Chevy Silverado - Continued XVIII
It was off
Truck has been drifting right lately (probably last 2500 miles)
Toe was really off that was the main thing wrong
Also the left side was worse than the right
Drives and straight as an arrow now. Big difference in the ride.
The coupons are 1 per vehicle (too bad because a glitch with GM server sent me about a hundred), non-transferable and expire Oct 1, 2001.
Rick
Thanks again,
Barry
We rented a machine to take our flooring up. Me and my dad worked on that today (fun stuff)
Well we took it back and taking it off my truck i knicked off a chunk of paint where there is no sprayin liner on the tailgate (in the crease)
This aint no small chunk either.
Ryan
Good luck. I got some goofy noises too.
Dano
Went to set it down...super glued my #@%$ fingers to it....Oweee!!!!! %^$#
Anyone else have success carrying kayaks with ladder racks ? I figure I can carry the kids' 2 kayaks (11 1/2' long) in the bed with tailgate down but mine and the wife's 16 1/2' would go on the rack. Would like to use my Yakima kayak saddles - does anybody make a ladder rack with round crossbars ?
So many hobbies, so little time...
Basically warned or tornados, hail, wind, rain etc
Visibility at times was near 0. Pretty much sucked. Glad i had autotrac. Worked awesome.
I know the impala's have a thing where if bad weather or traffic warnings come about they will break into your radio transmission and tell you. Is this the same for the silverados? Never had this happen before it was kinda wierd.
Also when we left we put our shoes in the bed. Drove about 50 miles in terential downpour. Got to a gas station stopped for drinks and the bed of my truck didnt have a drop of rain in it. Guess i was going to fast and the water was going right over the bed
Also went over 19K miles
got my best tank of gas ever 17.8 mpg
Ryan
wasnt available on a 2000 LS
(i dont think i really would have wanted it anyway)
-Eric
Check the air pressure. HEHEH
Dano
Last year was first time with new truck, rained like hell the 1st 2 days and flooded me out of campsite and after returning home it took 2 weeks to get the tree sap from the pines off, swore I'd never go back. Well this year had a little dryer campsite and no pine trees to deal with, just a passing Tornado, geez!
Just got back from Stowe, Vermont this past weekend and heading up to Lake Placid then Watkins Glen 1st week of September.
19,000 miles on Rado and love it! 11.9 mpg towing, best mileage yet towing my trailer. Do things really improve with age/mileage!!!!
Ray T.
woah man be careful
The part number for the flaps is 12497448. These are 11" wide and have the bowtie on them.
I installed the fronts by turning the wheels, it took about 1/2 hour. The back ones I removed the wheels to make it easier, if you have a stubby screwdriver you probably wouldn't have to remove the wheels. The rears took about an hour because of wheel removal.
No drilling into the sheet metal is required.
I have the factory flares and the 265 tires and these fit fine.
Let me know if you need more information and I'll be glad to help.
-Mark
They were 13.50 a pair. Yes they are the normal GM ones.
Looks like I gotta call them back!
Jim
-Mark
Ryan: whats wrong with Lake Placid? Or do you mean from the movie? If so, wrong state...
-Eric
grrrr
went to blockbuster to rent the dvd hannibal. Leaving this guy is cutting grass (huge lawnmower) next thing you know i hear a boom (like a brick hit my truck) rock flew out from under it. My heart sunk i got out and ill be damned i have 3 knicks on my lower drivers side door. Paint completely gone. NO DENT however. from the noise it made i was sure it would dent.
Got home put some touchup paint on. Looks like crap upclose ,3 bloches. Far away cannot tell (before you could see 3 white spots)
My question any way to smooth out the touchup paint spots? Clay bar?
You will need the finest wet/dry sand paper 1500 grit
or 2000 if you can get it. and wet sand the touch up after it
has had plenty of time to harden. (I know, OUCH, sandpaper to
my truck)
Then you will need rubbing several grades of rubbing compound.
Meguires is good.
Medium cut cleaner first. Make sure you don't put too
much on and have a polisher fast enough to break the grit
down over a short time. The medium grit is designed to break down
and become a finer grit over a short period of time.
Then use the fine cut cleaner. Same as the medium.
Then use the Swirl remover
Finish with the wax...
I know it is alot of work. But it pays off
I had to work on my last truck after off roading. Black GMC 1500 extra cab.
I had to remove the "desert pinstriping".
Good luck...
Id rather not F it up
But people couldn't tell what had been done...
- Tim
Also wondering if the bars on the HD's mount on the frame directly or mount on the body mount bolts like the 2500ld.
I'd appreciate any help. Thanks.
Ken
I am sure all the 2001 versions will fit since GM didn't modify the frame or bodies for 2002. Hope this helps.
-Eric
Its not bothering me as much today. Doesnt look to bad. More rocks chips will come thats inevitible.
Ryan
Ken
Dano
Are the threads SAE or Metric on the grease fittings?
Danke!
Did see a few new Rado's there though, mostly 1/2 ton 4x4's pulling a SeaDoo trailer or boat.
On another note I drove my first shaker the other day, it was a 99 Tahoe, at 60 mph the front end was shakin all over the place. Sure glad my 2500 Rado doesn't have that problem or I'd be heading for a buy back real quick!
Ray T.
grrrr<
Ya see...this is why we told ya not to get those first scratches fixed, on the tailgate. You got the full curse now...doom!
oh well im over it today but when i see a lawnmower i cringe.
Why does it not bother me when i put a scratch in my truck (loading unloading things).
Ryan
I had my brother try and find the damage today and he couldnt until i pointed it out.
it's a truck Pal..get over it
- Tim
So ya gonna come up and go 4 wheeling at silver lakes (looks like probably spring time)
