If nothing else is working, check those lines!
Would appreciated if any one has had this same problem would let me knw wat they did to fix it.
the truck will not start if I jump the starter with screw driver it starts and stays running, it sounds like the problem is between ignition and starter,
anybody has any ideas
thank you
Thanks for any help you can be.
When I turn the ignition, all i receive is a click inside the engine compartment. It sounds to be comming from the fuse/relay box, but I didn't have a second person turn the engine for me to check, since it was 11:30 at night.
By the messages I've read, it may well be an ignition relay, or simply a contact inside the fuse box? I hope to take a look at it tomorrow before work, but not sure I will have time. I very much appreciate any suggestions.
Hope this works for you and good luck, Terry
