If none of those ideas work, you may have to have the car scanned for trouble codes, or taken to an AC specialist---perhaps you have an issue with the orifice/expansion valve (not sure which system your car uses).
The car is 4 years old and has 38,000 miles on it, but multiple actuator failure on the car just seems, well, highly improbable. Has anyone else experienced this or do I just have bad luck?
See: T-SB-0362-09
Rev1
October 14, 2009
KAT
Maybe you need to go the other way,
Any other suggestions? :confuse:
The Sandman
The car only has 14,000 miles so it is definitely covered under warranty.
https://www.surveymonkey.com/s/EdmundsForums
It's really important for us to hear from our members and visitors to get direction going forward. Only good things are planned for the future, but we need to gather insights to get there! Whether it's your first time or you're a regular, we'd love to hear from you.
MODERATOR /ADMINISTRATOR
Review your vehicle
I just brought a 2010 Corolla LXE and it has abt 32,000 miles and it's making that whistling sound that you are describing. The Toyota dealerships swear it's a normal sound and they must think i'm stupid to accept that answer.
I was reading one of your post stating that you have a pdf document to solve this problem. I was wondering if you still have it and if I can get it. My email address is masenmcm@yahoo.com. I'm sorry i couldn't find your email address to write you privately.
Thank you Kindly:)
Clean off the ABS sensor itself with a scotbrite pad or anything mildly abrasive like that. You may need to reset the computer but all will be fine now...... Grease, honestly.
My mother recently came to me with a similar issue. The first place I would check is your evaporator drain tube. These cares are notorious for the drains getting plugged. Sometimes it will even spew water into the passenger side floor. Do you have a musty odor in your car? I fixed my mothers by sticking a piece of string trimmer line into the drain tube.
My mother came to me with this same issue. Is the smell kind of a musty wet smell? After doing some investigating I figured out water was coming from the passenger side floor vent and giving off the stinky smell. These cars are notorious for the evaporator tube drains getting clogged with spiders and road debris. I fixed my mothers by sticking a piece of string trimmer line into the drain hole. You would not believe how much water came pouring out!
