Jeep Wrangler
1201202204206207455
  • twylietwylie Member Posts: 619
    FWIW, the '98 TJ FSM calls for GL-3.
    -twylie
    Here is some basic info I found on GL ratings:
    http://www.performancempg.com/Drivetrains.htm
    GL = gear lube
    numbers indicate level of service severity
    I also found some references to the fact that certain gear parts may require certain additives or an elimination of components (i.e. limited slip diffs need "friction modifiers").
    To me, it looks like GL is just the starting point and other factors come into play. The confusion continues...
    -twylie
  • mtngalmtngal Member Posts: 1,911
    Thanks for the info - maybe I don't have as bad a situation as I thought. I know I need pads and rotors resurfaced, so maybe the indicator is a reflection of that rather than a leak. I picked up a bottle of brake fluid and will add it later today, drive home and see what happens.
    When I got to work this morning it was still too dark to see much, then I had to park in my husband's parking lot (since that is where the permit is good for) and I had to walk a mile to get to my office. Now I have to figure out where there's a parts store between the office and home (there has to be something easy to reach within the 75 miles I cover) so I can buy a battery for the Wrangler. And I don't want to be late getting home - it's an election day! As I said, not a good day for me...
  • bmg132bmg132 Member Posts: 28
    Thanks for the recommendation on the tow lines the other day, just didn't get a chance to log in sooner.
  • 01r101r1 Member Posts: 280
    Thanks for the link, good info, also good oil. That's the only gear oil I've used for the last 15 years.
    BTW, I looked in my owner's manual for my '02 X 5-spd, it lists Mopar Manual Transmission Lube (P/N 04874464) as the only fluid recommended. While it does list 75W-90 GL-3, or Mopar equivalent for the 2.5L models.
    Do I have to use Mopar's, or will a full synth 75W-90 GL2-GL5 gear oil work?
    -Pete
  • comanche_ajcomanche_aj Member Posts: 18
    i'll check this post more often, even if i get proved wrong by the host again, i told you guys i didnt know much about radiators, i'm just goin off of high-school classes which are majorly lacking in the automotive area. Ive never been wheeling east of the mississipi, well...ive never wheeled my comanche yet at all, but i go with my dad and we always go to Moab Utah, The Rubicon in California, and all sorts of trails in the Black Hills of South Dakota near Rapid city. Although i'd like to go east once, i highly doubt it, im still just starting my interest in wheeling. -ajjjjjjjj
    All this talk of gear oil and transmissions made me look at the Maintenance Schedules listed in the owner's manual. Neither schedule 'A' nor 'B' recommends changing the tranny oil. I was planning on inspecting mine at 30K and definitely changing it at 60K even if it still looks good.
    What kind of mileage intervals have other people been changing their manual transmission's oil at?
    Pete
  • mac24mac24 Member Posts: 3,910
    I like to change all fluids (except coolant and brake fluid) after the first 1000-1500 miles on a new vehicle. Initial break in of the gears and engine produces the heaviest deposits and the most suspended contamination in the first few hundred miles, and I like to remove them at the earliest sensible point. The cost is minimal compared to the potential added longevity.
    I'd be happy changing the manual transmission fluid at 20-30,000 mile intervals after that unless there's any chance of water contamination, when you should obviously change it immediately.
    ...all sorts of trails in the Black Hills of South Dakota near Rapid city.
    That's a FANTASTIC area! Just don't get lost!
  • tsjaytsjay Member Posts: 4,591
    Haven't gotten a response yet, but I emailed Valvoline to get some clarification on the GL-5 vs brass synchronizers issue.
    Tom
    Have you hugged your Jeep today?
    I'd love to go to Moab, though I know there are trails there well beyond my experience. One of these days I'll try the beginning of the Rubicon - I understand the first few miles aren't that tough and my stock Wrangler could handle that part of it.
