Visitor Agreement.
Hey, I like Nissan's cars, but they ARE a little weak in the SUV line.
Since were slamming here. Lets talk about the great Mercedes. I remember when I was looking for a SUV in 2000, I read Consumer Reports. As I recall, the Mercedes SUV was like 150% worse than average on reliability, while the 4Runner was 78% better than average. In other words the Mercedes reliability was in the toilet.
http://mbspy.bacosys.be/mbquality.htm
I also considered the Nissan Pathfinder. Here are a few things I didn't like.
1.) Power Steering, not being speed sensitive, felt over assisted at highway speeds. It felt like my parents Buick, (not a good thing).
2.) Crash tests were OK to Marginal while the 4Runner was Good.
3.) Pathfinder had a small trunk and a small payload.
4.) No frame, but a uni-body. Some people desire a full frame, like me.
5.) Use of premium fuel, I didn't like paying 20 cents more for each gallon I used.
Now you noticed I didn't slam the Mercedes and Nissan on their boards, but since your visiting I felt it was OK to respond.
Question for Cliffy, or anyone else in the know:
While there I was eying up a Tacoma Double Cab with 4Demand 4WD. Two of the Toyota sales reps there swore that the Tacoma 4Demand has full-time 4WD capability, that you could drive it year-round in 4WD without any adverse axle binding, etc. Is that true? If so, that's great to know.
Bob
Did you know that the rear door armrest on the Pathfinder/QX4 is hard plastic??!! Cheap.
Look at Pathfinder's suspension components...cheap. Stamped steel front control arms. Wimpy shocks. Thin skidplates.
Cheap Unibody structure. Just does NOT feel solid when you close the doors!
Interior materials felt cheap. Hey, where's that rear legroom??
Payload sucks. Many quality issues. Oh yeah, can you even drive with All-Mode 4wd at highway speed???? Gear-whine. Cheap 4wd system. Sorry, actually, AWD system...that's right, all-wheel drive!
Oh yeah, how's your RESALE value?? Why do you think the Pathfinder with the CAR-based engine cost less than the 4Runner???????
Need i say more?
That being the case, and since there is a 4WD *button* on the transfer case gear shift, can you operate the vehicle in 2WD low range? The way it's set up, it looks as if you can?? If you don't put the 4WD button, but move the transfer case into low, it would seem that you would have a 2WD low mode. Is that incorrect?
Bob
Off-Subject: Intmed99, after reading some of your posts in the last 6 months, I am guessing you started a NEW 4Runner board for owners of the 4Runner. Are you part of the new 4Runner board or am I just making a terrible guess? Either way I hope www.toyota-4runner.org finds a good following.
I am Thai on that website. I would be more than happy to see a fellow 3rd gen owner on that board!
Also whatever Toyota rep told you that about the Tacoma was on drugs.
Arrugh!
Bob
Hope this helps.
Ken
Often, a wheel bearing that's gotten rough can be diagnosed by swerving the vehicle back and forth in broad arcs, so you load first one side, then the other. If the noise changes as you load, then unload each side, likely it is a wheel bearing. For example, if the bad bearing is on the left and you turn left, you're unloading the bad bearing and the noise will diminish.
Good luck. My '98 was a great truck. I hope my '03 will turn out to be as reliable.
-Karl
The first thing I think of anytime there's a problem shifting a manual tranny is that the clutch isn't fully disengaging. If the clutch engages when the pedal is very low in its travel, this is likely to be the problem. Try jacking up the rear wheels, engaging 1st or 2nd gear, then depressing the clutch pedal. If the wheels don't stop turning within a couple of seconds, you've diagnosed it. Most likely either a clutch bleed job or adjustment of the pushrod for the clutch master cylinder will cure the problem, although it could be a mechanical problem with the clutch itself.
I've cured problems shifting when cold on two cars by draining the factory tranny lube and replacing it with Mobil 1 75w-90 synthetic gear lube. The difference in one case (Porsche 944) was just unbelieveable. If Toyota says 75w-90 is OK for your tranny, I'd sure give it a try.
-Karl
Also, do you know the power rating on the 2002 4Runner Limited radio??
