Ford Explorer Transmission Questions
I have a new 2006 Ford Explorer with the V-8 engine. When coming to stop the car lunges or clunks when down shifting from 2nd to 1st gear. I have no codes that show up on the dash. What can be the problem? Other than that problem car shifts normally.
It was shifting rough, delaying between 2nd and 3rd gears.
I had the Transmission serviced as per the maintenance schedule.
The problem continues and now the O/D light is flashing on and off when I drive it.
Any ideas?
:sick:
It is obvious to me there is an issue with this new trans, seems since I started this chain alot of folks are having similar issues.
I spoke to a friend of mine about the lemon law, it seems on the surface you have a real case. Stay firm and keep pushing
You say that like you're irritated at how long it took. Just for reference, NOBODY replaces vehicles quickly, and some manufactures just won't ever. Ford does it quicker, and with more integrity than anybody I know of. Try to get Honda or Toyota to do that when their transmission is screwed up, and it was in 04 for Honda, and is currently for the Camry 07. Good luck with that.
You should be singing Ford's praises, IMO. I think they've been pretty stand up. As they were for a friend of mine.
I don't regret getting the car - they don't all do it, before my warranty is up - something will be done about it. You can be sure of that, but I'm patient, as long as I'm covered.
Thirteen months ago I put eight hundred dollars into a tranny repair on my Ford Explorer 2003 @ 58,00 miles. OK...I accept that.
Today the dealer told me I need a new transmission. No second or fifth gear @ 71000 miles. I've owned it less than 2 years. My wife drives it 12 miles roundtrip to work a week. Then some weekend trips to NH.........we don't beat it.
I still owe $10,000 on this. New tranny going to cost $3200.00 with a 36 month warranty.
I'm at a loss, I was stunned with silence when the dealer told me this. 71,000 miles and it needs a new transmission. As much as I like the Explorers, (this is our 3rd), I don't know if I could buy another.
Maybe it's time to go Toyota. I've got good friends who swear by them. I've been looking at the Ford Eddie Bauer models.
Not now. And not again until Ford can build something that'll last a bit longer than 71000 miles. I know,........ it's the pick of the draw.
Still sucks.
Rod
~tom
if the light doesnt light, then it is most likely either the relay or the switch in the dash.
hope this helps
~tom
~tom
