg's and 270hp. The Duratec30 in the current Mazda6 is rated at 215hp and only gets 25mpg's.
Duratec is just Ford's name for their DOHC engines. Their current 4 cyl "Duratec" named engines are Mazda designed DOHC engines.
How about this? The resemblence would be closer with the 2009 Sonata, as it has a mostly red lens.
One thing about the new Mazda6--it's really hard to pen a fresh design in the mid-sized sedan world, but I think Mazda did as good a job as any recent re-design on that score.
Oh I thought it debuted in 2006. The Lexus IS debuted in 2005. I doubt they copied the sheetmetal too close to change the styling of the car.
As far as the pictures of the Lexus and the Sonata, the lights are (mostly) red, and are both on the rear corners of the car. I don't see any other similarities.
I heard a report on the radio today that said GM is planning to build about 90,000 fewer large trucks and SUVs this year than last year--a move that is related to the numbers in the article.
And they said the 08 Accord was too big. :confuse: Not for those people down-sizing from SUVs and trucks. Seems a lot of these consumers are buying the V6 model, and VCM is part of the attraction. It even outsold the F150!
Edmunds needs better editors, though. The article says: Honda was the only brand with three vehicles on the Top 10 Best-Selling Vehicle list. but there are three Toyotas in the top 10, as well (Camry, Corolla, Prius).
Point to whatever you would like but the result is still the same - a substandard engine (relative to things like the Toyota/Nissan/Hyundai engines). The 'old' DT while it might have had the right number of camshafts and even the 'right' architecture was and is a poor excuse for an engine these days, besides being seriously short in the HP dept. it is noted for primarily its lack of refinement. Fast forward to the too late 3.5/3.7 and yes with a 30% displacement increase we do see some reasonable (and competitive) HP but the same lack of refinement and ALSO an apparent increase in appetite. You'll see these kind of comments pretty regularly in expert reviews and not just based on my own experience 500-/Fusion for the 3.0 or the 3.5 with a Edge. Specifically look over the February issue of CR and its test of the Taurus - the second rate nature of the 3.5 and the fact that FE is DOWN with the new engine are both discussed at some length. So which to believe, the spec sheets or actual tests and experiences - I know I know publications like CR all have it in for poor old Ford, despite ranking the Fusion near the top in this category despite the engine 'insufficiences'. And yes, I'll freely admit to a anti- Ford bias when it comes to what they did to Mazda
From what i reading from pressroom.toyota.com sales report, 40487 units of camry (including solara) were sold in March. Solara should be counted as "camry coupe", but still the dual still outsell the accord (including accord coupe)!
Well that about sums it all up right there folks.
A little research goes a long way captain. I don't believe anyone here has the time or desire to correct all of your opinions with facts though. I know I certainly don't.
Other options eleswhere (based on UK site) are 1.8, 2.0, and diesel.
The 2.5L seems to be enough for me. I have the 2,3L right now. I have always thought the 2.3L could use some more power, so the 2.5L should be just fine, as long as the fuel economy at least stayed the same, or better.
you are welcome to spend your time however you choose...
No. That you don't even know where the Duratec block originated from and the differences between applications is where things get cloudy in your posts. You seem to have driven one example of it and wrote off the whole line. Some versions of the Duratec line are a little rought I'll admit. But after having owned 3 vehicles, and driven a few others, with different versions of that motor, I know better.
Now that we all know you dislike Ford and Mazda (the latter for belonging to Ford) those clouds are parting.
I especially like that in contrast to the Toyota and Nissan offerings, Premium fuel is not required for the Duratec (or Ecoboost, for that matter).
Not anymore. The North American Mazda6 grew a bit. It's not as big as the Accord or Camry, I really think it will be a shade smaller then the Altima.
Can't they get enough power for that car out of a smaller engine?
3.7 v 3.5. Really, what's the difference?
The Malibu and Aura have 3.6L V6s. As was noted, some other mid-sizers have 3.5s. So 3.7L, not really a big deal, is it?
Isn't the 3.7 heavier than the 3.0? And less fuel efficient? Of course the 3.0 is no fuel miser either.
Not really. Remember, the 3.7 and 3.0 use a smilar block, if not the same block. Also, preliminary EPA estimates have the 3.7 with 27mpg highway and the 3.0 is rated at 25 mpg highway. The 3.7 will also boast a 55hp advantage.