One other occurance that is common, the "U" shaped bracket that holds the clutch pedal assembly inside, is known to crack. This causes the linkage to not always completely engage. It feels similar to the shifter fork problem and as if the clutch just went out. The fix for this is a lot cheaper than the bent shifter fork. They just have to replace and weld in the "U" bracket. I know 2 other people that this has happened to.
I would think that the cold weather probably amplifies your symptoms, or at least until the vehicle has warmed up a bit.
2. I don't know
Sorry 'bout that. I'll let you know when I find out a time frame on the cladding.
http://www.toyota-4runner.org/showthread.php?s=&threadid=128
3rd Gen is mighty capable! :-)
Didn't indicate the cost $$
M
In any event, you may want to try sitting in the Lexus GX470, which has finally reached the dealers. It's mechanically the same vehicle, with several alterations to the bodywork, including a higher roofline.
-Karl
thanks for the feedback
M
Test drove the XC90 the same day I got the 4Runner. If they had one in inventory, I would have driven off the lot with it and never looked back. Safety features are absolutely amazing. Nav system was poor compared to Toyota (and Acura on my previous car). And even with all that twin-turbo horsepower, accel is mediocre with the 4-spd trans. Still, it's the SUV I'd buy for my wife. I think it might survive a near-miss with a tacnuke.
I looked at everything on your list except the RX300, plus the Acura MDX. Like I said, if not for the 2-3 month wait for the Volvo, I would have bought it. But I hadn't been in the 4Runner at that point in the day, either. Having driven them both I couldn't say either was a bad choice, but I know I made the right choice for me.
Stay safe!
Ken
steve d
steve d
Hope this helps.
Ken
Jere
As for off-roading, there isn't a lot of opportunity around here. My only fun is on the farm where I have permission to hunt and even that is pretty mild.
SV
initial impressions and comparison with my current 96 4WD LTD S/C with 56,500 miles.
1. I had trouble finding the emergency brake pedal (tiny) right off the bat.
2. The seat felt low but well bolstered; after some adjustment I found a comfortable position.
I loved the telescopic steering and overall feel and handling of the vehicle, it is very car-like
and better than my 96 Runner (with Bilsteins) and 02 Sequoia.
3. The interior materials were quite good but I am not a fan of the hard mottled plastics used
on the dash. They are about the same quality as in my Sequoia but inferior to those used
in the last generation 4-Runner.
4. Power was adequate but not as good as in my current S/C Runner especially in initial
acceleration but boy is it smmooooth!
5. I did not take it out on any major highway so my top test speed was about 50mph. At this
speed, noise of any kind was almost imperceptible.
6. The sound system was excellent, as good or better than in my 2002 Sequoia; far superior
to that in my current Runner.
7. Overall, aside from some of my subjective styling complaints, I found it to be a very likeable
vehicle. The handling was exceptional for an SUV of it size, weight and ground clearance and the V6 delivered silky smooth quiet power. IMO it is a much more civilized vehicle than
the model it replaces.
I guess the final question is; Am I willing to part with my current Runner for this new beast, be
it V6 or V8???? The answer is no (for now). I will wait to see what new features and improvements come out in the next couple of years.
sherry
Wasn't aware there was such a thing as a 10th Anniversary Edition, so can't help you there. However, I do have a couple of tips:
You're probably aware that your 4Runner has part-time 4WD, which must not be used on dry pavement unless you're driving straight ahead. If you use 4WD on dry pavement and go around anything more than the very gentlest of curves, the drivetrain will bind, possibly causing damage. You can engage 4WD at any speed below 55 mph (if you're going too fast, it'll beep at you and won't engage) and drive at any speed once in 4WD. But I'd wait until a rainy day (or go to dirt roads) to do the 10 4WD miles per month. I have to confess that I didn't always do my 10 miles per month and it didn't seem to hurt anything.
Your 4Runner uses wheels which are lugcentric, and needs a special adapter (made by a company named Haweka) to be used when balancing the wheels, such as when you get new tires or have a flat fixed. Toyota dealers are supposed to have these adapters, but they're very hard to find otherwise. In my experience, you're not likely to get a good wheel balance job if the adapter isn't used, and your truck will have the shakes.
Good luck with your truck. I sure liked mine.
-Karl
