Nice Jeep...somebody's gonna have alot of fun this winter.
Hope to come back more often...still in grad school and working too so time is limited these days.
You all have a great rest of the week and a Jeepster's paradise this weekend...plenty of mud and rocks for crawlin'
Hug your Jeeps for me
Deb aka smedranger...and others but this one's gonna stay
We've had frost the last two nights.
Oh well, there's always next year.
Gonna hook up with Jim and see what that good lookin' red YJ of his will do at Turkey Bay in the morning! Should be a blast!
Tom
Have you hugged your Jeep today?
-Pete
Andrew
I was thinking a stainless steel line would work & last best. Especially w/regards to the saltwater & air.
Any suggestions pro or con about the various line types? How about the ends of the line, are thimble loops ok or is some type of hook better?
How tough is it to install sway bars on a Jeep? I'm looking at the Adeco sway bars that were referenced on WJJeeps but I've also seem some in JC Whitney's catalog (rear only).
Is Adeco a decent brand?
I know, I know... you guys are gonna tell me to get quick disconnects and all that for my GC, but this is the daily driver that is usually used for snow duty, and unfortunately, no real offroading, except trails.
BTW, that YJ looks great! Once the tranny is ready, it'll be rockin'!
-Paul
My GC really rocks and rolls even with a slight sidewind and ooh boy hold on if you hit a corner anything above a crawl.
Is it possible to just put on the 1" rear bar (up from 9/16" hollow) and not do anything on the front or does it need to be done both front and rear?
-Paul
Walt
-twylie
-twylie
That YJ looks just as nice "in person" as it does in that pic.
Jim really enjoyed the day, and his little boy, Benjamim, seemed to be having a real good time too. Think they'll be wanting to go again soon.
I stayed on after Jim left and wheeled some more with some folks up from Franklin, Tennessee, Sam and his wife Hayden. They had a guy named Jody with them, but I have forgotten if he was just a friend or a relative. I have invited Sam to join us here in Jeep Wrangler.
Another guy joined us named Chris, and he has an XJ (Cherokee), but I don't know what year. I had wheeled with Chris a couple times before.
We had a great day, and the weather was beautiful!
Tom
Does that sound right? And are there any preferences?
Maybe someone here can give feedback on the roll up bags, but I would think they are a better choice if you want the windows with you. Whichever route you go, make sure you have a soft material to put between them. I have a thin cotton towel I use between my soft uppers.
Also, the biggest tip I can provide to keeping the plastic windows scratch free is to make sure they are clean before storing them. Not always easy when you're pulling them out while travelling, but will make a difference long term.
When (not if) they scratch, I recommend using Novus to get the scratches out. I need to do mine again before winter, but given some time and elbow grease, their products to a really good job on plastic. My windows are still in really great shape.
-twylie
But I got a new problem on my TJ. It looks like there is a radiator coolant leak. At first I thought it was from the upper hose mount, but after looking some more, it appears to be coming from the "seam" at the top of the radiator (where the little strips of metal fold over the top of the radiator to apparently hold things in place. I have some pictures I'll put on Webshots if I'm unclear. What I'm trying to figure out is: is it just overfilled and nothing to worry about, is is that a place that can be repaired or should I just replace the radiator and the hoses?
If I replace, what kind of radiator should I get, aluminum or what?
You can smell the coolant when the car is cooling down in the garage. Good thing though, my valve cover reseal is holding great!
Thanks for any input. Twylie, I had planned on going with the new bushings as well, but was wondering how hard the front sway was to install. Like I said, my WJ doesn't do any serious offroading to justify quick disconnects.
-Paul
http://www.stu-offroad.com/radiator/radiator-1.htm
http://www.jeepradiator.com/radiators.cfm?carmodel=wrangler
If I'm noticing gunk in my overflow, should I go ahead and do the thermostat as well? I've changed it out before on my old Monte Carlo, so it shouldn't be that big of a deal (Stu's walkthrough is top notch!)
-Paul
Mac, you have any input for us on this one?
Tom
http://modine.com/english/index2.php?pagecontent=markets/aftermar- ket/aftermarket.php&expand_index=4
My shop had a source for "scratch and dent" Modine radiators, so that's what we put in my Sahara. I've had no personal experience with Radiator.com but they seem to be well regarded on several of the other Jeep boards. And yes, I'd go ahead and R&R the t-stat while I was at it-and I'd do the belt(s) and hoses as well. As for coolant, I'd go with the D-C stuff; no point in taking a chance with anything else, IMNSHO.
