Toyota 4Runner
1126127129131132221
  • bcmalibu99lsbcmalibu99ls Member Posts: 625
    mrwhipple said: "The 16" rims would be better suited for off road [than 17 inch]. There is more rubber (between rim & road) allowing the tire to flex better over terrain."
    -------> Then why do off-roaders want bigger tires? Why don't they get like 13-inch tires, and want to get them as big as possible?
    I would think the X-REAS might hamper suspension articulation off road.
    -------> Or, it can prevent serious vehicle damage by not allowing the vehicle to lean on the side and strike obstacles
    We should have some off-road experts here, what's your opinion?
  • kbhockeykbhockey Member Posts: 29
    Just bought a 03 SE V6-black/grey cloth. Love it! Noticed the chirping/squeak on cold startup, will give it a few miles to see if it works out, else take to the dealer (TSB #??) otherwise, tight as a drum.
    Very smooth vehicle, good handling for a truck.
    V6 plenty of power.
  • oldnavycdroldnavycdr Member Posts: 17
    Any intel as to improvements coming in the V6 coming that will correct the belt squeals and the more catastrophic noises reported here? I'm debating over an end of model year '03 or waiting until September/October. Your thoughts, owners?
    As a slip owner near a boat ramp, some of my best summer entertainment has been to watch folks try to haul their boats out at the end of a weekend. Let me suggest that a 4WD is far superior, for even a smaller runabout than RWD. On most ramps the rear wheels will be in or under water on a ramps where moss and algae grow (regardless of the frequent traffic). Powered (and dry) front wheels avoid all the problems that have given me chuckles over the years. Can you get them in and out with RWD? Sure. But if you don't want the attention of nearby slip owners, go with 4WD.
  • grizbear1grizbear1 Member Posts: 4
    mrwhipple is essentially correct. I am an off-road enthusiast here in CO. Let's be clear on the difference between larger wheels/rims and larger tires. Larger rims, 17", 18", 19" mean mounting a lower profile tire to maintain the same overall tire diameter. A low profile tire in an off-road situation is very susceptible to rock and other obstacle damage. Also, in off-road situations it is easier to "pop" the bead on a low profile tire, less sidewall to work with. So, if you are unwilling to "lift" the truck to accommodate extra large wheels/tires, then a 16" wheel with a higher aspect ratio tire is better suited to off-road use. Of course, if you are willing to "lift" the truck, the sky is the limit, 17-18" rims with extremely high aspect ratio tires. That will give you a lot of extra ground clearance, etc. This does not take into account the change in speedometer readings with oversized wheels/tires, and change in performance for the transmission. Oversized wheels and tires are very much a purpose driven off-road customization.
    This is the same issue many of the Land Rover Discovery folks are having. With the '03 Discovery SE, Land Rover mounted 18" wheels with high speed low profile tires. Folks that have taken those vehicles off-road have posted on that board about experiencing flats. They have since looked to purchase 16" wheels and higher aspect ratio tires to maintain the same overall diameter for off-road use.
    I'm on the fence with regard to X-REAS. It will limit vehicle articulation in off-road situations which is bad. Articulation is not so much allowing the body to lean over and strike obstacles as it is trying to keep all four tires planted on the ground when crawling over rocks, logs, etc. Good suspension articulation is a must have in those conditions. Also, I should think the system would make it more difficult or expensive to "lift" the truck or modify the suspension package for heavy duty off-road use. A simple upgrade to Old Man EMU springs for instance, might be impossible with X-REAS.
    I am under the impression X-REAS is more meant for limiting body roll in cornering on-road. It tightens the truck up, makes it feel more like a sports sedan than a SUV. Like I said, I'm on the fence on X-REAS.
  • jaredmsdjaredmsd Member Posts: 127
    It seems that people are making the assumption that no one likes the body cladding. I know for myself, I love the body cladding on my SE, and I've talked to others who have taken it offroad, and they loved it too. So as far as 'SPORT' is concerned, I think it should be left on, or left as an option. Taking it totally away like some have suggested, doesn't make much sense when there are two other trims to choose from or when it can be an option.