    My Noble Black Steed is once again running - new battery went in with minimal problems. I found out that checking brake fluid in a parking garage is difficult - not enough light. But the Taco got me to Pep Boys and home safely.
    And even better, our local gas station just lowered their price to $1.59. So perhaps the day wasn't so bad after all.
  • geepersgeepers Member Posts: 93
    I'm not letting this one die. I went to the source, American Petroleum Institute, of the ratings and found this. Make of it what you can.
    http://api-ec.api.org/filelibrary/glchart.pdf
    Most interesting is that GL-3 is NOT a designation that is currently in use and I don't recall seeing any of it on the shelf at the local auto parts store.
    So I called the Valvoline 800 number. They get high marks for only making me punch two numbers before I got through to a live person. Asked him if their GL-5 gear oil had problems when used in transmissions with brass synchros. He said NO. Kind of what I expected him to say. But I asked again, he still said no.
    This is not the first time I've heard the GL-5 yellow metal controversy. Perhaps since different brands use different additives, some are bad, and some are OK. I'm still not sure, but I'm sticking with my Valvoline GL-5 rated gear oil for now.
    I put the same stuff in both diffs. Even though it says it works for limited slip, (I've got Trak-lok) I still get a noise on sharp left turns and starting headed uphill from the rear. So I hightail it down to the Jeep dealer and for about $8 get 4 oz of Mopar Limited Slip Additive. I put 2 oz of it in the rear and all seems to be well after that.
    Hope this helps rather than muddies more. Please make any additions or corrections you feel are necessary. Will be most interested to hear the results of your email Tom.
    You've got to read back some messages if this speel makes no sense. Or perhaps, it just makes no sense anyway.
    Gary
    Thanks for the info! I like your attitude, too. Let's dig and dig and dig until we get this issue clearly exposed and understood.
    I will definitely pass on what Valvoline says, but it is most likely gonna be the same thing they told you over the phone.
    I DEFINITELY think that there is something to this GL-5 eating brass synchro's issue. Why did DC back off from recommending GL-5 to GL-3? Doubt if you could get a straight answer from them, since they would be admitting liability.
    Geepers, you are probably right in saying that SOME GL-5s are formulated with sulfur and some are not. Maybe ALL GL-5s originally contained sulfur, and when the problem concerning the synchro's was discovered, they all changed their formulations to eliminate it.
    This could be similar to the synthetic oil problem when it was first introduced years ago. People were having leaks, and synthetic oil got the reputation for causing leaks. The problem was fixed with additives that soften and preserve gaskets and seals, and for years now synthetic oils have not caused leaks. Unfortunately, many people still to this day will not use it, because they think it will cause leaks. So, maybe the first generation of GL-5 ate synchro's, but the problem might have been fixed.
    Although I have an 01 Sport, and the problem was apparently recognized and fixed before my Jeep was built, I have lots of Jeep buds with older Jeeps, and I would like to know the truth about this issue for their sakes.
    You have to be careful about what you believe when you see things on the Net, but I'm telling you that I have seen enough posts on that "other" message board to make me believe that there is some truth in this. Also, you have to wonder why DC changed their recommendation for gear oil type.
    Let's make this a Jeep Wrangler project, and let's all try to get info on this subject and share it here.
    Tom
    Is Edmunds in a position to help us out on this GL-5 controversy? Is there any "conflict of interest," if the resources of Edmunds are used to get to the bottom of this? I don't know the relationship, if any, between Edmunds and the car manufacturers. As far as I can tell, Edmunds is independent of them and is, therefore, unbiased.
    Tom
    We've had reps from extended warranty companies, Toyota (sludge) and currently enjoy an official presence from a Subaru representative, so anything is possible.
    Maybe we could get a Valvoline engineer in here too, and maybe I can get the engineer to admit that oil changes every 3,000 miles are overkill, LOL.
    We'll send a note to HQ - maybe someone there knows someone, or if you're reading this Valvoline (or Chrysler), feel free to jump in.
