Mitsubishi Montero Sport Maintenance and Repair
5280
Member Posts: 3
in Mitsubishi
After searching the forum I was unable to find an answer to my question.
I own a 2003 Montero Sport Limited which I bought used a little over a year ago. The dealer provided only one transponder key at the time I purchased the vehicle. Later I discovered my truck had been a repo, hence only the one key. This is the first vehicle I ever bought which had a transponder key, and I though "I will just go to the hardware store and get a couple of more made," otherwise I would have negotiated a little better to obtain an additional transponder key and keyless remote. Live and learn!
The dealership wants $100 per transponder key and $150 per keyless remotes (this of course includes "programming"). Any suggestions on alternatives to paying these outrageous dealer prices? :mad:
I did get a key cut at the hardware store which gets me into the door if I lock my keys in however, as you know, the ignition will not start without the transponder chip attached.
My email address is johnxhewel (at) yahoo (dot) com for anyone who might have a better idea than paying dealership prices.
Thanks for your time and any help possible! :shades:
John
John
"troubled" Service Engine Soon light. Have taken it to the dealer on numerous occasions and they are telling me there is nothing wrong yet the light continues to come on. All I really need is someone to tell me how to turn it off when it comes on? Thanks in advance for your help.
Skidave
1)disconnect the battery cable for 30 seconds, keep in mind you will need code in order to play your radio again if you do this. Its an anti-theft feature
2)go to autozone and they will reset the error code for you for free.
Bewilderd.
How many drive-cycles does it normally take for this to shut-off?
Do any of you have any other ideas as to why the light is staying on??
Any advice would be appreciated.
Shannon :confuse:
cable on your battery for 5 minutes. It worked for me and I haven't had a problem since. The Montero Sport is famous for dash lights going nuts. Also, make sure you check and change the fluids in your transmission. That is critical with the Montero Sport.
Hope that helps.
Dave
MS 2001 LS with 73k on it, V6 3.0L. Trying to find out if it's an iterference or non-interference engine. Interference engine would be trashed when timing belt breaks.
Any help is apprecciated.
Apparently, they put a tougher belt in the low emission states. If you can believe that. If that is the case, then why not replace the one you have with the CA spec one.
Went to the dealer and they changed the "Freewheel Clutch Solenoid valve" part # MR263723 and took care of the problem. No more 4x4 indictaor light flashing and no more anti lock brake light. Bingo..........
Thanks again.
Any suggestions would be appreciated
John
Tim
Bud Mckay
(silverinram)
Thanks and best regards to all
sport LS 4WD. I have searched Amazon, Ebay, etc?
I recently purchased a 1999 montero sport with about 120k on it.
After about 3 months the neutral light started flashing. The transmission would also start to shudder and not shift right. I took it to a dealer (recalls?) and they flushed the tranny and said that if that didn't take care of the problem that I needed a new torque converter. My mechanic got a trouble code of P0710. Is there anything else I can do besides putting in a $1500.00 torque converter?
I have had the same problem. I took it to a reputable shop and they indicated that my speed sensors needed to be replaced. I'm not sure if this will resolve the issue. They said that there were no internal tranny issues. Did your neutral light ever stop blinking? Mine stopped along with the engine light.
The tranny was giving my wife fits so I had our mech. replace the torque converter.
He found a place in Indy that rebuilds them and it ran $700.00 installed. It seems to have fixed the problem except for the check engine light. In re the speed sensors...what are they and where are they?
Basically, the computer does this, puts it in 3rd gear, so you can't damage the tranny, even if its not a tranny issue. Worked fine first thing in the morning then went into fail safe, third gear mode.
Tranny guy wanted to do diagnostic testing and "let me know." I took it to my local mechanic who said there were 8-9 diagnostic tests which should be done before getting to the last one: OPEN TRANNY AND REPAIR IT!
He just called me.....It was a simple speed sensor.....$275 installed.
thanks. Mrsstokes
