Jeep Wrangler
1241242244246247455
  • tjmuddertjmudder Member Posts: 9
    The advantage of going to 16" wheels is that you can go to taller tires, for clearance, without going to wider, poor mileage and highway performance, tires. I went from 30x9.5x15's to Firestone 235/85r16's. These are 32" tall and 9" wide. Super offroad traction and good highway performance. They do hum a bit, but ride about the same, same inflation pressure, as the old tires. I like the hum. The most noticeable difference is the drop in rpm at a given speed, you have to down shift more for steep hills. For tons of info and ratings on tires check out the Tire Rack website.
  • erickplerickpl Member Posts: 2,735
    If you could come out Sunday, bring the boys! I'm sure they'd get a kick out of seeing dad wheel! :)
    I don't want to put any pressure on ya, but it would be so cool to meet as many people from here as I could.
    I won't get to Nashville until 4:30 or so, so I won't get to Cadiz until around 7:00 or so. I may putz around Nashville a little bit so see some country music stars :) heheh j/k. But I'll be meeting Tom at Cracker Barrel at 8:00 for a hearty breakfast before we head to TB Sunday morning.
    -Paul
  • drosketerdrosketer Member Posts: 203
    They're great (look, sound and performance wise). Although, as Mac indicated, I have had them spit up rocks that have been picked up at slower speeds (hear them in the wells and bouncing off various components). The strangest one was a rock I spit up and subsequently hit with my windshield - luckily no chips/cracks....
    Andrew
  • mac24mac24 Member Posts: 3,910
    "...The advantage of going to 16" wheels is that you can go to taller tires............I went from 30x9.5x15's to Firestone 235/85r16's. These are 32" tall and 9" wide...."
    True, but similar options are available for 15" rims. For instance, BFG ATs are available in a 33"x 9.5"x 15", which are 33 inches tall and the same width as the original 30 inch tires.
    Just a small clarification. The '00 30" optional wheel/tire package has 'Canyon' rims, and the Rubicon wheels have 'Moab' rims.
    Okay, dumb question, but is there anyplace that lists the TJ's features/fixes/bugs by year starting with 97 through 2003 or 2004?
    Maybe just a list of major changes between, preferably including fixes.
    -Paul
  • tsjaytsjay Member Posts: 4,591
    We'll need some input from others to go with this, but what I know about is as follows...
    1997
    exhaust manifolds cracked
    1998
    same thing
    1999
    Think there was a fix in place for manifolds for the 99s
    2000
    NV3550 tranny replaces AX-15 (early 00's had the AX-15, those produced later in the model year had the NV3550
    2001
    sail cloth (four ply) soft tops [MUCH QUIETER by all accounts I have read]
    Also, believe this is first year for distributorless ignition.
    2002
    X models come out
    2003
    RUBICONS!!!
    4 speed auto introduced
    2.4 L engine replaces the 2.5 (supposed to be peppier)
    2004
    Not aware of any changes
    Hey, if anyone can add to this, or if I have made some mistakes, someone please speak up!
    Tom
    Have you hugged your Jeep today?
    I couldn't find any M/T's in anything taller than 30", in a 15" rim, without going wider than 9.5". If such a tire exists, let me know.
    I found a 2000 TJ with auto. They're trying to ask 15,000, but TMV via Edmunds is showing 11,000 and change. Wondering what kinds of issues I would have to worry about with a 2000 TJ.
    Here is what it has:
    31x10.5
    aftermarket wheels - nice
    soft top
    aftermarket stereo
    K&N filter
    auto tranny
    51,000 miles
    no tranny leaks
    clean
    I don't know the VIN (didn't write it down), but I guess I could email it to DC using Tom's directions, but would that list which tranny it is? I would prefer a manual, but I found a 98 but it had 110,000 miles and a leaky tranny. It didn't feel like it was in nearly as good a shape.
    It had Smittybilt bumpers and nerf bars, but they didn't match the red/black color scheme of the car.
