That's exactly it, too. Whenever there's a lag in interest within a trade, the pain comes way down the road as the industry has to reinvent itself in order to recover.
My primary hesitation every time I consider replacing a car is the added complexity of it that a shade tree mechanic like me has no hope of understanding. At the core, they're still machines, but that means less and less these days because it isn't the machine part that goes awry most of the time.
Also noted was the RH downstream sensor connector was not secured to the bracket at the side of the transmission as designed, it was simply laying on top of the exhaust and had suffered some heat damage but not to the dont that it was at risk of failing. Those two issues were solved and confirmed to operating correctly at that time. Keep in mind the B2S2 sensor has been replaced at least two times. I can't rule out some intermittent issue or sensor performance problem at this time. I left the advisement that if further troubles are presented, that an O.E. sensor should be considered.
The misfire. Road testing with the Ford IDS made it easy to see the misfires were logging on Cylinder #1. While the misfire was common it was falling short of the counts that result in a trouble code for that cylinder. Getting back to the shop I ran the relative compression test and that passed. Normal misfire diagnostic require confirming good spark and the tool of preference is called the ST-125. This is a tool that looks like a spark plug with no outer electrode and it takes 25,000v of energy to jump the gap or "spark". The ST-125 showed some sparking, but occasionally it stopped and the spark was observed to be coming through the insulation of the spark plug boot. Taking a grounded probe to the boot allowed the spark to constantly arc through the boot instead of across the gap of the tool. The misfire was confirmed to simply be a bad plug wire.
Now you CANNOT reliably replace just the wires. The old wires gong onto a set of spark plugs scratch the porcelin and encourage carbon tracking to occur due to the high spark Kv demand on a lean burning engine. Once a carbon track starts, say on a plug if you replace the plug but not the wire the carbon tracking of the wire transfers right back to the plug. Now replace the wire, and your new plug which is now also carbon tracked fails shortly afterwards. You literally end up repeatedly replacing the plug or the wire until you finally replace both at the same time and stop the insanity. BTW, if you don't do all of the plugs and wires Murphy's law takes over and then you have another plug and/or wire fail and the customer comes back saying It's doing the same thing again".
Now when I was road testing I noted that the engine load pid during a hard acceleration only hit 70%. Normally I would be looking at fuel trims to help determine if that is a mechanical issue with how the engine can pump air, or if it is a MAF sensor problem under reporting air flow. The problem is with a misfire, fuel trims shut down and the system doesn't learn so it cannot give me that data. Not to mention the O2 sensor issue also had the fuel trims unable to learn. The plugs and wires needing replaced are essentially a tree blocking the view of the forest and that must be dealt with before we try to go any further.
So I called the
customerconsumer and ran down the details with him. When I gave him the price for the plugs and wires he said "Well I can get them done for a better price than that". Then he proceeded to change his story about who had done what and when and allegedly his old engine had gotten new plugs and wires when all of this trouble first started, and the junkyard that installed this engine had said that they either put new plugs and wires on it, or would do it, but then finally admitted they didn't do it after he talked to me on the phone.So he's supposedly going back to the junk-yard to have the plugs and wires done. After that is done, I could get to watch the fuel trims learn and that would help me decide which way we need to go to correct the low engine load pid on a hard acceleration and take the last step towards solving this for him but I'm not going to. If I'm not doing the repairs then it simply isn't worth the effort to be involved any further, and people wonder why its hard to find a good technician.......
What did you guys do before sensors anyway?
I thought of a new model. Now that cars are so computer intensive, and with internet technology, become more of a guru, and handle some things remotely 9diagnostics). And keep the shop as an escalation point, working for other shops. basically work on a contract basis for the stuff they can't handle. At a price, of course!
A company in North Carolina is already trying to do that. They can handle remote reprogramming but the real hard diagnostics require a hands on approach.
There is some potential on the personal side to make this work, and really 50% of what I do today is already directly for other shops. When I evolve to close to 100% then the prices would get to be more ready to reflect the real value for what we have been investing. But there is a catch. While it could be good for me, its bad for the trade and the consumer. By making it possible for the others to continue to take the easy way out and not make the investment in the tools and their people they won't be prepared for the day that life does what life will do and we won't be there anymore. They will then be painted into a corner that they won't have a way out of.
my son has a 2000 Acura TL with him at college. 170K, but runs great. Until last weekend. Driving along, starts to lose electric (dash getting wonky, warning lights coming n (ABS/TCS etc.). runs rough, and dies. Gets a jump, makes it a few blocks, ties again. Gets towed to Honda dealer, they can't even jump. Put a new battery in, fires right up. They test the alternator, and say it is charging, so good to go.
2 days later, after a few mile drive to the store, starts doing the exact same thing, then totally dies and won't restart. almost made it to the dealer (1/2 mile away!), so needs another tow.
well, I talk to them today (he left it last night and they say it started right up, and is running fine. Battery was charged, and alternator is putting out. So they were driving it around the lot, trying to get it to act up, but nothing. Said they looked at the obvious stuff (the grounds they could see, loose cables I assume) and nothing. No fault codes stored either.
so, seems to be one of those intermittent deals that either needs a genius, or a lot of time spent (and my money of course!) to debug.
