Hyundai Veracruz Maintenance and Repair
biocranialjks
Member Posts: 8
in Hyundai
Well, I have only had the 2008 Veracruz for about 3 weeks with under 1,500 miles on it and the air bag light is on. My wife was told that this could be up to a 5 hour diagnostic test and the dealer does not offer a loaner car. I am not sure about shuttle service either.
Anyone have any service issues so far with 2007 or 2008?
Tell the world about your dealer experience:
Dealer Ratings and Reviews
2800 miles
Purchased Dec 07
While driving down a two lane mountain road, I experienced a failure of the accelerator and gear shift capability followed by burning electrical smell and the activation of the check engine light. I was using the manual Shiftronic to help control downhill speed varying between 2nd and 3rd gears, 2000 - 3500 RPM when this event occurred.
The dealer is reporting that the computer became confused between all the manual gear shifting and simply stopped working. A technical support case was opened with Hyundai but there is no solution or software update.
The error codes indicate that that the Traction Control System engaged several times.
P2106 - Throttle Actuator Control System
P1295 - ?
P161b - ?
Anyone had experience with this type of error or Shiftronic behavior?
After one race at Timberline, we left the mountain and were caught in horrific traffic and driving snow. I pulled the Shiftronic into manual mode to control the hill descent. It was stop and go traffic, so during the long pauses I would shift to neutral and hit the park brake. This goes on for about an hour until....
Suddenly, there is a clunk in the transmission, check engine light and a transmission light. I have no idea what's going on but traffic starts moving again. The rig is gutless. I push over into manual mode, try to shift down. No go. I'm stuck in 5th gear and car will not accelerate over 1000 RPM. Bizarre. I'm caught between pulling over in a driving snow storm or just riding it down the hill until it's safer. So, I just let'er coast.
Once down the hill and in the town of Welches, I pull over and just turn off the car and restart it. Everything resets except the check engine light. Monday AM I take it to the dealer. They pull the codes, and are uber surprised. The code is set to "Limp Home", which forces the car into 5th gear and won't go over 1000 RPM.
What the hell is that? They promise to get back to me, but I'm nervouse because I'm going up every weekend in this thing to the mountain. 3 weeks later, I get a call that Hyundai Techs have no idea what it is.
Ski Team season is over, and it never happened again after that time.
I now have 2,500 miles on the rig, and other than the shifting behavior being a little puny on hill climbs and wanting to run down the hills in 5th and 6th gear, I haven't had any issues with the transmission.
I also had a squeak in the rear of the vehicle. The spare tire was flat which allowed it to move from side to side in the carrier; causing a squeak. Service tech stated that the spare "had a pinhole in the top of the tire and it could not be fixed." To my knowledge, the spare has never been touched since it left Korea. The warranty does not cover tire parts. $95 for a new tire installed. Since it is the spare, I am going to check for a better price at Walmart or Discount Tire.
The car was driven with no issues until it ocurred again yesterday, 9/17. This time I was told the following errors appeared:
2135 - Throttle Body
2106
1295
I was advised a Service Bulletin had been issued to dealers in February for this, and they were replacing the Throttle Body unit, which would take care of everything. The dealer stated they had replaced the unit on 3-4 cars to date and that it took care of the issue I was having.
I am not happy. We will see if this resolves the issue.
I have been a Veracruz owner for half a year. This is one thing that really bothers me.
It is the engine rumble when the transmission is trying to shift up at low speed. When I accelerate fast, the automatic shifts very smoothly. However, when I accelerate slowly or just trying to maintain my speed at exactly 20 mph,or 30 mph or 40 mph, the engine starts to rumble and generates a lot of noise and vibration. At this time, I need to heavily step on gas to make the rumble go away.
Anyone has similar experience?
I took my car to my dealer. They acknowledged that was a problem and they did a transmission relearn. But the problem was still there. They do not know what to do now.