    -Paul
    Mac can tell ya the model of the tranny, but that 3 speed auto was around for years and years. It was in 2003 that they dropped it in favor of a four speed auto.
    As far as I know, that old 3 speed auto was a real workhorse and had great reliability.
    That K&N filter would worry me some. Maybe it was fine, but there have been reports of dust getting past those filters and into the tube going to the engine. In order to be efficient at trapping and holding dirt, they need to be cleaned and re-oiled on some interval, and I wonder if the previous owner did that? I don't believe in those K&Ns, and the good old 4.0 L has enough power to suit me anyway. Sure, the K&Ns pass more air, but what about filtering efficiency??? Heck, just take the air filter out, and then you will get a lot more air to the engine, but you will also get a lot of dirt to the engine too.
    It is very much in question as to the benefit of the extra air anyway, unless some other modifications have been made. Maybe there have been some other mods to the engine, but that would make we shy away from it even more.
    Give me a used Jeep that just has the good old factory air intake system.
    I would at a MINIMUM talk to the previous owner!
    Tom
    Here's a list of TSBs for the TJ from origination to date. A Technical Service Bulletin details the fix to a recognized problem. It's not indicative of a recall (though it can be), and a TSB isn't necessarily covered by warranty (though it can be).
    TSB Number...Issue Date........TSB Title
     18-008-03 MAR 03 Engine Controls - Co-Pilot Support/Cable Selection
     24-009-02 OCT 02 A/C - System Leak Detection
     08-025-01 NOV 01 Air Bag - On/Off Switches
     19-009-01 OCT 01 Driver Airbag - Trim Cover Service
     24-012-01 SEP 01 Evaporator Drain Tube - Water Leaks Onto Passenger Floor
     23-025-01 SEP 01 Soft Top - Window Zippers Difficult To Operate
     21-006-01 JUN 01 A/T - Fluid Usage
     08-010-01 MAY 01 Airbag/Clock Spring - Service
     18-012-01 MAY 01 Generic Scan Tool - Reference Information
     25-003-01 FEB 01 PCM - MIL ON/Erroneous DTC P1398 (or $BA)
     08-006-00A DEC 00 Wiring - Revised Splicing Procedure
     21-04-00 JUN 00 TCM - MIL ON/DTC P1763 Set
     18-08-00 JUN 00 MIL ON, Erroneous DTC P0107 Set
     08-11-00 MAR 00 CD Player - CD Compatibility
     18-01-00 FEB 00 EVAP System - Leak Detection Pump Misdiagnosis
     23-41-99 OCT 99 Door Weatherstrip - Water Leaks/Wind Noise
     24-21-99 OCT 99 Evaporator Drain Tube - Water Leaks Into Interior
     26-10-99I OCT 99 ABS - Kelsey Hayes EBC-5H, EBC 310 Test Revisions
     02-12-99 AUG 99 Front End Alignment - Adjustable/Offset Ball Joints
     23-29-99 JUL 99 Tailgate - Rattling/Chuckling Noise
     08-23-99 JUL 99 Radio Communication Equipment - Recommendations
     24-13-99 JUL 99 A/C Evaporator - Freeze Up
     18-12-99 JUN 99 Leak Detection Pump - Monitor Test
     08-07-99 MAY 99 Power Distribution Center - Service
     21-08-99 APR 99 A/T - Buzz/Whining in Reverse When Cold
     23-09-99 MAR 99 Interior - Water Leak Diagnostic & Repair Procedure
     26-03-99G MAR 99 Brakes - Teves Mark IVG and Mark 20 ABS Revisions
     26-01-99D JAN 99 ABS/TCS - Diagnostic Test Revisions
     08-17-98C DEC 98 Air Bag System - ON-OFF Switch Availibility
     25-02-98 OCT 98 I/M Testing - OBDII CARB Readiness Monitor Information
     18-32-98 SEP 98 PCM - Flash Programming Failure Recovery
