Ford Fusion/Mercury Milan Hybrid
1246723
    coldcrankercoldcranker Member Posts: 877
    Replying to kdhspyder's post #150:
    Well, Car and Driver mag clocked a Prius 0-60 mph in 11.3 seconds. Thats very slow. In comparison, my '05 Freestyle goes 0-60 in 8.5 seconds, and its even considered a little slow. And since the electric motors and batteries weigh about 400 lbs, one could build an all-gas-engine Prius that comes in at 2500 lbs instead of 2900 lbs, which means a 1.2L or 1.3L engine can easily get the same 11.3 secs 0-60 times the Prius Hybrid gets now. And braking / handling would be better because of the more nimble weight. And it would be $5,000 cheaper. The light narrow body and small narrow wheels contribute a lot to the fuel economy, more than non-engineers might think. (My guess is you're not an engineer, kdhspyder.)
    kdyhspyder, this is the easiest argument I ever won.
    But to the real subject of this thread, the Ford Fusion is a much more robust car than the Prius. Fusion is roomier, more rugged, better in crosswinds, handling, etc. than the Prius, so Ford has done an excellent job. As for me, I wouldn't buy it since I don't do anywhere near 15,000+ miles per year, as I can get a 4-cylinder Fusion non-hybrid for thousands less.
    ral2167ral2167 Member Posts: 791
    Anyone know the actual release date of the 2010 fusion-- either gas or hybrid? thanks
    kdhspyderkdhspyder Member Posts: 7,160
    I was estimating the weight of the vehicle. Yes 2900 is more accurate.
    Even without the battery pack, two e-motors and PSD...but plus the weight of a traditional tranny the vehicle would likely weigh in at about 2600lbs which puts it slightly heavier than the Yaris and Fit both of which also use the 1.5L ICE.
    Because of it's extra size and weight, with or without the hybrid option, the Prius is quicker to 60 and in the 1/4 mile than the Yaris but not as quick as the the Fit. But that's more due to Toyota's tuning of the engines for Fuel Economy rather than for performance.
    The passenger volume of the Prius is significantly greater than the other two but the real kicker is that the fuel economy is far far better than the other two 1.5L ICE-only vehicles.
    Fit.......... 28 City / 35 High / 31 Comb
    Yaris...... 29 City / 35 High / 31 Comb
    Prius...... 48 City / 45 High / 46 Comb
    So dropping the hybrid option would essentially make the Prius into a Fit. Whoopee. The whole idea of the hybrid option is to improve the fuel economy.
    BTW all of them have normal 15" wheels which at the time they were designed 6+ yrs ago was the standard for that vehicle size. We'll see about the Gen 3 is debuted in about 5 min.
    Three other reviews including one here at Edmunds had the 0-60's at 10.2, 10.4 and 10.4 so it appears that the C&D driver forgot how to use the GO Pedal.
    See prior post about weight and engine size. That's what this tangent was about in any event. But that's all moot now. The Gen 2's are finished as of today. The G3's will soon be built with 0-60's closer to your Freestyle.....but getting 50 mpg.
    Yes your point about driving well under 15000 miles is critical. At that level it really doesn't matter which vehicle is chosen. Just choosing the most enjoyable one is all that matters.
    akirbyakirby Member Posts: 8,062
    Production starts in about 3 weeks. Probably hit dealers in March - no later than April. No word yet on the hybrid having a different schedule.
    The main point to consider here is the Ford Fusion Hyb will be a roomier, better handling, better steering, tougher alternative to the Toy Prius. Also, remember you can go up to 47 mph in the Fusion Hyb on electric power only, beating the Prius yet again. (One thing Toyotas, and the Prius is no exception, gets criticized for repeatedly is their numb, lifeless steering feel. I confirmed that common complaint after driving a couple of models. Toyota falls very short in that important driver experience.)
    The other thing to question is - if they can get such great mileage out of the Prius - why is the Camry hybrid so low? That's the real comparison for the FFH, not the Prius.
