Visitor Agreement.
You're correct on the description of the Rubicon's locker, but the Trac-Loc limited slip has always been an option on other models, on both the D35 and D44 axles.
Several ways to check. Tag on the diff cover bolt, sticker in the glove box, and with the rear end jacked off the ground and one wheel is rotated the other will rotate in the same direction. If the diff is open then the wheels will rotate in opposite driection.
No, the smaller back spacing WILL cause more wear on the hub! :shades:
However, with the wheel bearings likely to last the life of the vehicle, even a 50% increase in wear isn't something to cause immediate concern.
Of course, we welcome them to THIS discussion and ask them to become one of the family. That's a given.
I guess we are going to sort of end up with the something similar to what I proposed many moons ago, when I suggested that we start threads for the most commonly asked questions. Most of you guys at that time feared that to do so would discourage people from coming to this general discussion and becoming part of our family. I could see your point, and I decided that you were most likely right, so I didn't try to create new single-issue forums.
Apparently, Edmunds wants those single-issue discussions, so let's give it a fair chance to work, what do you guys say? Please be sure in put in a plug for this discussion when you create a new discussion or participate in an on-going discussion in the single-issue threads.
Tomster
Have you hugged your Jeep today?
P.S. You might check the last few posts over here: Forums Software! Your Questions Answered...
I'll hold off on creating any more new discussions until we see which way things are going to go around here.
Tom
I went to the off-road expo this weekend. I guess it is a new event. It is only taking place in three cities this year. I hope they continue it and that it gets bigger and better every year. I forgot my camera so I didn't get any pics.
Off-Road Expo link
Here is a pic of my Jeep after getting in some mud without my doors. I didn't realize it was that muddy where I was going. I did end up stuck and eventually got out. It made me laugh when I had to drive a couple hours home with my Jeep looking like this.
The tire rotataion test for LS seems to be very interesting and I'll give it a try over the weekend.
I plan to stay on stock for a few months until I figure out what to do next. Mostly likely a small lift of 2" or 3".
One thing I dont like about the Jeep is the raw plastic color on the fender flares. I am thinking about spray paint them to semi-gloss black.
No personal experience, but many people swear by Krylon Fusion paint for the fender flares. It supposedly bonds real well with the plastic.
Do a search on "Krylon," and you will be able to read for yourself the many posts on the subject.
Tom
I don't think 4rider's flares were ever black. From the way his post reads, I would say he got one of those Jeeps that came from the factory with the ugly gray flares. I'm pretty sure 05 was the year when DC decided to leave the flares gray, but that didn't even last through the entire model year. There was an uproar among the Jeepers over those UGLY gray flares, and DC backed off and went back to black.
Do a search, and I'll bet you will find TONS of posts about those gray flares. Those things were so ugly they would gag a maggot.
Tom
If Krylon is to be used, then as was said earlier, surface prep is really important, and the newer the plastic the more important it is. I'd suggest doing an area on the underside of the flare first.
You might also think about replacing the flares with aftermarket ones (Bushwacker maybe) which seem to retain their color better than O.E. ones.
Bushwacker.com
Mac, I have an interesting question for you. A friend of mine asked how many revolutions the "average" Jeep wheel will turn in one mile? Strange question but how does one figure this out? John
I'm not mac, but if you consider the "average" to be 30 inch diameter, you would get about 672 turns per mile. 32's would get around 630.
Wheel diameter times pi (3.1416) gives you circumference in inches. Divide by 12 to convert to feet. Divide the circumference (number of feet in one turn) into 5280 feet per mile to get the number of revolutions per mile.
Terry
Terry
To satisfy the original question for an average figure, it would probably fair to ballpark it at somewhere between 650 and 750, but it would be easier to give an reasonably accurate figure for an actual Jeep. If a completely accurate answer is required then the speed of the Jeep is relevant, as the tire will 'grow' back from its weight reduced radius because of centrifugal force, which will increase with speed.
Terry
My OE speedo gear was off by 8% with factory fitted 30"s, but it's spot on with 31"s.
Thanks for a great forum.
Yesterday, the wife, teenagers, and I put it back on with NO problems. The only issue that became problematic was loosing the space in the garage which prompted me to put it on a little sooner than I wanted to.
I was thinking about storing it next year under our elevated deck in the back outside. Your post has convinced me that this is not a good idea.
Mac, Tomster, et. al - This is just the kind of general reading that we needed to get back to instead of that silly system that Edmunds was forcing on us. Without having to post for a particular issue, my general reading alerted me to a potential situation to avoid that I MIGHT not have seen in the 'problem specific' forum.
This proves that the old 'Jeep Wrangler' forum is still the BEST! -- Chuck
For home use, I think if we bolt the hardtop on a simple wood frame made of 2x4s may help keeping the hardtop in shape particularly if it is stored outside.