    X-REAS and offroad, here's my take. I know you want articulation, and I'm not arguing that, but I am arguing that X-REAS really interferes with the benefits of articulation. In my opinion (and with my experience in this vehicle off-road) X-REAS helps keep all 4 wheels on the ground more than without. Since the shocks are cross linked, and most off-road techniques teach to go over high-centering objects at an angle, the cross linked shocks actually help. When the front-right tire for instance is going over the high object (being a rock or steep whoop-di-woo) then the back left is pushing against the lower ground, which is keeping the vehicle nice and stable (rockcrawler has a good section on the X-REAS in their review of the 4runner). I loved the X-REAS for medium rated terrain offroad. I'm sure if you are doing harcore rockcrawling where you need tons of articulation, you wouldn't be using a new '03 4runner anyway, but rather a '92 or something like a rubicon heavily jacked up, so that point is moot.
    -Jared
  • coranchercorancher Member Posts: 232
    Ah, that's one of the best things about these discussions. grizbear1's answer is impressively clear and concise, and very well balanced, IMHO. I think a little of the confusion about the purpose of the Sport edition is due to Toyota's marketing efforts, where they'd like to have it both ways. In terms of actual hardware (rather than perception) the Sport seems to me to be slightly tilted toward on-road use. Toyota is probably conflicted about the fact that most folks never really take these vehicles (even the 4Runner) seriously off-road, and only a tiny minority do it often. Nonetheless if you like the other features of the Sport, you can easily rectify the tire situation, though it wouldn't be very cheap unless you could sell off the factory tires/wheels at a good price. It should be said, though, that the profile difference between the factory 16" and 17" wheels/tires is small, and so there's not really much of a situation to rectify anyway.
    As for towing and whether to choose the V6 or V8, I'd suggest considering how much load and how often you expect to tow. If the trailer is substantially less than the max rating for the V6 (say 3000 lbs or so) and you don't expect to be towing for the majority of the time, the V6 should do very well. A proven transmission is a plus when towing, as towing seems to kill transmissions more often than engines. However if you expect to be towing much of the time and/or you want to tow heavy loads, it seems like the V8 (especially with the new upgraded hitch, whatever that is) is the ticket. I'd be comfortable assuming that Toyota has done a good job with the new 5-speed transmission. Also, heed the recommendations of others here previously in terms of towing and shifting practice. I've towed and pulled and driven heavy trucks a bunch in a previous life, and it can be a whole different form of driving if you're very heavy overall or near vehicle limits.
    As far as towing boats, I've also seen big problems at concrete boat ramps with 2WD vehicles. As a poster stated, having rear wheels on wet and on mossy concrete is a recipe for slippage and onlooker (but not driver!) entertainment. The limited-slip functionality provided by the traction control feature through braking of the lower-traction wheel will help, but having two front wheels pulling on dry pavement (even if they're not very heavily loaded) has got to be a plus. In addition, 4WD lo-range might be helpful in terms of a slow, easily-controlled start and pull. I haven't tried this myself, though, and the more-abrupt shifts in 4-lo (discussed previously here) might be a problem as you pick up speed on a slick ramp.
    Fuel grade and mileage: Please do some searches on this thread and you will find lots of good information. As a summary, though, I'd say that premium gets you the full rated horsepower of these high-compression engines (especially the higher-compression V6), but costs you $ and a little mileage. The engine is spec'd to adapt well to octanes as low as 87, so you should be fine there, if max HP is not a requirement. As far as mileage goes, I'm getting around 20 on a V6 in mixed driving, with a slight bias toward highway.