    Right, the Fusion Hybrid handily beats the Camry Hyb in MPG, and is styled better as well in my opinion. Car and Driver, Feb. 2009 issue has the Ford Fusion Hybrid handling better, too. Toyota is so far taking a back seat to Ford. We'll see if the next Camry improves, because it needs to.
    True this. With the FFH Ford has just hit an overhead smash into Toyota's court..it's up to them to react or lose the point.
    texasestexases Member Posts: 10,711
    A smash, yes, if Ford can make enough of them...
    gagricegagrice Member Posts: 31,450
    You can bet that Toyota will do everything in their power to undermine the parts supply as they did with the Escape Hybrid. They had common suppliers if memory serves me. And Ford claimed they were being held up by Toyota.
    bpizzutibpizzuti Member Posts: 2,743
    That could actually be a great piece of PR if Toyota sinks that low. However, it sounds as if a couple of new battery manufacturers are coming on-line in the States (well, assemblers maybe).
    AFAIK Ford still has to use the same Japanese suppliers it did in the past for the near term. But...it has already signed a supply agreement with Johnson Controls/SAFT of France to be their main client. When it comes on stream is anybody's guess. I'd say 18 months for full production for Ford alone.
    Oh, and who said that business needed to be fair? The business I know is kill, maim and crush...but do it with a smile and a handshake.
    Actually, I've always thought of it as more of a football game. You can get away with murder so long as the refs don't throw the yellow flag. Then you're gonna get penalized.
    I believe they're using a different battery supplier for the FFH (Sanyo??). They're still constrained by battery capacity though.
    How many TCHs did Toyota sell last year?
    larsblarsb Member Posts: 8,204
    For the 2008 calendar year, Camry Hybrid sold 46,272 units, a drop of 15.1% from the year before.
    The other thing to question is - if they can get such great mileage out of the Prius - why is the Camry hybrid so low? That's the real comparison for the FFH, not the Prius. The Camry hybrid does not get "low" mileage. It is a bigger, heavier, roomier car than the Prius, it is equipped like a luxury car, and it gets better mileage than all intermediates, save the Fusion hybrid. The Prius as I am sure you know is a dedicated hybrid, with comcommitant weird styling and very low hp relative to the Camry. The Fusion leapfrogged the Camry a bit...I expect the next Camry hybrid (the current one is several model years older than the 2010 Fusion) will show strides as well.
    Remember, too, that until we get cars on the road a "real world" drivers tell us the MPG the new Fusion/Milan is really getting, we don't really have good comparison data.
    Since the FEH is the best-mileage hybrid SUV on the road, it's not surprising that the FFH/MMH will have a strong number for it's size.
    I meant low in comparison to the Prius and the FFH. My point was that you can't compare the FFH fuel economy to the Prius because it's a different vehicle from the Camry/Fusion.
    dieselonedieselone Member Posts: 5,729
    One big advantage Toyota has is their hybrid's have been reliable. While I haven't heard anything bad about the hybrid Escape, the Fusion will be unproven. That said, I wouldn't be caught dead in a Prius. I don't need to make a statement. Hell, I love my '07 Expedition that I use to tow our boat and camper. The Camry Hybrid seems to be a good car, but to stale a driving experience for me. I've driven many Camry's and their steering feel is like a Buick, horrible IMO. The Fusion would be my pick, decent acceleration, with good steering and chassis performance, plus class leading FE.
    I read the C & D comparison and at least Ford seems to have something for their efforts. As usual GM is a mess as the Malibu hybrid is basically a joke. I'm thinking the Volt will to be to late.
    At $40000 the Volt won't even be a blip on the radar. It's too expensive, especially in this new world of diminished expectations and diminished credit availability.
    Ford, Toyota and Honda have it right. Get the hybrid technology into the vehicles that the bulk of the customers actually can buy. GM needs it's 2-Mode technology in the Malibu tomorrow, but it's at least a year or two away. GM has all of its efforts wrapped up in the Volt.
