2010+ Buick Lacrosse - Options
As the title says, issues related to options, except where there is a more appropriate discussion. Such things as factory and dealer options or add-ons.
Can someone tell me what you got in yours?
On the Malibu it was a clear plastic film on door edges, rear end, and one on the bumper to protect it from scratches when accessing the trunk.
I think I'd like to have the film at all those locations.
Is there an aftermarket version?
I saw a new one that showed the package on the window sticker but the vehicle did not have flaps or protective film on it.
My CXS stay pretty clean w/o mud flaps.
The flaps I saw in picture are quite small, but may be valuable against stones being thrown by tires.
On two occasions the screen became very dark, once to the point I could make out nothing.
Both times it happened when the headlights automatically came on.
The other day I was under a thick canopy of trees about 1630. I adjusted the dimmer control on dash to full brightness and that did not help. I gave it the command "Display Day" which it accepted but did nothing.
Also the camera has trouble with late afternoon images. They appear blurry and unable to adapt to lighting conditions.
Has anyone seen these issues or a fix?
I was by the dealer today because of issues. First by sales. Another salesman wandered by and I asked him about the seat memory. I showed him what was going on. No problem he could fix. He was going to turn the memory function off. I'm glad his customer was standing nearby when this occurred, and I think he left.
I was then shuffled over to service manager. He told me someone did something to the car, the crease that has paint in it? Also did not seem to want to do anything related to the flaws in headlamp. He was going to look into the Nav display issue and seat memory issue.
Have you taken the vehicle to another dealership in order to get a second opinion? Does this happen intermittently? Have you tested the vehicle on an incline at the dealership with a service tech with you? Thank you,
Mariah GM Customer Service
http://townhall-talk.edmunds.com/direct/view/.f21a666/1#MSG1
Has anyone else experienced this?
In the NAV manual, page 100, there are several commands that in brackets it says, "(used in conjunction with another command)". Does anyone understand what that means?
Some of the voice commands seem stupid, such as the first one to access phone capability if you have NAV, "Hands Free". Is not that the whole purpose of using voice commands? Why is it not "phone, telephone, or OnStar, etc.".
And on the subject of "hands free" voice commands to the NAV system, it seems stupidly limited. Example, Show Gas, Hide Gas. It seems to be an all or nothing, no asking for particular brands. That is if you enter manually, you can get specific brands from a list to show, such as Shell, Chevron, etc.
I had manually done such with Arby's fast food. And then tried the voice for dining. Show plastered map with location symbols, hide removed all but Arby's and I had to dig through menus to get it removed manually.
What seems to be very limited commands I can compare to a very old program, Corel 7, which had a speech add on by IBM which enabled basic menu commands, no voice to text. That was the time when the fastest CPU was 200 MHz, biggest HDD 2 GB. That was 5 computer lifes ago, so I wonder why this system seems feeble.
My old Bluetooth phone does a better job of recognizing commands accurately, using voice pass-through.
I recently tried entering a destination with voice. It worked fine until I got to the street and then it kept popping up a list that did not contain the correct one. I could not find a way to enter it manually without losing the state and city. That is manually entering the entire destination.
When will GM come out with an update to fix these issues?
Sadly, my money is on 'never'!
GM better start making mine fixed or it will be the last.
Page 27 of Nav manual. The playlists I'm familiar with are associated with specific programs such as Winamp, Foobar, & WMP. I think each one uses its own format or extension for saving playlists.
Are there any other known playlists that are recognized? It might help eliminating music in folders as a predesigned playlist substitute.
My daughter set it up for my wife so I'm not familiar with Apple apps other than the ones for computer use.
I turned on ACC, HDD, & played a couple of tunes in the cool quiet air and cranked the volume a bit. Beetles 'Come Together' with some very bassy passes. Then I played "He ain't heavy, he's my brother". That has some very nice higher harmonic and other, but with very little low bass. It was with this tune I learned just what the sound system is capable of, minus the bass issue, and you won't believe us less you try it.
Or will You?
But this should convince you especially if you try same tune of equal to mine. That this is a fantastic system with acoustics that don't quit.
BTW I learned reason the bass is distorted. I have not yet decided upon fix but I've located the harmonic spot with issue to within inch. I'll see if I can come up with esthetic appearance to fix as well as let it churn out the bass notes it is capable of.
A hint at one of the surround or stereo point of this system. Pick something that has a wide front with vocalist center.
I now need to do more road testing to see what interference there is to the quality. Air and road noises might reach the level of deterioation that is objectionable, subjective to me. I'll post what I learn related to driving.
Several places I've read indicate this is a non-lossy format, but when I run conversion using Foobar it pops a warning that I'm converting to a lossy format.
If anyone has experience I'd appreciate feedback.
Maybe it is the Nero encoder I'm using?
But I will copy to disc and see what happens. :shades:
Still somewhat uncertain, but I've read that m4a is not lossy and will give exact quality of CDA but in a much smaller file.
Example, the Beatles One album, 1Hr 20 M long. That is a little over 1GB.
If you transcode it to MP3 at the highest rate, the file is about 200MB. I'm not certain because three songs I transcoded at a lower rate just for comparison. My coding to m4a yielded a little over 220 MB, but I think I used the standard rate which is deemed CD quality. That would mean four times as many full disks to the HDD.
