Does anyone have any experience with this who can give me a heads up on what to expect?
BTW, in the meantime, I'm driving around in a 1985 Prelude. Could there be a more different driving sensation?!
Mike
Clueless in Seattle,
Stephen
Also, if I am not mistaken, the gear type units tend not to wear out, unlike the clutch types which eventually require new plates. Is this correct?
Heh, I think I've been reading too many wheelin' books and can no longer keep everything straight... Can't wait to stop reading and start doing!
Andrew
Yes to your second question as well. Geared LSDs wear much more slowly than those that are clutched. Expect it to last as long as a standard open diff.......... probably, maybe, perhaps......... well, you get the idea, a lot longer than the clutched type anyway!
My foglight lense has a bad crack for a year or two now. It still works so I haven't bothered doing anything with it.
I would go aftermarket if you replace it.
Here is a link to Twylie's upgrade.
http://www.ewylie.com/jeep/electrical.htm#IPFH4
Anybody know anything about the Detroit Electrac?
Stephen
Andrew
Could be gas. Are you getting 87 octance gas?
Hope ya get it figured out.
Welcome to the group!
Tom
Have you hugged your Jeep today?
The situation that you describe is called "spark knock" I believe. It's typically caused by higher compression ratios, which you don't have, or a cheaper grade of gasoline self-igniting nano-seconds before the spark plug ignites. This self-ignition sends out a shock wave that makes the pinging noise when it strikes the cylinder walls. This typically doesn't cause any real damage unless it's allowed to go unchecked.
Are Jim and I on the right track?
If the tranny is shifting at the right RPM, then it's either the engine timing or the gas quality, right? The timing being right depends on, among other things, a good reading from the CPS, correct? Could it be a CPS problem?
Mike's username indicates possibly that he lives in Arizona. If that's true, then don't they have 85 octane gas out west as their "regular," and couldn't that be the problem?
Tom
We are taking my Noble Black Steed, and I hope the weather will cooperate - I would hate to bring it back clean!
Have a great time everyone!
Increasing the octane rating of the fuel used is the easy way to analyze the problem. However, to be true to it's image, a Wrangler ought to run fine on Mexican gas pumped from a drum that's been standing in the desert sun for five years! (Of course, that's just my opinion.)
I have to used mid-grade 89 octane on my Jeep because the knock was so bad with 87 octane. The dealer wouldn't investigate because I have 33" tires and effectively too tall of gearing. Oh well, guess that's just another trade off for having big tires.
-Pete
Now I need a new oil filler cap and the hose that comes out of the valve cover - slight leak from those and this thing should be nice and tight again.
-Paul
Pingless in Seattle,
Stephen
http://home.earthlink.net/~tsjay49/
Getting ready to head for Turkey Bay pretty soon. I will be meeting Jim (mullins87) down there, and he will have his brother in law and his boys with him. He tells me that his brother in law is beginning to get Wrangler Fever.
I think after today that brother in law will be beyond help... he will have a full blown case of Wrangler Fever.
See you guys later. Check out that website.
Tom
I've got the itch...hoping to get it scratched this coming spring. Thanks
BAMA is still around..
I was jeepless for a few days.
I had the engine light on took it too the dealership had it fixed plus a winshield leak & some paint chipping off under the passenger door.
Tazz is ALL GOOD now, All clean & shiney.
thought I would catch everyone up to date.
KEEP JEEPIN
NOW TIME FOR THE IRON BOWL BAMA vs AWBARN!!
ROLL TIDE!
BAMATAZZ
Same Jeep, different sources.
Scratched up a rear fender flare pretty bad today, and the old license plate holder got crunched some more.
Had a super day, though! There were two YJs (one was Jim's... mullins87) and two XJs besides Thelma Jane. Weather was great, with temps in the low 70s.
Check out the pics in Gill's gallery. I'm still uploading some, so check em out again later.
http://www.itsajeep.org/PhotoPost/showgallery.php?cat=15034&p- puser=4
Tom
The advantage would just be the extra cargo room, I guess, Sonny. It would be nice to be able to carry a little bit more stuff in the back.
Tom
It depends on the temperatures and humidity, but I think six months under most conditions would be my limit. I wouldn't even go that long if the Jeep had only been used for very short trips and hardly ever gets driven long enough to get the oil warm enough for a long enough time to evaporate the moisture. Just because your coolant temperature reaches normal, doesn't mean that your engine has run long enough to get rid of the moisture in the crankcase.
We are sorta getting into the realm of "opinions" here, and I am always interested in getting Mac's opinions, because he obviously knows his stuff about vehicle maintenance. So, Mac, give us some input on this, please.
Tom
Some advantages are more cargo space, and more rear seat room. It's still a 4 seater. The pictures show the Wrangler Unlimited Rubicon prototype. Trim levels will be X, Sport, and Rubicon. The Sahara will not exist after model year '04.
Hug your Jeeps for me!
Marlon
Three thousand miles or three months (which ever comes first), is a pretty good rule of thumb. However, should you only do a couple of miles to work each day never allowing the oil to get up to temp (which takes a lot longer than the coolant does), I think I'd drop it to a thousand miles or a month. Oil is so cheap compared to the cost of repairing the engine.
To be honest, I'd rather change the oil every month using the correct spec WalMart brand, than every five thousand miles using Mobil 1. Nothing wrong with Mobil, but the engine would never have more than one thousand miles worth of contaminants in it, and additive package in the oil would unlikely ever reach depletion.
Personally, I drive about twelve thousand miles a year and change my oil by mileage at three thousand miles.