    The Fusion hybrid system is just an improved version of the Escape system. The Escape system has been flawless as far as I know - they're even being used as NYC taxis. If it hasn't failed by now I don't think it will. And there's no reason to think the Fusion will be any different based on it's track record.
    I agree with you, but the point I was attempting to make is that Ford does not have the reputation regarding their hybrids that Toyota has. It's been well publicized that Toyota's hybrids are very reliable. I'd say most people aren't aware of a hybrid Escape.
    With the 2010 Fusion, I think Ford definitely has a winner. GM still looks lost as ever.
    But Ford's overall reputation for quality is becoming widely known (finally), especially on the Fusion. So you have a vehicle with stellar quality and a hybrid system that's been proven in the Escape. I don't see a problem.
    bigtbigt Member Posts: 412
    I agrree and I am in about to go pre-order my Milan Hybrid. Going to sell my MKZ.
    bigt said: "I agrree and I am in about to go pre-order my Milan Hybrid. Going to sell my MKZ."
    Smart move. Fun one, too. I'm guessing you'll have it in another 4 months. The delay will be caused by the glowing Feb. 2009 Car and Driver test review of it spiking demand.
    Well, the upcoming Honda Insight got its first test from Edmunds recently. Its small like the Prius, and has even wimpier wheels/tires, 15" 175mm wide tires. The Prius has 15" 185 mm tires. They're now saying they expect the Insight to have EPA MPG figures of about 40 for both city/hiway, about the same as the Fusion. The Fusion hybrid will be a roomier, larger, more useful vehicle for those that need the interior space, and the Fusion will be safer (larger vehicle). The Insight will be priced much cheaper than a Fusion or Prius, so there is an advantage there.
    Plus, contrary to that report, the Insight will get significantly better mileage.
    Huh? Contrary to the report that it will get about the same mileage as the Fusion, it's going to get more? Based on what information exactly?
    http://www.autoblog.com/2009/01/11/abg-first-drive-2010-honda-insight-63-4-mpg/
    Ratings will be higher than Fusion (as they should be...smaller, lighter, less powerful), and careful driving should net you 60 mpg.
    Ford Fusion Kicks Tail among family-hauler hybrids
    Ford has a weiner.
    Ford has pulled off a game changer with this 2010 model, creating a high-mpg family hauler that’s fun to drive. That achievement has two components: First, the machinery is unexpectedly refined—call it Toyota slickness expressed with car-guy soul. Second, the electronic instrument cluster involves the driver, invites you into the hybrid game, and gives you the feedback needed to keep increasing your personal-best mpg number.
    Or you can say the heck with it and opt for a minimum-distraction display that shows little beyond the speedo.
    No matter which you ultimately choose, you’re welcomed to the game with green grass and blue sky, a dashboard notion so corny we would groan if it weren’t so vividly executed. Hybrid enthusiasts will select the expert screen. All eyes sweep to the power grouping that shows the level of battery charge beside two columns of discharge meters, one for power consumed to propel the vehicle, the other a sum of all accessory loads (lights, fans, air conditioning, stereo, etc.).
    How far can you go without the engine? That’s the game. Easy on the accessory loads, of course, but whenever you’re moving, the propulsion meter gives you an EV bracket. Keep your propulsion power within the EV bracket by modulating the “gas” and you’ll drive on the battery, up to 47 mph under ideal circumstances. Call it a video game to go.
    Under normal driving, the engine starts and stops far more often than in the other hybrids. It comes and goes stealthily. Your wife won’t notice, and you probably won’t, either, unless you’re really into the hybrid game.
    Nothing about the leather-lined test car, optioned up from its $27,995 base price to $32,555, seemed economy minded except for the mileage readings. On that score, the Fusion topped the others, turning in a 34-mpg score card for the overall 300-mile test run. It also finished highest in two of the three specialized tests, with a 34.3-mpg mark on the rural loop and 36.9 mpg on the city loop. Official EPA fuel-economy numbers are 41 mpg city, 36 mpg highway, roughly 720 city miles between fill-ups. For a four-door with civilized room for five, that’s a standing-O achievement.
