Visitor Agreement.
Great line...there are facts, and there are facts as you see them. You can believe whatever you like, but when there are no facts (those being observations made and documented by unbiased individuals) supporting your position, then I don't think Plato would lose sleep over it.
Here's an example of the lengths to which the hope of HHO working will drive people: An individual posted a question on "Ask the Community" about how hard it would be to replace the perfectly good fuel injection system on his vehicle with a caburetor, because HHO was showing losses in mpgs on his fuel injected system (imagine that!), and he was sure it was the computer messing things up. Just put in an old fashioned carb, and THEN HHO woould work...sure.... :confuse: :sick:
That's a "fact"? Sorry, wrong. Modern gasoline and diesel engines are VERY effective at burning over 95% of the fuel to completion (H2O and CO2). Only the very small amount of incompletely burned fuel is the target of all our pollution controls. Another "fact" bites the dust...
This seems more like a religious type of experience rather than tinkering with cars.
After we test the HHO kit, can we test the gas mileage on a '68 Wildcat?
This is the starting point for all the incorrect information about HHO. These values are the amount of mechanical energy each engine produces for a given amount of gasoline (or HHO, for that matter) or diesel fuel burnt. So a gasoline engine produces 30% of the fuel's energy as mechanical energy at the driveshaft. Of the remaining 70% of the gasoline's energy, 65% is lost as heat, either out the (hot) exaust pipe or the (hot) radiator. At most 5% of the energy is lost as incompletely burned gasoline (CO and hydrocarbons). Got it?
Well I must say you don't let scientific facts get in the way of your belief system. Facts bounce off your argument like rocks off an Abrams tank. :P
Huh. And here I've been letting my education and simple physics tell me I can't climb to my roof naked and fly away when all I should do is try to find out for myself.
1. The Wildcat uses 3X the gas to go the same distance as the Honda
2. The Honda's emissions (even at 1/3rd the dose) are chemically changed by the catalytic converter.
In fact, some new cars are so good in eliminating emissions, that the air coming to the air filter from the atmosphere can be dirtier than the air going out the tailpipe.
Actually you're right--at times this country was built on fraud, that's true. :P
But it's one thing the get taken in by something and another to keep running headlong into it WANTING to believe. Sort of like insisting that you COULD make a fortune by replying to that Nigerian email scam if only you'd put aside your silly caution. Dub Schwartz pops a couple of balloons at once today on the Alternate Route :P
However, the flat-earthers had a good excuse. There was no science to help them. But people who want to know if HHO kits work or not have plenty of good science to assist them in coming to the right conclusion.
They don't work because they can't possibly. You can't generate enough hydrogen, nor can you use the minuscule amounts you do generate. There's not enough energy in that little jar to light a match, much less propel an engine.
Okay then, tell us why this guy is wrong:
http://www.aardvark.co.nz/hho_scam.shtml
The majority of HHO boosters here are salesmen, wanting to convince folks they should spend their hard-earned money on something that has never been shown to work by an objective organization. I don't believe a group of salesmen, even if they outnumber me.
P.S.
Thanks for that web site, Shifty, it summarizes lots of points that folks need to know.
You can't throw a baseball into orbit either, because the numbers don't work. Your car's alternator does not have the power to generate any significant amount of hydrogen, and certainly not enough to double your gas mileage!
In other words, with your device you use more energy than you gain. That's another way of saying it doesn't work.
They stop coming here because they can never answer the questions put to them. All the scientific evidence points to such a device not working, and this evidence has been put on the table time and again. Much like you are doing, every request to provide evidence to the contrary is answered with "It works because I said so."
So yeah, you want to run lean as all hell and bump your timing radically to gain a few MPG, be my guest.
The energy density of hydrogen is VERY low compared to hydrocarbon fuels. The amount of usable energy in a 10,000--that's ten thousand-gallon propane storage tank filled with hydrogen at standard pressure is equivalent to the energy in about 45 gallons of gasoline. Do you really imagine the tiny wisp of hydrogen and oxygen fed into your engine from an hho bubbler is going to make a difference? Sure the hho will be burned along with yhe gasoline, but it's not going to make any significant difference in your gas mileage.
how 'bout showing some respect to your fellow man. Verbally beating up on anyone who doesn't agree w/you as a means of improving your self esteem is childish.
