Visitor Agreement.
Transmission fluid: There is something proprietary about the ATF (additive package maybe?) that Honda is not sharing with the rest of us. I'm sure other lube-makers would like to bring a clone of the Honda formula to market, but can't yet. I would stick with Honda fluid for peace of mind.
Rear-Differential fluid: Same story as above. The RT4WD uses the same fluid as Honda's CVT trannies. If we ever see a clone of the CVT fluid come to market, I believe we ought to be able to use it in place of the Honda "Dual-Pump Fluid."
Coolant: Finally . . . this is one fluid whose requirements are well-known. You don't need Honda coolant, but whatever coolant you choose must be silicate-, phosphate-, and borate-free. Key words on the bottle to look for are "Long-Life (5 years)," "organic rust inhibitors," and/or "GM DEX-COOL." Havoline, Prestone, and Xerex have such products in their lineup, but make sure you have the right one. For example, the Prestone in the long-familiar yellow bottle is a no-no.
I haven't quite gotten to the point where I need brake fluid yet. Maybe someone who has been there can comment on that one.
Part of the problem could be the photo service you have your pics hosted on. Some allow external linking while others do not. Posting the URL alone should tell us the answer.
Slugline - Is the CVT and Dual Pump fluid exactly the same stuff? I thought our engineer friend had some contrary advice on that subject. Maybe I'm remembering the end result of the debate incorrectly.
Also, is there an easy was to search on this board if this has been answered without me having to go thru all the post? I would like to just do a search for 'extended warranty' on the this thread.
-fern
when I bought my CRV.One reason you buy a Honda
is reliability not that it is fast or quiet or
comfortable.Sure there is a chance sonething will
break at 36001 miles but not likely.You can still
get the warranty before the factory one expires
meanwhile use your $1000 for something else.I was talked into getting a 7 year 100k warranty on a
98 Acura CL I bought new.Never needed it and
when I traded it in at 64k miles I was refunded
about $350 of the $995 I spent on it.If you can't
save $1000 in 3 years to buy the warranty maybe you better roll it into the financing.
Varmint: Dunno if the formulations are different, but their applications are the same. The original CR-V manuals specified "CVT Fluid" for the rear differential. The newer bottles labeled "Dual-Pump Fluid" (now recommended by our "Engineer pal") indicate that the contents are to be used for CVT trannies. I can't help but infer that the two are interchangeable!
TIA
Two annoyances:
1) The temp-control detents reveal significantly non-linear performance. Going one-notch warmer from "COLDEST" produces a dramatic difference in air output. It could be said that COLDEST is too cold, with one-notch upwards too warm.
2)...and most irritating. When you accelerate strongly, the compressor cuts out for the high engine-rev moments of the event, leaving you with humid air for the duration of the event. Maybe it's a governor on the compressor, or the MPU is cutting out the compressor to eliminate drag on the engine during strong acceleration. Either way, it's not my fondest feature.
As long as people keep paying sticker price you are in a pinch, however if you ALSO pay sticker price, the next guy is in the same boat as you are now. The manufacturer's are (in my opinion) throttling supply to create the artificial demand. The Highlander from Toyota is a perfect example of this.
Try this: Print up or write down what you want and what YOU are willing to pay for it. (even if that turns out to be below the TMV) Include documentation that shows you know the invoice and the holdback. Offer to buy a vehicle right off the truck to minimize dealer costs. Don't get greedy and ask the dealer to take NO profit at all, be reasonable. Put a line on the bottom stating "This offer is good for 'X' business days.", sign and date it and take it to the dealer. Tell the dealer you see his position, but that you have your own parameters to follow, present them with your offer, tell them to look at it and call you if they are interested in making a sale, and LEAVE. (that's the hard part) Don't call them back either. If they have not responded to you in the allotted number of days then move to the next dealer and do the same thing until you find one that will deal with you. If you call or go back even ONCE, the dealer knows they have you over a barrel and they are in the drivers seat. If after several dealers you can't get what you want for the price you want, seriously consider a different vehicle.
If all that fails, buy a one way ticket to a State that has them on the lot (and their are plenty of them) and go strike a deal. TMV in my area is sticker, and I didn't pay sticker and was STILL able to buy locally AND get what I wanted. (a blue 02 EX) Why would anybody pay sticker or even OVER STICKER is completely beyond me. If you have more money to spend, then go buy more vehicle.
I could rant more, but I'm cutting myself off here which is already too late....
Freeber - I like your suggestion. There are two things I would add. If the dealer does not respond and you buy from someone else, tell them about it. Send another message letting them know why they lost a customer. It may help the next guy/gal who walks into their showroom. I would also remind them that the average life-long customer is worth at least $160,000 in sales business. After doing this, I will generally point to my wife and say, "she's the other customer you are losing; and she has expensive tastes".
A note on artificial demand. It doesn't happen. Honda has nothing at all to gain by reducing production to allow dealers the opportunity to overcharge. Any extra money made over invoice goes to the dealership, not Honda. The practice of price gouging also engenders mistrust and bad will with the customers. That's bad for all Honda dealers and Honda corporate.
Like yourself, I could go on and on, but there is essentially no good reason for Honda to do it. The reason for the short supply is a lack of production facilities. Honda is doing what they can to meet demand (like building the new Ody plant and bringing over English CR-Vs) to prevent this problem. They are not encouraging it.