    Though the Fusion gets out-hustled by the Altima and the Camry—at 3805 pounds, the Ford is the heaviest of the four—we think 8.5 seconds to 60 mph is just fine considering the fuel economy. All of these players were too tightly grouped in braking and roadholding to draw significant distinctions, but for the record, the Fusion did tie with the Altima at 0.80 g for top marks on the skidpad. The suspension feels nicely taut, well planted. The tires communicate more than the Camry’s and speak in tones more refined than the Altima’s.
    As in the Altima and the Camry, the power delivery of the Fusion’s CVT is hard to hold steady in cruising conditions. The test logs include many comments about “surging.” Engaging the cruise control deals with it every time.
    Ford really hit all the marks with this hybrid Fusion, combining excellent fuel economy with slick manners and an engrossing personality. Fun and fuel economy have finally gotten married in a mid-size sedan.
    Likewise fewer and smaller battery packs storing less energy, which hurts fuel efficiency. It's a tradeoff. Their more "normal" drive got them 44 MPG. That 60+MPG figure was what they call an 'efficiency drive" which was a Honda-designed 16 mile loop (which means it was designed for the Insight to get REALLY good MPGs, probably with the hills set up so that it re-gens exactly enough battery power to get up the next one or something) and A/C was unnecessary.
    Basically we have to see what the EPA says. That's the ultimate level playing field, where the vehicles are tested under the exact same neutral conditions. Though i have to admit that Insight is one sharp-looking vehicle; MUCH better looking than the Prius. And I do like hatches.
    I may put this up against the I4 Fusion...though the Fusion has Sync. :shades:
    The Fusion and Insight do not really compete. The Fusion is a mid-size (more than a foot longer and 1,000 lbs heavier) and so is roomier, faster and quieter. Trade-offs are much higher price and lower mileage. Yes, when pushed, the Insight "only" got 44 mpg. When driven normally, the Fusion got 34 (see post above yours). When driven for economy, the Fusion has seen high 40s. The Insight when driven that way, will go to mid-60s. Both are great figures for the respective size of the cars. But obviously and for good reason, the smaller, lighter Insight gets better mileage.
    It's going to be next to impossible for anyone to get 60-ish mpg in an Insight for any long period of time or of driving. The technology is the same as the HCH except that the e-motor is less powerful ( less capable ). Yes the vehicle is more aero and may be somewhat lighter but neither is going to jump the fuel economy from the low 40's to the 60 mpg range.
    After some months and millions of miles of driving I'd expect the Insight II to be just at or just below the HCH real world numbers of 43-45 mpg day-in and day-out.
    Now even if the Insight II does 'only' get 42-43 mpg overall it will exceed the FFH values overall by 10% or so. However the key point is that it will cost $8000 - $10000 less!!! The two vehicles are not targetted toward the same demographic segments.
    The Insight IMO will be a HUGE hit and put a real hurtin' on GM and Ford and Toyota and Mazda and Nissan because it will hit them squarely in the middle of their compact car segment where the Corolla, Focus/Fiesta, Sentra, Accent, Mazda3 and Cobalt live. Honda's gain in the Insight II will come at the expense of these non-hybrids, not the Prius or FFH or TCH.
    It's going to be next to impossible for anyone to get 60-ish mpg in an Insight for any long period of time or of driving. Well of course that is true, but you keep missing the point! It will also be next to impossible for the Fusion to get high 40s for any long period of driving. Mid-30s will be more like it...and that is darn good mileage for any mid-size.
    And no, the Insight will not put much hurt on the ICE compact sales, because while it is the cheapest hybrid, it still costs more than a Corolla or Sentra or Accent. You can buy a lot of gas with the difference in prices. In addition, there are at best only 100,000 available for US buyers. It's another choice and choice is good.
    kdhspyder said "However the key point is that it will cost $8000 - $10000 less!!! " ... No, the Fusion Hybrid will be $27,000, and Honda says it is "trying" to bring the new Insight in at $20,000, so thats $7,000 diff.
