Hyundai Santa Fe Climate Control Questions and Problems
                    I just had my 2003 Santa Fe serviced and the climate control got set to Celsius.  I looked in the manual and I only have information for the manual controls, not the automatic.  Cna anybody tell me how to set it to Fahrenheit?  Thanks.
Please type in a mixture of lower and upper case(mixed case for lack of a better term)so we all can have a fighting chance of reading your message.
Good luck! I hope it works. Be sure to report back here when you find out.
I have a 2001 LX and the AC is barely adequate at best. I had it go south on me twice in all this time and each time my dealer has replaced what was needed and at no charge to me. Well we go in once more this Friday and from the sounds of it the compressor is going bad. Nasty sounds and it all started with a loud hiss and then warm air.
I have an extended Hyundai warrantee which expires this coming January. I cannot say enough good things about the service I get from my Hyundai dealer in Cocoa Florida.
Next year we will be replacing our 2001 with a 2008.
Have to pay off my new Chevy HHR first.
Best,
Rich R
Not as good as a Fusion or Escape
Not as good as a Honda Accord.
Not as good as a Forester
Not as good as a Camry
I've read the manual several times and it should be as simple as turning off the Auto AC button. Then the air coming out the vents should be fresh air.
Well, actually if you are in AC mode and you turn it off, everything is off, even the fan. Then I touch the fan speed button, the fan comes on but AC (cold air)comes out the vents. I also hear the compressor cycle.
I've gotten the system to work right just once. The screen showed the two temperatures that moved simultaneously, which vents were being used, and the fan speed. Then it got warmer outside and AC was needed, and switched over to Auto. A little later in the same ride is when I realized I couldn't go back to just outside air.
Anyone else have this kind of difficulty??
I've turned Auto off and the fans blow but no A/C seems to be on, unless I push the A/C button in and it lights up. Everything stops(fans, A/C) if I push "Off".
I also noticed that the fan speeds are much higher with "auto" setting with the recirc. on than regular dual or A/C mode. It must have a booster for the fan in "Auto" recirc. mode.
I posted elsewhere asking if anyone else experienced a lag of about 8 seconds or so, when first starting up with the Auto Climate control on. I noticed it doesn't start blowing immediately, even though the engine is running - does yours do that too?.
When you select "Auto", the system will automatically control temperature (whether heating or cooling is needed), fan speed, fresh air intake vs. recirculation, and choice of output vents.
If you just want fresh air (without A/C), turn off the A/C button and manually select a fan speed and choice of vents (using "Mode" buttons).
If you want A/C but want to choose your own fan speed and/or output vents, just make sure the A/C button is on and manually adjust the fan "<" and ">" buttons and "Mode" buttons to your liking.
That's pretty much it. If the system is in the "Auto" mode, it will come out of "Auto" the moment you adjust fan speed or mode or the moment you turn off A/C.
I've been a long-time reader of this forum....very helpful!!
This is my first post.
I concur that the A/C system is pretty simple & agree with your summary. What bothers me, in AUTO mode only, is that (at least on my '07) the A/C button never lights up, even when I know that the A/C is running. The button will light up when I take the system out of AUTO.
Is this how it is designed or do I have a problem?
I also agree about the A/C switch not lighting up in "Auto" mode, but you can feel the cold air OK.
There is also no way of knowing whether the cabin is reaching the set temperature, either. I will try with a separate thermometer and see if it is accurate.
I also experience a short delay before the system comes on when starting up. It almost seems like the system is doing a check of outside and inside temperatures before blowing inside the car. I also notice that the front windshield vents will blow for a short while after starting up. This is very helpful in colder weather. This is the best climate control system I've ever owned.
2007 Santa Fe AWD Limited with Premium and Touring packages
Dark Cherry Red with beige leather interior
I was told by the service shop @ the dealership, "it appears you had leaves and other natural debris stuck in between the A/C condensor. The leaves have now rotted and caused a hole in the A/C condensor. This is not covered under the warranty because this is due to leaves not manufacter defect. Repair comes to $850."
My question is: I have only had this vehicle a short while, it stays in a carport, I don't go running off street with the truck. Are you telling me after the dealer did all the inspections on it prior to selling it to me, that leaves came in between my A/C, rotted within 8mths and it's my fault? I believe this is manufacter defect & not my fault. Any takers on this problem??
If it's in Auto mode you get it's light. But turning the whole system off and then touching the fan >> button seems to start the ac. But neither Auto or AC buttons are lit.
I think turning off the Auto, then making sure the AC button is off by cycling it seems to get me to just fresh air.
Isn't just leaving the Auto on all the time running the compressor all the time? Even if it's 70 outside and the cabin is set for 75, the sensors are going to see that if the cabin goes to 77, the AC will be turned on to try to correct it? Same for heating....won't the compressor go into reverse-cycle mode?
I'm not nitpicking. This is my first Auto climate control vehicle. There's a lot to figuring out what all the new toys are doing!!
On separate notes, my map lights have been upgraded, finally.
But, as someone who actually takes advantage of a lot of mp3 music on CDs, I'm not real satisfied with Hyundai's single disc base cd/mp3 player (pre-xm). Mp3 sound quality on this unit is drastically degraded. I've had it replaced by the dealership once because of the levels of distortion coming out of the unit... still the same problem. I've even tried different recording techniques offered by users of these forums... still the same problem. It appears to be a problem isolated to this specific type of unit as other hyundai mp3 players work fine. But the other Santa Fe's on the lot with this particular unit all had the same problem.
The dealership has thrown up its hands and said that since the Hyundai Corporation has not yet identified a problem with this unit, there's nothing that can be done.
Needless to say... I'm not pleased.
07 Santa Fe Limited
I do not take long trips so the XM is a waste for me. They just keep on sending me reminders...I hate recurring revenue models anyway!
On the auto climate control issue. I had it in another car and will not ever buy another with it. I find just setting a comfortable spot on the temp and fan dials just fine. I am a computer consultant so this will sound strange. TOO many computers in cars these days...too much to go wrong!
What I do not like is the xtra $$ it will take to repair the electronics when the warranty is over and if it breaks!
WHAT I DO LIKE ARE THE FAN CONTROLS and vents (and placement On the Pillar too!) FOR THE 3RD ROW SEATING THAT HELPS CIRCULATE THE AIR IN OUR DESERT 100 DEGREE DAYS in NEVADA. The SF's have a substantial cabin!
When it gets that hot...the auto system goes to high or the manual system is set by the driver to high! ONE nice feature I miss is the different temps for the driver and passenger...I personally like that idea