    Don't be disappointed if nothing happens with the request; the Toyota rep got abused pretty good and there was only so much that Toyota legal would let him say, so there's not a lot of incentive for a manufacturer to open themselves up in a forum like this. But Subaru has earned themselves a ton of goodwill by being here, so who knows?
    Not only other Jeep boards, but from tractors to exotic cars to vintage cars, GL-5/brass problems have been documented for some years.
    Certainly you shouldn't believe everything you read on the 'net, but when you find many, many, many instances of the same problem spread over a wide spectrum of applications, you have to start giving it some credence. Unlike UFO's and alien abductions (my apologies to believers), there's plenty of repeatable evidence here.
    Here's a relevant excerpt and link from the Q&A section of the Castrol site:
    "Q: What is the best way to choose gear oil?
    A: In general, GL-3 or GL-4 gear oil is recommended for manual transmissions and GL-5 for differential gears. GL-3, 4 and 5 are quality standards regulated by the API (American Petroleum Institute) and are classified according to intended use. They especially indicate the anti-wear and oxidation resistance qualities that these oils possess but GL-3 and GL-4 are predominantly specified for transmissions with syncromesh compatibility taken into consideration. Using GL-5 here can cause synchronisation difficulties and poor shift quality. Please refer to your manufacturer’s handbook for guidance.
    http://www.castrol.com.tw/eng/faqdetails_atfgearoil.02.shtml
    i guess i never really answered tsjay's question, i am from alliance nebraska. Now that ive done that: mtngal, im assuming you are from somewhere in the Moab area or from colorado because of the obvious Mountain abreviation in your name, but my family has gone to Moab so many times and my dad's jeep got soooooo huge, that moab doesn't even phase it anymore. The only thing that my dad wont do in Moab is the Lions Back, it's such a simple drive, no obstacles, but the steep drop-off scares him to death! Moab is cool, i like slick-rock and would love to take my jeep there before i go to college, and ive been through the rubicon in all three stages and you are right on track. You are right in saying that the first few miles of the rubicon are not that hard, they are just like Big Barrett Lake Trail near there (if i remembered that name right) which is a 3+, but the thing that makes the Rubicon a "5" is all the side-obstacles like the Little Sleuce that you can completely avoid, or if you have a buggy or my dads jeep you can go through with moderate difficulty. Although your jeep might not be amazingly big, the rubicon will be fun for you, just make sure you have front air lockers and a spare tire. oh! and sunscreen! a bonus of the trip is that when you get to the rubicon springs trailhead (the second stop) there is a helicopter ride that you can take that will show you an awesome view of spider-lake and the trail from above. its really cool, spider lake is cool, but i would have enjoyed it more if there wasnt an annoying 7-year-old saying "AJ come look what i found!" then he's hiding under a tree and says "i found a fort!". in all, in one week the said my name 220 times, and yes i did count, but thats not even accurate because i didnt start counting until tuesday when he'd already been angering me since sunday. but anyways, i hope you make it out to the rubicon and have fun with your wrangler.
    -ajjjjjjjjj
  • boredbored Member Posts: 300
    I always thought that synthetic oils caused leaks because they cleaned out gunk that filled holes in gaskets...at least that's what I heard from another really popular Jeep site.
    What's the real story?
    One thing fairly well accepted is that if synthetics are used in an engine from a reasonably low mileage then it's unlikely to suffer from an above average incidence of leaks.
    Your theory is one of several I've heard, and I know of nothing to indicate that it couldn't be true.
    My set of mountains aren't so grand as those in Colorado - mine don't even have a name, though they do go up over 8,000 feet. I'm stuck in one of the nameless mountain ranges of California, so the Rubicon isn't all that far.
    I've heard the same theory about synthetics. Up until recently I was putting so many miles on I was changing the oil about every 2 months. Now that gas is so high we haven't been driving the Wrangler much, and I thought about changing. However, don't think it would be such a good idea with a 5 year old high mileage vehicle. Is this sound thinking?