    The Insight is a good compromise from a real car, I admit, for those that don't mind the skinny tires and SLOW acceleration (0-60 mph in about 11 seconds, a snail's pace). The Fusion Hybrid is a real car, not wimpy.
    kdhyspyder also said "The Insight IMO will be a HUGE hit and put a real hurtin' on GM and Ford and Toyota and Mazda and Nissan because it will hit them squarely in the middle of their compact car segment where the Corolla, Focus/Fiesta, Sentra, Accent, Mazda3 and Cobalt live. Honda's gain in the Insight II will come at the expense of these non-hybrids, not the Prius or FFH or TCH. "
    Actually, you can get a new Sentra right now for $10,000, half the price of an Insight. Comparably equipped, the Sentra with automatic and air, will come in at about $13,000, much cheaper than a maybe-$20,000 Insight.
    Still, as Ford's Fusion Hybrid deserves the most credit here for how they are stomping the Camry Hybrid, Honda and Toyota are providing the Insight and Prius that are cheaper to buy than a Fusion Hybrid, so kudos to them. The winner will be the consumer.
    All that being said, I'd still rather just buy a 4-cylinder Fusion with automatic and get my 33 MPG EPA hiway mileage, and save the $7,000 into a CD, the diff from a comparably equipped Fusion 4-cylinder and its Hybrid cousin. For some, they will want a hybrid, and if you do over 15,000 miles per year, you can make the difference up. However, with a hybrid, you will sacrifice braking, steering, and some safety performance with all those expensive, heavy batteries under your butt. With the addtion of direct injection and start/stop tech in a standard Fusion, you can boost the MPG another 10% anyway for an additional $900 of equipment, so hybrids just aren't the future for me.
    My understanding on the Insight II prices are that Honda will start them at $18500 and range them up to ~$23000. At $18500 that's right in the middle of the Corolla, Civic, Mazda3, Focus, Cobalt,Sentra pricing.
    $13000 Sentra's are loss leaders at best. That's not truly indicative of the market price for this model. If so that would put the Versa well under $10000... Sorry can't buy it.
    Yeah, I think I said Sentra was currently $10,000, but I think I mean Versa. I was confused. There was a big push by Nissan recently to have the lowest priced car in America, and the Versa came in at $10,000, a good buy.
    It is NOT in the middle of Focus, Cobalt, sentra pricing. It is very much at the high end of compact/subcompact sedan market. Sure, you can pay over $20K for a Focus, but almost no one does. And remember, the Insight is not as large or as roomy as a Sentra or Focus. It is subcompact in size (based on the Fit), has subcompact hp, wheels, tires, etc. It is more expensive precisely because of the hybrid equipment.
    gregg_vw, I agree. I think you can get an '09 Cobalt with automatic, air, traction control, and ABS brakes as the only options, for about $17,000 (edmunds.com price). Thats actually kind of close to an Insight's projected estimated price in the future. There is not a great deal of difference in the prices, but there is about $3,000 worth!
    Bottom line, if a consumer can live with snail-slow acceleration in the Insight/Prius, either one, then those might be a good choice. The Fusion Hybrid (191 HP, 3700 lbs) accelerates 0-60 mph in about the same time as my '05 Freestyle (203 HP, 3900 lbs), which is 8.5 seconds, instead of the slow 10 or 11 seconds it takes an Insight/Prius to meander to 60 mph. Also, the Fusion Hybrid will handle best.
    I bought an 08 Suzuki SX4 Crossover last April with AWD, stability control, traction control, brake assist, keyless go, climate control, and all the usual power options, for less than 16K...and you think that an Insight at $18.5K to $22K is going to take over sales of FWD compacts (which do not have stability control, AWD, traction control, etc.) starting at $13K? Excuse me, but what are you smoking?
    gregg_vw, Whoaa, slow down there Skippy. You must have me confused with kdhspyder (see posts above). I was just saying the Insight will be reasonably close to some comparably-equipped FWD vehicles out there. I cited $3,000 diff between a Cobalt and an Insight, and some may consider that reasonable. Prius sales have been good, and people have paid many thousands more for it than Corollas. I'm also saying many people will pay that to get in on the hybrid band-wagon. I'm more of the opinion I'd rather buy a $15,000 or so FWD small car that gets decent MPG before I'd want to pony up the extra thousands for an Insight or Prius.
