GMC Envoy keyless remote problems
I own a 2002 GMC Envoy. Not sure what happened but all of sudden I can not use my keyless remote to lock or unlock my doors. I checked the batteries and they are not dead, but I can not open the back hatch or use the back windshield wiper or rear defrost. This happened once before and I thought I corrected going through the computer program for Driver 1 and Driver 2.
Please help.
Please help.
James
Renee
Have you had the dealership check the key fobs to see if they have gone bad? Thank you,
Mariah GM Customer Service
:lemon:
What would really be helpful is if someone knows how the disassemble the latches and clean/relube the mechanism.
This past winter (Michigan) was very mild. The remote issue (and the others) would go away for days at a time but always come back when it got cold. Since it turned warm a few months ago everything has worked fine.
It's evident this is a common problem, like the instrument panel and headlight failures. I'm sure GM is aware of all of them and knows exactly where the failures occur and how to fix them properly. Unfortunately, instead of owning-up to their engineering and/or supplier eff-ups, they insist you take it back to a dealer charging $75/hour...plus outrageously over-priced parts and "shop supplies".
