Visitor Agreement.
the original manufacturer. True? even when maintaining stock intake system?
Hypothetical time!
Let's say you own something nice and sedate, with 100hp. You wish a 15hp gain from the filter. That's a tall order from an air filter. Now, throw on heads, a turbocharger, a new intake, off-road exhaust and a reprogram, and you're now making 500hp (for one glorious pass on the drag strip, during which your pistons will shatter with a sound not entirely unlike a grand piano being dropped from a great height, because you forgot to upgrade the internals).
If the filter frees up 15hp from this 500hp engine, it's not that big of a deal any more, is it? But it's still 15% of factory orginal horsepower.
Expect maybe 3-5hp total with a stock setup. And that's pretty generous, really.
My Nissan's stock setup wasn't great, so I saw a surprising 6 hp gain at the wheels (on a dynojet) by switching to a cone-type filter.
If you have this problem, a cloth filter or a K&N is the least of your worries. Driving through lakes is probably top on the list.
Switching to an underhood cone filter is probably not a wise idea.
The instructions say to just let it sit somewhere outside and let the fresh air do all the drying.
I can't wait all day and I don't want to install the factory air box in the interim. It's a pain in the ###.
It did say a hair dryer may shrink the material, so that's out of the question. Maybe a fan would work?
thanks....
It is just as good as a KKM, costs less, and you can use a K&N filter cleaning kit too!
Kurtz Kustom Automotive:
Only if this is what your engine looks like
http://www.kustomz.com/zetec.jpg
xorbtant, What type of exhaust system, and headers do you have? In most cases there is not a improvement with just a filter change. Usually it is done with a exhaust modification.
Don't go by "feeling" pick out a strech of road that you can do compareson tests on. or have the car dyno tested.
I had a dual exhaust installed on my 300M and noticed a big difference, esp. in the MPG +4 on the Freeway. With a friends filter (K&N)I noticed a increase in the noise levels, at the exhaust and under the hood. Not a lot but noticeable
Good Luck,
Go for it!
The K&N allows 6.02 CFM, as opposed to a NEW paper filter allows 4.95 CFM - but only for a short while, until it starts getting dirty.
I removed the lower air box, and ran a 3" plastic
flexible hose from under the bumper for a "Ram Air" effect! Works great - No flat spot anymore!
0 - 60 MPH 6.51 sec
Ron
Red Type S
O.C./So.Cal.
"Boy, I am sure glad I spent that money on that filter. What a difference it made."
So, K&N owners, was it worth it?
The K&N replacement filter, alone does not produce BHP increase, it will only (in some cases, like supercharged/turbocharged vehicles) increase it's throttle responsiveness - to reduce lag.
Just some FYI: a Dyno's results can be affected by several factors, i.e engine temp, tire temp, fuel mixture etc.....
The only thing it does is allow a slight increase in air flow - and increase air flow, does not equate to added BHP for naturally aspired cars...
You need an aftermarket intake system for that.
I had a drop in K&N in my turbo eclipse and did'nt notice any difference.
It will only make a difference if your stock intake is poorly-designed, as mine is on my NX2000.
I believe that the gains are mainly due to the machined aluminium intake horn with came with the piece. For what it's worth, I recorded a startling 6hp @ the wheels over stock. I expected 1-2, at the most.
Believe it or not.
With the K&N drop-in I had, I felt no difference. When I removed the stock air filter box and connected a cone K&N filter to my eclipse, it was a totally different story. The car at a minimum gained at least 10-15hp.
I washed my K&N filter about three weeks ago.
Boy what a difference it made. I'm really glad I got the K&N. Instead of dropping yet another $25 or so on a paper filter, I just had to invest a little time and be willing to get a little dirty.
I just cleaned my filter too and the car runs much better.
my 99 Grand Caravan Sport with the 3.8L engine and put a K&N cone-type filter on instead. Has anyone else done
this? If so, what kinds of results did you get?
I've already done the same thing with my 98 Buick
Regal GS and it improved both fuel economy and
mid/upper rpm power and responsiveness. Are there any kits out there?