  • sacstate1sacstate1 Member Posts: 189
    I like the grey cladding on the SE also. It is easy to wash, wax and helps protect against road/trail garbage and parking lot door dings. I just hope Toyota doesn't eliminate this option/accessory as it would make my vehicle obsolete, or using a positive twist, make it a 'collectors' model. It would have been nice to choose the color (not painted) of the cladding, say perhaps a black, tan or darker grey cladding.
  • claddingsuxscladdingsuxs Member Posts: 11
    Its great that Toyota now offers the AP package on the SR5's but does Toyota have any plans to offer the AP package (port install) to those who bought the truck when they 1st came out? Seems to me that we all get slammed from behind. I bought this truck the week it came out which means i paid close to sticker. The same truck now has a $6000 discount at the same dealer where i bought it. No one wants the cladding since you can now get the AP package so they are discounting the cladding models like mad.
    To me it seems like Toyota doesent really care for those who paid top dollar for their trucks and just worried about sales. This was my 1st Toyota and it will be my last if Toyota doesent offer us the option to upgrade soon.
    You may not think it matters if i never buy toyota but im sure im not the only one who feels this way.
    jaredmsd, Good point on the X-REAS. I have to admit, I am not a 4Runner owner, yet. I will be when the lease on my Ford runs out in Sept. Oct. It's just a matter of timing for an '03 or '04. I am new to this discussion, been lurking a while, but wanted to answer bcmalibu99ls from a purely off-road perspective.
    What I know about the X-REAS is what I've read in reviews, on this board, and talking with the boys at the 4x4 after market shops. Guess I need to read the Rockcrawler review ;)
    Point well made about where would you take your new 4Runner. Definitely NOT going to Moab with it to rock crawl, get the old CJ out for that. So, your point about the stability of X-REAS in moderate conditions is well made. Just curious, and trying to get a point of reference, have you had your 4Runner on any trails in Colo.? For that matter, has anyone had their '03 4Runner on trails in CO, AZ, UT? If so, which ones? I would like to know where folks have taken their 4Runners off-road.
    corancher,
    Thanks. The whole thing about large wheels and low profile tires can be confusing. They are great on road, terrible off. The manufacturers really don't know which way to jump. Do they please the folks that want good on-road handling, or do they please the off-road crowd? There doesn't seem to be a good compromise. But, the 17" wheel and tire combo on the 4Runner is pretty close.
  • tfuzztfuzz Member Posts: 93
    Steve,
    Thanks for steering me to the thread on towing. I hadn't seen it before and find it interesting.
  • reddfishreddfish Member Posts: 54
    bkahn1, If you opt for the 2wd, just don't use the 14th ramps in Pompano.
    Yeah, I learned a lot in there too.
  • rward99rward99 Member Posts: 185
    Let me start by saying that the sales division will have the most current information, and I'm not with sales. I ordered an '04 based on information that was recently given to me. That could change before production starts.
    It's interesting about the "standard" for the cladding on the '03 SE. The information I received showed it not being available for '04. I'll have to check into that. I ordered the SR5 because I thought the SE had that gray cladding.
    The engine / transmission options for '04 are the same as '03', at least that's the information I have.
    >did you see anything about memory seats or hid headlights as a 2004 option ???
    No, I dont' see either of those as options.
    >Also, is the interior fabric changing in any of the models?
    No change; same interior colors
    I have emailed corporate Toyota and have my very reliable Toyota service manager asking the regional Toyota rep if an option will be available to grey cladded owners to change to color cladding. I even offered to pay half of the parts/install. Toyota reply, 'not at this time'. So, if enough grey cladded people contacted Toyota maybe something would be offered. My question to you....would you let the local Toyota shop guys rip apart your factory installed cladding. I can't imagine the fit and finish would be as tight and professionally done as the factory application? The dealer cannot even get out of my car during an oil change and not get black oil smear all over the kick panel, floor and steering wheel.
    Taking the cladding off and on is easier than you might imagine. Of the 10 gray cladding 4runners at the dealership i saw today, 4 of those 4 runners had their gray cladding color matched by a local paint shop. They looked great. The fit was prefect. So taking off the cladding and re applying it would not be a problem.
