Chevy Silverado/GMC Sierra - Owners hangout
kcram - Pickups Host
So does anybody have any advice on taking care of this rig? Can the oil % used monitor be trusted or should I just get an oil change every 3000 miles?
Thanks in advance...
Erik
http://www.gm.com/company/corp_info/history/gmhis1900.html
Max and Morris Grabowsky built their first truck in 1900. In 1902, they organized the Rapid Motor Vehicle Company and began production to build one-ton trucks. This company was the beginning of GMC Trucks.
Am looking at new 1500 models and a lot of them come with this option,don't want to get one if it is going to decrease the miles per gallon.
thanx
wgreen
http://www.gminsidenews.com/forums/showthread.php?t=34507
Maybe us Chevy owners have a stronger feminine side than Ford/Chrysler owners?
I dunno, but I find myself worrying about the upholstery stitching color a lot lately...hmmm.
In this case however I would think that it would be far easier and probably about as cheap to trade in the "05 on a "07. Plus it sounds like you already have the 'other half's' approval
What is your opinion of Michelin LTX M/S tires regarding ride comfort, milage performance, handling performance, tire pressure and any other comments you can make comparing: P265-75-16 & LT265-75-16 ("C" rating) on a 2K Sierra short bed, standard cab? The bed is fairly heavily loaded with tools most of the time. My daily commute is short but most weekends involve several hundred miles of hi way travel.
Ed
Who determined that your driveshaft is the root cause of the problem? I have the same aluminum driveshaft on my '06 crew cab Z71 and no vibration. If the driveshaft is bent or out of balance, it should be replaced/rebalanced. That's not that hard to figure out. As for body mounts being the culprit, I have not heard that.
As you may have noticed, we are reorganizing the Forums to allow better focus and easier searching when you have a particular problem or comment about any given vehicle. Many of the large generic discussions (like this one) will be closed to new posts, and we ask that you continue in the more focused discussions that you can find at the Group page for the vehicle, linked below. This discussion will not be deleted, so you can still search for information in it.
We recognize this is going to take some getting used to (for the hosts too!), so please bear with us. If you have any questions, you can always email the host of any discussion - the link is at the top of each page to the host who oversees that discussion.
If you don't see a discussion in the group appropriate to your question or comment, start a new one, or send me an email, and I'll point you in the right direction!
Chevy Silverado/GMC Sierra Group