    From what I can gather, the earliest versions of synthetic oils did cause leaks. The engine's gaskets and seals were kept soft by something in refined dino oils, and this substance was lacking in the synthetics. This problem was recognized and fixed by an additive at some point early on, but the synthetics got that reputation for causing leaks, and these many years later, some people are still afraid to use it.
    Now, also from what I have been able to find out, there probably is still, to some degree, a greater propensity for synthetics to leak than is the case for dino oils. This is because the synthetic oils are so uniform in molecular weight compared to refined crude oil. They don't have the long molecular chain material to "plug" potential leaks like the dino oils do. But, this is also why they circulate better and get to the critical areas of the engine faster for better lubrication.
    I firmly believe in synthetic oil, and I have used Mobil 1 for years. As I have told you guys in here in past posts, I have personal experience with Mobil 1 reducing the cold start engine noise on a Z28 Camaro I once owned. That convinced me that the stuff was good for my engine. It also increased my gas mileage by 5% as measured over a LONG period of time, not just hit or miss gas mileage checking. Higher gas mileage HAS to mean less friction, and that is a GOOD thing.
    Tom
  • mullins87mullins87 Member Posts: 959
    Does anyone know anything about "Phoenix Remanufactured Transmission?" I found them on e-bay. They have a ton of feedback and a store. They have rebuilt AX-5 trannies for $600 with a 6 month/6,000 mile warranty. They do charge $250 for a core.
    Has anyone ever heard of them? If so, please respond. Considering a DIY'er rebuild will probably set me back at least $300, this almost looks too good.
    In your situation I'd stick with the dino. Synthetic won't hurt your engine, but it'll probably find it's way out and onto the floor for the reasons that Tom gave in his second paragraph.
    Don't discount the value of the experience of doing it yourself.
    Man, that would be COOL, but can the average guy do a job like that and get it right?
    Are there some special tools required? Are there kits you can buy that would have instructions?
    Tom
    That's the ONLY reason that I don't use Mobil 1 in my little S-10. I bought the truck with 134,000 miles on it, and it now has 164,000 on it.
    I was afraid to use Mobil 1, since the truck had most likely gotten dino oil its entire life before I got it.
    There is a risk of leaks on older engines that have always had dino oil. I think the synthetic gets to places where the dino has kind of plugged a hole, and the synthetic washes out the old dino oil, thus allowing a leak.
    Tom
    Not as hard as you'd think. A copy of the FSM is the greatest asset, followed by snap ring pliers, feeler gauges, a puller, and equal measures of enthusiasm and common sense. No point in doing it if it's only to save money..... you'll be cursing at every step!
    I'll bet that installing a Detroit, or lift kit, or gas tank skid, seem a little more daunting that it does now that you've done it (or helped do it).
    The only times it's probably not worth rebuilding a box yourself is if a shaft has broken and punched out the side of the case, or if the box has been run dry and overheated.
    Yeah, that Kilby installation was something that I was really proud of myself for tackling. I would NEVER have tried that before becoming a Jeep owner. I struggled with it about all day, but I got it done. Then, when my bud at work got his, it was a breeze to install his.
    I was just a spectator for the Detroit installation, and I'm not sure I would tackle that job by myself even now. Setting gears is something that I don't think I'm ready for. :)
    Tom
    Provided by mac24:
    "Here's a relevant excerpt and link from the Q&A section of the Castrol site:
    A: In general, GL-3 or GL-4 gear oil is recommended for manual transmissions and GL-5 for differential gears. GL-3, 4 and 5 are quality standards regulated by the API (American Petroleum Institute) and are classified according to intended use. They especially indicate the anti-wear and oxidation resistance qualities that these oils possess but GL-3 and GL-4 are predominantly specified for transmissions with syncromesh compatibility taken into consideration. Using GL-5 here can cause synchronisation difficulties and poor shift quality. Please refer to your manufacturer&#146;s handbook for guidance." <end>
    Mac, while I'd like to believe these companies have it all together, if you go to the Castrol USA products, you won't find anything BUT GL-5 for both conventional and synthetic gear oils. And it's recommended for manual transmissions, no disclaimers about synchros at all.
    http://www.castrolusa.com/products/Default.asp
    (look under specialty products)
    I don't believe you can even find GL-3 and also that GL-4 may be going away also. At least at my friendly auto parts store anyway. Something is amiss but I believe their FAQs may be outdated.
