The same thing has happen at least seven time I lost track. The symptoms are when I return to my car I inserted the key as usual. Ordinarily the dash instrument gages would activate. The security door locks are inoperative, the engine starts but will not stay running. I have taken it to the dealer and each time they could not find an problem. They even kept it for a week. This failure happens randomly and I can never predict when the car might not start.
I understand that it is the cars computer network. The fix is simple but who wants to put the hood up and remove the ground cable on the battery? I keep the tools I need in my car if and when the car will not start. It takes less the five minutes to re-boot the computer.
It functions fine for weeks until I try to start it. My car problem is a glitch in the ECM. Had Saturn engineer a remote re-set button I would not have to remove the ground strap on the battery for two minutes. I do want to caution anyone who has a vehicle that has the same symptoms. My cars problem could be different then yours. When you remove the battery cover stay clear of the positive post. If you drop a wrench between the positive terminal and ground you could get seriously injured. This is best left to a qualified mechanic.
I am thinking of installing a relay and a switch to remotely re-set the computer. from all the feedback that has been sent to me I can conclude Saturn needs to come up with a software patch. With the economy as bad as it is it is doubtful they will recall Vue's :sick: and come up with better software. I guess I am eligible to have the car deemed a lemon? Since I can resolve the problem and the fact I other wise like the Vue I'll have to live with the problem. Happy motoring Vue owners
:sick:
I found by experimenting that removing the cars battery ground cable e.g. bolt and waiting a minute the computer system resets.
Keeping my fingers crossed that it does not happen again. I caution anyone to avoid removing the ground cable from the cars battery. You have to reset your cars
radio time and favorite stations.
I only recommend this ECM reset in a emergency. Since no one has up dated the cars firmware it might be done with the On Star link.
I can only suspect my ECM has been upgraded without going to a Saturn service center. It has been almost a year since the car refused to start.
I can suggest keeping the tools required to take the battery cover off and a wrench to back off the ground bolt at the battery in your cars tool box.
Warning if any metal like a wrench or watch band comes in contact with the plus terminal of the battery major injury can occur. If your not a electrical type then find someone who can safely remove the ground cable from the battery.
The whole process should only take 45 second or less. Be careful :shades: and double check the batteries polarity...
They replace the electronic control module (ECM). The car had to be driven back the following day because a warning light (seat belt) was on. The tech forgot to
re-program the computer network. There are three modules that need to be in sync.
That lasted for a month and the car was hauled back to the dealer. NO problem was discovered. A few weeks later the car refused to start so it was returned to the dealer. They kept it for a week as I suggested. The service manager could not find any reason why the computer system failed.
I suspect they upgraded the firmware to correct the problem. It has not happened again for over a year.
I believe the problem is a software glitch that happens randomly. The last two times it refused to keep running I simply removed the battery ground cable. That resets the ECM computer.
When I reset the computer I also removed the error code stored in the module.
I carry the tools needed to remove the battery cover and the bolt on the battery ground terminal.
My honest opinion is the service techs do not want to troubleshoot a complex
system as in the Vue. I found by resetting the computer (reboot) that should solve the problem.
I must warn anyone that has not worked with a car battery to find someone who is skilled. If your wrench or metal watch band comes in contact with the positive terminal serious injury can occur. The ground cable need only be removed for one minute to clear all data out of the CPU memory.
I'm not sure if the upgrade of the Vue firmware resolved the problem or my re-boot
procedure resolved the problem.
We live 60 miles from Death Valley so in an emergency it is necessary to remove the battery cover and it's negative cable connection.
Other then that annoying problem our car with 26,000 miles has given excellent service.
If you have the same problem and need to get off a freeway or go for help then remember this. Attempt to start the car a dozen times. It will not start or run for more then a milli second. After 12 attempts the computer will change modes and allow the engine to start. That enables you in a emergency to drive a few miles.
Note the power steering will not work nor the power breaks. The car is extremely difficult to drive but allows the driver to seek help. So please be extra careful if you ever hav :sick: e to drive the vehicle in this way.