     05-03-98A AUG 98 Front Brakes - Pedal Pulsation
     26-08-98G AUG 98 Brakes - Bendix® Antilock 9 & 10 Diagnostics Revisions
     21-09-98 JUL 98 Transfer Case Shifter - Creaking/Thumping Noise
     08-36-98 JUL 98 Auto Computers - Y2K Effects
     19-04-98 JUL 98 Steering Column - Boot Squawk
     18-22-98 JUN 98 MIL ON, Engine Misfire DTC's Set
     18-21-98 JUN 98 Powertrain Control Module - Service Precaution
     26-06-98O JUN 98 Interior - Air Bag Service Manual Revisions
     23-21-98 MAY 98 Front Seat - Squeaking Noise
     26-05-98D MAY 98 Engine Controls/Electronics/Emissions - Manual Revisions
     24-03-98 MAR 98 Heater A/C Actuator - Squeaking Noise
     05-02-98 MAR 98 Front Brakes - One Click on Initial Application
     23-09-98 MAR 98 Tailgate - Rattle/Knock on Rough Roads
     26-01-98D JAN 98 Brakes - Kelsey Hayes ABS Manual Revisions
     23-64-97 DEC 97 Body Mount - Creaking/Popping Noise
     26-12-97C DEC 97 Brakes - Bendix® ABX 4 ABS System Test Revisions
     26-12-97F DEC 97 Brakes - Teves Mark IV/Teves Mark 20 ABS Revisions
     14-08-97 NOV 97 Engine - High Driveability Index Fuels
     24-16-97 NOV 97 Heater A/C Housing - Water Leaks To Interior
     24-13-97 OCT 97 A/C Manifold - Refrigerant Leaks
     23-49-97 SEP 97 Door Latch - Binds/Door Remains Locked
     26-08-97 AUG 97 Brakes - Kelsey-Hayes ABS System Diagnostic Revisions
     08-19-97A JUL 97 Fuel Gauge - Inaccurate
     24-11-97 JUL 97 A/C Evaporator - Emits Odors
     08-24-97 JUL 97 Odometer - LED's Flash When 4 Way Flashers are On
     14-06-97 JUL 97 Fuel Pump - Diagnosis
     14-05-97 JUN 97 Fuel Tank - Slow to Fill
     23-37-97 JUN 97 Hood/Fender - Rattle/Paint Chafing
     19-09-97 JUN 97 Steering Column - Clicking Noise When Turning
     22-01-97 JUN 97 Tire & Wheel - Runout
     26-06-97G JUN 97 Brakes - ABS Diagnostic Procedures Revision
     26-06-97F JUN 97 Engine Controls - Oil Pressure Sensor Art Revisions
     14-03-97 MAY 97 Fuel Gauge - Inaccurate Readings
     23-30-97 MAY 97 Windshield - Stress Cracks
     07-03-97 MAY 97 Engine - Coolant Recommendations
     18-14-97A MAY 97 MIL ON, DTC's #28, #6A, #9B, #BA Set
     231697 APR 97 Soft Top - Improvements
     181297 MAR 97 PCM - Erroneous MIL ON/Driveability Improvements
     08-09-97 FEB 97 Air Bag - Warning Label Requirements
     23-03-97 FEB 97 Black Plastic Body Components - Chalky Residue
     080197 FEB 97 PCM - Wire Harness Connector Repair Package
     240197 JAN 97 A/C - Evaporator Drain Tube Leaking into Interior
     236996 NOV 96 Paint - Fallout Damage Repair
     183296 NOV 96 PCM - Erroneous MIL ON/DTC's Set/Hesitation
     211496 NOV 96 TCM/TV Cable - MIL ON/False DTC #94 Set
     236396 OCT 96 EZ Entry Seat Back Release Cable - Detached
     082196A OCT 96 Wiring Harness - Connector Repair Package
     050996 OCT 96 Brakes - Noise Explanation
     26-10-96D OCT 96 Engine/Steering - Oil Capacity/Pressure Switch Revisions
     261096 OCT 96 Service Manual - Revisions/Updates
     182696 SEP 96 PCM - Erroneous MIL, and/or Driveability Concerns
     235796 SEP 96 Carpet -Poor Fit/Slides
     241396 SEP 96 Heater A/C - No Air From Panel Vents
     190396 JUN 96 Power Steering Reservoir - Fluid Seepage
     26-06-96A JUN 96 A/C - Vacuum Schematics Revisions
     260696 JUN 96 Service Manual - Revision
     241096 MAY 96 Heater/AC Housing - Water Leaks To The Interior
     240896 M
    The transmission is the three speed 32RH.