I am getting used to the road noise level as well as the puzzling off-the-line hesitation now.
One interesting point I have noticed is that every time I make a turn, I can feel some kind of flexing and fishtailing in the back. When I travel straight on city streets, I can also get similar "wondering around" feeling enough to make me feel the Jeep is not willing to go straight. I vaguely remember test drove new Jeep also gave me the similar feeling.
Lots of low end torque is needed for off roading, and that good old inline 4.0 had plenty of it.
Tom
The 3.8 is a version of the engines they are putting in the minivans (and maybe the Pacifica?) and not is not as related to the Liberty's engine as it is the minivans.
Many feel it adequate for on road, but with it had a bit more oomph, especially with the 4 door.
I personally haven't driven one yet.
-Paul
Alan in the Desert
Here are the product details (my bold emphasis):
"Product Details
Manufactured to OEM tolerances by Bestop, this set will help you to keep your interior cooler with 31% tinted rear windows. Three piece tinted window sets will reduce heat build-up. And let's face it - they look cool too! Versions for all '97-'00 Wranglers with the orginal top or with a Bestop® Replace-a-top™.
Bestop offers replacement sets for your aging, damaged or lost windows."
Here is the link to the Black ones, but also available in Dark Tan and Spice:
Bestop@Quadratec
3.8L - 237 ftlb @ 4,000 rpm
4.0L - 235 ftlb @ 3,200 rpm
Although a graph is not shown, it is logical to assume that the 3.8L has less torque available at 3,200 rpm than the 4.0L and probably less most of the way down to idle conditions.
The red line is the relevant one here. As you imply, a high level of torque is available even at idle (750rpm), then rises to a peak at 3200rpm before dropping a little at maximim revs. However, the term 'peak' is a little misleading because, as can be seen from the graph the curve is virtually flat, which is what makes the 4.0 I6 so good at low speed and for towing.
Oh, and other than using them myself, I have no connection with BFG or any other tire company.
NO REGRETS about the BFG AT.
As for the windows, Bakersfield finally got a 4 Wheel Parts? Bout time. They were lacking for a 4x4 shop (I used to live in Tehachapi).
If you have concerns about the replacment windows, take your Jeep there and try on a set of the windows that they say won't work. That is the surest way to find out.
-Paul
As for your 99, you have the basic 1 ply top. To survive the heat wind and conditions you see in Cal City, the sailcloth replace-a-top may be a good option if you can swing it.
I bought my 97 with the same type top from a Lt.Col. at EAFB and the top was so thin you could see the sun through it. I put on a R-A-T and the difference in sound was incredible. Since it doesn't rain much there, the RAT is more for sound abatement, but it is worth it.
If you can't, try eBay and see what is available. There are always windows available.
-Paul
I really need to replace the TJ with something that has four doors and at least a little more room. The new Unlimited looked like the answer until I read a few tests. Why should I pay a premium for a vehicle that is slower, less capable off road, and no more economical than my TJ?
However, I have to admit that engine is the only thing I don't like about the new '07s, apart from the unavoidable complexity of the new electronic stability systems. To my eyes it really is a step forward. Unfortunate the 4.0 I6 is gone and won't ever be coming back. How long can you wait? There are usually many improvements to subsequent model years of any new vehicle, and DC has been no exception to this in the past. Also, I don't think it will be long before the aftermarket starts offering solutions (other than the usual air filter stuff).
I am used to driving relatively sporty midsize sedans. I know this car will not drive like a midsize sport sedan, but what I would like to know from current owners is whether the 2007 new Jeep has "sufficient" power and handling prowess.... or do you feel it is woefully inadequate...
There is a major "coolness" factor to this vehicle. It is the ONLY 5 seat convertible out there!! That alone may justify a sacrifice in power/handling....
Now, I DO realize that power and handling is an individual thing with every person being satisfied with different levels of each.... That being said, I am just looking for generalizations....
Thank you very much!
The new 3.8 V6 actually has a higher output of both torque and hp compared to the 4.0 I6, it's just that they come in at different points in the rev range, which changes the response characteristics, both on and off road. In simple terms it means it has to be revved higher in traffic than the previous engine, but it should keep up without any problems.
To see if it suits you, you really need to take an extended test drive in the conditions that you intend to use it. Drive it for a while solo, then loaded with family etc. My opinion as to its suitability would almost certainly be different to yours.
Cal City is still trying to grow. Right now we have way too many builders putting up overpriced houses they will surely lose their a**es on soon.
Anyway I understand the economy and usefulness of investing in a new top but I have a hard time tossing one that is still good as well as my side curtains and quarter windows.
The main concern is that winter is coming on quick and I'll miss no back window soon. I hope to hear from Besttop on Mon. so I can make the right decision and move on. Normally, I wouldn't squeak about having to invest in the best but with knee surgery and having been mostly laid up for so long makes $ a consideration for the next couple of months.
