Visitor Agreement.
We put the old IAC motor back on but now when testing it it isnt working. Above the IAC motor on the ERG Valve (i think) are several wires. 2 sets of them and they are disconnected from the connectors. The wires (2 sets) are taped together and not connected to the terminals. Been this way since I bought it and never had a problem. It runs to the vaccum. Not sure if this is related.
When we spray starter fluid in the intake, it still wont crank. Its not a fuel issue.
Stuck now- not sure-
i think it is air intake also- does crankshaft sensor involve that?? or MAP sensor?
will re- convene tomorrow!
Thank you so much!!
Oh, by the way, if your check engine light is coming on, it's a SMOG issue, that's what that particular "dummy" light is for. Which tells me that you have an air issue for sure. Check your EGR valve. It should be on the other side of your throttle body then your IAC was. You should be able to just clean it out, replace the gasket and see if your car starts. And even if your check engine light is going out, there is still a problem, your engine's computer temporarily corrects or compensates for problems, that's why it goes out, but the longer you go without fixing the problem, the longer the light will stay on and the more often it will come on.
Gotta tow it to the shop now. Been way to long not running. Any other ideas?
I will check Mass Air Flow Sensor
I have replaced the fuel pump. fuel pressure regulator. idle air control. map sensor and the crank sensor. It want start at all now even with starting fluid. I have a Haynes manual and it says that the crank sensor is suppose to produce 2.5 volta ac, The one I have is only producing .3 volts ac and i got another one and it is the same. The brand is a borgwarner. Is it possible that I need to get one from ISUZU?
Please help.
The fuel filter was replaced about 6 months ago, but I was thinking about the MAF or O2 sensors.
Unrelated...but we replaced the OEM shocks with Monroe SensaTrack on Saturday...amazing upgrade in ride quality and handling.
Right now I can start it and it runs fine, but in the past, I have had it die on me while I was driving on the highway. I have replaced the fuel pump with another one from a '96 or a '97 rodeo and when i turn the key to the start position or to the position where it doesn't start the car but turns everything on, the check engine light comes on and I can hear the fuel pump pumping. Once i start it up, the check engine light turns off and it runs fine.
But every so often, when i turn the key to the on position, the fuel pump wont pump. And it will stay like that for a while. It is quite unreliable and I would like to find out more. I was thinking of just rewiring the fuel pump cause it might be a bad connection but I don't want to have to pull off the fuel tank for the third time.
Please help. Thanks.
Thank You!
IMG replacement and cleaning and it's running like a new truck. It has a little desire to stall when I put it in Park, maybe the EGR valve. I hope this doubles or close to, my fuel mileage, was only getting 200 miles to a tank.
Anyone had the same issue? Any advice?
thx
Jess
The transmission shifts fine and everything. Don;t know what is the electronic problem. I changed spark plugs, computer and some fuses, but nothing changed.
pls help with this problem.
jim
If I pour a little gas in the throttle body, it will start right up and keeps running. However, it will usually stall just around the transition to normal running temperature. Sometimes it will restart and sometimes I have to pour a little gas in then it immediately starts and runs. I might go through this 7 or 8 times sometimes before getting it to run. During this time, if I put it in gear, it will normally stall. Eventually, it will restart without the assistance of having gas poured in. When it does this, it will run with no more problems. When it finally, fully reaches operating temp, it's perfectly fine. No problem with stalls, restarts, strange idle, surges, nothing. It runs great. I have never gotten a check engine light and according to a friend of mine with a code scanner, there are no codes stored.
The problem seems to be a little more prevalent in colder weather, but does happen in all weather. It will also occasionally give a check trans light. When this happens, as soon as I slow to about 10 mph, it stalls and will not restart without having the gas poured in. This also normally occurs before reaching normal operating temp but has happened at normal temps.
This vehicle has 230,000 on the clock. I have replaced the rear end once, probably looking at replacing or new bearings if the pin bolt isn't broken, again pretty soon. It has all the normal stuff for a 20 year old car, rust in a couple spots on the body, normal rattles, most bearings in the engine rattle, uses a little oil, leaks a little oil (not much), driver's seat is beginning to wear out.
The only real problem I have is this starting issue. I haven't found a posting anywhere that really covers this issue. So, I am hoping that someone has an idea where I need to go from here to solve the problem. It's a pain to sometimes have to take 10 to 15 minutes to get out of the yard.
I have replaced the fuel filter, plugs, rotor, dist cap, wires, checked vacuum hoses, MAP sensor seems fine, tried gas from different stations.
Thanks for any help anyone might be able to give.
Steve
As for that vacuum line with no hose, did it make a difference when you capped it? That darn line has baffled me for years and my Chilton Guide doesn't seem to say anything about it. I am just curious.
The fuel and vacuum lines for the tank run on the passenger side of the 97 rodeo. Our manual nor the vacuum diagram show that line. I just capped it.
The only thing I can think of is that it goes to the transmission vent that sits in the corner of the engine compartment on the passenger side, but I highly doubt it.
your car sould start.. then run for a few min.. then stall again...????? mine will do this and then after 2 tries will not restart again for about 4 hours...
ANY GOT ANY ANSWERS???????
