The creaking noise I'm getting happens when the amount of pressure my back exerts on the seat back changes, e.g. when slowing or accelerating. I can create the sound by pushing in on the top of the plastic seat back; it sounds like it's being caused by the plastic seat back rubbing against the leather (or vinyl) trim on the outer seat back. Is this what you're hearing, also?
If this is indeed what's causing the sound, I doubt that it will be helped by tightening the anchor bolts.
This is something that really did not bother me, it has since gone away, at least for the winter.
The only problem that I have had in 20,000 miles was a windshield leak that Mirak Chevy/ Hyundai fixed to perfection.
PS. did your immobilizer meet Canadian Standards?
I am living in Ontario, Canada, and my Santa Fe has the same gas mileage problem - it used about 20 -30 % more gas than the specificaition, especially in the winter! My mileage is close to 10,000 km and I monitored about 12 tanks usage.
Looking forward to hearing from you.
As an aside, it's also possible that yours has XM radio while your daughter's does not. The addition of XM as standard equipment was another mid-year change.
This is a HUGE dissapointment because Gray was going to be the interior color of my parents' Limited when they buy it because they hate Beige and Black is just too dark.
Gray is available on GLS and SE trims, but not Limited.
GLS and SE trims now have diff cloth types, not like 2007 when they had the same.
The GLS has Cloth (Beige and Gray), SE "Premium" Cloth (Beige and Gray), and Limited Leather (Beige and Black)
Colors gone for 2008 are:
Artic White
Platinum
Golden Beige
New EPA Mileage Estimates:
2.7 L - FWD MT 17/24, FWD AT 18/24, AWD MT 17/23, AWD AT 17/23
3.3 L - FWD 17/24, AWD 17/24
This is not a malfunction of the tranny. The automatic trans is a close ratio unit and because of that,
There is no recall for the dome light fix, and there will not be one. You have to call Hyundai consumer affairs yourself to request the map light fix kit, which will be sent to your dealer for free installation. There is more info for this earlier in this thread, including the phone number.
I'm with you!
what does the light to if the alarm is set off?
Its a great looking color and i cant tell what color it is... im thinking Slate Blue, but does anybody that maybe owns a SF in this color tell me for sure??
Thx...
http://greathyundai.com/img/ebay/8H136573/pic-1.jpg
http://www.greathyundai.com/img/ebay/8H136573/pic-9.jpg
http://greathyundai.com/img/ebay/8H136573/pic-8.jpg
http://www.greathyundai.com/img/ebay/8H136573/pic-7.jpg
http://greathyundai.com/img/ebay/8H136573/pic-4.jpg
Yea the 2008 Brochure does show the NAV system, i got one from the dealer about 1 week ago.
I have noticed that the front Ashtray does not have a light. There is a hole for the light and a little lens in the removable tray, but it does not look like it was ever installed.
Does anyone else have an Ashtray light? My dealer said they looked into this and confirmed that the vehicle did not come with front Ashtray illumination.
Pete.
Yes, my 2007 has a light in the ashtray lens. It's a regular white incandescent bulb (not a blue LED like the rest of the illumination in the car).
Whaddya think? Is something wrong with my seat heaters? Can I bypass something to get them to turn on immediately even without a butt in the seat? It makes a difference to me, because I live in Minnesota. It was 5 below zero this morning when I left to drive in to work, and warm seats would've been really nice to have.
No, but if you have a remote car starter installed, you can have it set up to turn the seat heaters on when the car is started. That's what I did. I bought a remote starter (Viper brand, from Directed Electronics, Inc.) for about $200 at Circuit City. I paid for a few extra relays (around $12 each) that were hooked to the auxiliary output on the remote starter and then wired into the seat heater switches. I can now engage the electric seat heaters remotely at the same time I start the car. To do so, I just press the AUX button on my remote after starting it.
What I've discovered, of course, is that I don't accomplish anything because the seat doesn't actually start to heat up until my butt is in the seat, despite the fact that the light on the switch shows the heaters as being on and having been on for 10+ minutes. Therefore, I'm no better off than if I just waited to turn them on when I got into the car. I'm tempted to try to find and bypass the switch that only allows the seats to warm up when a butt is in them, but I'm hoping someone else has already solved this problem.
