Visitor Agreement.
state when, it does state to change the belt on the v8 at 90k. I called the dealer and they said they should be changed around 60k to 90k. Is that true??
Thank you,
sam
Does anybody know what the recommended break in period is for the 2005 model and the details to the break in period?
2005, no.
2006, yes.
"All 4Runner models include a reinforced center pillar for improved rigidity and increased thickness on the front windshield and front door glass for reduced wind noise. "
Also, MP3 player, Ipod connection, rounded fenders(above the wheels), power seats (standard on all models), new headlights and tailights.
If the manual says 90K, I would go with that. The dealer's best interest is to sell you one sooner than later.
To other's out there with the v6, need not worry, you have a timing chain.
If you don't need to pull something heavy, the V6 is very nice and not that much slower. It now has the 5 speed auto so there isn't much difference between the two except the 2-3 mpgs, 30 hp, and 200 lbs.
Consumer reports fair rating was based on a recall that Toyota had on the V6 in 2003. I haven't heard of any issues after the first 4 months of production. I haven't even heard people complaining about it on this forum, and people complain about the smallest things on this forum. The only complaint that I've heard is that some don't like the sound of a timing chain instead of a timing belt. The timing chain is a little noisier, but I can only hear it when my car is parked and idling. Plus the cahin doesn't need replaced at 90,000 like the belt in the V8, which is a $400+ service. A downside to the V6 is that it requires more frequent spark plug changes (recommended every 30,000), which are very easy to do yourself, but if you need a mechanic, then this will add a little cost.
The concern about a newer engine is valid, but realize that Toyota does lots of accelerated lifetime testing on new engines during development. Does anyone have any longer term reliability data on the V6?
The fact that the V8s are not moving off the lots very fast should be the first clue that, assuming the current fuel pricing continues, that the resale for the vehicle will be negatively impacted. So, if you don't get the incentive, you may end up giving that much away at your resale.
The four wheel drive system in the V6 is identical to the one in the V8 with the addition, in the transfer case, of the ability to disengage power to the front. This allows for slightly better fuel economy. It is perfectly acceptable to leave the V6 in 4Hi all of the time becaue the transfer case has the same Torsen limited slip differential that the V8 has. In this configuration, it is identical to the V8. Toyota has a reputation for unkillable transfer cases so I wouldn't be too worried that the additional complexity in the V6 will result in failures. Look at the forum topic on "toyota 4 whell drive systems explained" for a more detailed discussion.
The V8 is a nice, refined engine that you'll be happy with. Just expect to get 16 (or worse according to some on this forum) mpg in mixed driving instead of 18-19.
I have a 4 Runner 1994 4X4.
Last Sunday I was in a small road on the country.
I try to turn around and the back tires were on the grass (on one side of the road).
Beside the road was a dig that I did not saw because of the grass.
I try to use the L4 but only the rear right tire was spinning
The other 3 tires did not move.
The front tires were on the road.
The day was clear (no rein or nothing).
After some one helps me with another 4X4, I check the 4X4, and it is working. I can feel the 4X4.
Any idea why that happen?
It’s that normal?
Francisco Javier Banda
Fyi-most 4wd's have open differentials unless the vehicle was optioned (if available) with a locking rear differential. Most vehicles do not have a locking front differential as it's not an option.
It's not Prious numbers, for certain. But, am pleased with the fuel economy as I was expecting much less.
If you figure your mileage based on the odo and a fillup, you have to adjust the mpg up by ~3% because the speedometer and odometer are slow by that much.
But the 4wd was engaged.
After the other 4X4 help me.
I moved the truck like 10 feet.
And I was able to feel the 4wd, The truck and the trasmission felt heavy.
I disengaged the 4wd and the truck was more lighter (like normal when I used just 2wd).
I saw in the 4Runner manual that I need to use at least 12 miles per month the 4wd
to keep lubricated the front diffential.
That can be the problem??
The auto locking hubs don't engage immediately when you throw the lever. You often need to be in 4wd before you get stuck.
Unless your front differential is acutally broken from wear and lack of lubrication, I'm not sure how that could have made a difference.
FYI - my 1991 Z71 Chevy also took forever to engage, but at least it had a dash light to tell you when it locked in. On a side note, my 1997 Blazer locked in right away!!! I never got stuck in that vehicle.
Also, follow the manual. It keeps the hubs sufficiently lubed. BUT, and this may be important, I thought that only applied to manual locking hubs, not auto-locking hubs. My 1986 4x4 Toyota P/U advised to lock in only the manual hubs for the monthly self lube job. It was not recommended to lock in the rest of the drivetrain, unless you obviously needed 4wd. Double check to make sure it applies to your setup.
This may sound dumb, but look under the vehicle and make sure the front driveshaft is there. I only mention this because you are positive it was in 4wd with no wheels turning. It wouldn't be the first time someone has had a driveshaft stolen.
Last but not least, if you do have manual locking hubs, your 4wd should have engaged as soon as shifted into it.
Basically, if you don't have a seperate switch or lever that is used to lock the center differential, then you have a part time 4wd system that should only be engaged in off road conditions.
You could test your 4wd by going out into an desolate field of some type and jacking your rear wheels off the ground and trying to drive off the jack. There are probably better ways to do it, though.
i had a 1996 4 runner ltd.which i sold several years ago to a friend.he has 500,000 kilometers(312,000 miles).the only repairs except tires and oil changes was a new starter and shocks.i also used to tow a 5500 lb. travel trailer.the motor and tranmission run as when it was new.the front brakes were replaced first at 80000 miles and the second at 220,000 miles.the rear brakes were changed at around 250000 miles.
sam
Rod
"The auto locking hubs don't engage immediately when you throw the lever. You often need to be in 4wd before you get stuck. "
Posible that was the problem (reason why did not work!)
I was already stuck (the back right wheel spining) when I engage the 4wd, and the
front wheels need to move (al least a little) to engage the 4wd.
I say that because when I un engage (remove) the 4wd, the light on the panel
show engage until the front tire stats rotating and the light go off.
Thanks in advance
