Visitor Agreement.
-twylie
monkey5 - My hardtop didn't make a difference to my Roady's small antenna. I put it on the roll bar on the passenger's side at the corner because I was worried about the clearance between the roll bar and the top. Worked great - much better than when I tried the antenna on the dash of my Taco. You shouldn't have any problems at all.
A RUBI! Man, you didn't mess around on your first "Jeep purchase experience," did you???
Now, just gotta know... you gonna put those selectable lockers, dana 44s, 4:1 t-case, and MT/Rs to good use??? Gonna wheel that puppy???
Where do you live? Would be glad to show you around Turkey Bay, where I go wheelin' every weekend.
http://home.earthlink.net/~tsjay49/
Check out my website.
Tom
Have you hugged your Jeep today?
If you look at my pictures in Webshots (http://community.webshots.com/user/skimblz_), you will see my brackets with doors on.
Navigate to the Wrangler section. Look for the photo of the new rockers.
They work just fine either way and cost less than $30.00. You can install them yourself easily. You just need a Torx bit (40 I think).
-Paul
option A: drivers side mirror + windshield or dash mounted mirror
option B: drivers side mirror + passengers side mirror
It looks like to stay legal, at a minimum you'd need a mirror mover for the drivers side. The passengers side is difficult to see out of once you've used a mirror mover anyway.
HTH
-twylie
No mods so far. I did get all 3 sets of Huskie liners, front, back seat and rear, and they are awesome. Highly recommend them.
-twylie
A RUBICON! WOW! Nice Jeep!
Where do you live? I would like to take ya wheelin', if you could manage to get to Turkey Bay in Land Between the Lakes National Recreation Area in western KY.
Haven't posted a link to my website in a long time. If you want to know more about Turkey Bay, check this out...
Tom
My, my, I feel honored to have TSJAY respond to my post. I bet I've read more than a hundred of your posts. I'm just so lazy about registering for web sites. I live in the great southern meca, Memphis. How far is Turkey Bay from me?
I bought a Rubicon, not because I'm a hardcore off-roarder, but because it is one awesome Jeep, and I didn't want to be thinking that I should have bought yet a different Jeep than the one I bought.
BTW, the good news is, my wife loved my Grand Cherokee (selectrac 4wd). SO we kept it in the family and sold her Toyota Avalon (thank God!).
I've already been to your website. You know, you really should get some sort of soft top, if not for you, at least for Ross Allen ;-)
Smart move getting the Rubicon! Why not get "all the Jeep you can," right?
Bring that puppy up to TB, and we'll have a ball! I won't put you into anything too likely to lead to damage. Just some fun spots.
Tom
P.S. One of the main reasons I have not considered getting a soft top is BECAUSE of Ross Allen. He gets in and out of Thelma Jane right where the folded down top would be. He has to jump a little to get in, and he would just jump right into the top, if it was folded down across the back of the Jeep.
I don't remember if I turned off the headlights when I got to the train station this morning. Would there have been any alarm or warning if I had left the headlights on when I turned off the engine? Mine is a 2004 Wrangler X.
Ray
Hope you turned em off! You think you would have any trouble finding someone willing to give you a jump if you didn't?
Tom
I know I should have a CB for this type of activity, but I'm really not interested in installing a regular size unit. Do you think those handheld types are adequate for off-road only use? I kind of like the Cobra WXST or whatever it is called. I know it's about twice the price of a normal CB, but at least I wouldn't have to install it.
My next question is have you been to the off-road park in Hot Springs and if so, how was it?
I went out the garage and tested Ellie’Mae’s lights for an alarm.
Here’s what I found:
1. There is a warning that sounds when the engine is turned off and let the lights left on.
2. There are both a warning sound and a warning light. The high beam indicator flashes.
3. The warning sounds with keys in or out of the ignition.
4. The warning only sounds when the driver’s door is open (it is not affected by the passengers door).
Hope this helps.
Glen
-twylie
Well, I'll find out when I get back to the train station after work this evening (and I'll be sure to let you guys know).
Ray
You can mount an antenna to the bumper, using the holes where the bolts that hold the sissy plastic bumper corners on go through. You HAVE removed those things, haven't you???
The CB can be mounted in various locations, but one option is to use that little tray in the middle of the dash. Take out the rubber liner and drill the holes for the bracket in the bottom of that tray. If you ever remove the CB, you can put the rubber piece back in there, and the holes will not show.
Bring that Rubi up here! Let's get jiggy widdit! I won't try to get you to do any crazy stuff. If I want to do something that you don't want to do, no problem: I'll run it, and you can skip it.
Tom
You may want to opt for a full CB, but when doing the installation, rig the wiring so the CB can be removed easily. A lot of times you can get knobs to clamp the CB into the frame, but just twist to remove em. Antennas can be set up to be easily removable when not is use as well.
As for TB, it is such that it is easy to get around the tougher challenges like BP Gulch and Silo Hill. If you felt uncomfortable with it, Tom could go do his thing and you could safely go around and watch him. It is definitely fun to watch, and in no time, you'll be following right behind him.
-Paul
This might make a good poll for others on the forum. How many of you have removed your plastic bumper thingys?