    I would rather go with the smooth fenders like that of the limited than to have my current fenders just painted.
    Toyota needs to do its best to offer this package to existing gray cladding SR5's. This will help sales i think. Most of the general public assume that the SR5 come only in gray and the colored only in limited. Not to many people can afford the limited so they dont even bother with the 4runner. The more the toyota can wash out the gray cladding SR5 owners...the faster the public can be aware that the cladding is gone ;).
    The same color SE versions that I have seen around dealerships still have the grey cladded ridges along the overfenders, they are not smooth. If you find out anything from Toyota....drop me a line.
  • intmed99intmed99 Member Posts: 485
    XREAS will NOT likely decrease articulation. First of all, shocks are rarely the "limiting factor" in articulation. Springs, anti-roll bars, and bumpstops are more crucial to articulation...not shocks. If shocks were the limiting factor, you will destroy it when you go over the first speed bump!
    XREAS shocks are MONOTUBE high-pressure. Therefore, they are more fade ressistant in off-roading (better cooling & faster acting) than standard shocks (which are twin-tube low-pressure). The ride in XREAS is firmer due to this fact. Handling is better due to cross-linking and high-pressure/montoube system in XREAS.
    I also agree with Jaredmsd in the off-roading situation he described.
  • vodgutvodgut Member Posts: 162
    I have an '03 Limited V8 with X-REAS that I've taken on a few trails. Generally I use it on road, but I like to do some light to moderate off-road stuff now that I own a cool SUV.
    This past weekend I went west of Boulder to the Switzerland Trail and from there continued on the Sugar Loaf Mountain Trail west to highway 72. These aren't super challenging, with mostly just ruts, bumps, and rock fields that don't stick up from the trail more than about 6 to 8 inches in a few places. Still, I didn't get much over 10 to 15 mph on any of the trail. Both of these trails are listed as 'Easy' in the guidebooks I have. There were a couple minivans near the start of the Switzerland trail, but I'm not sure I'd want to take a minivan further on down where some of the rock fields are. Only saw a Jeep Grand Cherokee on those parts.
    It was fun, but I don't think it was challenging the ability of the 4Runner at all. There were some interesting side trails going up (and back down) a steep hill near the start (towards Gold Hill) that I elected not to take. I can't claim I'm all that experienced off-roading yet.
    I want to try the Jamestown-Ward trail (listed as moderate difficulty) sometime soon.
  • so_caliso_cali Member Posts: 65
    in a racing situation with a modified engine the correlation may apply, but for everyday driving i seriously doubt that you gain any significant horsepower by using a higher grade of octane.
    this is all a myth to pad the already overstuffed pockets of oil companies. even if it were true, i doubt that it would be more than one or two horsepower. i'd love to see dyno tests that prove this with the 4Runner engines or any others for that matter. octane has always primarily been related to engine knocking and compression ratios rather than measured horsepower at the driving wheels.
    for those who think it's worth the extra 20 cents a gallon for premium fuel because they will gain horsepower and performance, i am of the opinion that they are simply throwing money away. 87 Octane is just fine.
    Thank you all for a great discussion! It appears, however, that we have not reached consensus yet.
    As far as X-REAS, looks like no one really knows if it helps or hurts off-road
    As far as 17-inch rims, it appears people here generally agree that 16-inch rims would be better due to more rubber contact with the road, but at the same time 17-inch tires may have enough rubber to still be quite adequate off-road
    Would that be a correct summary of the discussion?
  • jcliffrojcliffro Member Posts: 108
    I hope that most consumers saw the news and the Dateline NBC report on how poorly the smaller SUVs without airbags did in the Insurance Institute's side impact crash test. I did an internet search and could not find a single 4-Runner SR-5 in North Florida, Alabama, Georgia, Mississippi, Louisiana or East Texas equipped with the relatively inexpensive side air bag/curtain option. I live in New Orleans and my next vehicle will definitely have the side air bags after seeing the results. I am wondering what percentage of 4-Runners are equipped with this option? I think I found a few Limiteds with the option during my search, but it makes no sense that only the most expensive models are being so equipped. I hope Toyota gets word of what consumers demand and put the side air bags/curtains in the majority of 2004 models.