The big hassle is he is at college (4 hours from here) so I can't really do anything, and he has neither the time nor experience to be chasing after it. And he does have a car that can't be trusted to get him home when needed.
does have a nice new battery though!
According to the note at the top of this page; this question should have been posted in the Edmunds Answers forum. It is understandable that you posted it in this forum because of who you were responding to; but the moderator might feel it does not belong here.
While a parasitic drain can cause a dead battery, it does so when the car is not running, and then you fail to start the car after it has been sitting. Yu are describing a loss of system power once the car is already running, for a period of time.
Is the battery genuinely dead when the car quits, or is it simply not able to deliver power to the vehicle? When the problem starts to occur, someone needs to get a voltmeter on this and measure battery voltage, measure alternator output voltage, and measure for voltage drops on the alternator output, and the ground circuits. You can't just "look" at them, they need to be tested under a load, and/or during a failure event.
In the "sounds like" catagory I suspect your losing alternator output and simply running on the battery until the battery can no longer keep the vehicle going. Just because the alternator tests fine sometimes, does not mean that it is OK all of the time. I'd hook up testing equipment, turn on several vehicle loads to stress the system and simply let it idle until it acted up and then troubleshoot the issue. If you don't get an answer to the problem soon, let me know exactly where your son is at and I'll locate a shop to direct you to that will take the time to solve this.
And I realized that I made a mistake when he first took the car up (2 years ago) in not scouting the area, and setting up an "account" at a local garage, just in case of emergencies. That's how we ended up at the Honda dealer. Usually a little more expensive, but in theory they should have full knowledge of the car (and all the diagnostic computer tools), but I suspect a much lower tolerances for actually spending the time diagnosing like you described.
if for some reason this does not eliminate the problem, I'll let you know for a reference.
"Automotive person with Leadership skills wanted.
We are looking for a person with an automotive background
who is self motivated, organized, has a hard work ethic and
a positive disposition. ASE certifications a plus especially
in brakes, diagnostics, and transmissions.
We are an established business who has been operating for
over 30 years. We control several locations in the Spokane
area. We are looking for a stable person to add to our team.
Looking for a candidate who has a clean driving record, at
least 25 years of age, non-smoker, who demonstrates
leadership and organizational skills. Clean cut and
professional appearance needed.
We are looking for a person who can multi-task and pays
attention to detail. Word dependability and work stability a
must.
Starting pay $10 to $11 per hour DOE"
We pay workers TWICE THAT to hand pick grapes in the vineyards.
How much are you willing to bet that they claim to beat everyone elses prices on the street?
Any wonder why there is a shortage of qualified technicians? There are a lot of capable parts changers and that company isn't even offering those kinds of wages. The add says they have been in business for thirty years, looks like they think they are still working on 70's and 80's cars.....
His field is so new, and changing so rapidly, he said, that there is little consensus on established practices or necessary skills. “It’s more difficult to know what we should learn,” he said. “We have advisers that we work with, but a lot of times they don’t know any better than us what’s going to happen in the future.”
Instead, Mr. Mehta, 26, spends a lot of time comparing notes with others in his field, just as many professionals turn to their peers to help them stay current. The International Automotive Technicians Network, where mechanics pay $15 a month to trade tips on repairs, has more than 75,000 active users today, up from 48,000 in 2006, said Scott Brown, the president.
To continue to try and remain current in your career imagine having to study some twenty hours a week, on top of the fifty+ you put in your business, plus the sixteen you put into a classroom and you have an idea of what I have been investing for years.
BTW the classroom part is only during the last five years, previously those hours would have been simply spent studying or in the shop working. Add in travel time to get back and forth to those classes and yes I do 100 weeks. I've been a sponsoring member of the iATN since March of 97 back then there was about 6500 members worldwide. It was my contributions there that opened the door to the educational side of the trade for me.
They'll be lucky to get a guy to even show up at that pitiful rate. Maybe Zutroy who's fresh off the boat will take the job?
"...and if you diagnose and repair every electronic system on that 1999 Mercedes S600, there will be a shiny new nickle for you, Zutroy!"
Turns out the ad was usually for a position they wanted to be filled by someone from the H1-B visa pool, and they had to run local ads and show that there was no takers in order to be able to hire the foreign worker, who was willing to work for 50 cents on the dollar.
There is definitely demanded skills/credential inflation in relation to pay, and it doesn't seem to be held to similar standards for managerial/tenured suits who are allowed to remain oblivious. At least at my workplace. Beginning analyst jobs now want a degree and some technical competence - when I started, you could get away with one or the other. Doesn't seem to have created any better classes of new hires, either.
That grape picker is probably paid piecemeal and may earn $27/hour if the weather is perfect, the back isn't aching, etc.
A middle school teacher ranges from $29,648 to $63,850.
A farmer field crop worker ranges from $12,746 to $73,017. Farmworkers way less ($5.03 to $12.73 hourly). Don't ask me what the difference is.
