Visitor Agreement.
girlfriend'swife's Buick LaCrosse since it was new with no ill effects. I only run premium in my Cadillacs however.I followed 2 Corvette Forums for over a year before I bought
my 2007 Coupe - and checked in at least daily for the 2 years
[ excluding a couple of vacations ]
I had mine - and I have never seen any reference to
anything remotely like this...
Odd.
- Ray
Ex-Corvette driver....
The smart and the Honda both call for premium, so that's what I put in there. The Sentra doesn't need it, but I want to bump the timing up a few degrees once I get it running well, so I've been filling it up with 93 to be ready.
Good for you!
I might guess that the type of people who bought Saturns might go in fairly large numbers to Subaru which is a smaller, "different", and loyal culture and company.
Anyway given the economic environment and the multitude of models and brands, Saturn really isn't needed.
But they'd never do that, since speed control and laws are all about revenue and taxation through fines, they'd never limit your right to "speed." It is completely 100% non-safety related, traffic enforcement in this country is a sham.
By the way, are high speed tire pressures higher or lower than normal PSI?
Well, those jets get expensive. They tried to cover up the shoddy quality with hot dogs and apple pie. It didn't work.
That's bad for the employees, but ultimately good for the market. GM was way too big and just rolling ownership to Penske did not downsize the capacity enough. Penske was smart to walk away.
Here's the lastest AutoObserver take. Just yesterday we were predicting a Wednesday or Thursday close.
"The Saturn dealership network represented a unique opportunity for Penske, but the risk was sourcing product and that proved to be too much to overcome to complete the deal."
OW
Take a look at the UAW forum if you get a chance. One of the reasons.
The only other is poor management. Period, the end.
OW
Higher pressures go with higher speed driving just like higher pressures go with higher loads.
Oh yeah, looks like premium is required after all.
...for cars.
General Aviation still uses 100 octane low-lead gasoline.
Nothing if the engine your running needs it (i.e. old engines). Lead additives can still be purchased at your local auto parts store I believe.
A key driver of the Chevrolet Volt project is defecting to start his own consulting firm, according to published reports.
Volt chief Bob Kruse, 50, has left General Motors. He's been replaced by GM engineering veteran Micky Bly, who has also been involved with development of the Volt. The Detroit News first reported the moves on Wednesday.
http://www.autoweek.com/article/20090930/CARNEWS/909309988
My Y2K E320 wagon fuel door said also indicated something very close to "premium fuel only". Also in the manual it said something like this:
"You can use 87 octane, but drive directly to another fuel station using maximum 1/4-throttle, and top off with premium, cowboy!".
So apparently 87 octane was *supported* by the manufacturer for my Y2K E320, at least to some extent, but maybe not to the full/100%/no-worries extent that GM/corvette/etc supports 87 octane.
I found some discussion about Caddy Escalades running fine on 87 octane, again consistent with the other GM V8 vehicles.
So - apparently this was a statement with no
grounding in fact....
I think my owners manual may say that same kind of thing, I will have to take a look.
And to answer "what are you achieving":
In recent years i've been driving about 50k or 60k miles per year, as did the other driver in my household. Many of the miles were on 45 mpg VW TDIs, but just for arguments sake let's say they were all done with GM V8s:
At 20 mpg that's 3000 gallons per vehicle per year. 6000 gallons total per year.
That's a household savings of $1500 per year, just by burning 87 octane instead of premium. (figure 2.50 for 87, 2.75 for premium?)
There's one gas station locally selling 87 octane at 2.59, premium at 3.29.
If that price-delta becomes prevalent, it would lead to a savings of over $3000 per year given the numbers above.
If I had a Corvette, Camaro, CTS-V I certainly wouldn't mind $80 extra/year to have some peace-of-mind that I'm pnot damaging the engine or getting lower detergent amounts on a $50K vehicle for that small amount of money.
that became mandated a decade or two ago.
I'm not sure that I buy their claims, but you can get more detergent in some brands than in others.
Fuel requirements per the owners manual in my E55
And the high octane desires of my old timer
Dang! I can't use my homemade gasoline-benzol-alcohol mixture :shades:
I think MTBE is no longer in any USA fuel now, thankfully... !