Turkey Bay sounds like a lot of fun, and I would certainly love someone with your experience there to guide me. Maybe I'll make it up there in September. The temps will be on the downturn by then. You never did say if you've been down to Hot Springs or not.
Do you guys have any personal experience with the Cobra 75? That looks like the only regular CB I'd like. The handset unplugs from base unit, which can be hidden behind the dash or whatever. I hate installing electronics in the car. The space is tight and the wiring drives me crazy.
I sure was thinking the regular handheld would be sweet...
Yes, I have been to Superlift ORV Park in Hot Springs twice. It's pretty cool. Long drive for me, though... about 8.5 hrs.
I really don't think it has anything over Turkey Bay, but it's always nice to see some new territory.
What's up with this temperature thing??? This summer has been a lot cooler than the typical summer. More rain, but less heat. Come on up! You ain't gonna melt!
Tom
Tom
I removed my front bumperettes but left the rear, figuring they would crush before getting into my rear corners. I've since replaced my rear bumper and am looking to have something fabbed that will give me some protection from rocks without using an entire corner panel.
Have fun with that Rubi!
-twylie
I haven't removed the corners from my bumpers. It doesn't make a difference to me one way or the other whether they are on or not. I've been thinking of mounting the antenna on the spare tire holder, but (like others) want something that is easy to remove.
By the way, do you still use an SWR meter to adjust the antennas? I still have one around here somewhere, I think (along with a very old, full sized CB that hasn't seen a vehicle in at least 15 years). I wonder if the CB would still work - it was working when I took it out of whatever vehicle I had it in. Or have CB's developed so much that it wouldn't be worth trying to use if I decide not to go the remote unit route?
I had a great experience at my dealership. My saleswoman was great! I paid invoice for the Jeep with NO hassle! I was in and out of the dealership within 2 hours (this included my test drive and inspection of the car).
Kai-Ling
What do you think?
Glen
http://www.arizonarockyroad.com/pages/2/index.htm
Glen
Glen
A BRAND NEW DUAL TOP RUBI!!!!! Way to go!
CONGRATULATIONS!
You really ought to get that hard top off at least long enough to remove the soft top and put the hard top back on, if you are going to run the hard top. It is NOT good to have both tops on at the same time. That is done for shipping purposes only. They probably warned you about that at the dealer, and if they didn't, they should have.
Tom
On the way into work today my other half asked what type of options I would want on an Unlimited. I realized that I didn't know what all the options are, since I hadn't been all that serious about buying one. Guess I'll have to read up about what's really available now. Is there really a possibility I could be driving one soon (I can't say that I could have one in the garage - I don't have a garage).
So, (i) remove enough 'stuff' to back Jeep into garage, (ii) hoist hardtop up to the ceiling, (iii) replace 'stuff' in garage, (iv) enjoy new Jeep.
http://makeashorterlink.com/?N470158F8
The remote unit can be concealed behind the dash or in the center console, and all the controls are in the handset. Additional remote units (Cobra AC-701) are available for about $20 to allow installation in multiple vehicles. The price for the whole thing is around $90.
Nothing changes with basic stuff. An SWR meter should still be used to tune an external antenna.
I know Tom has said this before, but this is the most fun on road vehicle I've ever owned.
Doing the soft top the first time is a bit of a chore. I think I wrestled with it 45 minutes getting it installed, but once you've got it on, it's a piece of cake to put up and down. There is nothing like driving with the top down. What a blast.
Congrats on the new purchases.
I went with the Cobra 75WXST. The receiver is installed more or less directly under the coin holder, making it nice and hidden. It does mean that if I ever flood Buffy, it may result in purchasing a replacement unit. From there you have easy access to grounding points and power source. The radio part hangs to the right of the steering wheel, fairly easy to attach to the receiver. The antenna (4' Wilson Flex) is mounted on the stock tire carrier. Setup works well, but I still need to tune it (as it is, I get a little over 1 km range in the city).
The "bumperettes" were removed in short order, front and back. That would make it my first mod I guess (if it counts!).
Andrew
Glen
-twylie
Has anyone installed side steps on a Wrangler X? In the 2004 Wrangler brochure, bodyside side steps is listed as standard on the Sahara and optional the Sport, and is not available on the SE, X, RHD and Rubicon. I have an X and I would like to add side steps to it. Is there any reason why I can't install side steps on the X?
Ray
They cost as bit more, but they will protect the body MUCH better.
-Paul
Toys By Troy makes a version, as does Olympic I think.
-Paul
The factory style steps get hung on stuff and get destroyed, damaging some of the sheet metal on your rocker panels in the process.
Tom
You can get quick disconnect setups for the soft top stuff, that way you can remove the soft top hardware entirely. (You can buy the necessary stuff at a hardware store for less than $10.00, but there are systems ready to install that don't require you drill out anything from places like Quadratec).
-Paul
-twylie
It's pretty cool. It mounts behind the spare using the bolts that hold the 3rd brake on.
When you unscrew the antenna, the mount is barely visible. It gets the antenna up above the roof line without having to use a 10ft antenna.
I don't mean to sound like a commercial, but I highly reccomend it.
-Dan