I have a 2003 Saturn Vue that won't start in the morning. I have replaced the battery, alternator, starter, cleaned all the wires, posts, and grounds. When you get in and try to start it, it makes a clicking sound. Everyone has said it's the starter. I have 2 perfectly good working starters so it's not that. Recently I figured out if I put the car into low 3 and then back up into park and turn the key 3 or 4 times it will start and it will start EVERYTIME after that for the entire day until it sets overnight. Then I have to do the same thing. I have read some stuff about the Neutral Safety Switch. Has anyone heard anything about this or know where I can find a diagram of where this switch is located? Obviously with the economy being the way it is... I can't afford to pay a lot to have this fixed. If I can do it myself, I'd prefer that! Any suggestions and thoughts are definitely appreciated! Thank you!
The Saturn Vue has a very complicated computer system. It requires all the modules to be in sync and communication data to each other.
Ours has not "glitches" for over a year. I made sure the system was reset by removing the negative terminal on the SUV battery and replacing it. Our problem might have been a bad connection at the battery. Note I really do not know why our 2006 Vue has been trouble free.
Service technicians have diagnostic computers to pin point most control module faults.
What your experiencing might be something only a Saturn engineer can resolve. It is not simple to diagnose a computer problem in a GM vehicle.
My point of replying is finding the right person to correct the annoying problem. I wish I could help other then we now own cars that are soon to become classics. I retired from GM Hughes am surprised that Saturn dealers can not support our cars.
Sorry that I can not be of any real assistance. :sick:
I have tried several things and my problem is just plain ole annoying. Having to take the car out of park to start it is a common sign that it is the neutral safety switch from what I have read and not just through "replies and forums" but actual car guides and mechanics.
I too removed the negative post on the battery first, so I don't think that is the issue at all. Like I wrote in my original post, I have replaced the battery (paying particular attention to the connection (it has a good connection), the starter, the alternator. All the wires have been cleaned. My next thing is I am going to get the neutral safety switch from the dealer and see if that helps. Do you know where I can get any "diagrams" so I can figure out where it is located? I saw a youtube video but it was for a "ford windstar" van, which I don't think will help me! :P
Well again - Thanks! For now I'm driving a :lemon: (funny part, it's BRIGHT Yellow)! LOL
Once again I had to re-set my vehicles computer. I do this by removing the ground cable on the cars battery. After replacing the cable the car always starts and run perfectly.
Like any digital system glitches can stop data flowing to make the SUV operate. I might have accidently discovered what is happening.
Note that I am troubleshooting without the aid of a cal lab service scope and a print out of the computer program.
I stumbled upon a web site that was for ham radio operators. Someone in California had a shortwave transceiver that did almost the identical thing my Vue does. Here is part of what he wrote.
just when the rig is ready to start making sound, the lights flash and it “reboots” itself. This happens over and over several times until it either starts or you shut it down.
To best understand the problem in simple terms follow this. My Vue only fails to start after I use the remote transmitter to open the door locks.
Only after the computer system is re booted using the negative cable
method will it start. There is some similarity between the ham radio and my SUV ECM module.
A9 refers to the radio, it is a printed circuit board.
The A9 Power Distribution board supplies voltage to, among other things, the CPUs in the radio. note this reference is for a radio not my car.
Here is what solved his problem.
I’m no expert, but one of the crew on the reflector (a technical news letter for hams) says that this design is very hard on the filter caps, especially C6 and C9, both 470 uf, 16 Volt, 85° C electrolytic. These caps need to have extremely low Equivalent Series Resistance (ESR) as well as excellent ripple specs. You can’t just pick up any old 470 uf cap from the junk box and expect it to perform. It would also seem logical that caps rated at 105° C with a higher voltage rating and with a larger physical size to dissipate more heat would make them last longer.
When he looked at the board, C6’s top was bulging, a sure sign it was the culprit. He determined that replacing all three of the 470 uf units, including C7, would make sense.