I found radiator.com has a 3 row all metal one for 199, but it has a copper core. The manufacturer is CSF. How does that compare to Modine? Can you tell I'm not wanting to mess with this again for a while?
Which would be better - a 3 row, all metal, copper core or a 2 row, all metal, aluminum core?
Keep in mind, this TJ won't see major offroading (75% road, 25% moderate off road).
-Paul
I understand the heavy duty nature of the 3 row, but was wondering if the 3 row copper would be comparable to the 2 row aluminum.
Man I feel stupid today...
Also, which manufacturer would be better, Modina or CSF?
-Paul
Also, copper doesn't expand as much as aluminum when it is heated, i.e, there would be less thermal stress.
Okay, so I know this is overkill, but to solve this problem for now and a lot longer, I should go with the 3 row, all metal, Cu core and replace the hoses and thermostat.
Sound good?
Sounds like a busy afternoon next Sunday and missing my Cowboys play.
-Paul
That's a good question since aluminum is about 25% cheaper than copper on the commodities markets.
At work now, so this will be just a quick post. Just wanted to say hi.
Where ya from? Like to wheel that Commanche? Would be great if you are within a reasonable driving distance of Turkey Bay, where I wheel my Jeep every weekend. It's in western Kentucky.
Tom
Thermal conductivity:
Copper 400 W/m/°K
Aluminum 237 W/m/°K
"A three (or four or five) row radiator won't lower the temperature of your engine. What it will do is have a greater reserve of cooling capacity (assuming that it's not just three small rows in the space that the standard two normally occupy).
Think of it in the same way as replacing your standard battery with a larger one. Your electrical system won't suddenly run at 24 volts, but you'll be able to draw more deeply from it than you could with the smaller one.
So, if the three row has a greater capacity and surface area (and not all do), there's no downside to fitting one, apart from the extra cost. Actually, the standard Jeep radiator is very well specified in terms of its cooling capacity. What is not so great is its construction, with an aluminum core and crimped on top and bottom tanks. It usually leaks from these crimped joints after a few years, although the leaks are often self sealing if you leave it for a while! The construction of an aftermarket radiator, two or three row, is usually soldered brass.
Finally, follow the recommendations in the handbook for servicing the coolant system, and always use distilled water for making up the correct antifreeze mixture. Don't change the radiator cap for one of a different pressure, and don't fit a lower temperature thermostat. The Jeep engines are designed to run at a fairly high temperature and the fuel system runs open loop till then. If it runs too long like that you'll get a 'check engine' light."
Would you recommend another of the OEM radiators of would you go with an aftermarket one? Also, would you recommend one of the all metal ones? One last thing, aluminum or copper?
I just want to make sure I replace this thing the best way I can.
-Paul
Recognize my advice here comes from owning cars that were mediorcre at best with the factory cooling or ones that had heads that would easily warp with a cooling failure.
I just checked napaonline and a new H20 pump and gasket is less than $45 total for your Jeep. Seems like cheap insurance against a down the road failure. You can keep the old pump as a spare.
Food for thought... I love spending other peoples $$$
-twylie
The ONLY downside to these I've found is if they don't have grease fittings, you'll need to drop the mounting housing every 12-18 months to regrease the bushings. After you've done it once, you can do them again in 15 min each I bet. The Explorer fittings don't have zerks; the Jeep ones did.
I think this is a great mod for just about every vehicle I've done it on. Unless your ride already has twitchy steering, it will tighten up the turn in response when cornering or making evasive moves.
-twylie
I have seen on another message board that Chrysler was recommending the wrong gear oil for the manual trannies for some period of time. They were specifying that GL-5 oil should be used, but the GL-5 has sulfur and will eat yellow metals, like brass, which the synchronizers are made of.
I can verify that the 97 FSM calls for GL-5 in the AX-15 and the AX-5 manual trannies, but the 01 FSM calls for GL-3 for the AX-5 tranny, which is still used in the four bangers, as I understand it. (The AX-15 has been dropped in favor of the NV3550, and this transition occurred in during the 2000 model year, with the early 00's having the AX-15s and the later ones having the NV3550s.)
I have also heard that Chrysler never admitted their mistake, and they never did a recall or anything. They just quietly changed their recommndation to GL-3 at some point.
Our buddy Jim just bought that 95 YJ with the synchronizers shot, and I wonder if the previous owner(s) had just run the recommended GL-5 oil, and it ate up the synchro's?
Mac, what do you know about this? Anyone else?
