The Honda Service Manual for the 1st Gen CR-V says that under "normal" conditions the trans fluid should be changed every 90,000 miles; under "severe" conditions it's 30,000 miles. Brake Fluid change interval is 45,000 miles for both schedules.
I'd also suggest that you have the rear differential fluid changed at 30,000 mile intervals, and also have the valves checked and adjusted. There have been problems reported with both on the 1st Gens.
13208 the_racoon: In regards to the rear diff. fluid, I take it that's for the 4wd models? My manual says the same thing, but for the life of me, I can't find any plug.
I'm approaching the big maint. item, the timing belt. I plan to also have the dealer change the water pump, accessory belts, and adjust the valves. Anyone have an idea what that should cost me?
The info. helps alot!
Yes, only the CR-Vs with RT4WD have a rear differential. It's a little larger than a football and sits between the rear wheels. It's connected to the front of the CR-V by a "propeller" drive shaft. There are two plug bolts on the left side (driver's side in the US) just in front of the left drive shaft. The bottom plug is the drain plug, the top is the fill plug. There are crush washers for each plug that Honda recommends you replace each time you remove the plugs.
Excellent point! And the fluid may drain faster if both plugs have been removed.
That almost happened to me years ago when I decided vehicle maint. was a piece of cake after buying my first shop manual. It took the longest breaker bar with an extension to get the fill plug loose.
Mike: I've heard of people that had to use a 2nd floor jack with a long-shaft 1/2" drive to break rear diffy plugs loose!
-juice
Do they have some kind of unbreakable agreement with Bridgestone that prevents them from changing to something else?
-juice
The first of the K series was the 2.0 in the RSX. This engine is actually quite a bit similar (not the same) to the 2.0 found in the S2000. They have it tuned with two forms of VTEC. One is good for 160 hp and the other other is rated at 200 hp.
The 160 hp version uses a valve technology that closes one of the intake valves during low rpms operation (below something like 2,200 rpms). This allows for decent low end torque, improved efficiency, and less vibration. In other engines, Honda has called this VTEC-E (E is for economy). It also adds VTC to control the "phase" of the intake valves, allowing the engine to adjust when the valves open in relation to the top dead center position of the piston.
The 200 hp version uses the VTEC that most people associate with Honda. It controls both lift and duration of the intake and exhaust valves. With the addition of VTC, this engine is quite feisty.
The CR-V's 2.4 is essentially a version of the 160 hp 2.0 in the base RSX. Honda enlarged the cylinders to boost the displacement to 2.4 liters. I *think* the cylinders are both wider and deeper. The head uses the same VTEC-E and VTC as the base RSX engine. Obviously, the computer controls and hardware had to be retuned for this application, but it's the same basic design.
Both the Element and Accord use a another variant on the CR-V's 2.4L block. It's the same VTEC, just tuned differently for a slightly different power curve.
The TSX takes the CR-V block and adds the VTEC head from the RSX Type S. It's the best of both worlds in terms of specific power output.
TSX still requires premium fuel, though, right?
-juice
engine that Honda has used a timing chain.
Hence the big trouble with a broken belt. I'm having mine changed with the next service.
Although mine is a non-interference engine, plus the service interval for Subaru's belt is a very long 105k miles.
Still, I'd prefer chains for the lower maintenance.
-juice
Bruce
-juice
There is a poster in one of the Odyssey boards here who hasn't changed the belt on his 300,000 mile Odyssey and has no intension to do so.
And, when they do break, engine damage ***can*** occur. Many times, nothing happens.
Timing chains stretch and cause trouble too along with tensioniers that go bad.
I guess, on balance, I would rather have a chain than a belt, I suppose but there are advantages to both.
Bruce
Vans tend to be used for long distance trips so you might be hundres of miles from home, or even the nearest dealer.
Being stranded is a bigger problem, IMO.
-juice
http://www.gates.com/downloads/download_common.cfm?file=GatesTBR.- - pdf&folder=brochure
NOTE: For your convenience, interference engines have been footnoted with a star (*), in the engine column, in the application tables.
Bruce
I didn't go as far as calling him "nuts" but I and a couple of others tried to point out what could happen. On a dark, rainy night with his wife driving etc...he didn't care.
He said he had talked to the guys at his Honda dealer and they had told him they had NEVER seen one break on an Odyssey.
To each his own...
Good reference, thanks for the link.
-juice
Although...usually belts show some sort of symptom, squeeling or slipping, before they fail. I just hope he notices it first.
Of course even with a timing chain, you have to change the other accessory belts. Isn't there one driving the water pump? So there's still some maintenance, it's just much easier to do those belts vs. the timing belt.
-juice
"If it's got 300K on it and is really shabby, I wouldn't do much to it aside from the basic safety requirements of good brakes, tires and a front-end check."
Mr_Shiftright "Maintenance & Repair Costs" Jul 19, 2004 12:56pm
And someone pointed out that he could be stranded just as easily by a flat tire as a busted belt.
So I'm not sure a flat would strand you.
-juice
Runflats would get the spare off the CR-V tailgate though. And that would help the bumper test scores.
-juice
Only by replacing all of the windows with non-tinted pieces. The tint is built into the glass, not an applied coating or film like aftermarket tints.
Not in the US. The LX can be equipped with optional side airbags, but ABS is only on the EX model.
Sorry.
-juice
In my experience, you can see out of the "built-in" tint as well as the non-tinted.
regards,
kyfdx
ABS is the only way you can safely brake around a turn.
When you turn left, for instance, the right front wheel does a lot more braking then the left rear tire.
Also, ABS modulates the brakes independently, in the CR-V's case there are 3 channels, one for each front tire and one for both rears (together).
That means that even with Michael Schumacher behind the wheel, he would need 3 brake pedals to be able to match what ABS can do. He'd also need a few extra limbs.
So unless I sprout as many limbs as a spider, I'll happily accept ABS.
-juice