  • rogers12rogers12 Member Posts: 140
    The issue, I think, stems from the ability of the detonation sensor to detect preignition and signal the computer to retard the ignition timing to prevent further preignition. IF the engine pings on 87 octane fuel at the normal ignition timing, then the computer will retard the timing until it doesn't ping any more. This will cause a loss in power. Running this engine on higher octane fuel will permit the computer to advance the ignition timing back to its optimum value and restore the power lost by retarding the ignition timing.
    If the engine can run without preignition on 87 octane, then running on higher octane fuel provides no benefit. If your enging requires 89 or 93 octane fuel and you run it on 87 octane, you will loose hp because of the retarded ignition timing.
    I have heard that changing fuel octane and monitoring your gas mileage will indicate if you are running the optimum octane fuel. Retarded timing from inadequate octane will lower your mileage. Put in a couple of tankfuls of 93 octane and see if your mileage increases over what you get with 87 octane. If you see no difference, then you are fine with 87 octane. If you see an improvement, then trying 89 octane for a few tanks and seeing if your mileage improvement remains. If it does, and it is better than what you get with the 87 octane fuel, then your engine needs 89 octane gas to get optmimum performance. However, your engine with the detonation sensor will run perfectly safely on 87 octane if your owner's manual says so.
  • tcbktcbk Member Posts: 2
    I live in Vancouver B.C. Canada and would like to install the toyota navigation system or any other system for my 03 4 Runner. Does any one know which toyota dealership in Washington State close to the border install such systems and any idea how much it would cost ?
  • suvowner1suvowner1 Member Posts: 33
    I have been noticing side air bag patersn for a while now.and so far on either the jeep or 4runner you pretty much have to either special order or hoope it is an option included on a limited model.........it is def an issue for sr5 and sport models.I look forward to the day when side air bags are not an option..as far as i know, currently only volvo includes side airbags on all of its models...most side impacts if not fatal often result in severe brain injury or c-spine trauma.....the life after a severe head injury is very unpleasant......
  • azrunnerazrunner Member Posts: 16
    I really do like the look of the gray cladding contrast to my silver (titanium) Sport model 4Runner! In fact, I purchased this particular vehicle because of the looks! Don't you all think that the Global Extremes 4Runner is cool looking with those beefy tires, rack, etc. (By the way - do you think that it was lifted? If so, has anyone heard of a lift kit for this vehicle??)
    In addition to looks, the cladding is a wonderful protectant against scratches and dings (whether they come from a parking lot or shrubbery on the trail.)
    Personally, I would be concerned to have the matching cladding as it is still vinyl and looks as though it would not be as scratch resistant.
    Are people pointing fingers and laughing at me driving down the road in my gray cladded vehicle???
    (By the way - It has side air bags)
    hey azrunner, count me on the list of owners who prefer the gray cladding. If Toyota stops offering it, it makes our vehicles that much more exclusive.
    i also feel that that the cladding provides a break to and cuts down on the monochromatic paint's tendency to make the 4Runner look like a fat slab from the side. Thin is in!
    Dude! Our Cladding is cooooooool.....
    Absolutely not! Goto www.safarigard.com, under product link, to see more pics of the Extreme Runner. I like my gray/black SE also, don't seem to mind the cladding. The Extreme vehicles are running 265/70x17 Goodyear MT/R's, no lift, stock is 265/65x17. With the XREAS suspension, some people have said a suspension lift will be impossible w/o disabling the system. If people are pointing at your rig, it is because it is rare and bada$$.