I tried this old trick thinking a small flek of metal from casting or milling parts of the transmission had become logged in a valve or spring inside the transmission. I manually put the transmission in 1st gear and then ran up the road to about 4000 rpm, then manually shifting to second and holding that to 4000 rpm again. The idea is to flush the passages in the valve body under high fluid pressure.
Bottom line....my problem vanished and it has been several months, apparently there was some trash in the valve body. I have no clue if this "easy fix" would help you but you might try it, can't hurt.
Ken
In any event bbmax_00, I would still have your transmission looked at if you haven't already. One thing about the Veracruz - I thought it had a sealed transmission. I know that sealed doesn't always mean sealed sealed, but how is your dealer going to flush out your system if its sealed?
I only have 4k miles on it.
The dealer did some thing on it with a code name Ti-48. I do not know what they did. I will ask them whether they can flush the transimission.
The rumbling only happens at the low RPM in a gear. If I step on gas and make the RPM go up, the rumble goes away.
Wonder if there are other complaints along this line in other threads....will have to check.
However, Veracruz has a lot more car for the money. That is why sold me.
The vibration is really annoying. I would never buy hyundai again.
The "mess" seems to be on the backside of the engine (the side that faces the firewall) and the oil splatter seems to be just about everywhere. Do you recall where the timng cover is? Front side or back side of the engine? When and how did you discover your leak?
Greg
Anyone knows how?
My Veracruz also has this downshift jerk at 15 - 20 mph, when slowing down. But it is not consistent. I heard other people having that as well, but dealer keeps telling them it is normal. I honestly don't care...I have 100K miles waranty :P
before that I had a mazda tribute, which is tight but not stiff at all.
I think the main reason is the large 18 inches rim. Another possible reason would be the tire pressure. Dealers normally put it very high, 45 psi.
Good luck
My car has exactly the same problem. and I do not think it only happens when it is cold. It happened even after a 300 miles road trip. When engine is cold, the rumble is just more prominent.
I do think this is a serious problem. Mazda CX-9 and lexus es350 are using the same transmission and nobody even heard situation like this. Hyundai did not do a good job coupling the transmission with the engine. They have to fix it. We paid more than 30K for this car.
Ken
The one thing I hope they do fix though are the shift points, they are too quick and annoying, especially the delay to downshift after making a turn too slow and it upshifts to 3rd from 1st. That is a programming problem that I hope they address soon, but the rumble will not be something they can fix with a reflash since it is a mechanical problem with the gearing. When the rumble bugs me, I just knock the shifter to the right and tap it down a gear, problem solved.
OTOH, what I find truly amazing is when I ask for some giddyup and go. Stomp that pedal and this beast can move, shifts are perfectly timed and smooth, and can get this beast up to 85 in no time flat! That makes having the rumble worth it! As far as ride goes, very nice compared to others I drove, the rear clunk is annoying but the radio can easily drown it out, and the radio is probably one of the best factory units I have ever had in a car, it thumps, it rocks, it sounds great, and it also filters out AM static and line noise far better than any radio I have ever heard. My other car is a 2009 Camry Hybrid, and even though that radio can put out good sound, great bass etc, AM gets drowned out from line noise, and I listen to AM during my hour long morning drive, and having good clean AM is great.
My Overall experience with the VC is great, 9200 miles of trouble free driving, other than two seat belt clips getting busted by a careless teenager, i have had no quality issues with it whatsoever, and coming up soon I will have had it a year. I got it in February last year, drove it a few months, then when gas shot up to over $3 a gallon we got the TCH in April, and parked the VC in the garage, only because it wasn't practical as a daily driver, and we put 17000 on the TCH so far, that's 17000 that isn't on the VC, and I plan to keep the VC for a long time, and when I do get to drive it, I get to enjoy it.
Yes, it does go away when I manually shift it down or step heavily on the gas.
I have had my Veracruz for over a year and so far zero problems, absolutely love it.
Reflash or Reprogram - means updating the ECU
ECU or ECM - means Engine Control Unit ( the computer of your car's engine)
