Hyundai Tucson Transmission Problems
2»
  • ct6559ct6559 Member Posts: 2
    Prior problem with transmission never fixed. After 2 wks service decided it needed a new wire harness on entire car. I had already mailed a certified letter to corp. because of lemon law. the dealership offer us to swap for another car but all they had was 2012's and they treated the defective
    car like a trade in. They made it sound like the lemon law was tough to prove and I didn't want to get stuck with the vehicle. They took off a few thousand on the 2011 toward the 2012. We probably didn't loose too much but their attitude was horrible when we brought up the lemon law.
    We still feel stuck with a car probably won't last more than a couple of years.
  • bloomer1952bloomer1952 Member Posts: 3
    Hello All. My 2005 Tucson was my 2nd Hyundai, after a 2004 Elantra GT. I still have both cars.
    At 17,000 miles, my Tucson shuddered while going up a hill, I took it into the dealership and they repaired it. At 60,000 miles, while on a trip in Mexico it started jumping from Overdrive into 3rd, or 2nd gear. If I turned the car off and on again, it would be okay until I put even the slightest load on it (hill). This was back in 2008 or 2009.
    We called the dealership, they said no service in Mexico, so we just babied the car for the next 4,000 miles and completed our trip......... without turning back.
    When we got back, Hyundai repaired it, and 5,000 miles later it happened again. Instead of turning it off, we went to the dealer, and they were able to download the black box information. I was sure that somehow the main shaft was out of round or something like that.
    1st off, Hyundai said naw, 3 times must be the way I drive. I searched on the internet and found something similar in England for a Tucson transmission, so I printed the email and showed it to them. The gave the repair to some tech from Yugoslavia and he spent two weeks going through the entire computer program and found the glitch and sent in a Service Bulletin (it should have been sent to all Hyundai agencies).
    Now we have 114,000 miles on it, not a single problem since. Besides this tranny problem we have not experienced any problems with the car, and the Elantra, still in the family, hasn't had any problems except the battery (at 80,000 miles) and somehow the carpet locking tab broke off and my daughter called stuck somewhere cause the carpet had gone under the gas pedal and she didn't realize it.
    I think Hyundai's are wonderful, the Elantra kicks butt with the 16 valve and Rack and Pinion, and my Tucson will dust off most Honda's (I have the 2.7) ha ha.......... Both cars have leather, oooh so comfy......... sunroof on the Elantra.
    I now drive a Mustang 2009, wife drive the Tucson, daughter drives the Elantra, and my son a 1967 Mustang.
    best wishes!
  • dannyd3dannyd3 Member Posts: 56
    Hello everyone,
    The brake switch was the culprit. It was replaced and so far so good. The computer should store the codes for the dealership.
  • 00110011 Member Posts: 1
    We own a 2005 Tuscon and it has had the first transmission resealed three times then replaced, the second transmission had to be resealed, the oxygen sensor replaced, the power steering pump replaced, after the hoses were replaced for it three times, the rear glass struts replaced, the rear shocks replaced, the tires never get the wear they are rated for, the front defrost for the windshield was never connected and was only fixed after an accident with a deer and they they finally the connection cable and fix it. The passenger seat belt belt locks when it should but won't release afterwards.I do not feel it is reliable transportation. The motor cover has five of its six bolts stripped when the dealership worked on it. It has been a very expensive car to maintain. It has only been to the dealership for repairs and scheduled maintenance. It does handle well but the repair costs have been out of control. I will not buy another Hyundai it will be an American brand. :lemon:
  • chucko6chucko6 Member Posts: 81
    Too bad you never tried a Japanese product. Have only owned Honda, Acura and Toyota since 1981 and even though some came from Ohio or Canada they were all topnotch. Got snookered on the 2010 Sante Fe since the wife liked it's looks and comfort.
    Never thought that basic components like struts, defrosters, transmissions would be a problem in a modern day vehicle.
  • pcal1028pcal1028 Member Posts: 2
    Same here in NY...wasted a day waiting at the dealership for them to say nothing was wrong...i just had to replace fuel injectors....well its still doing it, a few days ago a new problem- when I use the auto start, about 25% of the time it will shut off after a few seconds....I guess I will call the dealership AGAIN!
    I was merging onto a pretty busy highway today when I stepped on the gas and the car wouldn't go...glad there was no one behind me!
  • stefani_shookstefani_shook Member Posts: 4
    My car is a 2007 Hyundai Tuscson and I was driving yesterday and when I stepped on the gas teh car wouldn't go... I coasted to the side of the Road and tried to recrank the car and It won't crank... We can't figure out what is wrong with it... Anyone have any ideas???
    How many miles? Did you have your timing belt replaced at 60,000 miles?
    2007 Hyundai Tucson Maintenance Schedule
    No! Do you think that could be it?
    My car has 84,000. It is like choking for gas!!! It tries to crank but won't!
    edited December 2011
    Could be but I'm no mechanic.