    Perhaps I'll trundle down to the Jeep dealer this weekend and ask the parts guy what designation of gear oil they stock. Maybe sit in a Rubicon and make driving noises.
    Gary
    Just a thought but perhaps you should also look into an AX-15 tranny. I think they might be interchangeable with the AX-5 but a bit more heavy duty. I also thought the AX-15 might be more plentiful. Maybe someone knows if that's a fact.
    Gary
  • fenris99fenris99 Member Posts: 16
    I've been looking at getting a Jeep for some time now. When my last car broke down I figured I had my chance. Alas, my wife brought to my attention that you can't tote four kids around in a Wrangler. Sigh. So I got a CR-V.
    Maybe in a few years...
    Thanks again. You're a great bunch!
    Other thant the spendy dealer supplied stuff for the NV3550, the other oil I'vve seen people use and recocomend is GM Syncromesh, which I believe is a synthetic. Apparently the comosition of the Mopar fluid is the same as the GM product. Another one of those "its suppose to work". I'm due for a tranny flush, and will be using the big ticket Mopar stuff just to be safe.
    -twylie
    Now that you have the CRV, start saving up for YOUR car - a Wrangler. A Wrangler is a bit small for 4 kids, but would be great for a second car.
    It is funny - you had to choose something else because the Wrangler is too small. My problem for this evening is to see if I can remember how to put the back seat in again. It has been out for so long and this weekend there will be 3 of us heading for the Sierras, so I'll need a back seat, and the Wrangler's back seat is MUCH more comfortable than the Tacoma's jump seat.
    Thanks for the info. I've only got 9000 miles on my Wrangler, so I've got a while before I'll be changing the tranny oil.
    -Pete
    We can trade links to oil site for a while, but I doubt that it'll make things any clearer.
    The fact remains that in the past, GL-5 has caused significant problems with the yellow metal components in a multitude of manual transmissions.
    It may well be that the current conventional GL-5 lubricants now meet their specifications using a different mix of additives. However, if it were my transmission, I'd either use Mopar Syncromesh (a synthetic), or one of the many proprietary synthetics (like Redline) that meet the current specs.
    I know it's a little boring, but the CR-V is a great vehicle. I had a '98 EX 4wd and just loved it. Very reliable, good gas mileage and really versatile. I traded it in for a Honda Pilot and now miss the CR-V. The Pilot is just little too big. I'll probably go back to a CR-V when I'm done with the Pilot.
    Like mtngal said, a Wrangler is a great second car. I agree totally!! But in the mean time, don't be afraid to get out with the CR-V. They may not be able to handle an off-road park, but they sure can do any back road / forest road that you can throw at it (if it's 4wd). I was never short on traction, just ground clearance. But, a determined driver can usually find ways around a lot of those big obstacles.
    BTW, that removable picnic table comes in real handy when you're camping. Have Fun!!
    -Pete
    Thanks, guys! What a great bunch!!
    Yeah, I can try some lesser travelled trails. There are CR-V owners clubs (not as many as Jeep owners clubs, but still...) who meet and do some light off-roading.
    Thanks again for everything!
  • gocatsgocats Member Posts: 1
    Hi All:
    I'm new to the Jeep world, but wanted one all my life. Finally "jeeped" in! Found a one-owner, 2001 "city" Wrangler Sahara with 5,500 miles, very clean, from a Cadillac/Mitsubishi dealer. Not alot of extras other than DANA rear axle and dual tops. I'm probably one of those guys who will hesitate in taking it offroad the first time... Sorry about that! But my 7 and 5 year olds think I'm a king. And, my anti-jeep wife (perceived lack of safety, etc.) hasn't left me yet!