I digress....
I ordered mine last week and I am anxiously awaiting it so I can complete my rack so I can get the full use of my 2002 crv!
I heard from many places that it will be a couple more weeks. I ordered one last week from an internet site that said they would be shipping it to me last Friday and I haven't recieved a shipping confirmation yet. I am wondering if they just took my order and will send it in 2 to 3 weeks like everywhere else I called. Does anybody have any info they could provide?
Pics of GatorGreg's 'V
Gator - Love the accessory color palette you have splattered on the hood.
-Steve
marked up but in Temecula 70 miles north they are
dealing.Kind of like fishing.In a well stocked
lake the fishermen will throw any bait at the fish
and a lot bite.In a sparsely populated lake it
takes a better bait.
For you and other 2002 owners, however, I would not necessarily recommend blindly following my lead. As you may know already, the K24 engine in your vehicles is among a new generation of i-VTEC engines from Honda Motor Co., and is actually much more closely related to the K20 in the Acura RSX than the "old-school" B20 in my machine.
Y'all may actually want to consider comparing notes with the RSX owners to see what they are doing. Since they've got the more hyperkinetic (rev-happy) engines, I would guess that whatever works for them would be more than adequate for a new CR-V.
Diploid, yes I can open the hatch glass. The wiper also works fine, but it comes within a 1/4" or so of rubbing the wiper. I can manage to slide an envelope around the back of the spare, but that's it.
Tmeframe, I don't remember you, were you at the mdx forum under another name maybe? As for noise, as I said in my post above I think it is quieter, but I'm not sure. The noise in the 'V (1st and 2nd gen) has never bothered me, so I don't pay much attention to it. It's quiet enough that GG Jr. slept the enitre way home on a recent 2 hour drive.
Here's another shot. It's amazing what a little soap, water, and elbow grease can do
Here's a shot of the spare for diploid. Actually, I just wanted to show off my GoongalaGoonga sticker
Here's your last note to me:
Steve, sorry to see you go. The 1st gen CR-V is a fantastic vehicle, and the 2nd gen is even better. That's my beloved old 'V pictuted below (taken at the 2nd Annual Big CR-V Scrub........
-Steve
Also, has anyone ordered from Hondapartsforyou.com. They seem to be the cheapest and have free shipping, but I'm wondering about their reliability and service.
Thanks in advance.
But...we ended up buying a Legacy L wagon for $17,827. Hard to beat that kind of value, and we got AWD, 4 wheel disc brakes with ABS, PW/PL/PS, cruise, A/C, keyless, so it's not stripped. It has a little less rear passenger space, but a much wider and deeper cargo floor area, and more front leg room. In the cargo bay we were able to fit a stroller and change a diaper behind it, with rain shelter from the hatch (actually did just that on Saturday in pouring rain).
Honda ought to offer ABS on the LX model, to compete at lower price levels. Also, 2WD comes in automatic only. We have a Forester so FWD would have been OK for this vehicle, if only to get the price down.
We paid only taxes on top of that price, and got 6 free oil changes and a service loaner for life from the dealer, plus a longer powertrain warranty. Wife seems happy so we're good to go.
Thanks to everyone here for the advice and information. Maybe that no-hassle quote can help someone here, so I can return the favor.
-juice
But Subaru is guilty of this, too. WRXs in Canada get heated seats.
-juice
Steve
Anyhow, he said the system would look nearly identical to the "Locking Railrider" system on their web site. I took a look and I don't see how they can make it work. Maybe somebody else can.
Congradulations Fern!!! it sounds like you got a decent deal!
After a bunch of mumbo-jumbo about software upgrades and new designs, they convinced me there was nothing wrong with my car that a little "teaching it how I drive" wouldn't solve.
Since then, the Maintenance Required light has come on once more. However, when I checked the fuel filler cap, it was loose. I tightened it and drove on. In fact, I drove from my home in Neptune, NJ to Manhattan, NY and back. The light remained on the entire time. In the morning, when I started the car for work, the light was still on. But at some point on the way to work, the light went off. When I called the dealer about this, I was told it could take that long for the software to reset, even when the vacuum in the fuel system is restored within a short while.
All has been well since then until this week when my "Side Air bag Off" light lit up. Since it was only on for a short time (maybe five minutes) I tried to ignore it. My dealer had told me when I first bought the car that the Side Air bag Off light would come on if I sat in the seat in a way that put pressure on the sensor or if something leaned on the passenger door "just right".
With all these warning lights going on and off, my dashboard of my car is looking more like a Christmas tree than the great quality Honda CR-V I have grown to love!
Susan
A 2001 Honda CRV broke her fall..
-Chuck
Either that woman weighed as much as a toothpick, or the CR-V's roof is extremely strong. I'm no physicist, but I can imagine the extreme force of an adult human dropping 14 stories.
As for the side airbag light... The seats have sensors in them, which prevent the side airbags from deploying if they detect that the passenger is too small (a child) or if they are out of position (leaning against the door). In both cases, the airbag might do more harm than good. My wife's Acura TL has this feature and I've seen the light come on when she leans to reach something in the back seat. Some folks have found that a briefcase, heavy organizer, or any other reasonably heavy object can trick the sensors into thinking that there is a (too small) passenger in the seat and the light comes on.