However, as the wheelbase increases (assuming solid axles and the same tire diameter) the ramp breakover angle will decrease, which in the extreme will detract from it's off road ability in certain situations. However, ramp breakover height will obviously not be affected.
In real life it means that each version will be able to do some things better than the other. Neither will be worse overall off road, it will just depend on the type of terrain being tackled.
I need advice on getting a Wrangler and I think y'all are the people to turn to. I just moved to Denver, have never lived in a snowy area, and learned that a 5-spd rwd compact car stinks! After looking about for cars, the Wrangler really caught my eye. I have about 10-13k to spend, and really want a 6 cyl. model. My main concern is: How do these cars hold up? If I get a Wrangler with 50k miles, will I be able to drive it for years? I have never owned a domestic car and am a little bit skeptical about overall quality. Also, if you do have to do maintenance, is it expensive? cheap? do it yourself? Those are just some of my questions . I would appreciate anything you guys and gals think is pertinent. Thanks in advance!
The best thing you can do is read a LOT of the posts in here, and this should give you a good feel for what Wranglers are all about. You will certainly learn this... we LOVE our Jeeps!
I would highly recommend that you get the 4.0L inline six engine as opposed to the four banger. Out there in Denver, you are likely going to be doing some driving in the mountains, right? The six will get you up those mountains MUCH better than the four banger.
For your price range, I would think that you should be able to get yourself a 1997 to 2000 Sport or Sahara, either of which would have the six cylinder engine I just recommended.
You are certainly welcome to ask all the questions you want to, but reading as many of the posts in here as you can will give you info that you might not even think to ask about.
Stick with us, and good luck in your search. We'll help ya all we can.
Tom
Oh, as far as reliability, the Wranglers are at least average, and I think ABOVE average, in reliability.
I think I like them every bit as well as I like the Canyons, and I like the Canyons A LOT.
Tom
It's not a truck, it's not an SUV, and it's definitely not a CAR!!!
It's a Jeep.........or more specifically a Wrangler........... or more specifically still a TJ!
Now, to your questions. If it's been properly maintained and hasn't been abused, you can expect at least another 100K from a 50K 4.0, and probably another 200K.
Build quality is reasonably good, but it doesn't compare to say, a Lexus. Understandably, model years '97 to '98 1/2 had the most problems.
Regular maintenance items are basic, easy and inexpensive. Certainly a DIY proposition if you have the inclination.
I suggest you settle down to an afternoon reading as many previous posts here as you can manage.
A big time word of caution: when you are thinking "going well in snow," yes a Wrangler is a very capable vehicle, if you are talking about plodding along in deep snow at five or ten miles per hour. If you are thinking about how a Wrangler would do out on the highway under slick conditions, be warned that they have a combination of things that make them pretty quirky, and these are the same things that make them good off road vehicles. They have a high center of gravity, a short wheel base, and a narrow track. You have to SLOW DOWN, which would be smart no matter what vehicle you might be driving under slick conditions.
Also, Wranglers have part time four wheel drive systems, which are not supposed to be engaged on dry pavement. So, when you are constantly going from dry to snow covered pavement and back to dry, a vehicle with full time for wheel drive would actually be better.
Sure not trying to talk you out of a Wrangler, just want you to be sure you know what you are getting.
There is not a single vehicle that you could possibly buy at ANY price that would be more fun than a Wrangler!
Tom
Personally, I'd go for the 3.73s, but the 4.10s would be quite usable. They'd just have the engine rpm a little high when you're cruising at highway speeds, and you'd find yourself changing gear a lot more around town. Whatever you choose, don't forget to change the speedo gear to match!
I moved up to 31" tires and kept the 3.73 gearing. I noticed some loss in acceleration and in the ability to hold speed going up hills. No way it is bad enough that I would go to the expense of regearing from the current 3.73 to 4.10, as long as I stay with 31" tires. But, if you are going to regear anyway, then why not go with 4.10s? They would theoretically put you where you would have been with factory 30" tires and 3.73 gearing.
I don't think the 4.10s would be too much gear for 31" tires, since they would only put you to the equivalent RPM for a given speed and transmission gear that a person would have with the 30" tires with 3.73 factory gearing.
The 4.10s would be much better later on, in case you change your mind and go to tires larger than 31's.
Tom
Maybe I'm wrong. I hope so. This basic bodystyle has been around for more than 50 years and I'd hate to see it changed at the expense of its off-roading ability just because DC is chasing the more adventuresome soccer moms.
There are Jeepers who are willing to give up just a little in order to gain some extra cargo room. I don't think they will have to give up much, though. The Scrambler could sure get around.
Tom
Amongst other things, a longer wheelbase has advantages in terms of stability, load carrying (volume and weight), and of course towing capability and capacity.
Edmunds, thanks for bringing me and Jimbo together. (He saw me in Members Spotlight and contacted me: that's how we met. He didn't even have a Jeep then, but he got an idea about how much fun wheelin' and Jeepin' in general are, so he bought one.) He's makin' me a great wheelin' buddy.
Oh yeah, his brother in law didn't go with us Saturday, but his dad did. His dad wasn't real impressed with wheelin'... he says he will stick to golf.
Check out his pics as well as mine in the itsajeep photo gallery. It turns out that Jim is really good with a camera too.
Tom
The only thing I find a little difficult to understand is the Rubicon version of the Unlimited (or the Unlimited version of the Rubicon?), reported by Bored earlier. Seems a rather strange amalgamation of capabilities!
