PT Cruiser Air Conditioning Questions/Problems
                    hi my wife has a 2006 2.4 touring edition with 36.6 k miles on it and the AC knocked off today...i cant find any relays or anything in the fuse box that seem to have anything to do with the HVAC system except for a single 10amp fuse that is fine...fyi when i have the hood up and the ac on i dont even hear the compressor cutting in and out...i dont think that it is low on coolant because in my previous vehicle experience they would gradually become less and less effective until they quit cooling because of coolant loss....any help would be appreciated thanks guys and gals
See Also: PT Cruiser Electrical Problems
I have 49,000 miles on it.
Thank you :confuse:
Anyone else have this problem?
Anyone else having problems please contact me here. I'd like to see how many of us are having the same problems.
I would check the connection at the compressor first. Wiggle it with the a/c on and see if it makes the compressor go off and on. If so, you found your problem. Find other sensors(high and low) that are part of the system and wiggle them too.
Any thoughts? I have about 54,000 miles on it and bought it used.
One thing I learned is to call Chrysler (at their 800 number) and complain. When my timing belt broke at 85K miles, they agreed to pay half of the repair (since it didn't last until 90K which is their recommendation per the owners manual.) I will warn you that it is time consuming. It took me two hours with at least 3 different people (up the food chain) before they agreed to pay. Persistence (and the threat of buying a Honda or Toyota in the future) paid off.
Good luck!
He fixed it temporarily by simply bypassing the low pressure switch. The bad part about this is that the compressor runs all the time, so you must MANUALLY cycle it off when it starts freezing up so it won't burn up the compressor.
Does anyone know where we can find this part? With the Chysler Bankruptcy issue, I'm not sure how long it will take to get back-order parts back in stock.
I had several Chrysler minivans and swore to never own another Chrysler...should have kept to my promise. THIS IS THE LAST ONE I WILL EVER OWN -- EVER!!! I'm buying a Honda or Toyota next time.
Santech
2450 Handley Ederville Rd.
Ft. Worth, TX 76118
Hope this helps, InlayUSA
This Santech part (MT 1191) is available at AutoZone, XL Parts (713) 983-1100 and North Houston Starter (281) 586-7374. Good Luck to everyone!!
:shades:
Long story short, all I get now is hot air coming through the vents. I have verified that the cooling fan does kick in. I tried disconnecting/ bypassing the A/C Clutch Cycling Switch to see if that would make any difference with no luck. Is there any other switch/sensor or relay I can bypass to see if the compressor will cycle?
Jim Welsh
Jim Welsh
I have an 07 PT and this just started happening to me in the past few weeks. I am the original owner and so (supposedly) still have that lifetime warranty and have around 60,000 miles on the car. I took it to a local mechanic and he said that it was my fan not kicking on (didn't say which one) and that it should be under warranty still and that the dealership would have to fix it.
I know very little about cars and don't want to take it to the dealership to get royally screwed over. Can ppl advise me what I need to ask/talk to them about or what actions to take?
Would the fan be something that would be covered under the lifetime-power trane warranty? I am the original owner and if it's something covered under warranty I'll let them fix it?
You're great!
Jan
a note to other 2007 pt cruiser owners who can't get the original low pressure switch from chrysler -- the santech part (MT 1191) is on back order now too but MT 0205 in conjunction with MT0135 will work too. I got this info direct from santech.
Then I called Chrylser. They said they might be willing to consider a goodwill compensation for this repair if I had it done at a dealership. Well, the bottom line is I did that, and they decided to totally cover all parts and labor. This had nothing to do with the fact that I knew a Chrysler employee, either. In fact, he thought I was "screwed" b/c I was past the 36K original warranty (I'm at 52.7K). He was very surprised that they did this for me.
Chrysler clearly realizes that this is an issue. I think everyone should call them (800-992-1997) and at least report their issue. I was only on the phone a very short time both times I called them and had good reps, too. My second call to them, after the repair was done, was to see if they would be willing to help me with my car rentals, and I'm awaiting a response today. I am still out $500 ($360 for rentals and $140 for Firestone and AAA's diagnoses), but I am pretty happy to not have it any worse.
Thanks again to everyone who has posted here. You all gave me the inspiration and motivation to see it through to this point, and things have gone relatively well so far despite the time, stress and effort. My A/C is back blowing the cold air it is supposed to now!
Have a mechanic who is skilled with AC check the drains.
kcram - Pickups/Wagons Host
Thanks for calming my nerves. :-D