    Other than that, I'd echo Tom's comments.
  • chasingericachasingerica Member Posts: 102
    Well I was up at the dealership today and the guys there asked me what I was doing this Sunday. They said they were going up to one of the trail just across the PA line for some fun. They are all a bunch of Jeep guys.
    I'm busy Sunday but they invited me any time that I could make it. Thought they would be a pretty good group of guys to wheel with. I figure if I break anything they'll be right there to take in and have it warranted :) I think I'm going to have to make the next trip.
    Tony
    COOL!
    Go with those boys first chance ya get!
    Tom
    Man, I'd never buy a Wrangler with a list of TSBs like THAT! JUST KIDDING!
    Seriously, thanks for the list!
  • mtngalmtngal Member Posts: 1,911
    Wow! What a list. I read through it and decided I don't know very much about cars. The only thing I must have missed was the '98 dash gauge problem (which didn't affect all '98 models, just some of them like mine). I know there was a TSB on it. I also saw one there about the AC evaporator freezing up. I'd never noticed that one (or else it doesn't apply to my model year) - I have had my AC freeze up more than once and need to check it out. Thanks!
    No worries about that. I'll be out there with them as soon as I can. They had a few pics of the trails they were on and they looked great.
    Tony
  • nolid5nolid5 Member Posts: 148
    I found this cool page - very detailed
    <http://www.geocities.com/jeepboy49028/changes.html>
  • jeepheadjeephead Member Posts: 49
    Paul,
      I've got a 2000 TJ. I've got around 54k miles on it, and haven't run into any problems. As far as I know, the only real problem with the 2000 is the TSB about the debris shield that needs to be added to the engine. There is a place where leaves and other debris can collect, which could catch fire from the engine heat (next to the block). This one seems (to me) to be such a theoretical problem that I've yet to go in to get it fixed.
      The only other thing is that I didn't see what model the 2000 was - if it has the 4 banger with the auto, it is going to be a DOG! The 4 with a manual is slow on road, especially at higher speeds, but is acceptable. The auto and 4 are painfully slow on the road. (Off roading wont' be a problem at all.) I imagine you already know this, but it never hurts to add to the mix.
    JeepHead
    Thanks. :) I was concerned about a 3 speed on the highway.
    I have a 97 TJ with the 4banger(but a manual) and it struggles at 60+, unless I have a tailwind and am going downhill. :) It's low end/low speed characteristics are fine though.
    -Paul
    Tom,
    I hear you on the K&N. I have one in my Grand Cherokee and had one in my Civic. It improved the mileage on the Civic by a couple mpg. But for offroading, I would definitely keep the good ol' factory filters in there. If I did end up with this TJ, I would use the K&N on the road. I keep em nice and moist.
    -Paul
  • dchristo1dchristo1 Member Posts: 59
    Indy,
    I have a 99 Sahara that had the stock Grizzly rims 15x7's with the 30" wrangler GSA's. I just went with 31x10.5x15 MTR's in December.I know that the rim size is different than the Ruby's 15 vs 16 but my impressions driving with the soft top are that the MTR's are pretty close in noise level at highway speeds to the GSA's.Off road performance is much much better(understatement) with the MTR's than the "Get Stuck Always" tires that were on before.
