Chevrolet Uplander Steering & Suspension Issues
My '05 Uplander makes the worst sounds in the right front when going over even the smallest bump. You can push down on the right front of the van and hear it as well. Techs say there is a TSB (which I can't find) but no fix yet. Also, they say they haven't had any other complaints on this. Has anyone else had this issue? It sounds (and feels)like something is loose up there.
This is just one of many problems I've had.
-whistling windshield
-A/C
-doors askew
-weather stripping coming off
-A/C
-doors askew
Ever have an issue with the trim on the side panels. Mine is becoming discoloured and no longer matches my dark blue exterior quite right.
My biggest complaint: Road noise and roar from the Goodyear Integrity tires. Just awfully unpleasant.
Bill P.
The good news is that the new link was made stronger. The diameter of the entire piece was larger. The replacement link I used was shipped to my dealer on 08/10/07. I'm not sure when they upgraded the link.
Another rear suspension upgrade product to use is Timbrens SES units. They make Timbrens for the rear of your Uplander as well. For more details, surf: http://www.timbren.com/ses-van-suv.htm
If wondering, I haven't tried Timbrens or air bags on an Uplander van. But do have the Timbren SES 2,000 lbs units on the rear of my 2001 Safari van. Best suspension upgraded I ever bought / used. Install them / leave them and when needed, they do their "extra support" magic. With Timbrens, no need to fuss with air lines or worry about a future air leak.
If my family replaces our Safari van with Uplander or Montana van, I'd be ordering / installing Timbrens for it the next day. Especially since our van's internals is most often loaded down with people and/or internal cargo. And, our van is used for our under 2,000 lbs towing needs.
Hope this Timbren product and above drill down links help....
Seatbelt of rear replaced, stablibility and traction control light on, steering rubbing.
Now, when I go over small bumps under a low speed, a noise like something loose heard from front end, and the steering is a little bit sensitive. Went to dealership, two intermediate shaft replaced, and the noise still there, they said they are going to replace the steering column unit, but not sure for it.
Anybody here had same problem?
Thanks for any info.
I dont think it is exhaust, because I can feel something through steering.
EDIT: in another post or forum, there was mention of the stabalizer tie rod ends that caused the problem for some, so they replaced them and it fixed the problem.
The dealer said they will replace the whole steering column, and I am waiting for the parts.
and now, only two weeks later, it seems like slightly the noise come back!!!
going over bumps low speed, you feel something from steering......
I went to dealership yesterday, and they said the noise is normal!
so did you bring it into dealership to check?
I've been told that it is becoming an issue with 2006 uplanders and GMC is working on the problem. But frankly I'm a little scared to drive it out of town.I just want it fixed now and have been put off more than once. The uplander is still under warranty . It has gotten worse over time. I keep taking it back and they say there waiting for a solution from GMC. I'm losing my patience ,the noise is driving me crazy.
I don't think this is a safety issue, just an annoying noise.
ive had alot of electrical problems like
radio controls on steering whell doing other functions grrrrr
door coming driver side rear door comeing unlatched
my headlights go dim ALL THE TIME annoying as heck
My 2006 Uplander also had the issues with the power doors. First it was just the right side opening and closing, opening and closing, now the left side is doing it with no fix from the dealer.
The brakes are serious issues with pulsating. They upgrated the backing plate up front to keep dirt out. Let hope this solves this issue.
Hear: http://www.youtube.com/watch?v=ZLT1iYaFWgA
It has about 115K km's on it. I bought it used.
About $ 400.00 at the dealer- likely less by a private shop.
I'm new to the Uplander, just bought a 2008, just trying to gather as much info as I can. We had a Chevy Venture for the last 5 years - it was a great van. I really didn't do hardly anything to it other than the usual (brakes, tires, etc) I'm hoping the Uplander treats us as well.
It has about 115000kms on it.
I am from GM Customer Service. Can you please email me more information on your concern on your vehicle, so I can look into the situation further? You can access my email by clicking on my name. Thank you,
Mariah GM Customer Service
I am from GM Customer Service. Can you please email me more information on the concern on your vehicle so I can look into it further? You can access my email by clicking on my name. Thank you,
