My dealer did add a plate frame when I came back for my license plates, but that was easily removed.
stoner1011, here is a pic of my rear hatch:
At first glance, it looks painted, but the characters are indeed depressed below the surface of the glass. And yes, I didn't pay extra for it. In fact, I got zero extras at delivery of my 2000 CR-V EX, not even floormats! Even the gas tank was only 3/4 full. . . .
Oh, and before anyone makes any smart remarks: The car was last washed on Wednesday -- but Houston is under construction all over the place!
Styling wise, that vinyl covered spare detracts from the otherwise refined look. IMHO, Honda did not need that exterior tire as a prop to make the V look more rugged. I actually have an engineer friend who chose to get a basic 4 cyl Highlander over the CR-V EX, because they felt that spare tire really affected the aesthetics of the CR-V. I agreed, I too think that the CR-V could actually be a viable Highlander competitor for several $$$ less, if Honda stuffed that spare.
Sorry you had a bad experience although it sounds like you are more upset than your parents!
I too would be upset if there were advertising stickers on my new car.
Still...I have to wonder. Why didn't you or your parents simply cancel the deal and walk away?
Lots of other dealers around aren't there?
And, not to defend the dealer...I'm not..but I don't think the early delivery had anothing to do with dishonesty. These are in VERY short supply and high demand...for good reason!
That is what determines pricing.
I do hope they enjoy it!
Have fun
I do see alot of cr-v's with soft wheel covers that have dealership's name silkscreened on them and people don't seem to care. besides i use the dealership brandings as recognition marking when i am upstate to know whether the poeple in the car next to me are from my neck of the woods or not. New York is a big state, and seeing "coutesy" on a mercury in buffalo makes me warm inside :-) (courtesy is a mercury/linclon dealership near my house in the bronx)
I don't know if it's related to the vehcile itself or just the keyless control problem. Today i drove my 2002 CRV LX to downtown Boston. I found the keyless control stopped working. No matter how hard i tried, from different directions, different distance, it just didn't
function.
Then i drove back home, wondering if i should go to the dealership. But strange thing happened, after i got home, i tried the keyless control again, it suddenly started to work.
Why is that? can somebody give me an explaination? Is this typical to remote keyless controls?
Sorry if this seems obvious, but if you feel that you are treated poorly, but buy the vehicle anyway, that dealer isn't going to change.
They certainly are independent, and I'm in an area (DC) where there are several dealers of all makes, so maybe we're a bit spoiled. Those in rural areas may be close to just a single dealer, and that limits your options. Except used?
-juice
why are they doing this?I encourage everyone to not fall victim to their greed and shop elsewhere.
Hyundai,Suzuki,Mazda,etc all good choices!I'm in no hurry to buy.Remember the PT cruiser everybody
wanted one and prices were inflated now the lots
are full and deep discounts are happening.
That's all I can think of anyway...
On keyless entry problem -- you might want to try fresh batteries, just in case yours are bad....
I also have a 1990 Accord LX(145k) and am
considering a CRV. It will be hard to give up
my Accord but time for something newer. I like
the car-like feel of CRV and sitting "higher" in traffic. It's also getting old being blinded by vans and large 4WDs! You can email me privately or
on the board.
I have filled up the tank twice since purchasing my 02 CRV-EX/Auto.
I drove the car until the fuel tank light came on both times and continued to drive with the light on for maybe 15 or 20 miles longer so that I could get as close to empty as possible.
On both occasions I filled up until the nozzle fill up automatically stopped. I did not top off off the tank, since I've read this is not good.
It took 13 gallons both times until the automotic nozzle stop kicked in. On each occasion i had gone 310-315 miles before refuelling.
Can I assume that the tank will take another 2 gallons to top off completely or did I still have 2 gallons of driving left after the fuel tank light was on continuously for 10 or 15 miles.
I think the latter was likely. If true and I had 2 gallons left to burn, or maybe 40 miles) then I would have gobe about 350 per 15.3 gallon tank
or about 23 miles/gallon on 50/50 city and highway driving.
5-spped has lots of power and is very quiet at 60MPH on the highway, a vast improvement over 99V.
1. Fill up your tank and set your trip odometer to zero.
2. The next time you fill up document the amount of feul that you put in the tank (I just get a receipt).
3. Before you drive away, write down the number of miles on your trip odometer on the same receipt and then divide the miles by the # of gallons.