    Just my 2cents.
    David
    OK, Jeep Buds, Paul (erickpl) has arrived at his motel, and we are hooking up in the morning for a breakfast at the Cracker Barrel Restaurant. I just got off the phone from talking to him.
    We should have a good day of wheelin' tomorrow.
    I'll post tomorrow night and tell everyone how it went.
    Tom
    I could get the chat working on Gil's site. :( This hotel computer won't launch the silly chat program.
    -Paul
    Oh well, should probly get to bed anyway. :)
    Got some jeepin and battery chargin to do!
    Have a great time! Sure wish I were there with you. Guess I'll just have to suffer with our fabulous warm, sunny weather. Up here in the mountains the temp today was in the high 50's! While I miss having snow on the ground, tomorrow should be a good day to head for Lieber Mountain or another pretty dirt route. My Noble Black Steed has been sitting all week!
    Have fun! We still need to set a date for our Town Hall Jeep Wheelers Rendevous!
  • back2jeepback2jeep Member Posts: 2
    I bought another Jeep yesterday and it feels good to be back.
    I bought a new 97 kept it for 5 years and I decided that I wanted to go in another direction. I bought an 01 Audi A4...after not liking that I bought a 02 Audi TT. While it was a nice vehicle and I did love it...I just could not stop admiring a Jeep everytime I passed one. Well long story short, the Audi is gone and now I am back in a 04 Wrangler sport...nicely equiped may I add. I must say that it just feels "right" to be back in the only vehicle that I ever been truly happy with. Anyways here is what I got and the price...
    04 Wrangler sport-red
    5speed (the only way to drive a Wrangler in my opinion)
    Soft top
    30 Canyon Group
    Rear-Diff.
    7 speaker w/Sub
    Rearview mirror
    Smokers group
    Add a trunk
    A/C
    Dana
    Tint all around
    etc.
    paid---$21,000.
    Pretty good deal if you ask me
    Welcome HOME! :)
    Glad you "repented of your sins" and got another Jeep. What were ya thinkin' (when you traded your other Jeep)? Oh well, now you have a brand new one, and I'm sure you appreciate it even more than you would have, if you hadn't been Jeepless for a while.
    Thanks for posting and sharing your joy with us. Stick around now and post often.
    Where ya from, Back2? Would be cool if we could hook up for some wheelin'.
    Tom
    Well, Jeep Buds, the Old Tomster and Paul had a great day yesterday. I met Paul for breakfast at a Cracker Barrel Restaurant about 22 miles east of Turkey Bay. After breakfast, Paul hopped in Thelma Jane with me (and Ross Allen, of course), and we drove to Turkey Bay.
    We hit most of the fun spots that I like to go to while I am at Turkey Bay, and Paul really had a good time. Heck, I even let Paul drive Thelma Jane through Bronco Gully!
    Paul took tons of pics during the day, so when he gets them posted, he can share them with us. He uses webshots, I think. He will also post them in Gill's gallery.
    Tom
    Welcome, back2jeep! Sounds like a really nice deal. Once you have Wrangler fever, you can't get over it, except to own one. I still love my '98 and wouldn't trade it except on a new one.
    I can't wait to see Paul's photos! Yes, Paul uses webshots and he has some wonderful photos up there.
  • billy318tibilly318ti Member Posts: 38
    Went out looking for new tires today and the mud terrians caught my eye. I'm debating on the 31 x 10.50 ", or the 30's. Tom, i was reading a post of yours from a while back, and you were saying how the 31's and some other mod's hurt the gas mileage. How bad has it hurt the gas mileage. and with the 31's is wheel spacing all you need,,or is it recommended to put a lift on..
    Thanks..
    No lift is needed for 31" x 10.50" tires on a TJ. That's the biggest you can go, though, without a lift.