    I don't think the cladding looks *bad,* especially with the Titanium color. I think it's even better with the more-unusual Galactic Gray (a closer match between body and cladding color). However I think it looks rather odd with colors like red and green (whatever Toyota's name for those colors is). I'll bet the gray cladding is functional in terms of avoiding dings, but I bought my SR5 for occasional towing and not for serious off-road use, so I was interested in the color-matched cladding. Mostly, I think they made the cladding a little too big/bold/dramatic for the non-gray body colors.
    so-cali, I think Toyota is being honest in what they say in the operating manual about the fuel to use in the vehicle, and why. The high-compression engines (the V8 and especially the V6)can produce more horsepower if they can use the optimum ignition timing advance. That's the reason for designing a high-compression engine: higher specific output. Of course, this only affects the driver in terms of max HP available. Most of us don't use (or need) full throttle very often, and might not detect the difference otherwise.
    Normally, using lower-than-optimum octane fuel (which is easier to ignite than premium) would cause knock or mild detonation, and that would be bad (or very bad). These engines have knock sensors, though, and retard the timing enough to cause the knock to go away. This retaded timing causes an appreciable drop in HP (nobody has said just how much) but I doubt it's a dramatic one, as long as the octane is above the recommended minimum of 87. These engines, after all, are designed to run on a range of octanes.
    rogers12 and I are on the same page about the situation so far, but I have heard differently about mileage and octane. I suppose it depends on whether the engine has a single "right" octane it prefers, or if it's designed for a range of operation, like these 2 engines. High-octane gas actually has less energy/gallon, and so these engines should produce more horsepower and fewer MPG on premium. I haven't tested it, though.
  • saarkazmsaarkazm Member Posts: 11
    Any help would really be appreciated. I bought my truck a week ago and noticed the daytime running lights are not on. Only the side markers next to the fog lights are on. I took it to the local dealership Longo Toyota in So Cal and they told me the DRL are the markers. When I look at the brochures, I see the low beam lights are on. I tried calling several dealerships about the DRL and they can’t seem to agree if it’s the low beam lights or the high beams. They never mentioned the side markers as the DRL. Even the techs don’t seem to know.
    As for the engine noise, I hear a very noticeable clicking noise from the engine area. The service advisor said the TSB is for engines that are making a squeaking noise so it doesn’t apply. Basically I have to live with it. Anybody with input on this?
    Final one…I hear a low hissing sound when I step on my brakes. It only happens when the truck is in motion. Some sort of air leak. There was another person in this board posted the same issue. Service advisor said it’s a normal sound. Thanks in advance!
    Official
    !!Color keyed cladding on ALL 4Runners!!
    Gray cladding is no longer available. '03 or '04, makes no difference. Not an option, no way, Jose. Ain't gonna be no more.
  • ddw5ddw5 Member Posts: 23
    Orange turn signal lights are DRL's only. No headlights come on as DRL's. If you put on the low beams, you can leave the switch in the on position. The remote lock will turn them off until you start the car again. This option is in the manual.
    As the 'body colored' cladding is plastic, I would like to hear from a few after one year when it is scratched. Grey cladding, I feel, will be much more durable.
  • gsj3gsj3 Member Posts: 20
    About your engine noise, I have posted my similar problem(clicking sound)some call it fluttering, the fuel injectors make quite the racket IMHO at idle.However,under load there is a louder sound which I would call clacking, I thought it was an exhaust manifold leak. My dealership said they have had similar complaints but there is nothing they can do at this time. Hotelseven has posted the same complaint and I am eagerly awaiting their next post update to see what has been resolved if anything,so hotelseven if you are out there??? let us know, this sound is not normal and again IMHO not good. Bottomline, not acceptable for a $32,000.00 new automobile
  • bryancosbryancos Member Posts: 282
    The other day I turned on my headlights due to morning fog and turned off the ignition w/o turning off the lights. Of course the auto-lights off feature turned them off after a few seconds to prevent battery run-down. When I got back into the car and started it, the lights came back on (because the switch was never shut off). So for those who didn't get DRLs as an option and want them, you could just leave your headlight switch in the "ON" position all the time and the lights (ALL of them) will come on when the vehicle is started and will switch themselves off after key is removed. However, be advised that you may be shortening the life of all of the bulbs since the marker and tailights will be on all the time (at full intensity) -- but then again, some of the aftermarket DRL kits do this anyhow.
