Visitor Agreement.
Could never figure out the solution (fuel line?) but fortunately we aren't in cold weather country very often.
My local mechanic wants to know when drivers had their problem fixed with ford, what parts of the throttle needed to be replaced with success.Is there anyone here that can tell me a detailed description of the exact parts of throttle replacement?
Thank You In Advance
The local ford dealer replaced the throttle body & motor asy.
2nd i will tell you to call ford motor company and ask them if the computer is not reading the codes because everytime you start it it resets the computer.
if thats the case you may have to get a tow truck and flatbed it in to your local ford dealer,so they can plug a computer in before it gets started again.i hope this info helps,good luck!
I have kept a log of mileage, date, speed, weather conditions. The only common thread is that it always happens at 30 to 35 mph and while not accelerating. And it starts right up after stalling.
Ford consumer relations cannot help.
OK, so there is no code and it did not happen when my dealer drove it for 44 miles. But are there no troubleshooting skills in these service departments? I have seen this issue in various places on the internet so I am not the only one it happens to.
I have also made it clear to the service department and Ford that this is a safety issue.
Ford Explorer XLT
2005
45,400 miles
Terry
Any ideas?
Karen Stephens
Neraksnikl@aol.com
My daughter's '94 Explorer would start sometimes, then not start. We had the fuel pump replaced, fuel tank replaced, you name it. Finally my mechanic found the problem and it's worked ever since.
Under the hood is a black box containing fuses and relays. Replace the relay (those black,square plug-ins inside the box) that is marked EEC (it's the first relay on the right side for this Explorer).
The relays cost $10 . We have not had a starting problem since, and it's been months.
Try this before you do anything else and good luck! Not sure if this will help the newer models but it might be worth a try.
I got the car back yesterday, and so far, so good. I have a job interview on Monday so I sure hope the car is fixed this time..LOL
Karen
Changing all the relays apparantly solved the problem..Keeping fingers crossed!!
Karen
My daughter's '94 Explorer had the same problems as yours. It's the relays...I don't know why mechanics never think of them...maybe because they are the cheapest fix. You can buy them for $10.00.
A quick test would be to exchange one relay for the EEC relay (they are marked on the inside of the top of the black fuse box under the hood). My friend/mechanic exchanged the relay marked EEC with the relay marked ABS and it started up immediately and did so for the next 20 times he test started it.
Please try this...go buy one relay (they are black square plugs) yourself at a car parts store (I went to Carquest). Remove the EEC relay and put the new one in. See if it works...it has for my daughter's rig for the past 8 months. I'm trying to let every Explorer owner know (& trying to find the guy who gassed up his Explorer in front me one morning a week before I learned of the relay fix...he had the exact same start-no start problems). Good luck.
In the last month, it takes longer and longer to sit before it will start. I've had it towed twice to garages becuase it won't start (and you can't jump it). Of course when it gets to the garage, it starts up fine. The battery, starter, altenator, etc. all check out fine.
Any thoughts? I don't want my daughter to drive this and wind up stranded in a bad spot. Help?!?!?
Good Luck on yours or your daughters Explorer
Thanks for your reply. CARL
Thanks for your help.
Plugs and wires ok. Vacuum lines intact. Cleaned MAS, PCV valve and IAC valve. Cleaned out throttle body and replaced fuel filter. No check engine light ever came on either. I'm at a loss now what to do? Bought this one new 17 years ago, hate to give up up on her now.
I thought I would get some advice here before taking it into the shop as I don't have a heck of a lot of money to spend; I need new tires, and plus I am female and scared that I will be given a load of crap and end up paying more than I need to.
Anybody have any ideas?
We have an extended warranty,luckily,I will contact the number you listed, by the way while my wife was on the phone with road side assistance a supervisor was listening to her complaint and advised her she had the same vehicle with the same problem.
If you would like to contact me e-mail emcasebolt@comcast.net