    In browsing past messages, I do have some comments/questions: From a few years ago, there was discussion about "noisy manual transmissions" with the clutch disengaged. I also have that situation, and two different DC dealerships have said it's the throw-out bearing. One small-town dealership (sales manager, not too patient because I didn't buy his 2003 wrecked Sport for a "new car" price) said it will get better over time since it hasn't been driven that much. The other dealership (service manager) said it will probably NOT get better, and there's no guarantee a new throw-out bearing will be any quieter. I have a year left under warranty, and was wondering what some of the mechanics on the board (Mac, etc.) would do? Get it replaced now, and take a chance that the replacement could be worse (if we believe that particular dealership)? Maybe this Tranny noise is simply the life of the "beast" although some manual transmission owners did NOT report this noise? (I'm a Honda owner all of my life, and we still have a 91 accord and 2001 CRV. Just not used to my new baby's "noises.")
    Thanks, and for all of you living in Western Kentucky, "hello" from a Murray native who now lives in Western Missouri!
    If you get a noise with the clutch pedal depressed it could possibly be the throwout bearing. If the noise is present with pedal at rest and the transmission in neutral it's likely to be the standard NV 3550 rattle/rumble/clatter etc.
    Noisy bearings don't get any quieter with age, so if it appears it might be the throwout bearing go ahead and get it replaced. It's a zero cost to you and the noise certainly won't be any louder.
    As an aside, all Jeeps have Dana axles. The choice is between the D44 and D35. Dual tops are a great option to have.
    Great you finally got a Jeep. Sounds like a great find - loaded, low miles and not taken offroad - yet...
    The NV3550 manual tranny is a "truck" transmission and is notorious for rattling with the clutch out in Neutral. Sound could be decribed as "shaking a bag of marbles". There was a TSB on this and your local dealer may be able to check if that service was done on your Jeep. It won't make the noise go away, but may quiet it down a bit. Mine sounds noisy, but has not gotten any worse since 3/01 when it was new.
    You'll see a lot of people question the noise, but I am not aware of any failures or problems with that transmission.
    Good luck and enjoy the Jeep!
    -twylie
    If you are talking about the Kentucky Wildcats, that is. :)
    As said by previous posters, the NV3550 is known for that noise when the tranny is in neutral, the engine is running, and the clutch is out. My Jeep has had that noise as far back as I can remember... probably from the day I picked her up after she came in from the factory. It has NOT been a problem, and I now have about 37K miles on the Jeep.
    So, if you are from Murray originally, I have to wonder if you have ever been to Turkey Bay? I know you just got your first Jeep, but I wonder if you ever went there with a four wheeler or a dirt bike? It's a great place to wheel! When you come home for a visit, we will definitely have to hook up for some wheelin' at Turkey Bay! (Oh, Turkey Bay is an off road area within LBL, in case you don't know where I'm talking about.)
    I have a bud from Joplin, Mo., that's coming to wheel with me at Turkey Bay for the 18th and 19th. Would be cool if you could come then too. I don't know how close you and he might live to one another, but you might become wheelin buds.
    Congrats on that Jeep! Now, come on over and let's get it dirty! :)
    Check out my Turkey Bay pics on the itsajeep.org web site.
    Tom
  • drosketerdrosketer Member Posts: 203
    Congrats on your purchase gocats. Sounds like quite the find, am sure you'll enjoy it.
    Andrew
    Another reason not to Jeep alone:
    Teenager pinned under vehicle uses jack to free himself (CNN)
    congrats gocats! Sounds like a nice rig.
