Chevy S10/GMC S15-Sonoma: Problems & Solutions
Hope this helps.
Which leaves me with 2 questions. 1. With no sign of anifreeze leaking out of anywhere, where is it going?
2. Why isn't the reservoir refilling the low radiator?
kcram - Pickups Host
Some trucks are being recalled, call your dealer and see if yours is one, if it is not report it to NHTSA so they get another recall going.
Thanx,
Bewildered in Midwest
As it turns out, some time back I replace the catalytic converter with an aftermarket. The heat shield on top didn't match up. I manufactured a bracket and mounted back end to bottom of cab. Thus when conditions were low speed/ high torque I got a bad vibration. Bet next time I take a car to trans shop first, for test drive, before dropping it out to be overhauled.
Lets see: rotate and balance tires, new motor mounts, new drive shaft carrier bearing, new transmission, to fix a vibrating heat shield. Seems like it's learning the hard way.
Remember, If you ain't screwed up it's because you ain't been doing anything :shades:
Also, does anyone know where to get some decent shocks for the front? It's the ZR2 version. I don't want to spend a lot of money on them since we will probably be spending money elsewhere on the truck, but we put on 23,000 miles/year and I'd like them to last at least another 100,000...
The problem....it won't stop leaking. I even took the caliper back where I bought it, frustrated that no matter what I tried it would not seal and not leak.
When I take the banjo bolt out and look at the washers(using new ones each time) I have a contact problem of some sort, the indentation of the concentric rings on Caliper, brake line, and bolt do not appear evenly across the face of the washers.
The only thing I can think is that the "lip" on brake line is not seating properly...before I spend money to have someone fix it in 20 minutes, I thought I would quiz some owners.
Joe
Just registered here after buying my first S10. It's a 1996 black ext cab with a 2.2L 4 banger. Thank god I got two V8's in my garage because the 2.2 is...not....powerfull haha!
Anyway; I was hoping to get in touch with Nineline. My S10 has the same ticking sound when idling but at 1300 rpm it appears to go away. First I thought valve lifters but after reading the mssg of nineline I think it's the same as ninelines'! Also used a stethoscope and the sound is loudest/definitly coming at cyl #4 (closest to the firewall). Oil is 5w30. Anybody with some experience with these engines,please reply!! Don't want to replace lifters or re-invent the wheel if it's something else.
Many thanks,
Tjesse,
The Netherlands, Europe.
I have a 2002 Sonoma and I will shortly need some new tires (And I just replaced a ball joint after only 41K miles .... )
The Wranglers I had from the factory I never liked .... I was thinking of the Michelin Cross terrains - an arguably better tire - but a little more $$'s Anyone have any experience with these on the S10's/Sonoma's??
Consumer reports rates them just so so, but the overall specs for wear / noise, comfort are high - as are quite a few consumer references on line....
OR - am I Just going to waste good tire money after changing more and more front end parts and just trash'n these tires as well ??/
Canufixit !!!
Thanks for the detailed reply ..
Here is some more Info
- I mostly (99% ) drive paved roads.
- Do use 4WD in winter .. occasionally
- Past Michilins I've had (on Autos not trucks) have approached 100K miles with no issues to date on multiple sets ...
Overall, I've had good luck with Michelin - the slight cost vs the wear and great ride has always been the sales point for me.
But. I'm considering all you said - and still have not made up my mind ...
Anyone out there have Michelin Tires on their Truck ??
Thanks All!!!
Canufixit
