Visitor Agreement.
I keep mine around 30, so that if I don't check them for a while there's less chance of them going below 26. I try to check between oil changes, but sometimes I forget. It's more comfortable to ride on 26psi, I guess, but underinflated tires are big safety concern. The overinflation pressure is well over 40psi, so I think I've got some good margin there.
ps - for the legal types - use this info at your own risk. This is not my recommendation. Check your owner's manual for proper inflation specs.
Every tire store and mechanic I've been to recommends 30 - 35 psi for good wear and good mileage on tires. Since I don't care about a soft, squishy ride (after all, it's an SUV, right?), I've kept my last 2 good sets of tires at 32 - 35 psi, rotated them faithfully with every oil change, and they have given me over 80,000 mi. (rated 60,000). These are not fancy Michelins, either.
Just my $.02 worth.
VW's new ads for the TDI tout it's range (about double the CR-V), and never even mention that they're diesels. I thought that was kind of interesting.
-juice
Usually get between 22.5 and 23.8 around town and made one trip of about 1000 miles and averaged around 27 MPG. My driving style is moderate around town and 75-80 on the interstate. All things considered I am very happy with the mileage on the V. I am sure I could squeeze a little better mileage out the V but then what good would that peppy little engine be?
But most people don't do that, so the TCO tool can be a real eye-opener for those with no clue about how much it costs to own and maintain a car. Hopefully it'll be tweaked in future versions so we can put our own numbers in.
Steve
Those ar deep wide cuts you'd think fem88 would know right away the car drops on the rims with a big whoosh.
It's too little for insurance to cover, too.
-juice
tidester
SUVs; Aftermarket & Accessories
a way that the damage looked just like yours.Luck I guess.Beer drinkers have always thrown bottles
out of cars.Why doesn't it come in plastic?
The weirdest tire escapade was when I hit a pair
of tin snips laying in the highway.My front tire
caused them to open up and then my rear tire hit
the open blade and whoosh A BLOWOUT.
I used to drive in the city and frequently popped tires on road debris. However, the worst flat I've had was on the highway. I ran over a lag bolt while doing about 65 in the left lane during rush hour. I was in my wife's old Mazda 323 at the time. The bolt not only punctured the tire, but it also punched a whole in the steel rim!
There I was trying to change the tire on the left median (didn't have a chance to get over to the right) and the stupid tire wouldn't come off the car. I'd removed all the nuts and the tire was loose, but I couln't pull it off. Turns out the bolt had lodged itself behind the brake caliper and was holding it on. :-(
manufacturers use it?
>If it works why don't the
As to mileage, I run the OEM tires at 30 psi on my '99 EX 5spd. I average 25 mpg in daily driving (with includes some highway) and 28 mpg on extended highway trips. I drive within 5 MPH of the posted speed limits at all times.
After swapping out a lot of CDs and going through a lot of speakers, the ones that sounded best in the range I could afford were the Boston Acoustic Pro components. The $1500 MT Quart speakers were incredible, but I'm still making car payments! I'm getting BA coax speakers for the back.
To power it all is a 4-channel Kicker amp, chosen because it will fit out of site under one of the front seats. I also decided to get full door Dynamat for both front doors, and they will use a switch to take the speaker-level outputs on the factory unit to make them RCA.
I can't wait!!! Thanks for all the info guys - it really helps to have some idea of what's going on before going to the store - especially if you are a woman.
csj
i bought a 1998 when i graduated from medical school and i loved it to pieces! my only two complaints have been lack of get-up-and-go and the road noise. since i am graduating from residency in june, i decided that the 2002 just HAD to be my graduation present! i am so happy with my new purchase! in fact, since there is no longer a "hmmm... wish that was better," i will probably hand this down to my daughter when she turns 16 -- in 13 years! of course... maybe i'll just keep it
thanks for all of the info here in the postings. y'all made the decision that much easier!
btw -- my husband got a new liberty sport in 11/01 and we both agree that the v has more room and is better for the long family trips. his was more fun to drive than my 98, but my 02 wins the prize in my book!
I got 60K out of my stock treads.
had 60k miles on it's Michelin MXV4 tires and lot's of tread left.They cost $150 each.I think
the Bridgestone Duelers on my CRV will be lucky to go 40K miles and will cost about $80 each.The
advantage to 15 inch wheels is they are more
common thus cheaper to fit.When I replaced the tires on the CL I had to special order them cause
they weren't a stock item.If you ever have a
blowout far from home it is good to be able to get
an exact replacement tire fast.Last year my wife
ran over a bolt in the freeway and ruined a
$150 tire on a new ACURA TL.At that point I got
road hazard coverage on all my tires which replaces the damaged tire and is not prorated.
I just spent a good portion of the weekend using the Mother's 3-step wax system. on my car. It made a big difference! The shine is incredible! It definitely took a long time, but it was well worth it.
I'd recommend both Meguiar's and Mothers for store bought waxes. I know that there are some that you can only buy online that are supposed to work well, but I have no experience with them.
One thing I don't like is Armor-all. I've read way too many horror stories of people applying it and then their dash cracks when they don't re-apply it. Also, my friend put that stuff on his dash and it attracted dust like mad...and it made it stick too! I don't like a gleaming dash anyway...makes the glare on the windshield bad when it gets sunny out.
Glad you're getting respectable mileage running tires at less than 30 psi, but I'm not going to take the chance again, esp. when I'm getting 60K or better out of 40K and 50K rated tires running at 32 - 35 psi. Unless there's some compelling reason (other than a "soft" ride) to run them at such low pressure.
Regarding tires: My 2000 CR-V wore out the factory Dueler H/Ts after 30,000 miles. I strongly suspect, however, that this is due to my driving habits. I will say, however, that running them at 28 psi did not result in any uneven wear whatsoever. I'll ditto what varmint said above and add that a high-quality dial tire gauge will give you your money's worth; I have yet to find a "stick" gauge that I can trust.
For the dash, I know that there are products that have UV inhibitors and enrich the vinyl, as opposed to drying it out. I can't think of a specific product name off the top of my head though as I don't use the stuff.
For cleaning the dash, I just wipe it with a micro-fiber cloth. We don't get a ton of sun here in Calgary, and when it is blistering out, I use a windshield sun shade.
http://properautocare.com/propvincar.html
I'm sure there are other products that do this, but the Mother's product is the only one I've tried so far.
(I'm big on deferred maintenance but I do like 303 Protectant).
Steve
When I do sign up, my name will be something like Pro_fan or something. It's nice to see people around on different forums
I don't really like mail-ordering, but I've heard a lot of good stuff about klasse. I think I may have to bite the bullet and try.
Steve_host: I think the best forum for information on car care products is the "Store Bought Waxes Part II (No Zaino Posts)" forum here on TH. However, it's really difficult for new users to know to go there to get that kind of info.
The real reason I like it is that I can leave it in the car - see a little dust, get it off and I don't have to make a big production out of cleaning.
csj