    Once when my other half and I were coming back from a national forest hiking trail. The trailhead was on an easy dirt forest service road. We had a flat (nail in the tire) about 10 miles to the closest paved road, and 20 to the nearest travelled road. Getting the nuts loosened wasn't the easiest thing in the world and I did think about the fact that 10 miles is a LONG way when you are on foot.
    Steve,
    I saw no mention of it, but from the way he was pinned he must not have had his seatbelt on (leg pinned bewtween windshield and part of a roll bar). It would almost have to be that his legs were tossed up the upper windshield corner.
    Wheeling alone = be careful
    wheeling alone with no seatbelt = contender for the Darwin award.
    Glad he escaped with no worse injuries.
    -twylie
    to mtngal i think, its hard for me to remember names of people while switching pages, i hate having A.D.D., anyway, my dad is a new vehicle freak, he bought a 2001 Chevrolet Avalance pickup in november of 2001 and loved it, he traded it off 1 year later for a Dodge Ram 1500 Quad Cab with a 5.7litre hemi engine (hated it) but the Avalanche had 57000 miles on it (no joke), he travels to rapid city and casper wyoming allot from out hometown in the panhandle of nebraska. And still with 57000 miles on a 1 year old vehicle, the avalanche got sold in about 3 months, but it was at a dealers, so i'd plan on trading your wranger in for a more economical car instead of just buying one and selling the wrangler yourself. and by the way, my dad was on his way to california to an auto dealer show, his dodge broke down in utah, he walked down the street and bought a brand new 2004 GM Quad Cab dually pickup. my dad is so strange sometimes, but thats in the norm for us, my truck was bought within 30 minutes of our first sight of it because the dealer was closing, and my mom bought an audi A6 on the spur of a moment after she became a grandmother, but the sad thing is, she had to try to sell her corvette (that my dad bought her for losing weight), but it didnt sell (we tried it ourselves) so we traded it for a Nissan Frontier. we are just car crazy, so sell your wrangler for a good gas mileage car and all will be well, as long as you dont miss it.
    -ajjjjjjjjjj
    Sell my Noble Black Steed??!!!!?? Not hardly! That Wrangler won't get sold or traded in on anything but another Wrangler.
    Now my Tacoma is a different matter. When I can finally afford to dump it, I will. I still haven't decided what to replace it with - I keep changing my mind. Sometimes it is something really economical like the Prius, sometimes it is a Liberty, which I like, or an Element which has a great interior, and sometimes it is a second Wrangler (along with a prayer that the price of gas doesn't go through the roof again). It isn't a big deal - I can't afford to take the hit between what I owe on the Taco and what it is worth. Maybe next spring or summer I'll start looking again.
    At one point a while back I was reading that someone was developing a modular hard top for the Wrangler. It sounded like something that would be easier to store than the current hard top. Has anybody heard anything more about it?
    Hey, my fellow Kentuckian, email me. My email addy is tsjay49@earthlink.net
    Let's plan a little wheelin' get together for next time you come to Murray.
    I live in Greenville, if ya know where that little map dot is. It's a 68 mile drive for me to get to Turkey Bay. I go virtually EVERY Saturday.
    Tom
    I don't know if this helps or not, but Bestop has a new hard top for all Wranglers. They call it the Bestop Hard Top. :-)
    It's a two piece top, that also has plenty of roof storage space. The smallest piece, when it's taken off, mounts on the rear piece, creating a really big sunroof. Sorry, I can't describe the thing. The drawback is that it's very expensive. Take a look.
    http://www.quadratec.com/cgi-bin/sgin0101.exe?UID=200310092035519- - 0&T1=11090%2B001&UREQA=1&UREQB=2&UREQC=3&UREQ- - D=4&FNM=10&x=94&y=74
    you work for JKS, huh? Very cool; great products. I've been using their discos for over a year and will likely buy adjustable track bars and eventually control arms from them when I get to that phase of my build up. I'm guessing that's your dad's company? Need an "average joe" to field test some products for you? :-)
    -twylie