He searched around for premium caps for replacements and finally settled on ones from the Mouser catalog made by Xircon, model 140-ESRL50V470-RC. These units are rated at 50 Volts, 105° C and have excellent ESR and ripple specs. Even though they are physically much larger, the lead spacing is the same as the originals, so they fit perfectly.
I do not expect most of you to know what a capacitor like this is.
It is a $1.50 part that allows AC signals to pass through it. It blocks
or stops direct current.
In the case of the ham the manufacture of his rig knows they selected the wrong component. Yet, like Saturn they did not have a recall. In the case of the ham radio operator it is only a $2000. investment made in the US.
My best guess is a recall to replace components is not practical or safe for a SUV. That means those of us who are victims of what appears as a faulty design must suffer. The cost of solving a problem would be too costly
The only way we are going to have our car problem solved is having a
lab investatage if there are components in the Vue's computers that intermittently fail. I doubt if GM would volunteer to solve this unusual problem.
I can not positively state this is the correct answer to why my Saturn Vue and yours will not start.
Until someone sends their ECM system to a independent lab the mystery remains. :sick:
To restart disconnect the battery pole for approximately 5 minutes then reconnect. If it does not work repeat a couple times (5 minute intervals) it would eventually start so no need for towing. Leave a door open or make sure driver window is down as when battery is reconnected the car doors might lock automatically leaving you outside with no way in except with spare keys. Car starts then but the problem would reoccur in the most inopportune time. Most likely the problem is the BCM (Body Control Module) which cost about $300 for part at firm then it needs to be programmed. Since I have changed in my Vue 2003 it has worked like new. All the drama of not starting, no power steering, flashing headlights, security locking, no power, etc.... all gone. Problems with BCM tells car someone is intruding or breaking into car so security systems sets in and car cannot start thats why you probably would see security light permanently on during your problems.
Don't waste time speculating anymore. Change BCM and your problems would be over.
Regards
I bet it always has this problem when the motor is hot and rarely if ever when the motor is cold 1st thing in the morning...if so, its likely that your crankshaft position sensor is shot. Its not too difficult if you're a DIY and not necessarily expensive if you have a mechanic do it as its easy to access.
They also go bad on the 4 cyl but its much less common...same symptoms
this problem start after in a morning when get home, before nigh my car was Ok, some mechanic say computer fail , an scanner indicate computer freeze. some thing like that. sorry for mi english. I hope my word be ok for understand, thanks in advance. :sick:
Can you please email me directly? Feel free to include any information you have not in your message. I would like to discuss your situation further. I look forward to your message.
Christina
GM Customer Service
1. The BCM grounds are corroded and need to be cleaned (not likely but worth mentioning)
2. The BCM needs to be replaced - its a dealer only repair as it has to be programmed by them when it is replaced. Its about a $ 700.00 repair at your local Saturn Authorized Service Center.
Good Luck...
:shades:
But I do appreciate your help!
Best of Luck! :shades:
Any person with some mechanical or electrical skills can reset the Vue computer module.
Generally speaking removing the battery ground for one minute should
reset the module.
There is a problem doing what seems to be a "fix". The modules have a volatile memory. Once the vehicle battery is disconnected all error codes are cleared out.
Once you do this a certified technician can not reproduce the error codes.
In my case our 2006 Vue three years ago would randomly refuse to restart.
There was no warnings.
I left it at a Saturn dealer for on week and suggested the service manager drive it home. He could never duplicate the problem.
After that I experienced the same problem several times. I carried the tools necessary to remove the battery cover and it's ground cable.
Like magic the vehicle has not refused to start for the last 2.5 years. I seriously doubt that I inadvertently cleaned a bad electrical connection.
I dislike to guess what caused this very annoying problem to happen. It appears as a software glitch. The service manager updated the modules
software. I can not say or prove that was the problem
Our Vue has served us faithfully for five years with one problem. Perhaps the key to it's reliability is that it always has been service at a Saturn dealer. I recently was offer as much as we paid for the Vue in trade in on a new car. I decline to part with a car that looks and drives like it did the day we picked it up from the Saturn dealer.