    The subject of this thread is the Fusion Hyb. It will come in at $27,000, so people are going to have to add a lot to the normal Fusion's (comparably equipped) 4-cyl version coming in at a mere $20,000. This is somewhat of a problem for me, but not for many people who crave hybrids. The Prius/Insight discussion gives us some perspective on what people are willing to pay extra for all those batteries and electric motors in addition to a gas engine and transmission and extra computers to run it all and the extra weight, performance penalties.. whew!
    Your perception of the market is off, sorry. The Insight II is a Honda Fit with a $1500 hybrid option. The Honda Fit was sold out and oversubscribed @ $17000 MSRP until the recession hit us over the head. A $1500 option for 42-45 mpg day-in and day-out is a small upcharge and it fits ( ewwww ) right into the expectations of that buying segment.
    Yes if you look at the price through the eyes of the most hardnosed frugal buyer that won't buy unless the final price is sweating blood then yes the Insight @ $18500 is out of the question. But this is a HUGE HUGE market and if the Fit can be oversubscribed at $17000 MSRP the Insight II will also.....when the market recovers of course.
    Back to the FFH. This is the same good situation that Toyota has found itself in with the TCH. Fusion buyers range from $19000 to $30000. In this range there are enough who want to spend less on fuel to support the FFH. All buyers? Of course not. But there are enough.
    The good press that the FFH and Ford are getting will drive even more into the stores. Those that would consider a TCH at $27000 ( a very typical Toyota buyer ) will also shop this new guy on the block to see if the reports are true. You're viewing the pricing from the pov of a frugal I4 buyer looking to keep the cost of the vehicle as low as possible and still get decent fuel economy. Now look at it from the pov of a V6 buyer who wants some amenities, in fact would never drive or buy a base model, and normally expects to pay $25000 - $30000 for the vehicle. Now the FFH looks like a bargain. Look at it from the pov of one of the millions of Explorer owners who are now ready to dump their SUV that got 17 mpg. Those buyers always spent $30000+ for their wheels. Now for $30000 they get a loaded FFH and 38 mpg? They're in heaven.
    But it's a HUGE, HUGE market with a wide variety of price/value points.
    I think you're missing something here....if someone is looking for a V6, many are looking for power in most cases. Another large portion are looking for the artificial self-worth that comes from a "V6" badge. How many out of those two groups would consider a "greenie weenie" hybrid powertrain? THat is how some people think of hybrids still, you know (especially some of the ones who want that V6 badge).
    Admittedly, the rest, who are getting the V6 simply because that's the highest line trim out there would happily consider a hybrid powertrain as opposed to the V6, especially if the Hybrid trim matches the highest line as far as available options.
    A V6 buyer is going to be very disappointed in Hybrid snail-slow accel. While the Fusion Hybrid is nowhere near as slow as the Prius/Insight, its not nearly as good as a V6 Fusion. I drove an '08 Fusion V6 recently (221 HP, 3300 lbs) and it was FUN. The Fusion Hybrid can't equal that driving fun. So, yes, the V6 people out there do seem to be looking for power, not fuel economy, 2 opposing things when shopping. As for me, my breaking point is 0-60 in 9 seconds. I just don't want a vehicle that is slower than that, since its just too slow to pass other cars, to merge on to a busy freeway, to go uphills (Rocky Mountains nearby), and to have some reserve power when loaded up with gear and people. My '05 Freestyle does it in 8.5 seconds with a sweet hybrid-like CVT, so its in my sweet spot for the balance between fuel efficiency and adequate power.
    In summary, the typical Fusion Hybrid buyer will see its relatively slow accel as acceptable, looking for a good handling, robost hybrid with great MPG.
