Specs says the V6 has more horse power than the V8 245hp vs. 235hp but the V8 has more torque.
I am in Southern California so i don't need 4X4. IMO, the V8 feels more powerful (yeah right, it has 2 more cylinders)
Finally got a V6 Sport w/ XREAS and Sunroof and saves quite a few $$$ (the V8 cost a couple grands more) it has about 1K miles and the only complaint is gas milage, got 16.7mpg on average.
Has anyone tried to retrofit the newer style hitch receiver on their older 2003? Any help or clarification would be appreciated.
I was hoping to take in a print out of the $500-under invoice price to help with negotiations, but as of now, it doesn't look like that will be happening.
Thanks for any info you may have,
Aaron
Remember, TMV is a guide that tells you what buyers are currently paying for new vehicles. Most buyers don't do their research, but you are. Which means you should be able to beat TMV. And see this article for more.
They don't allow links to different forums but there are many 4Runner towers that could help you.
It looks like the reciever bolts directly onto the frame. There is no typical hitch assembly so... maybe someone else can speak to that issue better than I.
Did you get your TSB fix? How come everyone who has noisy engines say that they are going to get it fixed and then we never hear from them again?
I fear that I will be the next to mysteriously vanish, please folks,keep us informed. Thanks,
gsj (2003 V6 still sounds like a diesel)
I hauled the whole family (5 people) and all their stuff around yesterday. That engine is a winner. Didn't even hesitate. Took it through some light offroad too...and it has the smoothest ride and is very sure-footed. Go Yota!
Question: I wrote down the two TSB numbers for my dealer appointment tomorrow, but the weather is not cooperating. Does anyone know if they will fix this even if the rattle is NOT apparent on a test drive?? This is one of those aggravating things where I KNOW the second I pull into the service dept., the rattle will stop.
This would be of great interest to me,
GSJ3
I have had more than one dealership reject offers of TMV. I have even offered above TMV and still, no takers.
I want to make you proud Steve, but I don't see how it can be done.
No negotiating- go thourgh the fleet/internet sales. Why does anyone deal with salesmen anymore?
gsj3-
I'm sorry but Town Hall doesn't allow you to put up links to other forums so...if you do a search for toyota 4Runner forums, I'm sure it will come up.
Now the only challenge will be to have them see the problem. It's supposed to be hotter later this week out here so I'm hoping to show it to the dealer if I can get it to repeat. Bring-on the hot weather!
I also checked on all the Toyotas/Lexus with 4.7 l V8 discussions and there is no evidence that this is happening on any other vehicle. That it wasn't happening on the other (larger) Toyotas/Lexus with the V8 I wasn't too surprised. What is odd is that I didn't get enyone fess up to ever seeing it on the GX470 which I would suspect would have the identical power train to the 4Runner.
I did notice a separate issue with the GX470 powertrain making a noise. I wonder why the 4Runner owners here aren't seeing that. Riddle me this Batman...
Also it appears that this 4Runner discussion group seems much more active than those other Toyota/Lexus groups.
Stay tuned.
-Eric
I haven't experienced this problem from my V6
I think edmunds has a monthy payment calculator and financing advise elsewhere.
The rig tows beautifully at 70 mph. I'd have no hesitation about towing much more weight than I do, given the utter grace with which it handles the 4,000# load. My only criticisms are that the torque converter unlocks more readily than I'd like when the rig encounters slight hills on the Interstate and it's thirsty compared to my '98 4Runner. But otherwise I'm 99% satisfied. It's quiet, comfortable, stable and has loads of power.
The rig averaged 14.81 mpg going to Bowmanville (no wind) and 12.8 coming back (major headwind). These figures were calculated from corrected odo readings (odo under-reports miles by 2.5 %) and the gas pump figures. I use premium when I tow, but mid-grade or regular otherwise.
