Secondly, your transmission (other than the T-C) is not going to cause the shudders necessarily, in fact the odds are 1:5000. But...let's move on.
Lastly, those same symptoms are associated with a dirty EGR Valve, Aged-out spark plugs and a cracked intake manifold gasket. The primary culprit is a cracked gasket. These Troopers have aluminum blocks which heat up & cool down fast. So the gasket is the first to go under these conditions. Todays gaskets are all of superior quality and will permanently fix the problem. However, most shops will NOT clean the Intake manifold or Plenum (Joining apparatus) thoroughly and , hence, the symptoms will eventually return. So be sure to clean the parts thoroughly!
In general, not only must you replace the gaskets, clean the manifold and surround internal components but you also must clean the EGR valve assembly along with the pathway components near to it. Incidentally, you should replace the fuel injector O-rings and the Thermostat since you or the technician will be right there anyway.
It's true that the spark plug brand, type and other specs are critical to keeping this Trooper running smooth. The system actually uses the plugs to read the combustion factor. The surrounding sensors behave as a single unit so the plugs are very important. The EGR Valve is simply a tiny recirculating motor for the exhaust. It is of poor design and effects the idle, mileage and mostly low-end performance of the engine. Replacing, rather than cleaning is highly recommended. In doing so be sure to clean inside the seat before installing the new one with a fresh gasket as well as gasket adhesive for this and the manifold gaskets.
Clicking in Drive only is practically a mandatory trip to the mechanic. I know..
GH
Eventually, your rpm increase will be noticebale. If you went tinto a transmission shop talking about rebuild then that's often what they do. The TC is your issue.
Check you differential fluid as well.
A "hack" tranny shop "rebuilt" my trans, it was never right, they even gave it to me, I found out much later, with 5 stripped pan bolts, one of which they had literally stuck a PAPERCLIP in so that the bolt would tighten at all.
I've had a horrible 3 years of little or no income, so I've been driving it it limp mode using 1st and 2nd manually, and to my amazement, it's kept letting me.
Recently, I was able to get my finances in better shape, and at first decided to unload the trooper as many mechanics had recommended I do, and try to find a reliable car for around $3,500. After months of car shopping, I wound up paying homage to my reliable engine and too much attention to my deep adoration of my huge double-size moonroof, and decided to fix this transmission again instead.
One of my main problems has been deciding just what to do. I came close twice to trading in the trooper on small car lots, but I was too unsure about the replacement vehicle. I did a lot of research on all of the cars I looked at, too. I ALSO CAN'T GET A HANDLE ON WHETHER THE
TROOPER IS SOMETHING I SHOULD KEEP, LET ALONE SPEND BIG BUCKS ON.
My current dilemma:
I just spent $1,900 getting my tranny rebuilt again, by a shop who was helpful during the last siege. When he was done, he said "it has a vibration that is coming from the front axle" I told him there was no vibration before, but I was so sure he had truly fixed the transmission, and as I drove away I felt nothing noticeable.
By the time I had driven 8 miles or so, there was a horrible grinding, catching, and shuddering as I came to a stop, and as I began to accelerate. In subsequent days this has continued consistently, as soon as it's warmed up. I called the rebuild place, they insisted it was the axle, but said I could bring it back Tuesday after Memorial day. Over the weekend I decided it would be prudent to get some more local opinions for ammunition before I went two cities over to the rebuild shop.
Two general mechanics whom I believe are less likely to be dishonest than most had multiple mech's drive the car and believe it is the tranny, not the axle. I went to an AAmco in town (to whom I told the whole story) who supposedly did a lot of testing and to my surprise, showed me that it was the axle (both boots are blown) and he wiggled the front tires and said that the wheel bearings were bad. He then said that these two conditions would produce the symptoms I was having. HAS ANYONE EVER HEARD OF THIS?
I went back to my trusted mech, who put it back on the rack, drove it again, specifically paying attention to the axle, bearings, and the rest of the drive train, and cannot produce while on the rack, any friction or wobble that would create the problem. I went to another general mech and the-most-respected tranny people in town (expensive #$%) this morning, and they also believe it is an internal transmission problem.
Unfortunately, I called the rebuild shop after seeing AAmco and told them it looks like he was right. I no longer believe that.
The rebuild shop had said my tranny was extremely burned, and that he had to go into the valve case 3 times (with test drives in between) to get it clean. Can my symptoms be related to remaining grunge, or does it sound like something else?
Most of all, is there any chance that the axle and wheel bearings CAN produce these symptoms? Should I have my mechanic fix them for another $1,000 against his better judgement? Should I put another $1,000 into this car at all? It has occurred to me that since I told AAmco everything, they knew they were'nt going to make any TRANNY money off me, and came up with something I had reason to buy into that they could do.
PLEASE HELP. In 2008 I went through all the appropriate channels and filed all the appropriate complaints, thru to DACS and the office of the Atty General, and even went to ABC Action News for help. At least the ABC volunteer assigned to my case had the integrity to be appalled by the blatent lack of appropriate response from the officials.
