Bud H
Check out the link to the Nokian wr........they are great tires. OEM(what is standard on the Sonata) will not come close. :shades:
I am going to get my Limited tomorrow and I am planning on the red with beige. Anyone know how beige leather holds up in terms of not looking soiled over the course of a few years?
The Limited also has cocoa leather available in some paint colors. As the name implies, it's nearly black but with a hint of brown. It can be had with powder white pearl, silver, black, and cocoa paint colors. Gray leather comes with silver, medium silver blue, willow gray, and (my personal favorite on the Sonata) slate blue. I bet silver with the cocoa leather would be very sharp.
What do you think?
.I took my car to the dealer and he did a software reset and the noise was gone(at 350 miles)..and then again it started the same noise yesterday(at 1700 miles) and it feels just the same ...like I am driving a truck while it moves from 0-35mph.
Any suggestions....??
- Robert -
http://jalopnik.com/351848/chicago-auto-show-2009-hyundai-sonata-revealed-now-wi- th-super+capacity-cupholders
BTW, too, if you try to use the NAV or radio with the ignition switch in the ACCESSORY position, there is a frequent nag screen which warns that you may run the battery down. Hardly seems likely.
I've alerted my dealership to this---even though I know think they think I'm the crazy complaining lady. LOL
Might be worth experimenting with different brands to see if it makes a difference. Just a thought.
Have GLS 4 w/5 speed. Have noticed lately that when starting up in the morning (& evening after sitting all day) that the engine runs a little rough. Starts at about 1300 rpm and idles roughly enough that it can be felt through the steering wheel and brake pedal- after about 30 seconds or so, it settles down to about 900-1000 rpm and the roughness disappears. Is it something tied to the computer? A need to "check" the engine and get everything set before settling in?
Only 2500 miles on the car (oil changed to full syn at 1200 miles). No dash lights on. No other noticeable issues. Runs fine after that initial "warm-up" and getting good gas mileage. Live too far from the dealer to just drop it off and have them keep it overnight to check it out.
Any ideas or opinions would be welcome.
I just picked it up today after it being in the shop for over a week (I got a rental car from them) and they replaced the entire right front strut assembly plus some insulator part and rubber part. No wonder they look at women crazy when they come in. I hope it takes care of it, but I"m sure the left side will need replaced as well...just waiting to hear that "thunk" noise in the left side and it's going right back!
I too have a slight shaking of the car since I bought it. It happens at 1345-1410 rpm and there is a noticeable uneven acceleration of the car. I had a dealer do an in depth check and found the timing is spiking on certain cylinders, I'm talking from 30deg BTDC to 41deg in just certain cylinders. Hyundai says it's normal, I say that 20 grand is a bit much for an inproper working car.
In addition to the skipping, it has died several times, had oxygen sensors replaced, an alignment (pulls left from the factory), on its 4th time for the clutch blowing. Who knows how much more is going to go wrong. I've had my GLS manual for 7 months now and it's been in the shop 23% of the time. in the last 6 weeks, I've had it 7%. Yeah it has been in the shop 93%.
Wanna feel something weird? Start the engine, hold your foot on the brake like your on a downhill (steady pressure) and after 10 seconds you'll start to feel the brake pedal fade to the floor. After 30 seconds or so, it will be on the stopper.
Good luck on getting it repaired, I personally would never recommend this car to anyone.
I also called the 1-800 number and filed my complaints. They are in the process of contacting my service manager to "see what can be done about these matters". Probably nothing, but I don't want to be negative.
I know they think I'm wierd. My smell is coming from the window crack when we roll down our windows fully. Must be something to do with the trim or "gasket" material or adhesive they use on the gasket to stick it to the door panel. Not sure, but it's not a pretty smell, that's for sure. I can't understand though why more people aren't complaining about it??? That confuses me big time. But, my complaint is on the record books and HOPEFULLY something can be done about it.
I'll keep you posted...you too if you find anything more out about it.
Who/where is your dealer?
I had him smell the window crack after I put the window down and he smelled it. I'm not the crazy car lady after all! He called today and they removed the rubber gasket section and it is the culprit! He's not sure why some stink and some don't, it's frustrating and confusing at the same time. He has ordered 4 new rubber seals/gaskets to replace them all. He said he will open each individual bag and smell them to see if they have the same body odor smell. Let's hope not!
The rep really didn't hear the noise in the front end. Of course not, they had fixed the worse side and the left side hasn't made it to the really noisy part, but I'm sure it will and it WILL go back and get all the suspension parts replaced just like the right side. My service manager seems to be a pretty goody guy to deal with these things.
So, that's the story on my end. I will hopefully get my car back on Friday or Saturday....but at least I have another 2009 Sonata to drive in the time being.
I seriously now wish we had gone with the Ford Fusion or Toyota Camry...kicking myself. But, they may have their problems too. :confuse: :confuse:
Can you reply with the name of your dealer? I want to have that in hand in case it becomes an issue.
Thanks for the update!
http://www.fordfusionclub.com/index.php?board=1019.0
http://www.toyotanation.com/forum/showthread.php?t=180105
It really comes down on how well the dealer and the company handles the problems. I still think the Sonata is one of the better cars in the class.
It took 5Qts. Has any one changed theres and found the same. It has 3900 miles on it.