    I have the BFG Mud Terrains in the 31 x 10.50 size, and I like them fine. I do have a 2" lift, but I used to run 31 x 10.50 All Terrains with no lift. There was no problem running like that.
    Some people need to add a washer or two to their steering stops to prevent rubbing on the control arms at full turn. This wasn't necessary in my case.
    The rubbing on control arms or on spring perches is a backspacing issue. Most factory Jeep wheels are backspaced about 5" or 5.5". Less backspacing would pull the tires outward, away from the frame. This would give more clearance on the inside, but would make the tires stick out more. I now have 15" x 8" AR767 wheels with 4" backspacing. This gives me plenty of room on the inside and makes those 31 x 10.50 Muds stick out past the flares about an inch and a half. I like the looks with the tires sticking out like that.
    Tom
    I didn't even answer your gas mileage question.
    It would be hard to say how much each mod took away from gas mileage, Billy. I carry lots of extra weight with the Kilby gas tank skid, the rocker guards, the winch, and two sets of tools in the back.
    There's no doubt that the 31 x 10.50 Muds are gonna take their toll on gas mileage, but I would say not more than a couple MPG. I can still get about 16 MPG or slightly better if I take it easy and stay on the highway with no off roading. (Like that is gonna happen.) :)
    Tom
    I live in Phoenix Arizona and that was another reason to buy another Wrangler. There are TONS of places to go off roading out here. The problem is I would say about 60% of require your Jeep to be modded out. Some of the trails out here are really hardcore. So if any Arizona people would like to go off roading sometime...drop me an email.....Mike
    Thanks Tom, i'm gonna have to consider the gas mileage aspect, after hearing prices are expected to soar this summer. Prices are only $1.50-$1.60 in central N.J, but prices are slowly climbing. (Seems to be relatively cheap compared to some other states i've been through lately though)
    Thanks for all the help.
                                     Bill
    You're welcome.
    Just suck it up on the gas mileage: a Jeep looks SO MUCH better with the bigger tires, especially with bigger MUD tires. :)
    Tom
    Tom,
    I had a blast! I counted. I have over 200 pictures. I can only post 25 per album at Webshots. Uploading to Gill's will take a while. :)
    Having Thelma up on 3 wheels for a 10 fooot wheelie was too fun. :) Wish the pics were better of that.
    I'll put the highlights up on webshots, and put the others plus the highlights on Gill's. Sound good?
    I'll definitely put some pics of Stan's XJ on there. He's insane on those trails. :)
    -Paul
    Paul - When are you heading home? It was 91 at my office yesterday! I couldn't believe it.
    Gas is just as expensive as it has been and the radio was talking about it going up again. I think I'll have to take out a loan just to afford to get to work and back - I sure wish I lived in central N.J. It's been running well over $2.00 per gallon.
    Yea i agree that the bigger tires are great looking on a wrangler. I think i'm going to have to go with the 31" muds because eventually, i want a 2" or maybe 3" lift installed (depends how much i'm willing to spend), i figured i'd just go with the 31" muds so when i do put the lift in it'll fit the car a lot better then it would with 30" tires.
    I'm most likely going to put the spacers in, just to be safe from rubbing the tires.
    Tom i was reading the bfg muds can handle poorly in wet conditions, and sometimes hydroplane. I read about 50 different opinions about the muds, about 15 of them saying they had some trouble in wet conditions, but otherwise they said they loved them. Just curious what you think about them. Thanks a lot..
                                      Bill
    Man, I just plain slow down enough when there is a chance of standing water in the driving lanes or when the pavement is slippery that I could probably get where I'm going on racing slicks. (Well, that might be a SLIGHT exaggeration.)
    What I mean is that I keep the lateral g forces down in cornering and keep the speed down enough that I shouldn't hydroplane, or would at least be going slow enough to recover if I did hydroplane. I don't push the envelope, in other words.