I've read your wonderful forums and know that these Isuzu transmissions can reduce grown men to tears. I'm a girl.
Trooper owner/enthusiasts are an odd and magnificent lot. We like working on them. We love the international heritage Troopers they maintain, and their subtle yet uncanny ability to keep going. Thing is, your previous owners have 4-wheeled that thing rather harshly-that being said, it's really OK.
Your car has value, so you probably should sell it and get a 95 Camry (also indestructible yet more reliable)
Mechanics pull those stunts all the time, to all of us. It's shameful and shi%%y yet everyone pretends it doesn't happen to them. It appears as if you're doing everything correct, so keep up the fight...
Good luck
I looked through all the threads and couldn't find any information on anyone that actually worked on their transmission. Yeah I know how to replace the transmission fluid in a Isuzu trooper. The problem is I don't know what the recommended torque is for tightening the bolts around the transmission pan. I did a start pattern with a new gasket, but it still leaks. I am wondering about just puting some Lucas transmission gasket seal fluid in with the ATF.
Any suggestions would help.
Some people were telling me to use a silicone seal on both sides of the gasket and I talked to a transmission guy who said transmission gaskets are always a dry fit. That's what worked for me. The gasket from Fram is a nice composite of cork and rubber. The cork expands making the fit tight under pressure.
No more stalling, but car does not feel right, starts very heavy and rides like that a while, especially when foot on gas, gas economy has suddenly dropped from 15 to 9 mpg. Engine also feels like revving sometimes.
Any thoughts would be grealy appreciated, love this suv, thank you
How does one "check" the timing belt? I just replaced mine at 99,720 on my 2002 Trooper and it looked fine (although a little dried out).
Finally, you must consider that these if you are not the original owner it has probably been 4-wheeled in deep water, which mean accelerated dry rotting of the vacuum lines/connectors. The fuel consumption issues on this model is usually associated with the fuel system. Also, check the transfer case, axle, differential and LSD fluid levels. You will be amazed at the capacity levels these units hold.
Good luck
They put in a new one, but still stalled, that's when intake manifold gasket was replaced and put in new fuel pump . Stalling stopped.
Issue is really that heavy/revving of engine and sudden fuel consumption drop.
I will have O2 and H20 sensors rechecked.
Would bad timing belt cause any of this.
Since they changed pump, filter, cleaned fuel injectors, ran tests for vacuum/hose leaks, what else should I have check on fuel system.
Also, brought it to a different mechanic today and while he couldn't pinpoint cause of issues I mentioned earlier, he thinks there is an engine issue, when he put car in neutral and stepped on gas, there was a slight ticking noise. Does this sound true.
Thanks a million.
If you discover there is continuous noise after this procedure, you should have it towed to a transmission mechanic. If your Trooper is a 4wd Limited version like mine you should consider checking all the drive fluids: Front axels, slip differential, etc. even the propeller shaft has grease fittings (don't let any shop tell you otherwise)
Good Luck!
Sometimes my trooper revs up too, but I think it is just because the throttle sticks sometimes.
It does sound like a transmission problem. If it does need extra transmission fluid, you could put in the Lucas Transmission Fluid that fixes leaks and other transmission problems. It is really thick, so you may need to warm it up. You also have to pump it in like you would for the differentials.
If you're losing power to the wheels when revving high that could mean the torque-converter is slipping. In other words, the engine torque is not being converted to the transmission.
I had mine replaced on my 2002, I also had the transmission rebuilt just to make sure everything was SOLID. $2000 later.. it's fixed.
Your next alternative is to sell it to the transmission shop.
Good luck
As mentioned before, the engine is completely rebuilt. I even change the sensor on top of the motor. I'm just wondering, could it be another sensor? I read some where that there are three of them.
Any help would be most appreicated. Thanks
Sensors..Yes. However, you would have a dash light indicating high trans temp or a blinking trans light, or even a check engine. The fact that the symptoms are extremely sporadic and random helps to justify my Torque-converter opinion.
If you test it by towing something or pushing the car slowly against a wall to check for higher-than-usual rpming while stopped, it will only serve to take further life out of your worn out torque-converter.
A qualified transmission mechanic can test drive it and confirm for you in a couple minutes upon driving.
_
Hi II have a 1995 Isuzu Trooper with transmission problems. This is more or less the drift of it, hopefully someone can give me an idea.
When you put it in drive it takes off in second gear. When you put in low gear it stays, but if you put in second gear it rolls backwards then rolls forward. Like its trying to go into two gears at once. Once wheels start rolling, you put in third gear goes smoothly. If never goes into overdrive. Makes no attempt at all to go into overdrive. TCM has also been replaced to. Oh and we bought another transmission and it's doing the same thing. Anyone have an idea about this?
Robin
_
entonces señala unos 140 códigos. Que de ser cierto ni encendería el motor!!! Los borro del scanner, pero al reevaluar vuelve a señalar los mismos 140 códigos!!! Quién podrá decirme qué tiene mi guagua???
