No dissent here. After that incident, I know of one street I won't take in a rainstorm. It's a challenge finding a road that doesn't take on a lot of water here, but I'm better off now than when I was in a sedan. I don't intentionally seek a puddle, but sometimes you end up in one...
I just watched one of those "Amazing Videos" shows where the cars get washed away. :surprise:
-juice
Anybody help this fella out?
If the 2nd was not your fault, then that would be expected. The other guy's insurance would cover it, and his rates would be the ones potentially affected.
I'm a magnet for that - my Miata was side-swiped by a brand-new Saab with temporary tags, then my Forester was rear-ended by a Saturn with no ABS on a rainy day. Before that, my Escort was hit 3 times, the 3rd actually totalled it. :sick:
None of those ever affected my rates, because I was not at fault.
-juice
They also said those were about the best you can buy.
I had a 2000 CR-V and installed B.F. Goodrich Precepts all weather tires. They were far superior to the horrible OEM
Bridgestone Duelers that came on the car. I will probably put Precepts on my 2004 when I require tires.
It's a tough decision----too many choices.
Thanks for any feedback.
After two new tires, repeated balance of all wheels and checks by the dealer and district rep. it now wanders and pulls to the right. This makes it difficult to drive, but it does not shimmy anymore.
Back to the dealer next week for more evaluation and hopefully repair.
Has anyone else experienced this type of problem.
This is my third CR-V, 1998 and 2001 were perfect.
If you enter PTTR in the "Search Discussion"
you will find many entries that address this.
I think the reason why you see little discussion on the subject is because there isn't really a "fix" for it. That's just the way the floor is shaped.
Yep, found it here:
ateixeira, "The Forums Test Drive Team" #30, 9 Jul 2003 2:42 pm
Excerpt:
Sit inside and the first thing you notice is the impressive use of space. The front passenger seat could use more leg room, but the back seat is positively limo-like. Two 7 footers would be happy in that back seat, more so than the front seat, actually. No dead pedal for the driver, though at least it seems to have more room than the front passenger seat (I'm 6' and could not get comfy there when my wife drove).
My theory? People aren't driving them aggressively enough to require a foot on a dead pedal to hold them firmly in their seats. Even so, it would be nice to have a angled plane to rest your foot.
-juice
Of course, I also think it needs an entirely new seating position.... but, after seven years, I'm used to it..
regards,
kyfdx
Or maybe you had another 'V prior. If so, I would think the seating position of the 2G is different (at least a little). Perhaps you don't like either model's seating.
I'm sure the BF Goodrich tires are more quiet, as they are more passenger-car oriented.
Shop for a touring car tire, meant for quiet travel at high speeds.
-juice
The CR-V handles very well in the snow. If snow is on the ground constantly where you'll be living in Colorado during the entire winter (not true of either Rochester or Indy) then I'd suggest getting winter tires, as they will handle much better than any all-season tires. Look around for a set of steel wheels from an LX for your winter tires. The dealer might even have a set they pulled from an LX that the owner upgraded to alloys. They might even sell them to you fairly cheaply.
And.. strangely enough... I find the seating position almost exactly the same...
But, maybe they are slightly different.. and I just don't like either of them... as you suggest..
I did total the first one... maybe I got a big knock on the head... :surprise:
rich
rich
I did not. Years and years ago I owned a Subaru Brat and liked it, but probably won't buy another Subaru. Before the CR-V I drove a Geo Tracker 4WD (a very poor purchase decision).
A fulltime 4WD or AWD system will probably perform better in slippery conditions than the RT4WD system in the CR-V, because all four wheels get power all the time. Unless you're looking for a winter-only vehicle you should be considering other aspects, not just the handling in poor conditions. And the CR-V does very well in slippery conditions like snow, ice, and rain.
JM2C
But you can still count on them in the snow. Many models have heated seats, mirrors, wiper de-icers, limited-slip differentials, and weather band on the radio.
Honda offers most of those, but not all, and they limit heated seats to the SE model.
-juice
Hope this helps.
George
I was there for the Detroit show the last 2 years. NAIAS 05 wasn't that bad, but 04 was so cold I can still feel the chill. Brrr.
If I go this year I'm going to rent a car and really see Detroit, check out the Henry Ford museum and stuff.
Any how, I'm sure a RT4WD model does the trick up there.
-juice
So that's where the one Baja sold in Michigan is!!
-juice
The reasons I probably wouldn't buy a Subaru in the future has more to do with interior space then with mechanics.
The Brat was a fun car to drive and did great on ski trips and rock climbing trips to Joshua Tree (I lived in S. California at the time). It was totaled in an accident, and the design of the spare tire mounted in the engine compartment above the engine probably helped to save my life.
The Geo Tracker was also fun to drive and did great in the snow, including getting me safely through a June blizzard in Bear Tooth Pass in Wyoming, but mechanically it was a piece of junk.
-juice
Mine was a 1991 that fried it's ECU in 1998 with about 80,000 miles on it (which also took out the fuel injection system). That was after a history of problems, including a new clutch with less than 40,000 miles which was caused by a defective clutch cable. The dealer replaced the clutch, but not the cable, which means I was back at 65,000 for another clutch at which time they told me the cable had a recall and was being replaced, too.
