The red/white arrow will point in different directions depending on option settings.
IE:
North up, compass heading, track etc.
SUVs and Smart Shopper
Seriously, I hope your dealership performs the TSB (now that you have "schooled" them) and your squeal is no more.
- I have yet to read about a dealership that even knows about this TSB (admittedly anyway).
I finally took my wife's Mo in last Thursday and told them this is what it does and here is the Nissan published TSB to fix it...
My guy looked at me like I was getting cocky with him. I really wasn't but I just smiled and said: "the internet is a beautiful thing,,,, isn't it." He replied with: "we'll get her handled!"
I didn't hear the whistle at all on the way home.
Good luck!
First -Trade out of your vehicle. I have not seen you post anything remotely positive about your Murano.
Second - Paragraphs. Use them. They help to break up the wall of text which is assaulting me.
Third - Get counselling. You're unhappy and it shows.
Excellent advice. We're talking cars here, warts and all.
Thank you for sharing.
Oh - and the one complaint about the car is the silly sun visor issue - they get loose and hang down in the driver's way. Have you noticed anything different about the '09 sun visor design? Plastic on plastic is never good for the long haul.
I appreciate your comments - thank you!
First off, I have no experience with an "S" model yet if you get out of my wife's 09 Mo with the fob and the engine running it starts beeping at you like crazy. Yours does not??
Second, the Nissan V6 is "relatively" quiet, yet if you can get out in a/your garage and walk next to and around the front of your car and not hear that it's still running,,, I would worry more about my hearing.. Then I would go out and purchase a CO2 detector that was "really" loud. :P
I too have never read or heard of any one else having this issue.
Seriously, I'm messing with ya but am curious if yours really doesn't make any beeping/warning noises if you walk off with the fob and the engine running?
Cheers
Secondly, sounds like someone has the most spacious garage available... we do not. we cannot walk around the front of our car... we barely have room to get the car into the garage. the engine is wonderfully quiet... and having been driving for 40 years, the new technology of the Start/stop button would be perfect if one also did not have to use the fob at the same time... it actually adds an additional step to turning the engine on and off... so when we "old timers" pull the fob out, it feels like we have turned the engine off with a key... which explains why my husband left the engine running for 3 hours after he parked at the train station... Nissan told me there is no repair possible, no upgrading the ignition to the LE model type, no warning signal to be installed. they suggested i put a note on my dashboard to remind me...hope i have corrected your information
a faint beep...not on mine. shouldn't the dashboard message say ENGINE ON or TURN ENGINE OFF? Do you know if your engine would have turned itself off after five minutes or would it stay on?
i'm usually half way out of the car when i take the key out so i'm not really looking at the dash.... seems Nissan is much more concerned about telling you your door is open or your headlites are still on then reminding you that you might be asphixated ....
As for the IPOD.... Hopefully an aftermarket or factory IPOD adapter like found in the LE will surface... Many an owner looking for the answer to that question.
Cheers
I too have the 09 LE and vibration problem. The dealership did 2 balance jobs and the vibration is still there.
I took it in several times and each time they would balance the tires and send me on my way. It wouldn't fix it so finally on the third time I told them to do a little more looking. About an hour later they called me up and said that the rotors were warped and needed to be replaced. I asked about retooling them, but they said they were too worn for that.
So I picked up the car and then got the rotors replaced and the car was perfect again. Couldn't believe it was such a simple fix. With that being said it could be your rotors giving you the problem. I'd take the car in and have them check. If it's a new car they should be able to fix it or replace the rotors in no time.
So today when I went in for my first oil change at 3250 miles I had them check the rotors... and get this... They needed retooled! At 3250 miles. I'm not happy about that already, but the service manager told me that "rotors these days are made with crappy metal from crappy China". He also said that this problem occurs with all manufacturers, but at 3250 miles? Come on that's crap.
The guy wasn't lying to you. Unless you purchase a vehicle with very high dollar performance brakes/rotors, you are bound to have "warped rotor" issues during your ownership. Some happen right away, some after 10s of thousands of miles. Much of which is caused by braking/driving styles and or driving conditions etc.
My wife's 09 Mo seems to be doing great at the 12K mark yet my Acura rotors warped before 5000 miles. Our 4WD Suburban had 90K miles before I even touched the front brakes - and it pulls a 6000lb boat!... You just never know. Many times the rotors will last much longer after machining. The initial miles and braking heat bring out the metal stresses then machining removes the results.
Overall, crappy rotors/metal is a true statement and a fact within the industry....
Cheers
silly question, but i got exactly what i wanted: SL, premium pkg, leather pkg, 360 pkg, AWD. tinted bronze with beige leather.
paid 33500 and got "excellent" rating for trade in per KBB.
i know it's a supply/demand market, and i know it's MOST important that i'm happy (which i am regardless, this is a deal i can manage), but does this sound like a good deal? i was just surprised that i didn't have to haggle more when i said "this is what i'm willing to do" - especially when it was a car "en route" - thoughts?
Murano LE FWD model added
Leather Package and Moonroof Package availability widened on Murano SL FWD
Privacy glass added on Murano S (now standard on all models)
Intelligent Key added as standard on Murano S and SL models
Simplified exterior and interior color combinations
Vehicle Security System added as standard on Murano SL
Dual Panel Moonroof now standard on Murano LE
Roof rails now standard on Murano SL
