Visitor Agreement.
I recently went to a touch free (high pressured) carwash. I had the interior roof panel open and was watching the over head power washer. As the machine passed overhead I felt a drop of water hit my face and noticed a large drop of water coming through the sunroof mid point. It leaked into the metal type bar that sits under the glass but above the interior roof panel. My car is garage kept so I did not notice a problem before and also had no reason to look for it. Two days later it rained steady but not real hard . My car was parked outside when I got in it I put my hand along the metal ledge and sure enough it was wet. I am really disappointed with the quality of my car. I already had to replace a seat belt clip in the back along with some other interior flaws. I owned a chevy Blazer for 13 years prior and never had a problem.
If I didn't go to the pressured car wash I don't think I would have noticed the leak until there was obvious damage.
How do I cancel the current destination while driving? Is there a quick and simple method to do so? I always need to go through the menus to do this. I am sure there has to be an easier way.
How do you do the window and sunroof roll down with the remote? Anyone tried with their 2010 RX?
Not so. It is an older classic click wheel model and for some reason the system will not recognize it.
We have the latest software for the ipod and we are wondering what might be wrong and whether there is anything we can do to solve it. It works just fine on our usb hub on the computer at home and can't understand.why is there a problem in the Lexus. :confuse:
thx
Most people are not aware of this problem, I noticed something was wrong with my bumper and saw that it was not secure. I hope other people will see this and be aware of the problem. Lexus know of the problem and they are trying to rectify it. I will let you know had I make out.
Hopefully they can fix it.
Cheers.
JB
TIA.
Unless your tank is empty, there's nothing else and you're 350 miles from the next gas station
I will have this problem addressed when we are in Arizona this winter. Latest posts say that Lexus has a fix for this problem.
JB
I've been putting regular unleaded in the 2010 RX. I haven't had a chance to check with my service tech as to using unleaded vs. premium in the 2010. My stepdad has a 2010 RX, and he puts premium unleaded in it, but he's only getting 1 mile per gallon better than I am. By the way, the 2010 RX is not getting as good of gas mileage as the '07 was.
JB
Which is correct? Also, there are missing colors on the Lexus Web Site vs Edmunds???
Help
Gimme was asking how to translate package A, B, C etc to a term that is meaningful like Premium, NAV etc...
Gimme, you can probably guess the package by looking at the content of each package and match with box checked in package A, B, C etc.. I have the same problem but since the dealership is close enough, I will just drop by and check out on what is in the lot...
In regards to the heated seat, no vehicles heated seat should be making an odor. I would definitely have that looked into. I have seen a few Camry's and RAV-4 heated seats turn the seat brown and some reports of getting to hot but never an odor. Your seat might be getting too hot and releasing an odor from overheating maybe :confuse:
Unless someone peed on the seat, or worse...spills..?
Sounds like a muffler exhuast, but no noise in park only in drive. Anyone else have this occur.
My hatch makes a noise (driver side only,) opening and closing.
A (too) low idle speed will sometimes result in the engine lopping and the associated vibrations.
Lexus may have also made a bit of a compromise in idle speed in favor of a slight FE improvement. I'm continually amazed at the little things (lower volume ATF sump...{***}) that are being done in the name of FE, but I suppose when you add up the gain from ALL of those little things.....
*** SEALED transaxles: Fill level is now too critical, plus OR minus, to allow the average DIY ready/easy access, and most certainly so for the low hourly pay McD flipper graduates that most dealers use for routine (maintainance) tasks.
Then again it may just be the beancounters, less ATF for the factory fill and lower metal content for the muffler(s), or maybe even one less muffler. Note that lower exhaust restriction might also improve FE.
Could it be both...?
ALSO HAVE SAME PROBLEM WITH FRONT BUMPER. LEXUS REPLACED BUMPER THREE TIME AND THE GAP RETURNED 3 TIMES. I AM IN CONTACT WITH LEXUS BUT NO RESOLUTION TO DATE. PLEASE STAY INTOUCH AS I WOULD LIKE TO KNOW IF YOU HAVE RESOLVED PROBLEM