The Tracker/Sidekick was redesigned in 1999. Even the 1999's are showing some "Fair" categories at this point, and a number of "Good" (average). They did rate the 2002 as "Reliable", but not the 2001 or 2003, which are basically the same.
Compare that to the Honda CR-V, which for 1997 thru 2004 models has a single Good rating (1998 - paint/trim/rust), and everything else Very Good or Excellent for all years. The CR-V also has a "Reliable" rating for all years.
There's no comparision.
I own a 2003 CR-V, and comparison shopped the Subaru Forester. I have driven the CR-V in heavy mud and also in snow and ice conditions. It does fine. You always have to remember, with any vehicle, to slow down, drive carefully, and anticipate the starts and stops in cold conditions.
That said, the Subaru is clearly the better vehicle in snow. It has full time AWD, and limited slip differentials. The CR-V does not have LSD (the mechanical, not the drug!). The important thing to remember is to not depend upon the technology - your brain is the best driving technology in any vehicle.
The Subaru is too small for me. Others have a different opinion. Test drive both, and be sure and bring the family to ensure there is enough room for all.
Honda website lists the following for MSRP's:
21,595....... base
550......... dest chg
63 ..........splashguards
189 .........cargo area cover
139 .........drivers side armrest/compartment
22536................ total
What's the best deal that one can honestly expect the dealership to sell me this vehicle ?
What are the approximate percentage 'mark-ups' for the base... and then also for each option ?
Is there a tool anywhere on the web that would have these percentages for this specific CR-V ?
Of the BS fees (proccessing fee; convience fees; document fees...etc...)what would be a fair amount to have to pay ?
No trade involved.
Any other tips, suggestions, & help is certainly welcome !!!
I thank you, in advance, for your help !!!
It's fine to look at holdback and the price of accessories at various web sellers, but instead of bogging down in percentage mark-ups for various options when you do your deal, you may want to focus instead on your out the door price.
That way you're just negotiating one number instead of half a dozen.
Check out Confessions of a Car Salesman too.
And what about those Fees ??? What would be fair ??? (assuming they were 99% profit to the dealer)
Thank you & everyone again !!!
Convenience fees? Sorry, it's not convenient for me to open my wallet for junk fees.
Tax, Title, and license fees depend on where you live. They're usually not negotiable. The destination charge is not negotiable. "Documentation" fees also vary, and are sometimes negotiable. Any other fees are profit for the dealership and you should refuse to pay them.
The installation charge is all labor, so it may vary from dealer to dealer. H and A Accessories also provides links to the install instructions. Many accessories are easy to install. Download the install instructions and decide which you feel comfortable installing, and which you think are more than you can handle.
When I bought my 1999 CR-V I got the accessories for cost and installed for free. I purchased the CR-V through a buyers plan offered by the Credit Union where I bank that allows you to deal directly with the Fleet Salesperson. I paid about 1/2 way between invoice and MSRP (there were waiting lists in 1999 for the CR-V, especially the 5 speed manual transmission and "Hoosier" red here in Indiana).
I was able to kick in the ABS pretty easily, though it hadn't happened on the drive home. I spent a lot of time driving the car pretty fast (for a parking lot) and then making a sharp turn. Every time, something else kicked in - either the stability or traction control - and it really did keep the car right on track, pointed where it was supposed to go. (I could tell it kicked in because it comes with a heavy pulsing, like ABS except not in the brake pedal.) What a great car. I wasn't able to make it do anything dangerous at all.
(Note: I wasn't driving 45 or 50 miles an hour or anything. But I don't commute on the highway, so this was a completely adequate test for the snow driving conditions I generally face. I was doing turns in the parking lot much faster than I would normally do them even on dry pavement.)
I noticed VSC applying brakes when wheels lock up in a turn without applying brakes. If you turn off the VSC, turn the wheel to one side and stomp on the gas, the car will do doughnuts like a true RWD :-) With a little bit of coaxing, I was able to send it into a 4-wheel power slide. FUN!!!
Today was different. Here north of Boston, we had a storm that intensified into a thunder blizzard for about 90 minutes just as we all had to get to schools to pick up kids (it was unexpected, and schools were open).
Snow came down about 5 inches on top of a previous 5 inches within about 90 minutes, so there was about 8-10 inches on the roads (somebody decided to wait until it ended to plow).
I had real a tough time. The traction control kicked in even when crossing ridges of snow at intersections; hills were impossible (it was wet and icey underneath).
So today, at least, I regretted not getting 4WD.
But a question: is 4WD really going to move smoothly through 10 inch snow or so, and even up hills?
I am cheap too. That being said, with all due respect, you were foolish to buy a vehicle known primarly for all wheel drive in a 2WD version IN BOSTON!!!!! What were you thinking? I live in Pittsburgh and here you have to special order the 2WD CR-Vs (and Explorers and everything else...dealers can't sell 2WD versions so none stock any). This was clearly a case of being penny wise and pound foolish. Particularly since CR-V IS the way to get AWD on the cheap! It and Subaru and RAV4 ARE the efficient AWD vehicles.
I live in Pittsburgh...similar to Boston with bad winters and steep hills...and my new '05 CR-V SE was a champ yesterday in the storm. A champ. Right up my steep driveway...vroom!
It's tough to sell a fairly new vehicle. I guess you're stuck for at least a while but I'd plan to make the switch to AWD soon in Boston.