    Choking for gas sounds different from a broken belt though.
    Try asking here too:
    "No Start" Problems
    Gates.com says that both the 4 cylinder and V6 engines are interference, meaning if your timing belt breaks, you may damage the valves or worse. So you may want to try to get that work done soon.
  • jn5292jn5292 Member Posts: 1
    My 2011 Tucson with less than 30k, had the transmission go out. The dealer said there was a leak in a radiator cooling hose. Leak is not accurate. It burst on my way to work and the transmission went out. Has anyone else had this problem? What should I expect from the dealer in terms of repair? How do I ensure there isn't damage to the transmission?
  • haroldwharoldw Member Posts: 8
    Continuation of my post from Mar.15, 2011. Sorry for the delay.
    The trouble was the crankcase position sensor. On JUne 1. 2011, I went to Auto Zone and purchased a new crankcase position sensor for $60.00 minus a 10% do-it-yourself discount otherwise known as a senior discount.
    My local mechanic charged me $40 to replace it. He had to take out the radiator first.
    I'm sure my local Hyundai dealer would have charged me $150 for the 1-1/2 hour job.
    I now have 25, 800 miles on my odometer without any other problem.
    I have had no other problems since it was new. I suppose I'm lucky after listening to the problems of people in this forum.
  • nige1nige1 Member Posts: 1
    Hi, Did yiu ever find out what the rattle was ?,
    I have a 2004 crdi with the same problem between 1500 / 2000 rpm mainly in 4th and 5th gear. Ive recently put new clutch in still the same ,
    i am wondering if its a gearbox or transfer box problem ?
    Like yours ive had car for 6 months now and i tow a caravan and it hasnt got any worse
  • rowbeanrowbean Member Posts: 4
    My transmission died at 20K miles on my 2010 Tucson. The only answer they could give, "a flaw." It now has 31K and is going back into the shop tomorrow because its not shifting correctly. The traction light comes on when its in park and it will not come out of park. Its a lemon to me at this point and I'll never buy another Hyundai again. :lemon:
    2010 Hyundai Tucson from hell. New transmission installed at 20K miles then brake switch at 31K and now the speedometer broke and engine is on. You can feel the transmission is acting up again and its jumping as you speed up. Its going back to the shop tomorrow and I'm done. I've read way too many problems on the internet about this car and cannot tell you my disappointment :lemon: :lemon: .
  • jttxjttx Member Posts: 2
    edited November 2012
    :confuse: 33K miles on this and have only owned it a week!! It started when one day I turned on the ignition and two icons came on that I had not seen before, one is the uphill icon that was showing as red and the other was traction that was showing as yellow.
    When I came to a stop and tried to shift into park, it would not move past neutral and would not go to reverse or park of course, I could only drive forward or if I wanted to stop, I would have to put into neutral with the emergency brake on. But of course could not remove the keys in neutral.
    I drove it around a bit and then noticed the icons had turned off, so I came to a spot where I could pull over and tried to shift and voila! it shifted into park and reverse, did not have any problems for a few days until today when I went to start the car- same problem, so I drove to the dealer and as soon as I drove into the service aisle, the icons went off!
    So now she is at the dealer, not where it was bought, it was bought in another city a ways away. This dealer says they will do a diagnostic but cannnot promise anything unless the offending icons come on while they are testing her.
    anyone else have this problem? Any suggestions?
    ^^^ it's the brake switch. I had it replaced and it worked fine for less than a month! Then the transmission started surging. Took it back and they said it was the temperature control in the transmission. I traded it that day! I don't have time to be at the repair shop every few months for a transmission that only had 10k miles on it! Remember this is my second transmission in a 2 yr old car. I will never own a Hyundai again! Best of luck to you!
    Mine is a 2011 Tucson. There is no racing engine, but 2 sensor lights- the uphill grade goes on in red and the traction goes on in yellow, when I stop the car and try to go from neutral to park it will not go past neutral.
    Dealership has car and will run a diagonostic, should I tell them about the "brakeswitch" problem or let them figure it out in case that is not my issue?
    How is your car running now?
  • dillandillan Member Posts: 1
    can someone help? i bought 2007 tucson with only 55000 km. i get 14 miles to the gallon...BRUTAL.....mechanics say they dont know why because diagnostics dont tell them what to do! it feels like i dragging a house, as soon as i let go of gas it feels like i hit the brakes! there is no coast or glide to this thing at all! wheels are all moving free, nothing stuck or seized is all they say. i been reading about transmissions and timing belts????
    Sounds like time to find out how strong that Warranty is. Difficult enough to get satisfaction on a new vehicle let alone a used one.
    I have two Hyundai vehicles with the 100,000 mile warranty. ...
    I have only had one problem, the transmission went out on my Tucson at 17,000 miles and again at 70,000.
    The first time they went out of their way to replace it, but the second time I was stonewalled. .. ..