    That's where you err on the side of too little flexibility. This is a huge and diverse market. You are trying to pigeon hole everyone into tiny little places. I've been selling these since 2000. I've met thousands of real and potential buyers. There is no single size that fits all buyers. One of the reasons that some well-to-do people remain well-to-do is that they don't waste money unnecessarily. Getting a nice vehicle with nice amenities that also saves 50% of the monthly gas bill is a choice many many make. Some are just against paying Big Oil and the Mideast more more money than they have to pay. Some like the greenie aspect. But these buyers will not generally buy an econo-box or a strippie I4. They are used to nicer things and they are willing to pay for them.
    For whatever reason, when these buyers opt to choose a hybrid then $27000 is a bargain, $30000 is a normal to lower-than-normal price.
    I'm not talking about well-to-do people, or not just them, rather. But like it or not there are several people who shop for cars whose ego is measured in liters and cylinders, as well as HP and torque :shades: Those types are NOT going to see a hybrid as a value no matter what sales pitch you give them (ironically, they MIGHT have gone for the now-defunct Accord hybrid, except most wouldn't consider Hondas in the first place.
    I agree that it's a huge and diverse market, but in that market, the hybrids, while growing, are still a relative niche. Of course, when you get right down to it, every trim of every model is its own little niche (which fits in its own little pigeonhole with a few people) but that's beyond the scope of this thread.
    Granted. In fact, I think I mentioned that myself. But you've got whole other market segments that aren't even going to consider a hybrid, unless maybe it's a Corvette Hybrid. Or maybe a Camaro or Mustang Hybrid. Or something else with a lot of V6 badges, that go 0-60 in 7 seconds or less, with a cat-back exhaust and a grumble under the hood. That's just life.
    Then you have the others who like the general idea, but just decided that it isn't right for their driving style right now. Like me. :)
    kdhspyder said "Some like the greenie aspect. But these buyers will not generally buy an econo-box or a strippie I4. They are used to nicer things and they are willing to pay for them. "
    Strippie I-4? You can comparably equip a Fusion I-4 with automatic, air, traction control, etc., and still come out $7,000 ahead of a similarly equipped Hybrid Fusion. To me, thats too much, economically speaking. For some other people that think with their toenails, it might make sense. In reality, it only makes sense if you drive a lot of miles per year, or you want to stick it to the Mideast terrorists and/or Chavez, both good reasons really.
    So, if you want to strap 400 lbs of batteries to your butt and pay $7,000 for the privilege, be my guest. I'm sure there will be some.
    Yes there are certainly those that will not look at the FFH for a variety of reasons, not as much power as the V6, antipathy against the idea of hybrids, fear, normal reticence toward changes, etc.
    But since this is such a huge and diverse market there are also those buyers who hate Big Oil, hate the oil producers, want a loaded vehicle with very good power but excellent fuel economy, want to leave a smaller carbon footprint, love the idea of promoting new technology, are willing to give up some power for a lower overall cost, etc.
    All these variations are part of the buying public. You two may fall in the first grouping. There are however lots of buyers, enough to over-subscribe the vehicles, that fall into the second grouping. This is the brilliant marketing discovery that Toyota and Honda and Ford have made. There's money to be made here and in the end that's all that counts. This is just a business with the intention to make money and survive into the future.
    Oh, I wouldn't say I'm in that group...if my driving habits were different and I drove more city, I'd certainly consider a hybrid..I am a gadget-head. But I'd want a bigger MPG increase than I'm currently going to get with 90%+ highway driving, before I shell out the extra up-front money that a hybrid would cost, that's all. Reasonable request. Like I said before, they're not a cure all and they aren't for everyone.
    You know what would be interesting? A web-app where people can plug in the models they're considering, and their driving habits (city% and hwy%, miles per year) and their local gas prices, and it would give them an approximation of their fuel costs per year for each vehicle. Come to think of it, shouldn't be real hard, either...some of the guys at work may be able to throw something together.