    You couldn't get me to speed up under those conditions if you gave me the uncontested best rain tire in the world.
    Having said all that, I have heard it both ways about BFG Muds on wet roads... some people saying no problem, and some folks saying they are not good. I think driving style makes all the difference.
    Tom
    I think it IS true that, in general, a mud tread is not the most desirable tread design for water.
    Some people have them siped, which, I guess, is supposed to really improve them for wet roads.
    Tom
  • leafchildleafchild Member Posts: 24
    Hey, does anybody know what/where a propeller shaft boot is? I had my 03 TJ at the service dept of the dealership for some routine maintenance work, and was told on pickup that my propeller shaft boot was cracked and should be replaced, along with my bent controller arm (which I knew of). I was in a rush at that time, so I didn't have a chance to have them point out to me what exactly they were talking about. Upon running this through a couple of my jeep buds, neither of them had heard of a propeller shaft boot (but they have YJs....), and they think this may be some bogus money making ploy. Anybody know anything about this part?
    Hey, Gal! Long time no post for you. Good to hear from you again.
    "Propeller shaft" is just another term for "drive shaft," and there is a front and a rear drive shaft on a four wheel drive vehicle.
    I don't know what they are calling the "boot."
    Tom
    I have my TB pictures up at Webshots now. It is ony 23 of almost 200 pictures. I have others and if I find some other nice ones, I'll throw em up there.
    http://community.webshots.com/user/skimblz_
    I come home this afternoon, and should be home by midnight. Oh joy. I'm looking forward to the warm. It's been rather cool here. :)
    -Paul
  • mullins87mullins87 Member Posts: 959
    I also have a YJ and they don't have the "propeller shaft boot." However, the TJ's do have them. This boot is located where the rear driveshaft comes out of the transfer case, covering the slip yoke. On the YJ's the slip yoke is exposed to the elements. It shouldn't be an expensive repair and one most anybody can do themselves.
    Well I'm out $500 due to my damn taxes and the fact that my parents are claiming me this year. Since I'm being claimed I'm getting back $40 and change from the feds but I owe the state $140 and change. If I got to claim myself I would be getting back $350 from the feds and another $40 from the state. Funny how that's 500 diff and my mom responds with $100 isn't much to you. Funny I look at it as $400 I'm not getting. Sorry I know this has nothing to do with the topic of discussion but I had to vent.
    I'll make it fit. That's the difference between me getting my half doors now, and me not getting them until sometime after summer. Guess I didn't really want them anyway.
    Tony
    I don't know the arrangements that you have with your parents, but if you are living at home, isn't it worth that $500 as opposed to paying rent and utilities, and buying groceries? You didn't say whether or not you pay any kind of rent to your folks. If not, then you are getting a great deal for $500. :)
    Anyway, I know it is disappointing, since you were counting on getting something for that Jeep.
    Oh well, hope you can find some extra cash somewhere to allow you to get what you want for the Jeep.
    Tom
    I wrote an e-mail to jeep.com asking for my build sheet. Just a few questions of things i never knew i had.
    Axle - Front, Dana 30/186MM
    Axle - Rear, Dana 44/226MM
    Speakers - 7, Inc Subwoofer/Tweeters
    I see the back is dana 44 but why the front dana 30.....
    Also how can you tell you have the 7 speaker with the subwoofer..all i counted was 4 speakers in my jeep...by the way i bought it used and the guy who was selling was out of town so his parents were the ones that sold it to me,,and they had no idea what they were selling to me. So i didn't know all the specs...All his parents could say was it had big tires:)
    Thanks for the help..
                                Bill
    Hey Tom. Yeah I pay rent, I pay for most of the food I eat, and all of my insurances (health, dental, car). The only reason that I'm not out on my own at this point is b/c being a bartender the money isn't comepletely steady and I couldn't afford to have 2 bad weeks in a row. Once I get myself a full time day job or another bartending gig I'll be out in a few months and my parents already know.
    Tony