    Well that sucks.. the gray cladding on the titanium, dark grey, or dark blue is the only way to go. Now that it is not offered, I am so glad I got it in time. I agree with whoever said that the cladding broke up the monotony of the silver paint.. I hate the look of the titanium limited's, it makes it look the height of a Izuzu Trooper. I think toyota is making a mistake by not offering it as an option at least. That's my opinion. Oh, but I do agree that the grey cladding on red or green looks bad.
  • chas215chas215 Member Posts: 22
    I have a new 4runner V6 Limited and have experienced everything you mentioned. Firstly, DRL turns on side markers only. I confirmed this with my local service dept. Poorly designed by Toyota. I also have RAV 4 with DRL and it operates normally by turning headlights on. Not sure what Toyota was thinking about. They missed the boat on this. Secondly, my brakes also make a hissing sound (sounds like air escaping). Am taking vehicle into service dept tomorrow. Thirdly, and most importantly, engine chirping sound I am getting is coming from drive belt and tensioner. Have your dealer refer to TSB EG012-03 for the fix on this. I am still waiting for necessary parts to fix this annoying problem. Hopefully, the TSB fix works.
  • bkahn1bkahn1 Member Posts: 7
    Just wanted to thank everyone for the 2-WD vs 4-WD boat towing discussion. I just put a deposit down on a v8 4-WD SR-5 under the theory that its better to have it and not need it than get caught unprepared. The thing is a beast.
    FYI - I have a neighbor with a late 90's 4-WD 4-runner that tows a 25 contender w/twin 200's. That combination has an all up weight of 6,500 lbs +. Seems like it would kill his truck, but 170,000 miles and counting says it can handle it easily. Thanks all. . . .
  • bmw323isbmw323is Member Posts: 410
    >as far as i know, currently only volvo includes side airbags on all of its models<
    Well, BMW not only includes front and side airbags on all models, but it also includes head protection airbags, even on their SUV.
    Cladding - with vinyl, non-painted cladding on the overfenders, the lower sills and the bumpers, it is much easier and faster to wax, for a big vehicle!
    Octane - I've run 3 tanks of fuel using premium and 3 tanks with mid grade. My mileage is better with the mid grade fuel. However, this could also be caused by break-in, or driving habits, etc. - so not very scientific. I can not notice any difference in power between the two types of fuel. I also intend to try at least a couple of tanks of regular grade gas.
  • ricadriasricadrias Member Posts: 17
    count me in as one of those who likes the grey
    cladding on my silver sport v6. i think it looks great and it really prevents door dings. this is the only car i have that has no door dings yet
    even after 6 months of ownership.
    Thanks for the input people. I just got off the phone with the service advisor. He looked up the TSB number and will order the parts. Thanks chas215…I really appreciate it. I hope this will fix the issue permanently. Secondly…I agree Toyota blew it with the DRL design. But y&#146;know…it might just work out great for me. I was looking into getting the Silverstar or PIAA low beam bulbs anyway. And since the life expectancy of those bulbs isn&#146;t the greatest I wouldn&#146;t want it to be on all the time. As for the hissing noise on the brakes, the service advisor will keep an eye on any fixes that may come from Toyota HQ. I&#146;ll post updates as soon as I get it. Thanks again for all the help.