Does that help explain it.
It turns out that windows built in burning must have gotten corrupted. Added other burning software and burned files the car would not previously read.
M4A is really great!!
What I've also learned is that the system reads a CD just like the computers HDD. That is if you use the Nav screen for listing what is available, it reads the file name which means it is best to use the Artist, Album, song, etc for naming files, but it reads the tags to get that info when displaying what is being played.
The HUD could confuse since it says MP3 List, not an MP3.
BTW I used highest rate and 1:59 of music only take 325MB. That would be 60 hours on HDD. I'll try lower rates to see if I find them satisfactory.
Does anyone know what it is supposed to do?
And only a couple of hours earlier I fueled and reset everything. Brainfart? I'm thinking that I had the tire pressure sensors showing but uncertain. I guess what confused me was the sound coming from the NAV system and then looking in that area to find what the chime was.
Thanks (with a red face).
Could that be where the odor is coming from??? (Please don't erase this message for that) :P
I'm unhappy with the dimming that is controlled by the rocker button. Under quite dark conditions the speedometer area is too bright. Turning that down to what seems proper results in the blue lighting going out and before that point the Nav display being too dark, even in day mode. I learned this recently on a long drive with night driving.
This is a safety issue!
The Nav system is a safety item. Adjusting the guage area to a safe level for night time visibility makes the Nav Display useless.
Is anyone else having this issue?
It seems that having the Nav Display tied to the dimmer should not have been done, but handled by Day/Night mode instead.
That is 1:59 is 1 hour 59 minutes.
Or about 6 hours of music per gigabyte,
or 60 hours of very high quality music in the allotted 10GB for music on HDD.
I will also the next time I'm in. And from now on if my complaint is not satisfactorally written, I will add my own statement when they ask me to sign work order. It might even say, "See attached sheets!"
I forgot just what the reason was they were replacing memory module for you.
They did not answer my complaint on memory issues and next time I will have both FOBS and show them what the issue is.
Also the part of busted battery case. And they say battery is 60 month when installing dealer wrote it was 30 month. Tomorrow I will pull and verify myself.
Is the brightness level between standard guages and screen comparable?
One knob sets the HUD separately, so no problem there.
The guages, blue lighting, and Nav screen are tied together.
Full brightness is OK for some city driving, but for most city I'd prefer it turned down to at least where blue lights disappear, approximately 1/2 way. At that point the Nav screen is getting rather dim and hard to see in day mode, but even darker in night mode.
Out on dark stretches of highway where I'd prefer something resembling a black cockpit, dimming properly just is not feasible with this system design or problem.
Mine shows that it has an early 2009 Navigation.
I'm still hoping that when they do release an update it will fix other issues like shortage of voice commands.
I just keep hoping that they will come out with a firmware or software update to fix some of the other issues. There were quite a few complaints about early 2010 models and some features not working at all. Some of these features were supposedly enabled in later model.
I'm still confused on this voice command:
Route (used in conjunction with another command)
I don't see any use of that word, route, elsewhere in instructions and in most cases find (used in conjunction with another command) confusing and not comprehensible.
I found the road updates nice when it worked. Helped me avoid some bad stuff in Chicago. But on rural interstate I never got updates when traffic was delayed for over 2 hours each time because of accidents.
Is this a weakness in the system?
It also appears that part of system may not be working since renewal.
Also I'm not sure the quality of music is great. I'm not sure if it is XM method of sending signal, maybe a low quality stream? Does anyone know what their stream and compression method are?
I may try to find a couple of high range CD, checking for good low notes and trueness of ringing cymbals or bells.
I get the impression the quality is no better than a cheap tape with hiss removed.
The traffic updates require some time for reporting to get into the system. Whenever I have gotten them, they were accurate and timely.
Good luck with XM Customer Service. They are the worst, especially on billing. They can't even quote their costs correctly.
I have a related but different dilemma. I like OnStar but I also have AAA at $70 per year. Since I have a built-in NAV system in CXS, turn-by-turn service with OnStar is redundant. Furthermore, with my cell phone and Bluetooth I never use the prepaid minutes with the OnStar phone. I am very happy with AAA as they show up immediately when you call and the discounts at hotels and other places are fantastic.
OnStar was a great technology 10 years ago but given the many technology options motorists have today I think OnStar has lost its allure.
If you are into burning your own music, there are some streams from London that are ogg-flac at around 1Mb/sec. FLAC stands for free lossless audio codec. That is you get what was on the CD, not some chopped down version.
The AFL, xenon that aim with steering, are part of Driver Confidence package available on CXL & CXS, unless they've changed availability again.
I also like the ease of turning fog lamps on. Not true fog in my opinion or they'd be amber, but when driving slowly they add to close in lighting. It would be a pain except for that big round button that only requires a tap to turn on/off.
I also tried a program a computer club friend mentioned, Exact Audio Copy (nice interface, many options) but there it created .wav files OK but then couldn't use the Nero CODEC.
Which CODEC did you link to Foobar and what m4a method, AAC ?
Were you able to intermix mp3 albums with m4a on the same USB memory?