Any vehicle can have problems. Most come from poor maintaince and bad driving habits. All we all know Saturn vehicles are no longer built. There are around 300 in the town we live in. Most are on the road daily. I was extremely surprised to see how well they keep their value.
You can file complaints with:
National Highway Traffic Safety Administration (NHTSA)
Website http://www.safercar.gov/Vehicle+Owners/
Better Business Bureau
Website http://www.bbb.org/
Post your problem for the VTi transmission on forum boards
Tweet and Facebook your experience on the GM pages
Write your local politicians
Congressmen, local officials and attorney general you can find your local officials at c-span. You may have to Google your state and attorney general separately to find out who that is.
http://www.c-span.org/CongressDirectory/
Last but not least you can write the CEO of GM
Mr. Daniel Akerson
CEO GM
300 Renaissance Center
Detroit, MI 48265
This morning I went to start the car and it's completely dead. The key is now stuck in the ignition and the car is stuck in park; I see no way to remove the key or move the shift lever, and I'm stuck in our driveway with no access for another car to give me a jump. I love driving this car but wow--I have a Toyota with 120,000 miles on it that has never had a major repair. This thing now strikes me as incredibly unreliable. How the heck do I get it in neutral at least?
I apologize for the problems you are experiencing with your vehicle. Were you planning on taking the vehicle to the dealership? Please keep me posted.
Thank you,
Caron, GM Customer Service
I strongly suggest taking your Vue to a qualifyed repair shop and never let a three year old play with knobs or switches in any vehicle. :sick:
1. Try this, turn the steering wheel back and forth while you gingerly try to wiggle the key and hopefully it will loosen enough so you can turn it to where you can get it out. Don't force the key...last thing you want to do is break it.
2. Then, do not use that key but instead, use your spare key...the Saturn keys tend to wear out and not work in the ignition. IF you don't have a spare, get the dealer to make one from your VIN # and not from the worn out one
3. If even the newer key won't turn either, try using a little powdered graphite in the key hole before you put the key in. you can get it at Home Depot...use it sparingly, a little goes a long way. Don't use something like WD40 or you are asking for other issues.
Once you get the key to turn you can deal with the dead battery...
Good Luck.
About 2 months ago, I noticed at night that my Hazard Light button and the headlight switch are lit up. I was afraid I might have a dead battery, but never seem to. This weekend, my car wouldn't start two times. I took it to my brother-in-law this morning. He said that everything checks out perfect on it, and it started right up for him.
Am I losing my mind? Can anybody tell me if they have come across similar things? I am getting fed up with the GM dealerships, because they all seem to not give a rats butt when I call them. PLEASE PLEASE someone help me out here!
Adam Pfingstl
Dazed and Confused!
I apologize for the problems you are experiencing with your vehicle. Could you please go more into detail on the problems you have encountered with the GM dealership? Have you spoken with GM Customer Assistance?
Thank you,
Has the dealer involved Technical Assistance? If not, I would recommend asking them to do so. Have you spoke with Customer Assistance? I look forward to your response.
Christina
GM Customer Service
Sounds like I'm having the same or similar problem with my 2008 Saturn Vue Redline. Walked out to it yesterday, acted like a dead battery. Was able to jump start it last night, but walked out this morning - same thing. I realized that it might be more complex than a dead battery.
Just to make sure that I don't misunderstand, you're saying that you replaced the fuses, not just pulled and put back, to get your Saturn to crank? Are you saying that after all of that, the TDM still does not talk to the other modules correctly?
Also, I've read about Saturns having BCM issues. Is it possible that I instead or also have a BCM problem?
Finally, do you think that there is a possibility that my battery is O.K., but that I just need to go through the fuse pulling process? (I'm being hopeful)
I would recommend speaking with your GM dealer of choice. Thank you for posting your concerns. Please keep me updated on your progress. Please feel free to email me directly.
Christina
GM Customer Service
The garage replaced the Crank Shaft Sensor and this seems to be working so far.
Has anyone else replaced this?