Now if we can get rid of ethanol too we'll get better mpg and reduce oil imports.
Unfortunately The Old GM leveraged the E85/CAFE scam effectively.
That is probably going to increase with The New GM, eh? Probably more GM models will become E85-capable? (?)
Actually the alcohol scam was effected by ADM and other large corn processors as well as the commercial farm companies. Many middle-sized corner growers in the midwest lobbied for the increased use thinking it was raise prices on the corn which they sold. In the end it increased the cost of feeds used for farmers with livestock as well as cost of food products.
GM had little to do with it, so the vitriol toward the Old GM needs to be suppressed. GM was doing what the governments wanted.
After the increases in food costs and the huge subsidies to the AgriBusinesses who built corn-alcohol plants so they could make money with government subsidies, now we're stuck with the reality that producing alcohol from corner is water intensive and also CO2 producing. In effect there is no gain in pollution reduction by using ethanol because of the pollution inherent in producing it.
A local company had to abandon plans to inject under pressure CO2 from their alcohol plant (subsidized by taxpayers).
The Andersons Marathon Ethanol LLC, Ohio’s largest ethanol plant, generates annually more than 250,000 tons of carbon dioxide, a greenhouse gas thought to contribute to climate change. Virtually all of it would have been injected underground if a porous rock layer filled with saltwater far beneath the ethanol plant had been deemed suitable.
Further, "McKinstray said he was disappointed that some local citizens seemed to feel ethanol plant officials didn’t have the community’s best interests at heart. He’s concerned the area might get an activist reputation that could discourage future business investment."
This guy needs to go to DC; he'll go far in politics these days: blame the taxpayer as the bad guy for not wanting their groundwater turned acidic by CO2 pumped into the ground!!! for the benefit of his taxpayer- subsidized limited liability corporation as the shield for the joint business of Marathon and Andersons (a large grain company).
"So vast is GM's discarded empire it includes assets unrelated to making cars. In Clark, N.J., officials at the Hyatt Hills Golf Complex wonder about their operation's fate.
GM spent several million dollars to redevelop a former factory site into the sprawling golf operation, which includes a driving range, nine-hole course and 18-hole miniature-golf course. The complex, which opened in 2002, brings in about $1.6 million in annual revenue, said Robert Hoeffler, the complex's executive director, and most of its profit goes to local governments."
For Sale, Cheap: 'Old GM' Peddles an Empire's Remains (WSJ, via Yahoo)
Have a 16 year-old HP Laserjet 4L purchased for about $600 (1993) that is bullit-proof. Like energizer bunny. Now, if GM built vehicles (Suburban in my possible wants) that I felt had that reliability, I could be tempted to try American again.
"The rights to his short-lived DeLorean Motor Company have been acquired by a tiny firm based outside Houston, which still supplies parts to the stainless steel DMC-12 gullwing sports car that was designed by Giugiaro and built in limited quantities in Northern Ireland in 1981-82."
DeLorean Wants To Revive the Pontiac Solstice (Inside Line)
General Motors Co., working to cut its U.S. brand count in half as part of its restructuring, is trying to complete a deal to sell Hummer to China's Sichuan Tengzhong Heavy Industrial Machinery Co. for about $150 million, Bloomberg News reported Thursday.
The companies hope to make a deal today or tomorrow for the SUV brand, Bloomberg said, citing three unnamed sources.
GM said in June that it expected to sell Hummer to the Chinese heavy machinery maker, which has no experience in the auto industry.
Hummer spokesman Nick Richards declined to comment. A source close to the sale said GM expects it to close "any day."
GM had estimated in the summer of 2008 that the sale of Hummer “might realize $500 million or more,” CEO Fritz Henderson said in documents filed during the automaker's 39-day bankruptcy.
http://www.autoweek.com/article/20091009/CARNEWS/910099998
Or maybe I should say it AINT worth peanuts! :-P
And it's going to a Chinese company that has no experience in the auto industry. THAT bodes well for the garganta-brand.....
The "old GM" is finding out that most of the brands it thought were such huge assets are essentially worthless. I suppose the damage to creditors and suppliers was already done, though, when the bankruptcy occurred. So it doesn't really matter how much if anything they get for brands like Hummer and Saturn now.
OW