Also, the largest power difference between the D35 and D37 is not the HP but rather the torque. The D35 in the Edge and in the first year of the CX-9 makes 263 horses and something like 246 ft-lbs of torque. The D37 only increases the HP by 7 but the torque increase is roughly double that. I don't think the gas mileage decreased much if any when the CX-9 switched from the D35 to the D37 either. Both, like avi said, are more fuel efficient than the D30.
Now the PIP D30 in the '09 Escape (and possibly the '10 Fusion) is supposed to be right up ther with them in fuel efficiency among other improvments. Those specs aren't official yet so we'll have to wait and see. The Escape gets the new D30 because the D35 doesn't fit. I understand that the D35 does fit in the Fusion but Ford has been unusually quiet about the '10 Fusion which we're supposed to see this fall in L.A.
Regards:
OldCEM
Honda had three cars in the Top Ten for the first quarter, which was shown in the chart below the March numbers. Toyota did not. Read again.
http://www.autoobserver.com/2008/04/honda-accord-be.html#more
Also, Rumors are going around that NIssan will be dropping the 6spd manual from the Altima lineup in 09...wonder how true that is...
To that end, Honda’s success in March wasn’t limited to the Accord. Honda was the only brand with three vehicles on the Top 10 Best-Selling Vehicle list.
Of course, since CR (a magazine that tests toasters and fabric softeners) is such an "authority" on cars. Right...
This thread was seemingly started by conversations about this 'great new Mazda' 3.7, which I regard as still a DT and still a Ford engine. I only wish that the Speed6 hadn't been so short lived.
...And I only wished you weren't so short-sighted.
The "great new Mazda 3.7L" seem to have some merit, since it's included in the CX-9, winner of the North American Truck of the Year. Motor Trend picked it as it's SUV of the Year, saying the 3.7L "behaves in a silky, refined matter, accentuated by a sporty growl from the dual exhaust"(Motor Trend, December 2007). Car and Driver named it one of the 5-Best Trucks. I've seen nothing but praise for the CX-9, and the 3.7L is part of the reason.
Go ahead and put down the DT based on your limited experience with the 3.0L, but I've always gone on the phrase "Don't knock it until you've tried it." I've personally driven the CX-9 with the new 3.7L, and it's a HUGE step up from the 3.0L in my Mazda6, both in power and smoothness, and it'll make an excellent engine in the upcoming 6.
50 or 60 HP will do that, won't it, even in a heavier vehicle like the CX - making it unnecessary perhaps to wring every last bit of available power our of it as you did out of the 3.0. I 'm sorry but the the 3.0 at 5000 rpm is anything but 'fun' and I read the same sort of thing about the 3.5 and likewise have experienced it in the similar Edge - and I'm not nearly the only one - even if you don't like what an organization like CR has to say. It does lead one to the inescapable conclusion that there is whole lot more of the 3.0 in the 3.5 (and possibly the 3.7) than Ford or Mazda would have us believe.
I would suggest to you that the CX9 win in TOY has more to do with what the vehicle does unrelated to what happens to be under the hood - as is a tradition of sorts with Mazda products. Mazda, in particular, has always made a specific type of vehicle (call it 'zoom-zoom if you must) and done it well.
+1000!
The Speed6 is a total marketing blunder by Mazda. That car is a prime example of how not to market a car.
autoblog.com reported that a new Mazda6 MPS (Mazdaspeed in Japan and North America) is on the way with a 2.5L turbo and 280hp and AWD. I highly doubt it will make it over here. With the Mazda6 V6 putting down 270hp, I really don't see many people making the jump to the Mazdaspeed. Personally, I really think a new Mazdaspeed6 would need at least 300hp to be a success here in NA.
Edit: Just noticed there's an error on hyundaiusa.com. The Compare Trims page says the I4 is standard on the SE and V6 is optional. But other pages, including Build Your Own, are clear that the V6 is standard on the SE. That would explain why the SE costs more than the Limited I4.
Numbers I have seen, and probably not supposed to see, was 270hp and 268tq for the 3.7 in the Mazda6.
You got that right....
Sorry, wrong again. :confuse:
Two separate sentences, and two separate statements.
The second sentence does not say For March only, and does not mean just for March. What they were saying is, March was a good month for other Honda cars too, and it HELPED them get three vehicles into the Top Ten for the first quarter. The chart for the 1st quarter is directly under the chart for March, and that's the chart the last sentence was referring to. Not Edmunds fault, if you can't read and comprehend.
