Visitor Agreement.
Sarah, GM Customer Service
P.S. try the wire jiggle on the gas pedal terminal too as one of these wires could be loose.
If you want for us to get you more information about any applicable warranties or to assist with working with a dealership to get this checked into, please email us at socialmedia@gm.com with more details (including your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
If you want for us to check into this further, if for nothing else than further documentation, please don't hesitate to contact us at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
P1516 Electronic throttle mod VS, Throttle Position Performance
P2119 Throttle Closed Position Performance
P2135 TP Sensor 1-2 Correlation
It needs to be fixed quickly as I live in a mountainous area and I literally “get stuck” with my two young girls.
My trusted mechanic owns Sabaru here in Colorado springs. We have not had the best of luck going to dealers here and in Denver. We had transmission replaced when we were stranded near Denver and had to push car off the road (literally). It was amazing that it was replaced “no questions asked’ and the dealer there admitted they had to replace “a lot”. That told us that the car brand was having lots of problems.
Our local dealership is: Mike Shaw GM 1313 Motor City Dr 719-636-3881. This is the same place that argued with us about our headlight problems and then after we paid to have them fixed at a cheaper shop, a month later the recall went out about the light connectors.
Right now it is sitting at Sabaru Repair (they have been AWESOME on our subarus and I trust them totally) and Martin and I are researching the problem – and I came upon this website.
Please let us know what GM is doing about this problem. Thank you-
Brenda S
We're sorry to hear that you don't feel safe in your vehicle. Are you at all considering working with a GM dealership to get this looked into? Let us know if we can be of any assistance in that process! We can be reached at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
I have the same promlem, mine is included with Traction control needs service.
for icy weather, when its warm no problems but suxx in the winter I love my chevy but dont know what to do went to garage change wheel bearing but came back shortly after
Very unhappy.
PCM Pic 1
PCM Pic 2
PCM Pic 3
The Blue in the terminal is a bunch of Icemelt salt that had found its way into the airbox with water and rode the wires down into the PCM plug and corroded some terminals, including the Throttle body wire connection. He cleaned the terminals with air and got the corrosion off them and the gunk out of the plug and got the moisture out and for 3 days my car has been running with no hiccups even when the traction control has kicked on a bunch of times on slick snowy roads (which caused the reduced engine power before) The PCM is located in the bottom of the airbox as it requires air to cool it, although it doesn't require salt. Someone who owned the car before me apparently had the PCM box off ripped a gasket and put it back on with half a gasket. Luckily so far it doesn't seem like permanent damage was done to the PCM.
If you need assistance locating another dealership in your area to get this looked into, please let us know! Send us an email at socialmedia@gm.com with your request and ZIP code.
Was your garage one of our GM dealerships? If so, we'd be happy to follow up on your visit there. Please email us at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and as summary of the situation so far).
The ECM for certain 2005 through 2008 Toyota Corolla and Corolla Matrix models equipped with the 1ZZ-FE
engine and two-wheel drive may have been improperly manufactured. There is a possibility that a crack may
develop at certain solder points or on varistors on the circuit board. In most cases, if a crack occurs at certain
points or on certain varistors, the engine warning lamp could be illuminated*, harsh shifting could result, or the
engine may not start. In limited instances, if cracking occurs on particular solder points or varistors, the engine
could stop while the vehicle is being driven which may increase the risk of a crash.
The end result of this failure seems to be very similar to the Chevy reduced power problem many owners are experiencing. The vehicle may shut down at highway speeds and cause a crash.
My point is Toyota has seen the problem and is trying to correct it. I hope to get many good years of service from my Chevy but I also hope GM recognizes the problem many of their customers are experiencing and does something about it. I plan to remain a GM customer since I think they still build a quality product. I can see how many of the people on this forum are getting frustrated with this possibly life-threating problem.
Will you be working with a dealership to get this checked into? Please let us know if we can be of any assistance! We can be emailed at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation so far).
Depending on when your vehicle went into service and how many miles it has on it you may still be within your bumper to bumper warranty (3 years/36000 miles). Please don't hesitate to email us at socialmedia@gm.com if you have any questions! Include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of your inquiry.