All I need is one, just ONE, HHO proponent to step into the light and PROVE that their idea actually works. We keep seeing these claims of up to 50% gains in mileage, or that someone did it for $38.
That's all we skeptics need. No $5000 "challenges". No addtional conditions like "you need to make this modification to make the HHO kit actually work".
One simple, verifiable demonstration that can be repeated will be all it will take.
But until then, you can bet that claims that this nonsense actually works will be met with the same skepticism as today's press release on the Bio-EnerChi Fuel Patch
Boy, I bet that "eliminating hydrocarbon clumping" will make HHO obsolete!
This is not like the magnets of the past. This patch uses energy to stick to the pump. It is not the same as, or even similar to, a magnet. The two use completely different types of technology.
Ooo... it uses ENERGY to stick to the pump. :P
Now according to the logic, I'm supposed to believe that because they said it, right?
(+)8 Degrees C to (-)15 every 4-5 days. I currently drive a 2000 GMC 5.3Lt Z71 pick up truck.
Question:
1. I am very interested in any technical wireing diagrams and info for the HHO
installation, and any engine tune up modes required.
2. With our Canadian temp's, other then using a coffee cup warmer for the HHO
unite, does anyone know of other links or suggestions.
rgds / your neighbour to the north
Is HHO alien technology or am I missing something else here?
Adding extra oxygen is basically what turbocharging and supercharging do--of course, that's in vast amounts of air (as it's neither pure oxygen nor it is atmospheric) , under pressurized boost, and includes other systems such as intercooling, lowered compression ratios and computerized engine timing management---all in order to protect the engine.
If you mean just opening the engine up to atmospheric "air" by drilling a hole in the intake manifold after the throttle plate, then all you get is a rough running engine and a very lean mixture. You might recall how horribly early emission regulated cars ran with "air pumps", back when they didn't know what they were doing.
If you mean injecting pure oxygen into your cylinders---ah, I wouldn't do that.
I'm not sure what Popular Mechanics article you read, but he didn't say there might be something to HHO. After testing the HHO kit he said:
"Before you HHO proponents start bombarding me with hate mail, chill. You may have some amazing anecdotal evidence that these systems work. But I'm not swayed by over-the-road proof unless the conditions are constant—the variables are too, well, variable. And that includes my own testing. There's too much noise in the data collection, statistically speaking, and quite a bit of room for experimenter bias. From considerable experience with other gas savers, I know even the subtlest change in driving habits can influence the results. I won't be convinced of any fuel savings until I see results on a dynamometer, where I can control everything except the HHO."
He also flat out stated: My fuel economy is exactly the same, whether the HHO generator is turned on or not.
He also spoke for an hour with an HHO guy who gave him the (what a suprise) news that "HHO injection is only an enabler for other devices and changes."
So we're back again to someone, ANYONE, who claims that these things work actually proving they work and not just syaing that they do. You can cite references to NASA reports and try to dazzle us with all the pseudo-science that you care to toss around. You can twist an article that show NO results from a fair and honest testing of an HHO into somehow saying "there might be something to it". It all means nothing until you demonstrate that it works.
Popular Mechanics is a reputable source. They gave it a go, and zero, zip, nada.
It doesn't work, and it really doesn't matter how many people want to think it does, that doesn't make it so, no matter how forthright and honest their belief is.
If there's more testing to be done, it needs to be done by those who are trying to show that it works, because they haven't shown that it does... and to leave you a small smidgen of hope... yet.
For my part I will be very careful in my testing. If my gas mileage goes way up, I'll report it faithfully and eat my words.
ADDENDUM: I am NOT going to manipulate my engine's timing or lean out the mixture in any fashion. I just finished taking that motor apart, thank you very much.
PS: This has nothing to do with Edmunds. This is my personal exploration.
PPS: I'm not going to buy the plans, because I'm not going to contribute to the hokum.
So it's either free or forget it.
My "opinion" doesn't affect the results of an experiment unless I deliberately lie about it. I have nothing to protect. I'd like to perform this HHO miracle and defy all laws of science. I'm up for it. :P
If your argument is that "it won't work because you don't believe it" then you've really sort of blown up your whole case IMO.