4. Reset your odometer to zero and you're set to do this again the next time you fill up.
Doing it this way is more accurate and also it doesn't matter when you fill up. However, you do get a smaller margin of error if you run the tank closer to empty rather than re-filling with more feul in the tank.
Does anybody else use this method? I find it most accurate this way, rather than guessing whats left in my tank.
Okay, here's more insight into how much of a geek I am.
Steve
I find keeping track of mpg a great tool to determine if there is a problem that requires further investigation.
Some say geek, some say obsessive. I enjoy it.
It turns out that cracking only one window is not enough, so I woke with the interior completely fogged. Otherwise, it was just as comfortable as the couch (someone else managed to claim it before I could).
50/50 city/feeway driving.
It's a good idea, though, to have at least a general idea of how your fuel efficiency is doing. It could potentially even help you spot a problem early on.
26 people in one house? Yikes. No way I'd ever talk my wife into that. Her idea of roughing it means a Motel 6 instead of a Hilton!
-juice
tidester
SUVs
Purchase decision? Mileage is a big factor to me, always has been. Back in my idealistic college days, I promised myself I would never buy a car that did not get at least 20mpg in the EPA city rating. So far I've been able to keep that promise. I'm averaging 25mpg and never once dipped below 20mpg, so yes it would influence my decision to buy another Subie.
And I don't have to give up performance to keep that pledge. Look at the WRX (20/27) and Altima (21/26). Even the Forester and CR-V beat several less efficient V6 competitors.
-juice
But if I notice that my mpg is trending downward, I may think about switching brands or getting a tune up.
I can also tell you that the day I left for Idaho, I was getting 16.61 mpg. When I got to Idaho, I was getting 20.84 mpg. If you don't keep track, how else are you going to be able to figure out these useful little tidbits? ymmv :-)
Steve
Clearly we need a hypothesis for this one! ;-)
Hmm ... could be that mileage depends on latitude - good thing those Alaskans have ANWR to fall back on!
tidester
SUVs
Also have the "tick, tick, tick" noise following a drive. Sounds like metal cooling off or something dripping.
What model is your car?
What has been interesting to me is the drop during Winter months. As the soon as the average temp drops below 40 degrees, my mpg average drops from 25-27 mpg to 23-25.
Martha: the ticking is normal, from the expanding and contracting of metals in the exhaust. Most cars do that.
-juice
factor in gas mileage.
I have been using the 87 regular.
Should we be using 91.
IS it better to use super (91) unleaded.
High octane fuel is used to prevent knock. If your car does not knock, then don't use it. Edmunds has a good article on the subject in the technical advice section.
If the manufacturer does not recommended premium, stick with 87 octane. C&D tested some cars designed to run on regular, and some actually were less efficient on premium.
-juice
While I'm here, anyone else having back trouble? Can't seem to get comfy in the seat.
But you have to account for the different number of ratios and their ratio spread on manual vs. auto trannies.
Both final drives are actually quite high by industry standards, where 3.5-4.1:1 are more common. That's intentional, because Honda's engines like to rev to make their power.
-juice
I think you can purchase one of these computers that monitors your RPM's and such from www.cartoys.com. All your vehicles data will have to entered in to the computer and it should give you a fairly accurate measurement.
Hey Varmit what happened to you in my vs. topic!
Surely you aren't going to let me have the last statement. I average roughly 21mpg in all city driving. Although on a trip to Shreveport I got 25mpg!
Finally, my wishes came true and I picked up my new 2002 CR-V last week. So far, it is great! For all of you who need to know pricing, I bought it from Autoland and I did not have to deal with any dealer only with Autoland's salesman Robert Nomura. They do the search for you. Price was $700 over invoice plus tax and license. It is an EX automatic Satin Silver.
I wanted to provide some feedback to the board, as the information you guys and gals posted was always very helpful and reassured me on what I have researched on my own during the the past year. Due to my urgency in getting a car, I was looking to the Rav4 but I am sure glad I waited. There is a BIG difference and the CRV has more class.
As in everything, nothing is perfect, but this is quite there.
CRV is roomier and has taken into account several details that can please picky people like me. Since I do not know much about engines or tires, I pay more attention to quality and interior details.
My other choice would have been the Highlander, however it was not worth the extra money for what I would use the car for. Besides it it a bigger car that I did not need to have.
FYI, my car does not have a clicking noise either before or after I installed an aftermarket alarm system.
Thank you all for all your comments, advice and suggestions. It sure helps when the dealer or service doesn't know how to fix a problem and tries to blame it to your imagination.