-Karl
Open the sunroof. On the passagers side, in the back corner there appears to be a mounting bolt opening on the rail support structure (there is one on the driver's side). I wedged 4 1/8 in. thick vinyl pieces with adhesive backing just over the apparent bolt opening and the rattle stopped. My dealer now says that Toyota has issued a TSB describing this as a fix. (He asked me if I wanted a job.)
Thanks in advance.
Thanks in advance.
I wish you much luck on getting replacement tires, since the unusual wear was caused by a vehicle problem (the bad strut), but you never know. I wonder if there is any kind of prorated warranty left on the tires from their manufacturer? You never know. Check the paperwork you got when you bought the truck.
Given that the problem was in the front, make sure they check the alignment after replacing the front struts (make sure they do the pair at the front), or else you may have another set of unevenly worn tires a year from now.
http://michelinman.com/catalog/tires/MichelinCrossTerrainSUV.html- ?tiretype=5&tire=1
Yesterday evening it was only 84 degrees F and I began driving the car without the problem. Then I got on the highway and turned on the AC. At some point the problem started while driving on the highway. I turned off the AC and the problem went away at that instant!
I turned the AC back on and the problem did not come back.
This says to me that if it is the fan clutch engaging then it must be an electronically controlled fan clutch. If it were not electronically controlled then turning off the AC would not have had an immediate effect.
Some folks have also pointed out a bad O2 sensor as well. I'm still not toatally sure but the groaning sound sure sounds like the fan.
Maybe I'll do some tests measuing the fan RPM relative to the engine RPM for both with and without the problem (at various engin RPMs). I need to find a strobe light and pulse generator or something to measure the fan speed.
Does anyone have any creative tricks I could use to measure the fan speed?
Also now I'm pretty sure it'll be hot enough today to demonstrate the problem to the dealer.
That's all for now.
-Eric
2003 Toyota 4runner 4X4 4DR SR5 SPORT V8
Delivered Internet Price: $31,283
Delivered Value Price: $31,622
Factory Invoice: $31,083
MSRP: $34,480
Sport Appearance Package - YU :
C7 Convenience Package
CM Double Deck Cargo System
DJ JBL Am/Fm/Cass/CD W/8 Speakers
DK Owners Portfolio
FE 50 State Emission Requirement
KG Black Running Boards
RF Rear Spoiler
SP Sport Plus Package
SR PWR Tilt/Slide Moonroof
TR Transportation Charge
WH Wireless Headphones
WL Wheel Locks
Check this place for foglights for your 2003 4Runner:
http://www.overnightautoparts.com/toyota-4runner-4ru-4wdv8-001-fo- g-light.html
Looks like they carry them, but you'll need to call them at 1-888-267-1845 for pricing...
So for now, they work fine going to the Mall and to other wild places.
Otherwise, looks decent.
bummer.
Are they a true no-haggle?
I'll try offering them a 60% downpayment, what do you think?
They look to be one of the few honest dealers around here anyway.
How many people here waiting for the 04 to buy an 03?
Only me?
I'm not sure why others don't do it- maybe because it is expensive. I love it and it is very convienent.
Ford copied the Land Cruiser's clamshell rear hatch on the new Explorer so I'm sure someone will do the same with the 4Runner.
On the roll down rear window, I think this was a GMC/Chevy thing a long time ago. I still see some very old (20+ years suburban like) trucks that have that roll down window. I don't know why they got away from it.
GM Vista Cruisers with the power rear window- but do you guys remember the power rear window AND power rear door that slid down into the bumper??
My neighbor had one when I was a kid- it was kinda old then even but the door was cool. It had the green tinted sky light windows- doany of you remember that? Those old wagons were HUGE!
If you're putting 60% down, I'd think they might throw in some accessories for you at least! Or at least 500 free oil changes! hah!
But, my experience with Fitz was positive, but someone actually bought the 4Runner the day I was supposed to go there. Personally, it would be worth it to get a good price and not worry about the games the dealers play. Piece of mind!
Good luck! The 4Runners are worth every penny.
Put the money you would pay for an extended warranty in treasury bonds for use after your standard warranty expires. It will always be available, gaining interest, and you will probably never need it.
