I'm thinking a dealership will charge me to turn off the light.
Erik Haan
Leave odometer on mileage reading. Turn igntiion to "on" but do not start while holding down the odometer reset knob. Keep pressing knob until the odometer digits flash a series of dashes and stop. Release knob and turn ignition off.
The Maint Reqd light show now be reset for 5000 miles. (I think that each dash displayed is 1k miles, so if you want an earlier reminder, say 3k , you can let go of the reset knob earlier. You cannot set an interval longer than 5k miles though.)
I had no idea.
thanks,
FYI: Still still at the Toyota Shop (I now have it longer then I have ever drove the new car) :lemon: :lemon:
It took a couple of weeks to get use to this new steering since I previously drove a Malibu and it felt 100% different on the road.
I've taken several long trips and now I really enjoy the way the Corolla steers and handles. No problems with drift as discussed before.
:mad:
We have almost the same problem with our new Corolla (2009). Toyota service told me it a normal steering (issue) problem with this year of car. So far there is no fix that they can do. I think I am driving a shopping basket at 60 mph speeds. My car wanders all over the road.
I too have a problem with my "EPS" on my 2009 Toyota Corolla. I drove 4 of the same model and year. The one I have pulls to the left or right when going about 40-60 miles in hour. Toyota says nothing wrong. But they can't supply me with any specs. They just write down it's ok. But I am really scared me or my wife will crash. I pray others report the issue on http://www.safercar.gov/ .
Last month on Jan 19, I posted a question in regard to engine area noise on the left engine side of my 'S' model. At the time it had 8,500 miles on it. This noise developed over time, starting small and became far more annoying. Like you, I did not hear it sitting still or at high speed. No one on the forum had a good idea at that time what it might be, and I knew it was not the engine, transmission or the steering. So I dealt with it for almost another month.
Two weeks ago on a first time around test drive the service manage for my dealer did not hear it.
Last week at the 10,000 mile service I asked for the car to be closely inspected while it was up on the lift. It took three 'techs' to figure it out but I believe they have it, and have seemingly fixed the issue.
This is where it was; in the suspension. Parts replaced were: strut absorber assembly, support sub-assembly, and the dust seal.
My adivce is to try to eliminate what you know it is not, and go from there. Be persistant and I'm sure in time your serivce department will be able to work out what it is. Let us know.
Ed :mad:
Can you please provide us a link to the NHTSA.GOV page where we can file complaints?
Erik
:mad:
now even though they were down AGAIN for Feb.
another 40% from last yr.
They reduced the Corolla rebate from $1,300 to $1,000.
The showrooms are still like ghost towns. Stopped at
mine last week and it looked just like it did in Jan......empty....the only customers there were the
ones sitting in the service waiting area....all 3 of them.
Salesperson said he's never seen anything like this.
On another note the new car issue of Consumer Reports for April has very favorable things to say about the 09 Corolla and lists it as one of the best new cars under $20,000. It's also a recommended model in the Profiles section.
Those that wait for the 2010 Corolla will get the Vehicle Stability Control (VSC) standard which reduces the risk of a fatality in a serious accident and will be mandatory in all vehicles by the end of this decade.
I had a steering problem with mine. It cost me about $1000 and now I am happy with my 2009 Corolla. Some of the Toyota Corolla's steer just fine - others have a problem. I think they didn't use the same parts or change mid-year?
As for going from 09 to a 10 model they might as well open the window and throw out the first year's depreciation of about $1500-2500, plus the new
one that he just bought.
I will find the website but someone modified the EPS Power steering and made it much less responsive at highway speeds but I would be toooooo scared to hook up an computer to my car. So I guess a "firmware hack" and fix the response.
anyone thinking they have the expertise or experience
of a factory trained tech. using Toyota equip. to perform
a task as critical to safety as steering.
Reminds me of a plumber trying to remove a
brain tumor.
Anyways...I am having some issues with my new car, which I have had about a 2 months. I am trying to see if I am being too picky in general or if there is an issue(s) with the vehicle. I have taken it in once to have it checked and they told me it is fine. So I thought I would try another avenue.....
Here are the issue(s):
1. When I start the car in the morning it kinda chugs while still sitting in park. It only does this when I first start it while sitting in park. Sometimes I am getting situated in the car or doing whatever in the morning while it warms up and the "chugging" feeling over and over is annoying.
2. I have never experienced this on my other toyota's...but....When I am coming to a stop. The car will downshift through each gear (obvious I know but I am trying to be specific). As it dowshifts from 2nd to 1st (around 10 mph) it kinda shimmy's down into first gear. It is not a smooth transition. That is the best I can explain it. The other gears just downshift with one swift movement. However for some reason almost always.....it will "shimmy" when going from 2nd to first. I am also confused bec. it does this most times but not always.
3. Also during the stopping.....Right when the car is reaching the complete stop....the car kinda "shimmys" again. Now I notice while stopped the car kinda vibrates some, which seems normal. So I don't know if the last "shimmy" is due to the car going from in motion to no motion.....I dunno. This "shimmy" is very noticeable and sometimes I can feel it move (shimmy/vibrate) from the front of the car back. But it feels like something with the engine/motor.
Overall I just feel that this is annoying to me. lol. Each time I stop (almost always) I get a shimmy from 2nd to 1st then another shimmy of sorts right when I stop. I find myself so frustrated annoyed with it. None of my other toyota's have done this before.
I first wanted to see others' feedback to see if they have experienced this and perhaps it is just the way the engine/transmission function...or perhaps there is a true issue with my car. Either way I am looking to see if any of you are experiencing this.....or would know what is going on.
Regardless I do love toyota and happy with the product overall. It is a nice car...
SOS! What is going on with my car??? Thank you all!
Paul
Mine had a very infrequent engine stumble at idle after it was warm while in drive or reverse. After taking it in the problem has not returned since then. They only told me they made some "adjustments".
Here is an article on how to fix the issue, but it looks like you'd need to know a bit more than I do about cars to do it:
http://autospeed.com/cms/A_2390/article.html
I don't think messing with the steering can legally allow the dealer or manufacturer to void a claim on say the engine or brakes, but certainly could with anything to do with steering or the electrical system.
"Your brake rotors are gouged out because you changed a wire in your power steering"?
Or "AHA---THAT'S why your left rear door lock broke!"
I mean, you're right, they might TRY but I think one call from an attorney would fix that. Laws governing warranties are pretty specific and thorough.
Erik