    They told me various things, like I drove it hard, and also they looked at the tow hitch and claimed I was towing something heavy (actually the small hitch came with the Tucson for the bike rack option, so there) .. ..
    The failure was peculiar, so I did an intense internet search of a similary problem, printed it out and took it to the dealer, where I found someone in England who experienced the same problem.. ..
    So I went back to the dealer, and he had his best specialist ride along with me and when the failure occurred, he had me leave the car running and attached some kind of black box reader.... ..
    Two weeks later (they gave me a loaner) they figured it out, the software that recognizes up to 4 different drivers got confused and it was making it jump from driver to driver, that caused the erratic shifting. A few lines of code were added, and a Service Bulletin sent to all Hyundai dealers worldwide.. ..
    The point is, you might need to find some similar problem that is occurring in your vehicle and use that as leverage, include the words 'class action', 'lemon law', but in a casual friendly way. They will respond.. .. good luck.
  • jrh_iijrh_ii Member Posts: 1
    I am having the same issue with a 2010 Tucson. I can't seem to find a way to read the responses to your post, so I would like to know if you ever found the solution to the sensor and transmission issue.
    After all the transmission problems on my 2010 Tucson, i sold it. I was sick of breaking down and paying for a rental car each time it was in the shop. So not worth the trouble. I bought a Ford and will probably never go back to Hyundai. Defiantly never buy the first year of any car again!
    Yes my transmission problem was fixed by the dealer.
    After a thorough investigation, the technician (who was of European descent and brilliant) figured out that the software that recognizes the habits of up to 4 drivers had become confused.
    One of the causes was that I received that bike rack option along with the small trailer hitch, and my bike weighed a lot.
    There was a service bulletin issued, your shop must not have done a good enough job to find it.
    My Tucson now has nearly 138,000 miles on it, just passed the smog check two days ago.
    There was another problem I had not too long ago, when I gassed up, the car was hard to start, and the engine check light was on. Well, needing to fix that, and being out of warranty, I went to my local mechanic friend who investigated that and found that the valve that allows vapor into the charcoal canister was sticking. A few suck and blows later, it unstuck.
    I urge all who own Hyundai's to use the search engine wisely and find your same problem and print it out and take it to the dealer.
    My other Hyundai is a 2004 Elantra GT, 110,000 miles, never a single problem, ever. Then again, I take good care of my cars.
    For that nagging tranny problem I suggest you contact svelasco.frankhyundai@gs.reyrey.com
    3150 National City Blvd National City, CA 91951
    (888) 355-2980
    Rather difficult to solicit help from fellow owner's problems when some posting lag times are 3 to 6 months apart. With the number of Hyundai's you see on the road and all the problems you read and hear about, you would expect replies and responses within an hour.
    I once belonged to an Acura Forum and a question or comment posting would generate 2 to 4 replies the same day. I guess them Rich Guys had nothing better to do but spend time in front of that screen.
    Good luck with the Ford.
  • reberhartreberhart Member Posts: 1
    Bought my 2005 Hyundai Tucson new. Had to replace manual 5-speed transmission at about 2,000 mi. About 2 years ago, had to replace transmission again (125K miles). Didn't mind too much, it was the only major repair that had been needed. About a year ago, had total clutch failure. At first, the AAMCO guys said nothing was wrong with car. I had to take it in a second time with clutch smoking before they believed me and replaced master and slave cylinders (plus clutch plate, etc.) Yesterday, (now at 152K miles) I started having problems shifting, same as last year. After about 20 miles, was in heavy traffic on the beltway, couldn't shift at all, luckily was able to coast into a parking lot in 3rd gear. After putting it in neutral, I couldn't put it into any gear, including reverse. Got a ride to work, let it sit 9 hours, still couldn't get it into any gear (also had a friend try to get it in gear without success). I had it towed to AAMCO. They let it sit overnight, just called me and said nothing is wrong with car. I said "NUTS!!" I am not driving it again until it's fixed. Any ideas out there?
  • kyfdxkyfdx Moderator Posts: 271,382
    You had to replace a MANUAL transmission? Twice?
    Wow.... I've been driving sticks for 39 years.. replaced plenty of clutches when I was younger.... but, I've never had any manual transmission issues, other than shifter bushings on a 25 year old 325iS, with 190K miles...
    That sounds like incredibly bad luck... or, a defective design from Hyundai..
    I'm sorry that I don't have an answer to your question, though...
    regards,
    kyfdx
  • mechatony11mechatony11 Member Posts: 3
    I apologize for bringing up this old post. I recently bought a 2015 Hyundai Tucson; the car won’t shift from Park. I thought I’m having big issue on my transmission, but it turns out I just had a faulty brake light switch. Good thing that my friend saw that my brake light doesn’t work. So, I figured it out that it is also the reason why my transmission does not shift from Park. I learned this here: search for "Hyundai Transmission Problems on YOUCANIC” and you will see an article that goes over common causes and possible fixes; you can read about it yourself. I hope this information can assist someone else with a similar issue.