Would like to know which years Chrysler was calling for the GL-5 and when they corrected the owners manuals and FSMs.
Tom
Thanks everyone. I think I got very lucky to find that Jeep.
Tom, Benjamin, Sam, Hayden, Jody, Chris and I had a really good time Saturday. I hated to leave so early. Maybe this Saturday will be different. My youngest son, Barrett, has already claimed the passenger seat for the next trip.
So, are we on for next Saturday???
Tom
As for the transmission oil, my 1999 Wrangler owners manual calls for GL-3 as well. The VERY pricey Mopar stuff.
My bud at work has a 97 Sport, and when he went to get his tranny oil a few weeks ago at a Chrysler dealer, they gave him GL-5. Fortunately, he has not changed his tranny oil yet, so he can exchanged it or get his money back.
Thing is, he most likely has GL-5 in his tranny from the factory, and if anyone ever changed it before he bought it, they would probably have used GL-5, like is says you should in the owners manual for the 97s.
Tom
From what I've read in other places, some brands of GL-5 might be considered safe while others aren't for yellow metals. So is the old bottle I have a different formula from the new bottle I just bought? Heck if I know. I guess to be safe I'll be doing another fluid change soon though.
For the record, I've got no tranny problems other than a bit of grind going into reverse now and then. But then I'm also no longer sure just what's been going in the tranny all those years since Valvoline seems to be pulling a fast one also.
I even read where the owner of a tranny shop has been throwing ATF in the manuals for years and claims it's just fine. This is why I try to do my own maintenance.
I'm sure you know this already but I'm a worrier. Lock up any pets you have when messing around with that anti-freeze. It's inevitable that I spill some and I understand it doesn't take much to poison a dog or cat. I make sure I get it good and cleaned up after I'm done before turning my dogs loose.
I replaced my radiator a couple of years ago with a Modina. Came with a lifetime warranty for what that's worth. A couple of tips, again you probably know all this. I just cut the old hoses off with a utility knife, it's really difficult to get them to pull off. I replaced hoses and thermostat but not the water pump. New hose clamps and check them after they've been on a while. I had a small leak and had to tighten up one hose clamp after about a month.
Can't you drag the TV out to the garage? What's more American than football and Jeeps?
Gary
Whatever has gone into your tranny for all those miles seems to have been OK, as you have said. Maybe the fact that you have changed it every 30K has been a positive factor in that? Could it be that it takes a while for the acid to form in the GL-5 once in the transmission, and by changing it as often as you have, you have avoided the ill effects?
I would like to get the exact and complete info on this whole thing. I did a little searching on the Net last night, but didn't come up with anything.
Guess the safest thing for a guy to do would be to avoid GL-5, huh?
Maybe we could contact Valvoline or some other oil company to get some answers?
Tom
Jim, I checked at the dealership in Madisonville yesterday for ya, and Butch, my bud in the parts department, says he does not have a listing for rebuilt AX-5s. The best he can do on a brand new one is $2200, which is a pretty nice discount, considering the list price is $2755.
Gill must have gotten a rebuilt one for his son's Jeep, since it was only $1700.
Tom
I had already moved on past the worst spot by the time this pic was taken, but I had only about an inch or two of clearance between Thelma's sheet metal and the side of the gully in the worst spot. Close call!
Tom
-twylie
THe belt is brand new so I'm NOT swapping that.
The water pump is something to consider, but I'll have to read up to see what is involved. I wasn't planning on doing a cooling system replacement, but it would probably be worth it.
I keep my pets inside so that isn't an issue. I will be cleaning everything up when I'm done (wiping up any spillage, then drying the floor with cat litter to pick up any residue, then cleaning THAT up once it has soaked.
Thank you to all for your input.
I have something I'd like to point you all to. I lost a friend a couple of years ago in a plane crash while flying a chase mission at Edwards Air Force Base. He left behind a wife and 3 kids. They have put together (completed) a book of his work. If you love aerial photography and military aircraft, you've undoubtedly seen his work. Please check out www.ThinAirPublishing.com.
I got my book yesterday and it is well worth it.
-Paul
Can anyone explain exactly what the GL specification means? Is it an ingredient classifier, quality measurement, viscosity or combination of those?
While I don't have enough miles on my Jeep yet to do the first change, I did just do one on my Toyota. Interesting enough, they called for GL-5 in the book, even though there are brass parts in there. I guess I'll be fine with the full synth oil, but it just makes me wonder about the whole GL classification.
Pete
