Bob in the Mile High City
2. Squeaking brakes ... Noticed the sounds on my vehicle at about 1K miles. Problem solved by a complete brake job (dealer warranty service). No further issues.
3. Parking brake / light mysteriously comes on... Have noticed this maybe 3 - 4 times when backing out of the garage (down a slope). Oddly enough, only when I am driving. My wife (the primary driver) has never noticed or had happened. We suspect that something about the way that my feet are positioned, perhaps hitting the brake on the way in? We do not normally use the parking brake. On my list for the next (13K) service call, though.
mb fixed replaced fuse checked wire harness
blew again
anyone have this problem on 2008 c300
can you open from outside
2008 C-300 Luxury ...from time to time, I get this 'red' message that one of my tires is losing air. I cancel the message (OK botton on the steering wheel) and check the tires visually and they all look good. Further check shows that front and back pressure is correct at 2.8 & 3.0 psi
Anyone has similar a problem?
Yea the mirrors make noice ...occasionally when they fold .... never when they unfold.
2.my mirrirs make noise on closing too just a whrr which is to expected as a motor is turning
dick
great car
love it best mb i have had and better than bmws i owned too
Coolant fluid would Prestone any color do? Thanks Mario
i took it they did an ac flush. they tell me its normal because of the mold, mildew and bacteria in the air.
my fellow benz owners I know have not experienced this. i never had this problem in previous cars.
one friend say they had to replace something in the dashboard.
I've read the several posts re. noises from the auto-folding mirrors, and recently had my purchase dealer investigate. Their solution was some spray solvent (WD-40?). Have not noticed much difference; arguably a tad less noisy. I wonder, though, about those of you who have had the mirror (or drive system or ??) replaced. Any idea how a dealer makes the call to replace vs. try other, less costly "solutions." I've had mixed results with my dealer. One item, they did the right thing; complete replacement the first time. One other item, they attempted what I considered a very tacky work-around (before actually doing a permanent fix during a second service call).
Just wondering if this is worth pursuing, as I am coming up on the three year mark (although only about 18K miles).
Thanks in advance,
I need to know this to determine if front and rear tires can be rotated, or only side to side is rotateable.
Anyone knows? Thank you in advance.
They can only be rotated left to right. A proper tire technician should know this.
You can look at the tire sizes for yourself.
I don't have the car yet. I was asking a dealer if they can change all four wheels and tires to Luxury C300 setup. Still waiting fir his reply. Am I too crazy?
Go to Youtube and look for C300 maintenance rest video. Shows you the procedure, it is easy!
Does this sound like a good deal? 2012 improved C300 is coming. I am not sure if 2011 price will be lower however selection will be less (whatever is left). Or special order now and wait for about 90 days.
I want Premium 1 and Multimead package and nothing else. Most car with P1 and Multimedia have heated seats because most customers who want P1 and Multimedia also want heated seats, says my dealer. Heated seats cost more than rear view camera, which doesn't make sense in California.
thnx
thnx
Will update have to be done by dealer?
I never asked the dealer. I guess it's worth a shot. Who knows? Good luck.
I didn't upgrade because I have a smart phone with the Google Maps and Spring Navigation. I rarely use the the navigation system or any of the fancy things on the car.
I bought 2011 C300 Sport last weekend. It has P1 and Multimedia package, wood trim and heated front seats. I started with 7-sp auto only but couldn't help myself. With such a nice car I need to add something.
To me $300 to update the map is a bit too expensive. I bought a Magellan 3030LM (lifetime map) and the whole thing is $101 from amazon. I'd think to update map every other times.
I have a cheap phone with no bluetooth. I do not use cell phone unless there is no land phone and I have to make a call. I might have a wrong impression that some high-end cars have built in phones.
I am still slowly reading the owner's manual.
As for the Agility Control, is it only with 4Matic (I think), or all C-class has that?
Passing by TiresPlus dealership, we stopped and got an estimate for a set of 4 Potenza for $603 (all included).
What are the advantages of staying with the original equipment? Continental tires get good reviews.
Any suggestions?
We drive 6000 miles per year and rarely going over 60 mph.....is this important at all?
Someone said that the difference between an accident and close call could be good tires.
Good idea.
