Quick Links
See Official Rules for eligibility and other requirements.
My trusted independent mechanic believes it is the transfer case, $1500-2000 to fix.
I got a second opinion from Aamco, which guarantees they will fix it for $2000 if I let them overhaul the transmission. Upset that I let them take me for $280 to diagnose the check engine light and fix an oxygen sensor, my fault for not walking.
May take it to Ford dealer for a 3rd op just for fun, but there is no way I can justify investing $2k in an 11-year old vehicle with 102,000+ miles.
From reading this post it looks like Explorer transmissions are set to implode @ 100k miles, so if you have more you are living on borrowed time. Guess I was lucky.
Scott
Does anybody know if changing the transmission fluid and maybe doing a full flush helps with this issue? Otherwise, we're considering a Honda CR-V...
Looks like it's a huge problem that affects multiple years. My 2002 has an enclosed transmission so apparently it's a bigger deal to get to & fix. Not sure about the 2003 but I'm guessing it's the same. Good luck!
-John
-John
