Visitor Agreement.
How did you fix it?
Thanks for the info!
You probably ARE blowing a fuse....just not one that is in the fuse box that is on the drivers side dash...you have probably blown a MAIN 40AMP fues in the box over the drivers side Wheel under the hood! I ran into a similar issue. I blew the 40 AMP main and all that stuff wouldnt work...I replaced the fuse and would blow it a few days (maybe minutes) later.
The problem was that I actually USE my emergency brake when I park in my driveway. There is a bundle of wires that are right next to the gear teeth on the top of of the E-Brake pedal Over the years...those wires rubbed against the gear-teeth until the insulation wore off. Then when I applied the E-Brake....sometimes it would short that wire ...blow the main fuse...and ALL the stuff you listed....wouldnt work anymore.
Solution: Cover the exposed wire with electrical tape. ZIP-TIE the bundle further up in the dash....replace the MAIN fuse. No problems since.
Good luck!
JJ
My 98 Durango drains the battery every time it sits for more than a couple hours. Took it to a shop who couldn't find anything wrong, despite spending around 10 hours on it. For now, we are unhooking the battery EVERY TIME we shut it off for more than a few minutes, but that's a pain in the butt and I'm sure it's not good for the battery, either. Any suggestions would be appreciated! Thanks!
Any suggestions?
Damien
I am having the same problem. My blower went out, turn signals do not work, and the radio as well. The radio and turn signals go on and off. Do you know what this could be? Some please help! My durango has been in the shop 4 times now.
Thanks, J
BEEN ACTING UP PERIODICALLY. THE ICING ON THE CAKE WAS YESTERDAY WHEN I WENT TO PULL INTO A PARKING SPOT AND THE VEHICLE COMPLETELY SHUT OFF AND ALL THE WARNING LIGHTS ON THE DASH ILLUMINATED, I JUST TOOK IT TO BRIGGS DODGE IN TOPEKA, KS AND THEY CANNOT DUPLICATE THESE ISSUES AND SHOW NOTHING WHEN THEY HOOKED IT UP. THEY TOLD ME THAT DODGE HAS A "STAR CASE" ON FILE AND THAT STATES THAT DRIVERS ARE CAUSING THESE PROBLEMS TO OCCUR. (i totally disagree& think this is a cop out) THEY ARE TELLING ME I GENERATE TOO MUCH STATIC ELECTRICITY! HUH? I FIND THIS VERY HARD TO BELIEVE. I AM VERY DISCOURAGED AND FRUSTRATED. I GUESS WHEN SOMEONE IS KILLED IN AN ACCIDENT FROM ONE OF THESE FAILING, THEN MAYBE THEY WILL OWN UP TO THE PROBLEMS AND FIX THEM. PLEASE HELP! WHAT DOES ANYBODY ON HERE THINK? THERE ARE MANY OTHER PEOPLE WHO ARE HAVING THESE ISSUES WHEN I SEARCHED THE WEB. WHAT SHOULD I DO? JUST START LOOKING FOR A NEW VEHICLE OR IS THERE A FIX OUT THERE?
Hope that helps.
Also, there is absolutely no warning when it happens. Just randomly the battery light comes on and have to get it in shop ASAP.
