Chevy Equinox No Start Problems
                    2008 Equinox sport, the battery has completely discharged causing a no start situation.  This has happened three seperate times in the last month.  No indication of why or when this condition will happen.  After the first two times our GM dealer replaced the alternator and it has happened one more time since then.  Is anyone else having this issue?  There have been quite a few in our city with this same problem according to the boosting company.  GM doesn't seem to be sure of the cause or remedy.
How many months/weeks have you went before these episodes occurred?
One other question for you.. O/T.. have you ever experienced a "popping" noise in the front end between 15-20km/h after a cold start? Some owners have experienced this sound and seems to be common with all models, but GM can't figure out what it is.
Apparently GM has a bulletin on this, #02-06-03-008D, they refer to diagnosis of the battery and/or generator. My generator has been replaced and it has happened once since then. So, am seeking advice ...
We haven't experienced the "popping" sound in the front end in our 2008 Equinox.
Is the dealer still working to fix this issue for you?
Christina
GM Customer Service
I apologize for your experience and frustration. Can you please email me with your VIN, current mileage and involved dealer? I would like to look into your situation for you.
Christina
GM Customer Service
The mechanic who was working on the car also told me the battery was low
and wanted me to stay until he charged it. I was in a hurry so I said I would
wait an hour. He came back a half hour later and said the battery was
defective and had to be replaced. None in stock so I have to go back next week
After talking with the tow truck driver, the service rep , the mechanic and
several salesmen, they indicate dead batteries are common due to all the electrical equipment and computer modules on new GM cars drawing current even when vehicle is turned off.
What irritates me is that this problem must have been known for some time
for a Service Bulletin to have been issued so why was the problem not fixed at the factory or addressed at the dealership when the car was
delivered. It also leaves the question that whether the alternator is inadequate to put out enough current to run all the accessories and recharge the battery when the car is running!
It seems that no one knows how to troubleshoot problems any more. It's replace, replace, replace, at your expense.
Try this.... Remove the NEGATIVE battery cable at the battery.
Connect a battery charger to the battery. POS first and NEG last.
Allow the battery to charge for one hour. If the charger has a working ameter, the meter will display about a 10 Amp charge at first, slowly diminishing to zero charge as the battery is charged fully. This is normal for a GOOD battery. Defective batteries either don't take a charge or show full in a few minutes.
Disconnect the charger and re-attach the NEG battery cable.
If your battery discharges, say over night, this usually means there is a serious voltage draw ( bad alt, partially shorted hot all the time wire/s), anything that will suck a battery down. If there is no voltage draw down, the battery is probably bad.
When did you receive service bulletin? Is there any service bulletin # associated with this I can reference to my dealership? How did the dealer repair the drain problem? I just had the same dead battery problem this morning with my 2011 Equinox!
If you will email me your VIN and question I will look into recall information for you.
Christina
GM Customer Service
Can you please email me your contact information (including a good number to reach you), VIN, current mileage, involved dealer, and a break down of what you are/ have experienced. I apologize for your frustrations.
Have a great weekend.
Christina
GM Customer Service
What is the status of your vehicle? Have your issues been resolved?
Christina
GM Customer Service
been getting automated phonecalls telling me it is on backorder. I am
sure the dealer could go down to Canadian Tire and pick one up but
GM probably wouldn't reimburse the dealer.
So far the old battery hasn't gone dead again and everything but the
power seat memory seems to be working.
Can you please email me directly; just include your Edmunds name. Thanks! Have a great weekend!
Christina
GM Customer Service
Is it a bad battery, a need to reprogram the computer, a short.
I am nervous that the problem won't get resolved. Some told me I should have bought a honda CRV
I hope the dealership doesn't give me a run around.
A new car not starting sucks!
It happened in November when we were out of state, the dealer loooked at it and couldn't find any thing wrong.
GM is monitoring, still this is definately when I wished we had bought a different vehcile.........
They had put a new battery in it after the second no start, saying it was the battery . Maybe time to trade in and go with a honda or toyota.....
Bummer city as now if have to have gm roadside tow it into the dealer and without car for how long............ bummer......
THE SAME THING HAPPENED TO MY 2011 EQUINOX 2 TIMES AND AFTER A BIT OF WEB RESEARCH, I FIGURED THIS TO BE THE ISSUE. MY DEALERSHIP CONCURRED, DID THE REPROGRAM/CHARGE & LIFE HAS BEEN GOOD EVER SINCE!!
We are letting the car sit for a week or so and if you are correct that there is a battery drain, then it won't start, then we will go to a different chevy dealer for service. This dealership, won't consider this information.
I took the car to another dealer's service department and they seem more open to possibilities other than another "bad battery" as cause of no starts.
The G.M. customer service department have been very nice, monitoring the situation and communicating with me and the dealer service departments.
PS How long of car not in use, sitting, is considered a drain where the car wont' start? Out of the 4 no starts we have had with the vehicle, two were where the car sat for a couple of days.
Our apologies that you had trouble starting your new Equinox over the weekend. As you're under warranty, are you planning on working with your dealership to get this addressed? Please keep us informed of your progress on this, and if you would like for us to check into anything further for you we can be reached at socialmedia@gm.com (include your name and contact information and the last 8 digits of your VIN with your inquiry).
Sarah, GM Customer Service
The new battery was $175. Also a terminal was badly corroded, not sure where? Another $50 I was there almost three hours while it was fixed and came away with a bill for $375. Labor and parts.
Now I am gun shy with this vehicle. When I asked how I could maintain the terminals, I was told, no can do as I would have to remove so much equipment before I could even see the battery. What I had come to believe was a reliable stylish and practical vehicle has been sorely challenged
Foxhunter
We are having the same no start problems on our 2011 Chevy equinox.
Here is our Vin #2CNALBEC1B6227875
Can you please check for service bulletins or recalls please.
Shannon & Eugene
So all I did was install a new (charged) battery.
What works - radio and heater fan.
What doesn't work - starter won't turn over or even click, key won't remove (key moves from ACC, Run and Start but not to off/remove), xmission stuck in park, no interior lights, no door locks, no warning gong for key in ignition and door open, can't open rear hatch.
Dash lights say service soon when in run.
Odometer reads correct mileage and battery voltage, but no reading for tire pressure, oil % remaining, etc. (just 3 dashes for readings)
Any ideas? BCM is my best guess now.
P.S. I did disconnect the alternator 12V lead - no change.