It's not as dangerous as hauling nets on a fishing boat, but it's no walk in the park. You gotta pay attention all the time.
Injuries are simply part pf the job. As far as just how dangerous it is you also need to factor in road tests, and roadside assistance risks. On a dangerous stretch of interstate near here if I get a call under specific hours I'll leave with my car to get the people off of the highway, and then go back out with my truck to recover their car. That way I'm the only person at risk.
Two days later she called to say that she wanted the work done but didn't have the money and wouldn't have it until today the third. I advised her to plan to drop the car off at her convenience and we would complete the repairs so she could pick it up completed. It didn't show up. Then she called again and it was the same conversation only this time I had to schedule her for Friday. Today she calls and say's that she went somewhere else and got all of the work done and she wants to come in and get the sticker. It doesn't work that way. Pa regulations require the vehicle to be completely re-inspected if it leaves the premises. The regulations are very clear, it isn't free to have the vehicle re-inspected when required. Shops however can choose to do so for a customer as the inspection price is not regulated and market forces are allowed to set the pricing.
Having listened to her intentionally be dishonest more times in a few minutes worth of conversations than I care to count and having her also make a false claim that my wife told her that what she decided to do (go elsewhere for the work ) was OK I decided enough is enough. I asked her why wasn't the person who did all of the work inspecting the car? Her answer was because she would have to pay him to do so. I explained to her that she would have to pay us too, because I have to not only re-inspect her car I have to be sure that the repairs were done correctly.
That concept was very difficult for her to grasp. After numerous attempts by her to still manipulate a bargain I finally told her that as far as I am concerned she is his customer for now on. That was the first time that I think she genuinly heard and understood exactly what I said in any of our conversations. For several moments I heard silence on her end of the phone. Your serious about that she asked? Yes I am I replied.
If she is lucky her car will never have a failure that they cannot fix. If her car ever does have a problem that they can't handle, they won't get to sublet it to me like they usually do. My Choice.
stateCommonwealth of PA claims that it's a great saver of body work and medical bills but I wonder if the cost benefit ratio really pans out. What's your opinion "from the ground"?I actually have a local guy that I like and have used over the last couple decades. Far as I can tell, they are sharp and on the up and up. Really only had them do 1 out of the ordinary repair (evap canister on my Accord), and while it might have been close to the dealer cost, they did go above and beyond to address an issue. So maybe a crapshoot at times what is cheaper.
I just don't use them for under warranty stuff. Including the oil changes at the dealer. Same cost (if not cheaper at the dealer), plus I want them to have the records if I have an issue and need a good will!
on an older car if I get one? They can do the PPI and the basic repairs.
Tell me something, when is the last time you noticed a car sitting alongside the road with one of the front tires sitting at an odd angle because of a sperated tie rod end or ball joint? That's a very rare occurance around home because we find the joints that are failing and replace them before it happens. Drive into Ohio right next door to us and it's rare to not see one. I just taught a class in Indianna, I was amazed to see the trash that was still running around on then road there. The stories from the techs about suspension parts tied back together with bailing wire, and in one case a T-shirt were enough to make me happy when we got back home and off of their roads.
My shop is one that doesn't make a living doing the state inspections, I spend almost all of my time diagnosing and repairing electronics on the cars. There are many shops that if the state inspection program was shut down it would really hurt their businesses. We of course have a number of consumer types. Ms discount tire is an exception to the rule and not a typical customer for me. My regular customers would bring their cars in to be checked and repaired even without an inspection program. Anyway back to this lady. I still cannot get over how she kept trying to feed us one line of BS after another as if we aren't supposed to be smart enough to know better. She came to us because someone else had reccomended us. (Not sure if I should thank that person or not, VBG) Cars I can fix, people I cannot so in the end she really needed to move on down the road. My customers need to be able to trust me, and I them. Nobody would put up with us being as dishonest like she was nor should they. That's a two way street whether she understands it or not. People like her ultimately cause a shop to suffer a financial loss that get's passed onto the rest of the shops customers as part of the cost of doing business.
Well, maybe once or twice. In the last ~40 years. Must be some strong t-shirts out there. :surprise:
If the car is unsafe but the owner can still (illegally) drive it, then the inspection program doesn't seem to have much teeth. Wondering why bother.
One of my first jobs was a (mercifully) short stint in retail. You learn pretty fast that people either don't know what they are talking about or they lie. So do clerks, who will push one product over another for the extra commission. Not that I ever did that. :shades:
So you apparently have never made such a mistake, is that a function of your superior technical talents, or is it simply that you haven't had enough chances to have fate catch up with you?
No major league pitcher ever managed to strike me out. That's a fact that is based along a similar vein as your (or anyone else's) having never drained the wrong fluid, or misconnected battery cables. Given enough chances it would eventually happen.
Frankly as I read the last several responses I asked myself if any of you were qualified to perform those tasks unsupervised in a chain store, or my shop. I think it's safe to say it would be a regrettable decision (for the shop) to try and find out.
Check out his posts in some other forums and you will see he pretty savvy mechanically and in appraisals.