    They took care of that problem by dropping both of those colors for '04; no jade green or red pearl. They also dropped the charcoal gray interior on the SE and replaced it with the sand from the SR5. Now the SR5 and SE both have only one interior option. (option? doesn't sound like an option. Sounds like Henry Ford..."They can have any color they want, as long as it's black")
    Glad to know your Runner Sport has the side air bags. Just curious, was it on the lot or did you order it? And were you able to negotiate a fairly good deal on it? I would imagine that if there even were an SR5 or Sport around here with that option, that the dealer would not come down as much as he would on the ones without it. And maybe that is part of the reason they are having to offer rebates. Maybe if they had equipped 95% with side air bags (instead of the other way around), there would be more demand for the ones on the dealer lots.
    I'm trolling for reactions to this suspicion I've had for a while: Maybe side air bags are not generally offered on the SR5 models because they're a zero (or negative) profit option. Given their complexity and parts count (4 bag assemblies, at least a couple of sensors, wiring, etc.) I would expect them to cost more than they do. The sunroof alone, for example, costs nearly twice as much.
    I would like to have gotten the side bags, but I never ever saw an SR5 with them, and don't remember them in any Sports, either.
    I'm not too concerned about the lack of side bags, though, particularly on a vehicle like this. Its mass and frame should reduce the lateral acceleration from an impact, and its height should mean that the bumper and hood of even a high-riding vehicle (pickup or tall SUV, say) won't be impacting my chest and head, respectively.
    BTW, Toyota gets kudos from me for making the bumpers on this vehicle compatible with most passenger cars, and keeping the front end "soft" to avoid pedestrian injury as much as possible. I chose a body-on-frame SUV like the 4Runner rather than a unibody crossover like the Highlander because (among other things) I'll need to do some towing. But even though I had to choose a higher, heaver vehicle, I'm happy I could choose one that is, compared to some others, a better citizen of the road.
    Grey cladding on black looks pretty sharp! Really helps define the lines. I also like the grey cladding on Titanium.
  • pfessor10pfessor10 Member Posts: 9
    Has anyone seen the new hitch receiver that was supposed to be on models produced beginning in May? If so, are they really better? How are they different? Thanks for any information.
    saarkasm, I apologize if I am misunderstanding you,but the TSB chas215 is talking about will only be a waste of your time, that TSB handles a chirping belt or tensioner problem, not the clicking or clacking or flutter, whatever you want to call it. This sound is not related to any belts or tensioners. It is valvetrain noise or an exhaust leak of some kind.Call 1 800 go toyota and complain as I have just done. They need to get to work on this one so as to offer a TSB to fix it. I urge all v6 owners who notice this to do the same, thanks in advance.
    Yes, my V8-4X4 2003 Titanium Sport was on the lot (actually, it had just rolled of the transport!)
    The vehicle came with side air bags, moonroof, running boards, factory rack, X-REAS (standard on Sport), 6-CD stereo, floor mats and the incredible First Aid kit. I paid $200 over invoice....$32600 in January.
    Whew...thanks everyone for the input on cladding. I will drive with a smile now!
    Then why doesn't Toyota bite the bullet and make side air bags standard and that way the cost would be buried in the overall cost of the vehicle? I doubt if one person in ten thousand is going to NOT buy a 4-Runner because it is equipped with side air bags. But the percentage of persons who won't purchase a vehicle without them is going to rise steadily, especially as the Insurance Institute continues to run that side impact test on more vehicles. I also ran the same search on Nissan Xterras and only found a few models in a 5 state area so equipped, but at least a few could be found, unlike 4-Runners.
    Obviously, manufacturers have to always consider the cost of their base vehicles. They can't load them up with all the options or they will not compare favorably, dollarwise, with competitors. Although a vehcile with traction control and stability control as standard probably should come with side airbags. I'll bet that Toyota adds side airbags as they freshen up the 4Runner in it's mid-model life - maybe 2005 or 2006.
    gsj3,
    Thanks for the info. I&#146;ve already called the number twice and was given 2 case numbers. When I ran the TSB by the Service Advisor, he suggested going with the fix anyway because the symptoms are the same. The only difference is the noise but it&#146;s coming from the same are of the engine. I don&#146;t think the fix will harm the truck…or am I wrong to assume that?
